@homoran Ok, ja, wenn ich mir den Absturz vom 29.9. ansehe, sind die Zeiten auch durcheinander:
022-09-29 12:21:57.516 - info: smartgarden.0 (3568) 1/ setServiceStates: relationship searching
2022-09-29 12:30:00.019 - info: javascript.0 (1566) script.js.Hüllenüberwachung.Status_zum_Versenden.Status_in_Variablen_schreiben: 116T 22:15h
2022-09-29 12:30:00.058 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 24456
2022-09-29 12:30:16.386 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2022-09-29 12:31:28.291 - warn: fullybrowser.0 (3312) updateDeviceERROR 192.168.2.151
2022-09-29 12:33:31.006 - warn: fullybrowser.0 (3312) updateDeviceERROR 192.168.2.152
2022-09-29 12:35:00.324 - info: smartgarden.0 (3568) 1/ setServiceStates: relationship searching
2022-09-29 12:35:00.330 - info: smartgarden.0 (3568) 1/ setServiceStates: relationship searching
2022-09-29 12:35:33.255 - warn: fullybrowser.0 (3312) updateDeviceERROR 192.168.2.152
2022-09-29 12:24:07.310 - info: host.raspberrypi iobroker.js-controller version 4.0.21 js-controller starting
2022-09-29 12:24:07.320 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
2022-09-29 12:24:07.321 - info: host.raspberrypi hostname: raspberrypi, node: v14.20.0
2022-09-29 12:24:07.322 - info: host.raspberrypi ip addresses: 192.168.2.211 2a00:6020:b209:8e00:34a9:61f5:a0f7:b92e fe80::52bb:6457:77c6:c7f7 192.168.2.33 2a00:6020:b209:8e00:970b:f9f3:99e3:e2f5 fe80::2d77:3397:7440:5e5a
2022-09-29 12:24:09.464 - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
2022-09-29 12:24:13.857 - info: host.raspberrypi iobroker.js-controller version 4.0.21 js-controller starting
2022-09-29 12:24:13.863 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
2022-09-29 12:24:13.864 - info: host.raspberrypi hostname: raspberrypi, node: v14.20.0
2022-09-29 12:24:13.864 - info: host.raspberrypi ip addresses: 192.168.2.211 2a00:6020:b209:8e00:34a9:61f5:a0f7:b92e fe80::52bb:6457:77c6:c7f7 192.168.2.33 2a00:6020:b209:8e00:970b:f9f3:99e3:e2f5 fe80::2d77:3397:7440:5e5a
2022-09-29 12:24:15.978 - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
Das
pi@raspberrypi:~ $ date
Mo 31. Okt 17:58:18 CET 2022
passt aber.
Was kann ich dagegen tun?
