Ach so:
Heute bzw. vorhin kam noch folgendes hinzu:
Spoiler
javascript.0 2019-04-06 19:14:28.911 warn at TCP.onread (net.js:601:20)
javascript.0 2019-04-06 19:14:28.911 warn at Socket.Readable.push (_stream_readable.js:208:10)
javascript.0 2019-04-06 19:14:28.910 warn at readableAddChunk (_stream_readable.js:250:11)
javascript.0 2019-04-06 19:14:28.910 warn at addChunk (_stream_readable.js:263:12)
javascript.0 2019-04-06 19:14:28.910 warn at Socket.emit (events.js:211:7)
javascript.0 2019-04-06 19:14:28.910 warn at emitOne (events.js:116:13)
javascript.0 2019-04-06 19:14:28.910 warn at Socket.<anonymous> (/opt/iobroker/node_modules/redis/index.js:274:27)
javascript.0 2019-04-06 19:14:28.910 warn at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
javascript.0 2019-04-06 19:14:28.910 warn at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
javascript.0 2019-04-06 19:14:28.909 warn at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:833:9)
javascript.0 2019-04-06 19:14:28.909 warn at return_pub_sub (/opt/iobroker/node_modules/redis/index.js:794:18)
javascript.0 2019-04-06 19:14:28.909 warn at RedisClient.emit (events.js:217:7)
javascript.0 2019-04-06 19:14:28.909 warn at emitThree (events.js:136:13)
javascript.0 2019-04-06 19:14:28.909 warn at RedisClient.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:596:25)
javascript.0 2019-04-06 19:14:28.909 warn at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
javascript.0 2019-04-06 19:14:28.908 warn at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
javascript.0 2019-04-06 19:14:28.908 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
javascript.0 2019-04-06 19:14:28.908 warn at Object.<anonymous> (script.js.Klima.Heizungsabsenkung_Fenstersensoren:48:5)
javascript.0 2019-04-06 19:14:28.907 warn at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
javascript.0 2019-04-06 19:14:28.897 warn Wrong type of innogy-smarthome.0.Bad.Heizkörperthermostat-1.PointTemperature: "undefined". Please fix, while deprecated and will not work in next versions.
Der "wrong type..." fehler dürfte auf den Absturz von Javascript zurückzuführen sein.
Ich habe ein Script, welches beim Öffnen des Fensters die gerade eingestellte Temperatur am Heizkörperthermostat als Variable speichert, den Wert dann auf 8°C setzt und beim Schließen des Fensters wieder auf den Wert der Variable.
Durch den Absturz dürfte der Wert gelöscht worden sein, und daher die Meldung beim Schließen der Fenster, dass "undefined" nicht gesetzt werden kann.
Ob der ganze Rest oberhalb damit zusammenhängt, weiß ich nicht. Sonst kam das auch nicht....
