Hallo Asgothian,
zuerst mal entschuldigung, dass es solange gedauert hat. War von der Arbeit her unterwegs.
Ich habe deine Anleitung befolgt und folgende Meldungen:
zigbee.0
2025-07-18 12:47:45.198 warn ELEVATED:I02 (ad2b) value generated '100' from device 286847fffe6d37f1 for 'Brightness'
zigbee.0
2025-07-18 12:47:45.198 warn ELEVATED:I01 (ad2b) message received '{"brightness":254}' from device 286847fffe6d37f1 type 'Mec Driver module'
zigbee.0
2025-07-18 12:47:45.196 warn ELEVATED:I02 (ad2b) value generated '94' from device 286847fffe6d37f1 for 'Link quality'
zigbee.0
2025-07-18 12:47:45.196 warn ELEVATED:I01 (ad2b) message received '{"linkquality":94}' from device 286847fffe6d37f1 type 'Mec Driver module'
zigbee.0
2025-07-18 12:47:45.195 warn ELEVATED:I01 (ad2b) Zigbee Event of Type attributeReport from device 0x286847fffe6d37f1, incoming event: {"type":"attributeReport","data":{"currentLevel":254},"linkquality":94,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":2,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":11}
zigbee.0
2025-07-18 12:47:35.290 warn ELEVATED:I02 (8671) value generated 'true' from device 286847fffe6d37f1 for 'Switch state'
zigbee.0
2025-07-18 12:47:35.290 warn ELEVATED:I01 (8671) message received '{"state":"ON"}' from device 286847fffe6d37f1 type 'Mec Driver module'
zigbee.0
2025-07-18 12:47:35.287 warn ELEVATED:I02 (8672) value generated '0' from device 286847fffe6d37f1 for 'Brightness'
zigbee.0
2025-07-18 12:47:35.287 warn ELEVATED:I01 (8672) message received '{"brightness":1}' from device 286847fffe6d37f1 type 'Mec Driver module'
zigbee.0
2025-07-18 12:47:35.287 warn ELEVATED:I02 (8671) value generated 'true' from device 286847fffe6d37f1 for 'Switch state'
zigbee.0
2025-07-18 12:47:35.286 warn ELEVATED:I01 (8671) message received '{"state":"ON"}' from device 286847fffe6d37f1 type 'Mec Driver module'
zigbee.0
2025-07-18 12:47:35.284 warn ELEVATED:I02 (8672) value generated '91' from device 286847fffe6d37f1 for 'Link quality'
zigbee.0
2025-07-18 12:47:35.284 warn ELEVATED:I01 (8672) message received '{"linkquality":91}' from device 286847fffe6d37f1 type 'Mec Driver module'
zigbee.0
2025-07-18 12:47:35.284 warn ELEVATED:I02 (8671) value generated '91' from device 286847fffe6d37f1 for 'Link quality'
zigbee.0
2025-07-18 12:47:35.284 warn ELEVATED:I01 (8671) message received '{"linkquality":91}' from device 286847fffe6d37f1 type 'Mec Driver module'
zigbee.0
2025-07-18 12:47:35.282 warn ELEVATED:SUCCESS (85d9) convert result {"state":{"state":"ON"}} for device 0x286847fffe6d37f1
zigbee.0
2025-07-18 12:47:35.282 warn ELEVATED:I01 (8672) Zigbee Event of Type attributeReport from device 0x286847fffe6d37f1, incoming event: {"type":"attributeReport","data":{"currentLevel":1},"linkquality":91,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":1,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":11}
zigbee.0
2025-07-18 12:47:35.281 warn ELEVATED:I01 (8671) Zigbee Event of Type attributeReport from device 0x286847fffe6d37f1, incoming event: {"type":"attributeReport","data":{"onOff":1},"linkquality":91,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":11}
zigbee.0
2025-07-18 12:47:35.172 warn ELEVATED:O04 (85d9) convert state, "ON", {} for device 0x286847fffe6d37f1 with Endpoint state
zigbee.0
2025-07-18 12:47:35.172 warn ELEVATED:O03 (85d9) Publishing to 0x286847fffe6d37f1 of model Mec Driver module with state
zigbee.0
2025-07-18 12:47:35.172 warn ELEVATED:O02 (85d9) Change state 'state' at device 0x286847fffe6d37f1 type 'Mec Driver module'
zigbee.0
2025-07-18 12:47:35.130 warn ELEVATED:O01 (85d9) User state change of state zigbee.0.286847fffe6d37f1.state with value true (ack: false) from system.adapter.admin.0
So wie ich die Meldungen interpretiere kommt die 0 vom Gerät selbst oder?
Beste Grüße Tobias
