Danke, für den Link
hier ein kurzer Auszug aus dem Log
0 2017-08-11 19:56:00.993 debug stateChange system.adapter.rpi2.0.inputCount: {"val":0,"ack":true,"ts":1502474160952,"q":0,"from":"system.adapter.rpi2.0","lc":1502474130632}
mqtt.0 2017-08-11 19:56:00.993 debug stateChange system.adapter.rpi2.0.uptime: {"val":174828,"ack":true,"ts":1502474160950,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160950}
mqtt.0 2017-08-11 19:56:00.993 debug stateChange system.adapter.rpi2.0.memHeapUsed: {"val":12.28,"ack":true,"ts":1502474160948,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160948}
mqtt.0 2017-08-11 19:56:00.992 debug stateChange system.adapter.rpi2.0.memHeapTotal: {"val":14.99,"ack":true,"ts":1502474160947,"q":0,"from":"system.adapter.rpi2.0","lc":1502436562659}
mqtt.0 2017-08-11 19:56:00.992 debug stateChange system.adapter.rpi2.0.memRss: {"val":34.57,"ack":true,"ts":1502474160945,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160945}
mqtt.0 2017-08-11 19:56:00.992 debug stateChange system.adapter.rpi2.0.connected: {"val":true,"ack":true,"ts":1502474160944,"q":0,"from":"system.adapter.rpi2.0","lc":1502299334562}
mqtt.0 2017-08-11 19:56:00.992 debug stateChange system.adapter.rpi2.0.alive: {"val":true,"ack":true,"ts":1502474160942,"q":0,"from":"system.adapter.rpi2.0","lc":1502299334561}
mqtt.0 2017-08-11 19:56:00.992 debug stateChange rpi2.0.wlan.wifi_send: {"val":0,"ack":true,"ts":1502474160941,"q":0,"from":"system.adapter.rpi2.0","lc":1494783664442}
mqtt.0 2017-08-11 19:56:00.992 debug redis pmessage io.* io.system.adapter.rpi2.0.outputCount {"val":28,"ack":true,"ts":1502474160958,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160958}
mqtt.0 2017-08-11 19:56:00.991 debug redis pmessage io.* io.system.adapter.rpi2.0.inputCount {"val":0,"ack":true,"ts":1502474160952,"q":0,"from":"system.adapter.rpi2.0","lc":1502474130632}
mqtt.0 2017-08-11 19:56:00.991 debug redis pmessage io.* io.system.adapter.rpi2.0.uptime {"val":174828,"ack":true,"ts":1502474160950,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160950}
mqtt.0 2017-08-11 19:56:00.991 debug redis pmessage io.* io.system.adapter.rpi2.0.memHeapUsed {"val":12.28,"ack":true,"ts":1502474160948,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160948}
mqtt.0 2017-08-11 19:56:00.991 debug redis pmessage io.* io.system.adapter.rpi2.0.memHeapTotal {"val":14.99,"ack":true,"ts":1502474160947,"q":0,"from":"system.adapter.rpi2.0","lc":1502436562659}
mqtt.0 2017-08-11 19:56:00.991 debug redis pmessage io.* io.system.adapter.rpi2.0.memRss {"val":34.57,"ack":true,"ts":1502474160945,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160945}
mqtt.0 2017-08-11 19:56:00.990 debug redis pmessage io.* io.system.adapter.rpi2.0.connected {"val":true,"ack":true,"ts":1502474160944,"q":0,"from":"system.adapter.rpi2.0","lc":1502299334562}
mqtt.0 2017-08-11 19:56:00.990 debug redis pmessage io.* io.system.adapter.rpi2.0.alive {"val":true,"ack":true,"ts":1502474160942,"q":0,"from":"system.adapter.rpi2.0","lc":1502299334561}
mqtt.0 2017-08-11 19:56:00.990 debug redis pmessage io.* io.rpi2.0.wlan.wifi_send {"val":0,"ack":true,"ts":1502474160941,"q":0,"from":"system.adapter.rpi2.0","lc":1494783664442}
mqtt.0 2017-08-11 19:56:00.990 debug stateChange rpi2.0.wlan.wifi_received: {"val":0,"ack":true,"ts":1502474160939,"q":0,"from":"system.adapter.rpi2.0","lc":1494783664440}
mqtt.0 2017-08-11 19:56:00.990 debug stateChange rpi2.0.uptime.uptime: {"val":"174871.93","ack":true,"ts":1502474160937,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160937}
mqtt.0 2017-08-11 19:56:00.990 debug stateChange rpi2.0.temperature.soc_temp: {"val":"52.62","ack":true,"ts":1502474160935,"q":0,"from":"system.adapter.rpi2.0","lc":1502474100622}
mqtt.0 2017-08-11 19:56:00.989 debug stateChange rpi2.0.swap.swap_used: {"val":0,"ack":true,"ts":1502474160934,"q":0,"from":"system.adapter.rpi2.0","lc":1501089697484}
mqtt.0 2017-08-11 19:56:00.989 debug stateChange rpi2.0.swap.swap_total: {"val":"100.00","ack":true,"ts":1502474160932,"q":0,"from":"system.adapter.rpi2.0","lc":1494783664424}
mqtt.0 2017-08-11 19:56:00.989 debug redis pmessage io.* io.rpi2.0.wlan.wifi_received {"val":0,"ack":true,"ts":1502474160939,"q":0,"from":"system.adapter.rpi2.0","lc":1494783664440}
mqtt.0 2017-08-11 19:56:00.989 debug redis pmessage io.* io.rpi2.0.uptime.uptime {"val":"174871.93","ack":true,"ts":1502474160937,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160937}
mqtt.0 2017-08-11 19:56:00.989 debug redis pmessage io.* io.rpi2.0.temperature.soc_temp {"val":"52.62","ack":true,"ts":1502474160935,"q":0,"from":"system.adapter.rpi2.0","lc":1502474100622}
mqtt.0 2017-08-11 19:56:00.988 debug redis pmessage io.* io.rpi2.0.swap.swap_used {"val":0,"ack":true,"ts":1502474160934,"q":0,"from":"system.adapter.rpi2.0","lc":1501089697484}
mqtt.0 2017-08-11 19:56:00.988 debug redis pmessage io.* io.rpi2.0.swap.swap_total {"val":"100.00","ack":true,"ts":1502474160932,"q":0,"from":"system.adapter.rpi2.0","lc":1494783664424}
mqtt.0 2017-08-11 19:56:00.988 debug stateChange rpi2.0.sdcard.sdcard_boot_used: {"val":"20.88","ack":true,"ts":1502474160930,"q":0,"from":"system.adapter.rpi2.0","lc":1494783664404}
mqtt.0 2017-08-11 19:56:00.988 debug stateChange rpi2.0.sdcard.sdcard_root_used: {"val":"1680.72","ack":true,"ts":1502474160929,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160929}
mqtt.0 2017-08-11 19:56:00.988 debug stateChange rpi2.0.sdcard.sdcard_boot_total: {"val":"40.35","ack":true,"ts":1502474160924,"q":0,"from":"system.adapter.rpi2.0","lc":1494783664400}
mqtt.0 2017-08-11 19:56:00.987 debug stateChange rpi2.0.sdcard.sdcard_root_total: {"val":"7392.30","ack":true,"ts":1502474160922,"q":0,"from":"system.adapter.rpi2.0","lc":1498752107591}
mqtt.0 2017-08-11 19:56:00.987 debug stateChange rpi2.0.network.net_send: {"val":136877825,"ack":true,"ts":1502474160922,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160922}
mqtt.0 2017-08-11 19:56:00.987 debug redis pmessage io.* io.rpi2.0.sdcard.sdcard_boot_used {"val":"20.88","ack":true,"ts":1502474160930,"q":0,"from":"system.adapter.rpi2.0","lc":1494783664404}
mqtt.0 2017-08-11 19:56:00.987 debug redis pmessage io.* io.rpi2.0.sdcard.sdcard_root_used {"val":"1680.72","ack":true,"ts":1502474160929,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160929}
mqtt.0 2017-08-11 19:56:00.987 debug redis pmessage io.* io.rpi2.0.sdcard.sdcard_boot_total {"val":"40.35","ack":true,"ts":1502474160924,"q":0,"from":"system.adapter.rpi2.0","lc":1494783664400}
mqtt.0 2017-08-11 19:56:00.987 debug redis pmessage io.* io.rpi2.0.sdcard.sdcard_root_total {"val":"7392.30","ack":true,"ts":1502474160922,"q":0,"from":"system.adapter.rpi2.0","lc":1498752107591}
mqtt.0 2017-08-11 19:56:00.986 debug redis pmessage io.* io.rpi2.0.network.net_send {"val":136877825,"ack":true,"ts":1502474160922,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160922}
mqtt.0 2017-08-11 19:56:00.986 debug stateChange rpi2.0.network.net_received: {"val":-156195783,"ack":true,"ts":1502474160917,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160917}
mqtt.0 2017-08-11 19:56:00.986 debug stateChange rpi2.0.memory.memory_available: {"val":"506.83","ack":true,"ts":1502474160916,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160916}
mqtt.0 2017-08-11 19:56:00.986 debug stateChange rpi2.0.memory.memory_free: {"val":"309.94","ack":true,"ts":1502474160909,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160909}
mqtt.0 2017-08-11 19:56:00.986 debug redis pmessage io.* io.rpi2.0.network.net_received {"val":-156195783,"ack":true,"ts":1502474160917,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160917}
mqtt.0 2017-08-11 19:56:00.985 debug redis pmessage io.* io.rpi2.0.memory.memory_available {"val":"506.83","ack":true,"ts":1502474160916,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160916}
mqtt.0 2017-08-11 19:56:00.920 debug redis pmessage io.* io.rpi2.0.memory.memory_free {"val":"309.94","ack":true,"ts":1502474160909,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160909}
mqtt.0 2017-08-11 19:56:00.919 debug stateChange rpi2.0.memory.memory_total: {"val":"923.36","ack":true,"ts":1502474160906,"q":0,"from":"system.adapter.rpi2.0","lc":1494783664377}
mqtt.0 2017-08-11 19:56:00.919 debug stateChange rpi2.0.cpu.scaling_governor: {"val":"ondemand","ack":true,"ts":1502474160902,"q":0,"from":"system.adapter.rpi2.0","lc":1494783664375}
mqtt.0 2017-08-11 19:56:00.919 debug redis pmessage io.* io.rpi2.0.memory.memory_total {"val":"923.36","ack":true,"ts":1502474160906,"q":0,"from":"system.adapter.rpi2.0","lc":1494783664377}
mqtt.0 2017-08-11 19:56:00.918 debug redis pmessage io.* io.rpi2.0.cpu.scaling_governor {"val":"ondemand","ack":true,"ts":1502474160902,"q":0,"from":"system.adapter.rpi2.0","lc":1494783664375}
mqtt.0 2017-08-11 19:56:00.907 debug stateChange rpi2.0.cpu.load15: {"val":"0.07","ack":true,"ts":1502474160900,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160900}
mqtt.0 2017-08-11 19:56:00.904 debug redis pmessage io.* io.rpi2.0.cpu.load15 {"val":"0.07","ack":true,"ts":1502474160900,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160900}
mqtt.0 2017-08-11 19:56:00.902 debug stateChange rpi2.0.cpu.load5: {"val":"0.19","ack":true,"ts":1502474160894,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160894}
mqtt.0 2017-08-11 19:56:00.900 debug redis pmessage io.* io.rpi2.0.cpu.load5 {"val":"0.19","ack":true,"ts":1502474160894,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160894}
mqtt.0 2017-08-11 19:56:00.898 debug stateChange rpi2.0.cpu.load1: {"val":"0.56","ack":true,"ts":1502474160885,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160885}
mqtt.0 2017-08-11 19:56:00.897 debug stateChange rpi2.0.cpu.cpu_frequency: {"val":600,"ack":true,"ts":1502474160884,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160884}
mqtt.0 2017-08-11 19:56:00.897 debug redis pmessage io.* io.rpi2.0.cpu.load1 {"val":"0.56","ack":true,"ts":1502474160885,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160885}
mqtt.0 2017-08-11 19:56:00.897 debug redis pmessage io.* io.rpi2.0.cpu.cpu_frequency {"val":600,"ack":true,"ts":1502474160884,"q":0,"from":"system.adapter.rpi2.0","lc":1502474160884}
mqtt.0 2017-08-11 19:56:00.785 debug onStateChange javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_Speicher_prozentual: {"val":68.3,"ack":false,"ts":1502474160725,"q":0,"from":"system.adapter.javascript.0","lc":1502474160725}
mqtt.0 2017-08-11 19:56:00.784 debug stateChange javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_Speicher_prozentual: {"val":68.3,"ack":false,"ts":1502474160725,"q":0,"from":"system.adapter.javascript.0","lc":1502474160725}
mqtt.0 2017-08-11 19:56:00.784 debug onStateChange javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_CPU_Gesamt: {"val":20.4,"ack":false,"ts":1502474160724,"q":0,"from":"system.adapter.javascript.0","lc":1502474160724}
mqtt.0 2017-08-11 19:56:00.784 debug stateChange javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_CPU_Gesamt: {"val":20.4,"ack":false,"ts":1502474160724,"q":0,"from":"system.adapter.javascript.0","lc":1502474160724}
mqtt.0 2017-08-11 19:56:00.784 debug stateChange javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_Anzahl_Prozesse: {"val":17,"ack":false,"ts":1502474160723,"q":0,"from":"system.adapter.javascript.0","lc":1502299560734}
mqtt.0 2017-08-11 19:56:00.784 debug onStateChange javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_Speicher_gesamt: {"val":638,"ack":false,"ts":1502474160722,"q":0,"from":"system.adapter.javascript.0","lc":1502474160722}
mqtt.0 2017-08-11 19:56:00.784 debug stateChange javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_Speicher_gesamt: {"val":638,"ack":false,"ts":1502474160722,"q":0,"from":"system.adapter.javascript.0","lc":1502474160722}
mqtt.0 2017-08-11 19:56:00.783 debug onStateChange javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_Prozesse: {"val":"[{\"command\":\"iobroker.js-controller\",\"pid\":\"760\",\"cpu\":1.1,\"mem\":7.7,\"vmem\":172320,\"rss\":73260,\"sta
mqtt.0 2017-08-11 19:56:00.783 debug stateChange javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_Prozesse: {"val":"[{\"command\":\"iobroker.js-controller\",\"pid\":\"760\",\"cpu\":1.1,\"mem\":7.7,\"vmem\":172320,\"rss\":73260,\"start
mqtt.0 2017-08-11 19:56:00.783 debug redis pmessage io.* io.javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_Speicher_prozentual {"val":68.3,"ack":false,"ts":1502474160725,"q":0,"from":"system.adapter.javascript.0","lc":1502474160725
mqtt.0 2017-08-11 19:56:00.782 debug redis pmessage io.* io.javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_CPU_Gesamt {"val":20.4,"ack":false,"ts":1502474160724,"q":0,"from":"system.adapter.javascript.0","lc":1502474160724}
mqtt.0 2017-08-11 19:56:00.782 debug redis pmessage io.* io.javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_Anzahl_Prozesse {"val":17,"ack":false,"ts":1502474160723,"q":0,"from":"system.adapter.javascript.0","lc":1502299560734}
mqtt.0 2017-08-11 19:56:00.782 debug redis pmessage io.* io.javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_Speicher_gesamt {"val":638,"ack":false,"ts":1502474160722,"q":0,"from":"system.adapter.javascript.0","lc":1502474160722}
mqtt.0 2017-08-11 19:56:00.781 debug redis pmessage io.* io.javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_Prozesse {"val":"[{\"command\":\"iobroker.js-controller\",\"pid\":\"760\",\"cpu\":1.1,\"mem\":7.7,\"vmem\":172320,\"rss\":73
mqtt.0 2017-08-11 19:56:00.781 debug stateChange javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_Instanzen_einmal_aktiv: {"val":true,"ack":false,"ts":1502474160720,"q":0,"from":"system.adapter.javascript.0","lc":1501089699232}
mqtt.0 2017-08-11 19:56:00.780 debug redis pmessage io.* io.javascript.0.Systeminfos.ioBroker.Prozesse.ioBroker_Instanzen_einmal_aktiv {"val":true,"ack":false,"ts":1502474160720,"q":0,"from":"system.adapter.javascript.0","lc":1501089699
mqtt.0 2017-08-11 19:55:58.194 debug stateChange system.adapter.socketio.0.outputCount: {"val":8,"ack":true,"ts":1502474158164,"q":0,"from":"system.adapter.socketio.0","lc":1502299369996}
mqtt.0 2017-08-11 19:55:58.193 debug redis pmessage io.* io.system.adapter.socketio.0.outputCount {"val":8,"ack":true,"ts":1502474158164,"q":0,"from":"system.adapter.socketio.0","lc":1502299369996}
mqtt.0 2017-08-11 19:55:58.193 debug stateChange system.adapter.socketio.0.inputCount: {"val":0,"ack":true,"ts":1502474158163,"q":0,"from":"system.adapter.socketio.0","lc":1502299745285}
mqtt.0 2017-08-11 19:55:58.193 debug stateChange system.adapter.socketio.0.uptime: {"val":174822,"ack":true,"ts":1502474158163,"q":0,"from":"system.adapter.socketio.0","lc":1502474158163}
mqtt.0 2017-08-11 19:55:58.193 debug stateChange system.adapter.socketio.0.memHeapUsed: {"val":11.4,"ack":true,"ts":1502474158162,"q":0,"from":"system.adapter.socketio.0","lc":1502474158162}
mqtt.0 2017-08-11 19:55:58.192 debug stateChange system.adapter.socketio.0.memHeapTotal: {"val":14.99,"ack":true,"ts":1502474158161,"q":0,"from":"system.adapter.socketio.0","lc":1502300976229}
mqtt.0 2017-08-11 19:55:58.192 debug stateChange system.adapter.socketio.0.memRss: {"val":31.63,"ack":true,"ts":1502474158160,"q":0,"from":"system.adapter.socketio.0","lc":1502474098120}
mqtt.0 2017-08-11 19:55:58.192 debug stateChange system.adapter.socketio.0.connected: {"val":true,"ack":true,"ts":1502474158160,"q":0,"from":"system.adapter.socketio.0","lc":1502299340129}
mqtt.0 2017-08-11 19:55:58.192 debug stateChange system.adapter.socketio.0.alive: {"val":true,"ack":true,"ts":1502474158159,"q":0,"from":"system.adapter.socketio.0","lc":1502299340127}
mqtt.0 2017-08-11 19:55:58.191 debug redis pmessage io.* io.system.adapter.socketio.0.inputCount {"val":0,"ack":true,"ts":1502474158163,"q":0,"from":"system.adapter.socketio.0","lc":1502299745285}
mqtt.0 2017-08-11 19:55:58.191 debug redis pmessage io.* io.system.adapter.socketio.0.uptime {"val":174822,"ack":true,"ts":1502474158163,"q":0,"from":"system.adapter.socketio.0","lc":1502474158163}
mqtt.0 2017-08-11 19:55:58.191 debug redis pmessage io.* io.system.adapter.socketio.0.memHeapUsed {"val":11.4,"ack":true,"ts":1502474158162,"q":0,"from":"system.adapter.socketio.0","lc":1502474158162}
mqtt.0 2017-08-11 19:55:58.191 debug redis pmessage io.* io.system.adapter.socketio.0.memHeapTotal {"val":14.99,"ack":true,"ts":1502474158161,"q":0,"from":"system.adapter.socketio.0","lc":1502300976229}
mqtt.0 2017-08-11 19:55:58.190 debug redis pmessage io.* io.system.adapter.socketio.0.memRss {"val":31.63,"ack":true,"ts":1502474158160,"q":0,"from":"system.adapter.socketio.0","lc":1502474098120}
mqtt.0 2017-08-11 19:55:58.190 debug redis pmessage io.* io.system.adapter.socketio.0.connected {"val":true,"ack":true,"ts":1502474158160,"q":0,"from":"system.adapter.socketio.0","lc":1502299340129}
mqtt.0 2017-08-11 19:55:58.189 debug redis pmessage io.* io.system.adapter.socketio.0.alive {"val":true,"ack":true,"ts":1502474158159,"q":0,"from":"system.adapter.socketio.0","lc":1502299340127}
mqtt.0 2017-08-11 19:55:57.954 debug stateChange system.adapter.wifilight.0.outputCount: {"val":8,"ack":true,"ts":1502474157943,"q":0,"from":"system.adapter.wifilight.0","lc":1498997461045}
mqtt.0 2017-08-11 19:55:57.953 debug redis pmessage io.* io.system.adapter.wifilight.0.outputCount {"val":8,"ack":true,"ts":1502474157943,"q":0,"from":"system.adapter.wifilight.0","lc":1498997461045}
mqtt.0 2017-08-11 19:55:57.952 debug stateChange system.adapter.wifilight.0.inputCount: {"val":0,"ack":true,"ts":1502474157933,"q":0,"from":"system.adapter.wifilight.0","lc":1502299753011}
mqtt.0 2017-08-11 19:55:57.952 debug stateChange system.adapter.wifilight.0.uptime: {"val":174797,"ack":true,"ts":1502474157931,"q":0,"from":"system.adapter.wifilight.0","lc":1502474157931}
mqtt.0 2017-08-11 19:55:57.952 debug stateChange system.adapter.wifilight.0.memHeapUsed: {"val":11.4,"ack":true,"ts":1502474157929,"q":0,"from":"system.adapter.wifilight.0","lc":1502474157929}
mqtt.0 2017-08-11 19:55:57.952 debug stateChange system.adapter.wifilight.0.memHeapTotal: {"val":14.99,"ack":true,"ts":1502474157927,"q":0,"from":"system.adapter.wifilight.0","lc":1502470014916}
mqtt.0 2017-08-11 19:55:57.951 debug redis pmessage io.* io.system.adapter.wifilight.0.inputCount {"val":0,"ack":true,"ts":1502474157933,"q":0,"from":"system.adapter.wifilight.0","lc":1502299753011}
mqtt.0 2017-08-11 19:55:57.951 debug redis pmessage io.* io.system.adapter.wifilight.0.uptime {"val":174797,"ack":true,"ts":1502474157931,"q":0,"from":"system.adapter.wifilight.0","lc":1502474157931}
mqtt.0 2017-08-11 19:55:57.951 debug redis pmessage io.* io.system.adapter.wifilight.0.memHeapUsed {"val":11.4,"ack":true,"ts":1502474157929,"q":0,"from":"system.adapter.wifilight.0","lc":1502474157929}
mqtt.0 2017-08-11 19:55:57.951 debug redis pmessage io.* io.system.adapter.wifilight.0.memHeapTotal {"val":14.99,"ack":true,"ts":1502474157927,"q":0,"from":"system.adapter.wifilight.0","lc":1502470014916}
mqtt.0 2017-08-11 19:55:57.950 debug stateChange system.adapter.wifilight.0.memRss: {"val":30.91,"ack":true,"ts":1502474157925,"q":0,"from":"system.adapter.wifilight.0","lc":1502474127902}
mqtt.0 2017-08-11 19:55:57.950 debug stateChange system.adapter.wifilight.0.connected: {"val":true,"ack":true,"ts":1502474157922,"q":0,"from":"system.adapter.wifilight.0","lc":1502299362719}
mqtt.0 2017-08-11 19:55:57.950 debug redis pmessage io.* io.system.adapter.wifilight.0.memRss {"val":30.91,"ack":true,"ts":1502474157925,"q":0,"from":"system.adapter.wifilight.0","lc":1502474127902}
mqtt.0 2017-08-11 19:55:57.949 debug redis pmessage io.* io.system.adapter.wifilight.0.connected {"val":true,"ack":true,"ts":1502474157922,"q":0,"from":"system.adapter.wifilight.0","lc":1502299362719}
mqtt.0 2017-08-11 19:55:57.949 debug stateChange system.adapter.wifilight.0.alive: {"val":true,"ack":true,"ts":1502474157921,"q":0,"from":"system.adapter.wifilight.0","lc":1502299362717}
mqtt.0 2017-08-11 19:55:57.949 debug redis pmessage io.* io.system.adapter.wifilight.0.alive {"val":true,"ack":true,"ts":1502474157921,"q":0,"from":"system.adapter.wifilight.0","lc":1502299362717}
mqtt.0 2017-08-11 19:55:56.145 debug stateChange system.adapter.admin.0.outputCount: {"val":8,"ack":true,"ts":1502474156093,"q":0,"from":"system.adapter.admin.0","lc":1502472145789}
mqtt.0 2017-08-11 19:55:56.145 debug stateChange system.adapter.admin.0.inputCount: {"val":422,"ack":true,"ts":1502474156093,"q":0,"from":"system.adapter.admin.0","lc":1502474141092}
mqtt.0 2017-08-11 19:55:56.144 debug stateChange system.adapter.admin.0.uptime: {"val":174840,"ack":true,"ts":1502474156092,"q":0,"from":"system.adapter.admin.0","lc":1502474156092}
mqtt.0 2017-08-11 19:55:56.144 debug stateChange system.adapter.admin.0.memHeapUsed: {"val":15.12,"ack":true,"ts":1502474156091,"q":0,"from":"system.adapter.admin.0","lc":1502474156091}
mqtt.0 2017-08-11 19:55:56.144 debug stateChange system.adapter.admin.0.memHeapTotal: {"val":18.99,"ack":true,"ts":1502474156090,"q":0,"from":"system.adapter.admin.0","lc":1502474126078}
mqtt.0 2017-08-11 19:55:56.142 debug redis pmessage io.* io.system.adapter.admin.0.outputCount {"val":8,"ack":true,"ts":1502474156093,"q":0,"from":"system.adapter.admin.0","lc":1502472145789}
mqtt.0 2017-08-11 19:55:56.141 debug redis pmessage io.* io.system.adapter.admin.0.inputCount {"val":422,"ack":true,"ts":1502474156093,"q":0,"from":"system.adapter.admin.0","lc":1502474141092}
mqtt.0 2017-08-11 19:55:56.141 debug redis pmessage io.* io.system.adapter.admin.0.uptime {"val":174840,"ack":true,"ts":1502474156092,"q":0,"from":"system.adapter.admin.0","lc":1502474156092}
mqtt.0 2017-08-11 19:55:56.141 debug redis pmessage io.* io.system.adapter.admin.0.memHeapUsed {"val":15.12,"ack":true,"ts":1502474156091,"q":0,"from":"system.adapter.admin.0","lc":1502474156091}
mqtt.0 2017-08-11 19:55:56.140 debug redis pmessage io.* io.system.adapter.admin.0.memHeapTotal {"val":18.99,"ack":true,"ts":1502474156090,"q":0,"from":"system.adapter.admin.0","lc":1502474126078}
mqtt.0 2017-08-11 19:55:56.140 debug stateChange system.adapter.history.1.outputCount: {"val":8,"ack":true,"ts":1502474156088,"q":0,"from":"system.adapter.history.1","lc":1502213328476}
mqtt.0 2017-08-11 19:55:56.140 debug stateChange system.adapter.history.1.inputCount: {"val":137,"ack":true,"ts":1502474156088,"q":0,"from":"system.adapter.history.1","lc":1502474156088}
mqtt.0 2017-08-11 19:55:56.140 debug stateChange system.adapter.history.1.uptime: {"val":174768,"ack":true,"ts":1502474156087,"q":0,"from":"system.adapter.history.1","lc":1502474156087}
mqtt.0 2017-08-11 19:55:56.139 debug stateChange system.adapter.history.1.memHeapUsed: {"val":12.61,"ack":true,"ts":1502474156086,"q":0,"from":"system.adapter.history.1","lc":1502474156086}
mqtt.0 2017-08-11 19:55:56.139 debug stateChange system.adapter.history.1.memHeapTotal: {"val":14.99,"ack":true,"ts":1502474156086,"q":0,"from":"system.adapter.history.1","lc":1502473435978}
mqtt.0 2017-08-11 19:55:56.139 debug stateChange system.adapter.history.1.memRss: {"val":33.19,"ack":true,"ts":1502474156085,"q":0,"from":"system.adapter.history.1","lc":1502474156085}
mqtt.0 2017-08-11 19:55:56.139 debug stateChange system.adapter.history.1.connected: {"val":true,"ack":true,"ts":1502474156084,"q":0,"from":"system.adapter.history.1","lc":1502299390132}
mqtt.0 2017-08-11 19:55:56.138 debug stateChange system.adapter.history.1.alive: {"val":true,"ack":true,"ts":1502474156084,"q":0,"from":"system.adapter.history.1","lc":1502299390130}
mqtt.0 2017-08-11 19:55:56.138 debug stateChange system.adapter.admin.0.memRss: {"val":42.28,"ack":true,"ts":1502474156083,"q":0,"from":"system.adapter.admin.0","lc":1502474156083}
mqtt.0 2017-08-11 19:55:56.138 debug stateChange system.adapter.admin.0.connected: {"val":true,"ack":true,"ts":1502474156080,"q":0,"from":"system.adapter.admin.0","lc":1502299320171}
mqtt.0 2017-08-11 19:55:56.137 debug stateChange system.adapter.admin.0.alive: {"val":true,"ack":true,"ts":1502474156078,"q":0,"from":"system.adapter.admin.0","lc":1502299320169}
mqtt.0 2017-08-11 19:55:56.137 debug redis pmessage io.* io.system.adapter.history.1.outputCount {"val":8,"ack":true,"ts":1502474156088,"q":0,"from":"system.adapter.history.1","lc":1502213328476}
mqtt.0 2017-08-11 19:55:56.137 debug redis pmessage io.* io.system.adapter.history.1.inputCount {"val":137,"ack":true,"ts":1502474156088,"q":0,"from":"system.adapter.history.1","lc":1502474156088}
mqtt.0 2017-08-11 19:55:56.137 debug redis pmessage io.* io.system.adapter.history.1.uptime {"val":174768,"ack":true,"ts":1502474156087,"q":0,"from":"system.adapter.history.1","lc":1502474156087}
mqtt.0 2017-08-11 19:55:56.136 debug redis pmessage io.* io.system.adapter.history.1.memHeapUsed {"val":12.61,"ack":true,"ts":1502474156086,"q":0,"from":"system.adapter.history.1","lc":1502474156086}
mqtt.0 2017-08-11 19:55:56.136 debug redis pmessage io.* io.system.adapter.history.1.memHeapTotal {"val":14.99,"ack":true,"ts":1502474156086,"q":0,"from":"system.adapter.history.1","lc":1502473435978}
mqtt.0 2017-08-11 19:55:56.136 debug redis pmessage io.* io.system.adapter.history.1.memRss {"val":33.19,"ack":true,"ts":1502474156085,"q":0,"from":"system.adapter.history.1","lc":1502474156085}
mqtt.0 2017-08-11 19:55:56.135 debug redis pmessage io.* io.system.adapter.history.1.connected {"val":true,"ack":true,"ts":1502474156084,"q":0,"from":"system.adapter.history.1","lc":1502299390132}
mqtt.0 2017-08-11 19:55:56.135 debug redis pmessage io.* io.system.adapter.history.1.alive {"val":true,"ack":true,"ts":1502474156084,"q":0,"from":"system.adapter.history.1","lc":1502299390130}
mqtt.0 2017-08-11 19:55:56.135 debug redis pmessage io.* io.system.adapter.admin.0.memRss {"val":42.28,"ack":true,"ts":1502474156083,"q":0,"from":"system.adapter.admin.0","lc":1502474156083}
mqtt.0 2017-08-11 19:55:56.135 debug redis pmessage io.* io.system.adapter.admin.0.connected {"val":true,"ack":true,"ts":1502474156080,"q":0,"from":"system.adapter.admin.0","lc":1502299320171}
mqtt.0 2017-08-11 19:55:56.134 debug redis pmessage io.* io.system.adapter.admin.0.alive {"val":true,"ack":true,"ts":1502474156078,"q":0,"from":"system.adapter.admin.0","lc":1502299320169}
mqtt.0 2017-08-11 19:55:55.530 debug stateChange system.adapter.scenes.0.outputCount: {"val":8,"ack":true,"ts":1502474155460,"q":0,"from":"system.adapter.scenes.0","lc":1499015211808}
mqtt.0 2017-08-11 19:55:55.529 debug stateChange system.adapter.scenes.0.inputCount: {"val":0,"ack":true,"ts":1502474155460,"q":0,"from":"system.adapter.scenes.0","lc":1502299758397}
mqtt.0 2017-08-11 19:55:55.529 debug stateChange system.adapter.scenes.0.uptime: {"val":174759,"ack":true,"ts":1502474155459,"q":0,"from":"system.adapter.scenes.0","lc":1502474155459}
mqtt.0 2017-08-11 19:55:55.529 debug stateChange system.adapter.scenes.0.memHeapUsed: {"val":7.49,"ack":true,"ts":1502474155459,"q":0,"from":"system.adapter.scenes.0","lc":1502474155459}
mqtt.0 2017-08-11 19:55:55.529 debug stateChange system.adapter.scenes.0.memHeapTotal: {"val":11.99,"ack":true,"ts":1502474155458,"q":0,"from":"system.adapter.scenes.0","lc":1502300734059}
mqtt.0 2017-08-11 19:55:55.528 debug redis pmessage io.* io.system.adapter.scenes.0.outputCount {"val":8,"ack":true,"ts":1502474155460,"q":0,"from":"system.adapter.scenes.0","lc":1499015211808}
mqtt.0 2017-08-11 19:55:55.528 debug redis pmessage io.* io.system.adapter.scenes.0.inputCount {"val":0,"ack":true,"ts":1502474155460,"q":0,"from":"system.adapter.scenes.0","lc":1502299758397}
mqtt.0 2017-08-11 19:55:55.528 debug redis pmessage io.* io.system.adapter.scenes.0.uptime {"val":174759,"ack":true,"ts":1502474155459,"q":0,"from":"system.adapter.scenes.0","lc":1502474155459}
mqtt.0 2017-08-11 19:55:55.527 debug redis pmessage io.* io.system.adapter.scenes.0.memHeapUsed {"val":7.49,"ack":true,"ts":1502474155459,"q":0,"from":"system.adapter.scenes.0","lc":1502474155459}
mqtt.0 2017-08-11 19:55:55.527 debug redis pmessage io.* io.system.adapter.scenes.0.memHeapTotal {"val":11.99,"ack":true,"ts":1502474155458,"q":0,"from":"system.adapter.scenes.0","lc":1502300734059}
mqtt.0 2017-08-11 19:55:55.527 debug stateChange system.adapter.scenes.0.memRss: {"val":28.92,"ack":true,"ts":1502474155457,"q":0,"from":"system.adapter.scenes.0","lc":1502474155457}
mqtt.0 2017-08-11 19:55:55.527 debug stateChange system.adapter.scenes.0.connected: {"val":true,"ack":true,"ts":1502474155457,"q":0,"from":"system.adapter.scenes.0","lc":1502299398126}
mqtt.0 2017-08-11 19:55:55.526 debug stateChange system.adapter.scenes.0.alive: {"val":true,"ack":true,"ts":1502474155456,"q":0,"from":"system.adapter.scenes.0","lc":1502299398124}
mqtt.0 2017-08-11 19:55:55.526 debug redis pmessage io.* io.system.adapter.scenes.0.memRss {"val":28.92,"ack":true,"ts":1502474155457,"q":0,"from":"system.adapter.scenes.0","lc":1502474155457}
mqtt.0 2017-08-11 19:55:55.526 debug redis pmessage io.* io.system.adapter.scenes.0.connected {"val":true,"ack":true,"ts":1502474155457,"q":0,"from":"system.adapter.scenes.0","lc":1502299398126}
mqtt.0 2017-08-11 19:55:55.525 debug redis pmessage io.* io.system.adapter.scenes.0.alive {"val":true,"ack":true,"ts":1502474155456,"q":0,"from":"system.adapter.scenes.0","lc":1502299398124}
mqtt.0 2017-08-11 19:55:53.802 debug stateChange system.adapter.hm-rega.0.outputCount: {"val":8,"ack":true,"ts":1502474153793,"q":0,"from":"system.adapter.hm-rega.0","lc":1502474093788}
mqtt.0 2017-08-11 19:55:53.802 debug stateChange system.adapter.hm-rega.0.inputCount: {"val":0,"ack":true,"ts":1502474153791,"q":0,"from":"system.adapter.hm-rega.0","lc":1502474093785}
mqtt.0 2017-08-11 19:55:53.802 debug stateChange system.adapter.hm-rega.0.uptime: {"val":174741,"ack":true,"ts":1502474153790,"q":0,"from":"system.adapter.hm-rega.0","lc":1502474153790}
mqtt.0 2017-08-11 19:55:53.801 debug redis pmessage io.* io.system.adapter.hm-rega.0.outputCount {"val":8,"ack":true,"ts":1502474153793,"q":0,"from":"system.adapter.hm-rega.0","lc":1502474093788}
mqtt.0 2017-08-11 19:55:53.801 debug redis pmessage io.* io.system.adapter.hm-rega.0.inputCount {"val":0,"ack":true,"ts":1502474153791,"q":0,"from":"system.adapter.hm-rega.0","lc":1502474093785}
mqtt.0 2017-08-11 19:55:53.801 debug redis pmessage io.* io.system.adapter.hm-rega.0.uptime {"val":174741,"ack":true,"ts":1502474153790,"q":0,"from":"system.adapter.hm-rega.0","lc":1502474153790}
mqtt.0 2017-08-11 19:55:53.801 debug stateChange system.adapter.hm-rega.0.memHeapUsed: {"val":19.6,"ack":true,"ts":1502474153785,"q":0,"from":"system.adapter.hm-rega.0","lc":1502474153785}
mqtt.0 2017-08-11 19:55:53.800 debug redis pmessage io.* io.system.adapter.hm-rega.0.memHeapUsed {"val":19.6,"ack":true,"ts":1502474153785,"q":0,"from":"system.adapter.hm-rega.0","lc":1502474153785}
mqtt.0 2017-08-11 19:55:53.800 debug stateChange system.adapter.hm-rega.0.memHeapTotal: {"val":23.99,"ack":true,"ts":1502474153784,"q":0,"from":"system.adapter.hm-rega.0","lc":1502473373510}
mqtt.0 2017-08-11 19:55:53.800 debug redis pmessage io.* io.system.adapter.hm-rega.0.memHeapTotal {"val":23.99,"ack":true,"ts":1502474153784,"q":0,"from":"system.adapter.hm-rega.0","lc":1502473373510}
mqtt.0 2017-08-11 19:55:53.800 debug stateChange system.adapter.hm-rega.0.memRss: {"val":42.11,"ack":true,"ts":1502474153780,"q":0,"from":"system.adapter.hm-rega.0","lc":1502474123772}
mqtt.0 2017-08-11 19:55:53.800 debug stateChange system.adapter.hm-rega.0.connected: {"val":true,"ack":true,"ts":1502474153778,"q":0,"from":"system.adapter.hm-rega.0","lc":1502299415679}
mqtt.0 2017-08-11 19:55:53.800 debug redis pmessage io.* io.system.adapter.hm-rega.0.memRss {"val":42.11,"ack":true,"ts":1502474153780,"q":0,"from":"system.adapter.hm-rega.0","lc":1502474123772}
mqtt.0 2017-08-11 19:55:53.800 debug stateChange system.adapter.hm-rega.0.alive: {"val":true,"ack":true,"ts":1502474153778,"q":0,"from":"system.adapter.hm-rega.0","lc":1502299415678}
mqtt.0 2017-08-11 19:55:53.799 debug redis pmessage io.* io.system.adapter.hm-rega.0.connected {"val":true,"ack":true,"ts":1502474153778,"q":0,"from":"system.adapter.hm-rega.0","lc":1502299415679}
mqtt.0 2017-08-11 19:55:53.799 debug redis pmessage io.* io.system.adapter.hm-rega.0.alive {"val":true,"ack":true,"ts":1502474153778,"q":0,"from":"system.adapter.hm-rega.0","lc":1502299415678}
mqtt.0 2017-08-11 19:55:53.118 debug stateChange system.adapter.web.0.outputCount: {"val":8,"ack":true,"ts":1502474153098,"q":0,"from":"system.adapter.web.0","lc":1502474078082}
mqtt.0 2017-08-11 19:55:53.117 debug redis pmessage io.* io.system.adapter.web.0.outputCount {"val":8,"ack":true,"ts":1502474153098,"q":0,"from":"system.adapter.web.0","lc":1502474078082}
mqtt.0 2017-08-11 19:55:53.117 debug stateChange system.adapter.web.0.inputCount: {"val":139,"ack":true,"ts":1502474153096,"q":0,"from":"system.adapter.web.0","lc":1502474153096}
mqtt.0 2017-08-11 19:55:53.117 debug stateChange system.adapter.web.0.uptime: {"val":174832,"ack":true,"ts":1502474153093,"q":0,"from":"system.adapter.web.0","lc":1502474153093}
mqtt.0 2017-08-11 19:55:53.117 debug stateChange system.adapter.web.0.memHeapUsed: {"val":12.13,"ack":true,"ts":1502474153089,"q":0,"from":"system.adapter.web.0","lc":1502474153089}
mqtt.0 2017-08-11 19:55:53.116 debug redis pmessage io.* io.system.adapter.web.0.inputCount {"val":139,"ack":true,"ts":1502474153096,"q":0,"from":"system.adapter.web.0","lc":1502474153096}
mqtt.0 2017-08-11 19:55:53.116 debug redis pmessage io.* io.system.adapter.web.0.uptime {"val":174832,"ack":true,"ts":1502474153093,"q":0,"from":"system.adapter.web.0","lc":1502474153093}
mqtt.0 2017-08-11 19:55:53.115 debug redis pmessage io.* io.system.adapter.web.0.memHeapUsed {"val":12.13,"ack":true,"ts":1502474153089,"q":0,"from":"system.adapter.web.0","lc":1502474153089}
mqtt.0 2017-08-11 19:55:53.115 debug stateChange system.adapter.web.0.memHeapTotal: {"val":14.99,"ack":true,"ts":1502474153085,"q":0,"from":"system.adapter.web.0","lc":1502474138079}
mqtt.0 2017-08-11 19:55:53.115 debug stateChange system.adapter.web.0.memRss: {"val":41.71,"ack":true,"ts":1502474153084,"q":0,"from":"system.adapter.web.0","lc":1502474153084}
mqtt.0 2017-08-11 19:55:53.114 debug redis pmessage io.* io.system.adapter.web.0.memHeapTotal {"val":14.99,"ack":true,"ts":1502474153085,"q":0,"from":"system.adapter.web.0","lc":1502474138079}
mqtt.0 2017-08-11 19:55:53.113 debug redis pmessage io.* io.system.adapter.web.0.memRss {"val":41.71,"ack":true,"ts":1502474153084,"q":0,"from":"system.adapter.web.0","lc":1502474153084}
mqtt.0 2017-08-11 19:55:53.113 debug stateChange system.adapter.web.0.connected: {"val":true,"ack":true,"ts":1502474153079,"q":0,"from":"system.adapter.web.0","lc":1502299324050}
mqtt.0 2017-08-11 19:55:53.112 debug stateChange system.adapter.web.0.alive: {"val":true,"ack":true,"ts":1502474153078,"q":0,"from":"system.adapter.web.0","lc":1502299324048}
mqtt.0 2017-08-11 19:55:53.112 debug redis pmessage io.* io.system.adapter.web.0.connected {"val":true,"ack":true,"ts":1502474153079,"q":0,"from":"system.adapter.web.0","lc":1502299324050}
mqtt.0 2017-08-11 19:55:53.111 debug redis pmessage io.* io.system.adapter.web.0.alive {"val":true,"ack":true,"ts":1502474153078,"q":0,"from":"system.adapter.web.0","lc":1502299324048}
mqtt.0 2017-08-11 19:55:53.082 debug stateChange system.adapter.telegram.0.outputCount: {"val":8,"ack":true,"ts":1502474153056,"q":0,"from":"system.adapter.telegram.0","lc":1502472217314}
mqtt.0 2017-08-11 19:55:53.082 debug stateChange system.adapter.telegram.0.inputCount: {"val":0,"ack":true,"ts":1502474153055,"q":0,"from":"system.adapter.telegram.0","lc":1502299756787}
mqtt.0 2017-08-11 19:55:53.082 debug stateChange system.adapter.telegram.0.uptime: {"val":174761,"ack":true,"ts":1502474153054,"q":0,"from":"system.adapter.telegram.0","lc":1502474153054}
mqtt.0 2017-08-11 19:55:53.081 debug stateChange system.adapter.telegram.0.memHeapUsed: {"val":20.07,"ack":true,"ts":1502474153054,"q":0,"from":"system.adapter.telegram.0","lc":1502474153054}
mqtt.0 2017-08-11 19:55:53.081 debug stateChange system.adapter.telegram.0.memHeapTotal: {"val":23.99,"ack":true,"ts":1502474153053,"q":0,"from":"system.adapter.telegram.0","lc":1502473612842}
mqtt.0 2017-08-11 19:55:53.080 debug stateChange system.adapter.telegram.0.memRss: {"val":42.66,"ack":true,"ts":1502474153052,"q":0,"from":"system.adapter.telegram.0","lc":1502474153052}
mqtt.0 2017-08-11 19:55:53.079 debug stateChange system.adapter.telegram.0.connected: {"val":true,"ack":true,"ts":1502474153052,"q":0,"from":"system.adapter.telegram.0","lc":1502299396847}
mqtt.0 2017-08-11 19:55:53.079 debug redis pmessage io.* io.system.adapter.telegram.0.outputCount {"val":8,"ack":true,"ts":1502474153056,"q":0,"from":"system.adapter.telegram.0","lc":1502472217314}
mqtt.0 2017-08-11 19:55:53.078 debug redis pmessage io.* io.system.adapter.telegram.0.inputCount {"val":0,"ack":true,"ts":1502474153055,"q":0,"from":"system.adapter.telegram.0","lc":1502299756787}
mqtt.0 2017-08-11 19:55:53.078 debug redis pmessage io.* io.system.adapter.telegram.0.uptime {"val":174761,"ack":true,"ts":1502474153054,"q":0,"from":"system.adapter.telegram.0","lc":1502474153054}
mqtt.0 2017-08-11 19:55:53.078 debug redis pmessage io.* io.system.adapter.telegram.0.memHeapUsed {"val":20.07,"ack":true,"ts":1502474153054,"q":0,"from":"system.adapter.telegram.0","lc":1502474153054}
mqtt.0 2017-08-11 19:55:53.077 debug redis pmessage io.* io.system.adapter.telegram.0.memHeapTotal {"val":23.99,"ack":true,"ts":1502474153053,"q":0,"from":"system.adapter.telegram.0","lc":1502473612842}
mqtt.0 2017-08-11 19:55:53.077 debug redis pmessage io.* io.system.adapter.telegram.0.memRss {"val":42.66,"ack":true,"ts":1502474153052,"q":0,"from":"system.adapter.telegram.0","lc":1502474153052}
mqtt.0 2017-08-11 19:55:53.077 debug redis pmessage io.* io.system.adapter.telegram.0.connected {"val":true,"ack":true,"ts":1502474153052,"q":0,"from":"system.adapter.telegram.0","lc":1502299396847}
mqtt.0 2017-08-11 19:55:53.076 debug stateChange system.adapter.telegram.0.alive: {"val":true,"ack":true,"ts":1502474153051,"q":0,"from":"system.adapter.telegram.0","lc":1502299396845}
mqtt.0 2017-08-11 19:55:53.076 debug redis pmessage io.* io.system.adapter.telegram.0.alive {"val":true,"ack":true,"ts":1502474153051,"q":0,"from":"system.adapter.telegram.0","lc":1502299396845}
mqtt.0 2017-08-11 19:55:52.913 debug stateChange system.adapter.fritzbox.0.outputCount: {"val":8,"ack":true,"ts":1502474152891,"q":0,"from":"system.adapter.fritzbox.0","lc":1502299980992}
mqtt.0 2017-08-11 19:55:52.913 debug stateChange system.adapter.fritzbox.0.inputCount: {"val":0,"ack":true,"ts":1502474152890,"q":0,"from":"system.adapter.fritzbox.0","lc":1502299755938}
mqtt.0 2017-08-11 19:55:52.912 debug stateChange system.adapter.fritzbox.0.uptime: {"val":174804,"ack":true,"ts":1502474152889,"q":0,"from":"system.adapter.fritzbox.0","lc":1502474152889}
mqtt.0 2017-08-11 19:55:52.912 debug stateChange system.adapter.fritzbox.0.memHeapUsed: {"val":9.66,"ack":true,"ts":1502474152889,"q":0,"from":"system.adapter.fritzbox.0","lc":1502474152889}
mqtt.0 2017-08-11 19:55:52.912 debug stateChange system.adapter.fritzbox.0.memHeapTotal: {"val":13.99,"ack":true,"ts":1502474152888,"q":0,"from":"system.adapter.fritzbox.0","lc":1502299785950}
mqtt.0 2017-08-11 19:55:52.912 debug redis pmessage io.* io.system.adapter.fritzbox.0.outputCount {"val":8,"ack":true,"ts":1502474152891,"q":0,"from":"system.adapter.fritzbox.0","lc":1502299980992}
mqtt.0 2017-08-11 19:55:52.911 debug redis pmessage io.* io.system.adapter.fritzbox.0.inputCount {"val":0,"ack":true,"ts":1502474152890,"q":0,"from":"system.adapter.fritzbox.0","lc":1502299755938}
mqtt.0 2017-08-11 19:55:52.911 debug redis pmessage io.* io.system.adapter.fritzbox.0.uptime {"val":174804,"ack":true,"ts":1502474152889,"q":0,"from":"system.adapter.fritzbox.0","lc":1502474152889}
mqtt.0 2017-08-11 19:55:52.911 debug redis pmessage io.* io.system.adapter.fritzbox.0.memHeapUsed {"val":9.66,"ack":true,"ts":1502474152889,"q":0,"from":"system.adapter.fritzbox.0","lc":1502474152889}
mqtt.0 2017-08-11 19:55:52.910 debug redis pmessage io.* io.system.adapter.fritzbox.0.memHeapTotal {"val":13.99,"ack":true,"ts":1502474152888,"q":0,"from":"system.adapter.fritzbox.0","lc":1502299785950}
mqtt.0 2017-08-11 19:55:52.910 debug stateChange system.adapter.fritzbox.0.memRss: {"val":30.03,"ack":true,"ts":1502474152887,"q":0,"from":"system.adapter.fritzbox.0","lc":1502474092844}
mqtt.0 2017-08-11 19:55:52.910 debug stateChange system.adapter.fritzbox.0.connected: {"val":true,"ack":true,"ts":1502474152886,"q":0,"from":"system.adapter.fritzbox.0","lc":1502299350705}
mqtt.0 2017-08-11 19:55:52.909 debug stateChange system.adapter.fritzbox.0.alive: {"val":true,"ack":true,"ts":1502474152886,"q":0,"from":"system.adapter.fritzbox.0","lc":1502299350703}
mqtt.0 2017-08-11 19:55:52.909 debug redis pmessage io.* io.system.adapter.fritzbox.0.memRss {"val":30.03,"ack":true,"ts":1502474152887,"q":0,"from":"system.adapter.fritzbox.0","lc":1502474092844}
mqtt.0 2017-08-11 19:55:52.909 debug redis pmessage io.* io.system.adapter.fritzbox.0.connected {"val":true,"ack":true,"ts":1502474152886,"q":0,"from":"system.adapter.fritzbox.0","lc":1502299350705}
mqtt.0 2017-08-11 19:55:52.908 debug redis pmessage io.* io.system.adapter.fritzbox.0.alive {"val":true,"ack":true,"ts":1502474152886,"q":0,"from":"system.adapter.fritzbox.0","lc":1502299350703}
mqtt.0 2017-08-11 19:55:51.832 debug stateChange system.adapter.javascript.0.outputCount: {"val":8,"ack":true,"ts":1502474151812,"q":0,"from":"system.adapter.javascript.0","lc":1502474061784}
mqtt.0 2017-08-11 19:55:51.832 debug stateChange system.adapter.javascript.0.inputCount: {"val":138,"ack":true,"ts":1502474151811,"q":0,"from":"system.adapter.javascript.0","lc":1502474151811}
mqtt.0 2017-08-11 19:55:51.832 debug stateChange system.adapter.javascript.0.uptime: {"val":174823,"ack":true,"ts":1502474151810,"q":0,"from":"system.adapter.javascript.0","lc":1502474151810}
mqtt.0 2017-08-11 19:55:51.831 debug stateChange system.adapter.javascript.0.memHeapUsed: {"val":15.46,"ack":true,"ts":1502474151809,"q":0,"from":"system.adapter.javascript.0","lc":1502474151809}
mqtt.0 2017-08-11 19:55:51.831 debug stateChange system.adapter.javascript.0.memHeapTotal: {"val":18.99,"ack":true,"ts":1502474151807,"q":0,"from":"system.adapter.javascript.0","lc":1502472201428}
mqtt.0 2017-08-11 19:55:51.831 debug stateChange system.adapter.javascript.0.memRss: {"val":41.14,"ack":true,"ts":1502474151806,"q":0,"from":"system.adapter.javascript.0","lc":1502474151806}
mqtt.0 2017-08-11 19:55:51.831 debug redis pmessage io.* io.system.adapter.javascript.0.outputCount {"val":8,"ack":true,"ts":1502474151812,"q":0,"from":"system.adapter.javascript.0","lc":1502474061784}
mqtt.0 2017-08-11 19:55:51.830 debug redis pmessage io.* io.system.adapter.javascript.0.inputCount {"val":138,"ack":true,"ts":1502474151811,"q":0,"from":"system.adapter.javascript.0","lc":1502474151811}
mqtt.0 2017-08-11 19:55:51.829 debug redis pmessage io.* io.system.adapter.javascript.0.uptime {"val":174823,"ack":true,"ts":1502474151810,"q":0,"from":"system.adapter.javascript.0","lc":1502474151810}
mqtt.0 2017-08-11 19:55:51.829 debug redis pmessage io.* io.system.adapter.javascript.0.memHeapUsed {"val":15.46,"ack":true,"ts":1502474151809,"q":0,"from":"system.adapter.javascript.0","lc":1502474151809}
mqtt.0 2017-08-11 19:55:51.828 debug redis pmessage io.* io.system.adapter.javascript.0.memHeapTotal {"val":18.99,"ack":true,"ts":1502474151807,"q":0,"from":"system.adapter.javascript.0","lc":1502472201428}
mqtt.0 2017-08-11 19:55:51.828 debug redis pmessage io.* io.system.adapter.javascript.0.memRss {"val":41.14,"ack":true,"ts":1502474151806,"q":0,"from":"system.adapter.javascript.0","lc":1502474151806}
mqtt.0 2017-08-11 19:55:51.828 debug stateChange system.adapter.javascript.0.connected: {"val":true,"ack":true,"ts":1502474151801,"q":0,"from":"system.adapter.javascript.0","lc":1502299339099}
mqtt.0 2017-08-11 19:55:51.827 debug stateChange system.adapter.javascript.0.alive: {"val":true,"ack":true,"ts":1502474151801,"q":0,"from":"system.adapter.javascript.0","lc":1502299339097}
mqtt.0 2017-08-11 19:55:51.827 debug redis pmessage io.* io.system.adapter.javascript.0.connected {"val":true,"ack":true,"ts":1502474151801,"q":0,"from":"system.adapter.javascript.0","lc":1502299339099}
mqtt.0 2017-08-11 19:55:51.826 debug redis pmessage io.* io.system.adapter.javascript.0.alive {"val":true,"ack":true,"ts":1502474151801,"q":0,"from":"system.adapter.javascript.0","lc":1502299339097}
mqtt.0 2017-08-11 19:55:50.813 debug stateChange system.host.ioBroker-RasPi.outputCount: {"val":10,"ack":true,"ts":1502474150791,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474135800}
mqtt.0 2017-08-11 19:55:50.813 debug stateChange system.host.ioBroker-RasPi.inputCount: {"val":16,"ack":true,"ts":1502474150790,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474150790}
mqtt.0 2017-08-11 19:55:50.813 debug stateChange system.host.ioBroker-RasPi.freemem: {"val":303,"ack":true,"ts":1502474150790,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474150790}
mqtt.0 2017-08-11 19:55:50.813 debug stateChange system.host.ioBroker-RasPi.uptime: {"val":174837,"ack":true,"ts":1502474150789,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474150789}
mqtt.0 2017-08-11 19:55:50.813 debug stateChange system.host.ioBroker-RasPi.memHeapUsed: {"val":35.25,"ack":true,"ts":1502474150788,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474150788}
mqtt.0 2017-08-11 19:55:50.812 debug stateChange system.host.ioBroker-RasPi.memHeapTotal: {"val":39.72,"ack":true,"ts":1502474150788,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474120793}
mqtt.0 2017-08-11 19:55:50.812 debug stateChange system.host.ioBroker-RasPi.memRss: {"val":71.54,"ack":true,"ts":1502474150787,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474150787}
mqtt.0 2017-08-11 19:55:50.812 debug redis pmessage io.* io.system.host.ioBroker-RasPi.outputCount {"val":10,"ack":true,"ts":1502474150791,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474135800}
mqtt.0 2017-08-11 19:55:50.812 debug redis pmessage io.* io.system.host.ioBroker-RasPi.inputCount {"val":16,"ack":true,"ts":1502474150790,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474150790}
mqtt.0 2017-08-11 19:55:50.806 debug redis pmessage io.* io.system.host.ioBroker-RasPi.freemem {"val":303,"ack":true,"ts":1502474150790,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474150790}
mqtt.0 2017-08-11 19:55:50.806 debug redis pmessage io.* io.system.host.ioBroker-RasPi.uptime {"val":174837,"ack":true,"ts":1502474150789,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474150789}
mqtt.0 2017-08-11 19:55:50.806 debug redis pmessage io.* io.system.host.ioBroker-RasPi.memHeapUsed {"val":35.25,"ack":true,"ts":1502474150788,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474150788}
mqtt.0 2017-08-11 19:55:50.806 debug redis pmessage io.* io.system.host.ioBroker-RasPi.memHeapTotal {"val":39.72,"ack":true,"ts":1502474150788,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474120793}
mqtt.0 2017-08-11 19:55:50.806 debug redis pmessage io.* io.system.host.ioBroker-RasPi.memRss {"val":71.54,"ack":true,"ts":1502474150787,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474150787}
mqtt.0 2017-08-11 19:55:50.805 debug stateChange system.host.ioBroker-RasPi.mem: {"val":33,"ack":true,"ts":1502474150786,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474150786}
mqtt.0 2017-08-11 19:55:50.805 debug stateChange system.host.ioBroker-RasPi.load: {"val":0.38,"ack":true,"ts":1502474150786,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474150786}
mqtt.0 2017-08-11 19:55:50.805 debug stateChange system.host.ioBroker-RasPi.alive: {"val":true,"ack":true,"ts":1502474150786,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502299331470}
mqtt.0 2017-08-11 19:55:50.804 debug redis pmessage io.* io.system.host.ioBroker-RasPi.mem {"val":33,"ack":true,"ts":1502474150786,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474150786}
mqtt.0 2017-08-11 19:55:50.804 debug redis pmessage io.* io.system.host.ioBroker-RasPi.load {"val":0.38,"ack":true,"ts":1502474150786,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502474150786}
mqtt.0 2017-08-11 19:55:50.804 debug redis pmessage io.* io.system.host.ioBroker-RasPi.alive {"val":true,"ack":true,"ts":1502474150786,"q":0,"from":"system.host.ioBroker-RasPi","lc":1502299331470}
mqtt.0 2017-08-11 19:55:50.658 debug stateChange system.adapter.sayit.0.outputCount: {"val":8,"ack":true,"ts":1502474150612,"q":0,"from":"system.adapter.sayit.0","lc":1502299452187}
mqtt.0 2017-08-11 19:55:50.658 debug stateChange system.adapter.sayit.0.inputCount: {"val":0,"ack":true,"ts":1502474150611,"q":0,"from":"system.adapter.sayit.0","lc":1502299752383}
mqtt.0 2017-08-11 19:55:50.658 debug stateChange system.adapter.sayit.0.uptime: {"val":174730,"ack":true,"ts":1502474150610,"q":0,"from":"system.adapter.sayit.0","lc":1502474150610}
mqtt.0 2017-08-11 19:55:50.657 debug stateChange system.adapter.sayit.0.memHeapUsed: {"val":7.39,"ack":true,"ts":1502474150609,"q":0,"from":"system.adapter.sayit.0","lc":1502474150609}
mqtt.0 2017-08-11 19:55:50.657 debug stateChange system.adapter.sayit.0.memHeapTotal: {"val":11.99,"ack":true,"ts":1502474150608,"q":0,"from":"system.adapter.sayit.0","lc":1502302709566}
mqtt.0 2017-08-11 19:55:50.657 debug stateChange system.adapter.sayit.0.memRss: {"val":28.77,"ack":true,"ts":1502474150606,"q":0,"from":"system.adapter.sayit.0","lc":1502474075536}
mqtt.0 2017-08-11 19:55:50.657 debug stateChange system.adapter.sayit.0.connected: {"val":true,"ack":true,"ts":1502474150604,"q":0,"from":"system.adapter.sayit.0","lc":1502299422152}
mqtt.0 2017-08-11 19:55:50.656 debug stateChange system.adapter.sayit.0.alive: {"val":true,"ack":true,"ts":1502474150601,"q":0,"from":"system.adapter.sayit.0","lc":1502299422149}
mqtt.0 2017-08-11 19:55:50.656 debug redis pmessage io.* io.system.adapter.sayit.0.outputCount {"val":8,"ack":true,"ts":1502474150612,"q":0,"from":"system.adapter.sayit.0","lc":1502299452187}
mqtt.0 2017-08-11 19:55:50.656 debug redis pmessage io.* io.system.adapter.sayit.0.inputCount {"val":0,"ack":true,"ts":1502474150611,"q":0,"from":"system.adapter.sayit.0","lc":1502299752383}
mqtt.0 2017-08-11 19:55:50.655 debug redis pmessage io.* io.system.adapter.sayit.0.uptime {"val":174730,"ack":true,"ts":1502474150610,"q":0,"from":"system.adapter.sayit.0","lc":1502474150610}
mqtt.0 2017-08-11 19:55:50.655 debug redis pmessage io.* io.system.adapter.sayit.0.memHeapUsed {"val":7.39,"ack":true,"ts":1502474150609,"q":0,"from":"system.adapter.sayit.0","lc":1502474150609}
mqtt.0 2017-08-11 19:55:50.654 debug redis pmessage io.* io.system.adapter.sayit.0.memHeapTotal {"val":11.99,"ack":true,"ts":1502474150608,"q":0,"from":"system.adapter.sayit.0","lc":1502302709566}
mqtt.0 2017-08-11 19:55:50.653 debug redis pmessage io.* io.system.adapter.sayit.0.memRss {"val":28.77,"ack":true,"ts":1502474150606,"q":0,"from":"system.adapter.sayit.0","lc":1502474075536}
mqtt.0 2017-08-11 19:55:50.653 debug redis pmessage io.* io.system.adapter.sayit.0.connected {"val":true,"ack":true,"ts":1502474150604,"q":0,"from":"system.adapter.sayit.0","lc":1502299422152}
mqtt.0 2017-08-11 19:55:50.652 debug redis pmessage io.* io.system.adapter.sayit.0.alive {"val":true,"ack":true,"ts":1502474150601,"q":0,"from":"system.adapter.sayit.0","lc":1502299422149}
mqtt.0 2017-08-11 19:55:50.652 debug stateChange system.adapter.hue.0.outputCount: {"val":8,"ack":true,"ts":1502474150590,"q":0,"from":"system.adapter.hue.0","lc":1502458000634}
mqtt.0 2017-08-11 19:55:50.652 debug stateChange system.adapter.hue.0.inputCount: {"val":0,"ack":true,"ts":1502474150589,"q":0,"from":"system.adapter.hue.0","lc":1502458000633}
mqtt.0 2017-08-11 19:55:50.651 debug stateChange system.adapter.hue.0.uptime: {"val":174798,"ack":true,"ts":1502474150589,"q":0,"from":"system.adapter.hue.0","lc":1502474150589}
mqtt.0 2017-08-11 19:55:50.651 debug stateChange system.adapter.hue.0.memHeapUsed: {"val":14.66,"ack":true,"ts":1502474150588,"q":0,"from":"system.adapter.hue.0","lc":1502474150588}
mqtt.0 2017-08-11 19:55:50.651 debug stateChange system.adapter.hue.0.memHeapTotal: {"val":16.99,"ack":true,"ts":1502474150587,"q":0,"from":"system.adapter.hue.0","lc":1502473595249}
mqtt.0 2017-08-11 19:55:50.650 debug redis pmessage io.* io.system.adapter.hue.0.outputCount {"val":8,"ack":true,"ts":1502474150590,"q":0,"from":"system.adapter.hue.0","lc":1502458000634}
mqtt.0 2017-08-11 19:55:50.650 debug redis pmessage io.* io.system.adapter.hue.0.inputCount {"val":0,"ack":true,"ts":1502474150589,"q":0,"from":"system.adapter.hue.0","lc":1502458000633}
mqtt.0 2017-08-11 19:55:50.650 debug redis pmessage io.* io.system.adapter.hue.0.uptime {"val":174798,"ack":true,"ts":1502474150589,"q":0,"from":"system.adapter.hue.0","lc":1502474150589}
mqtt.0 2017-08-11 19:55:50.649 debug redis pmessage io.* io.system.adapter.hue.0.memHeapUsed {"val":14.66,"ack":true,"ts":1502474150588,"q":0,"from":"system.adapter.hue.0","lc":1502474150588}
mqtt.0 2017-08-11 19:55:50.649 debug redis pmessage io.* io.system.adapter.hue.0.memHeapTotal {"val":16.99,"ack":true,"ts":1502474150587,"q":0,"from":"system.adapter.hue.0","lc":1502473595249}
mqtt.0 2017-08-11 19:55:50.649 debug stateChange system.adapter.hue.0.memRss: {"val":36.92,"ack":true,"ts":1502474150586,"q":0,"from":"system.adapter.hue.0","lc":1502474150586}
mqtt.0 2017-08-11 19:55:50.648 debug stateChange system.adapter.hue.0.connected: {"val":true,"ack":true,"ts":1502474150586,"q":0,"from":"system.adapter.hue.0","lc":1502299354519}
mqtt.0 2017-08-11 19:55:50.648 debug stateChange system.adapter.hue.0.alive: {"val":true,"ack":true,"ts":1502474150585,"q":0,"from":"system.adapter.hue.0","lc":1502299354518}
mqtt.0 2017-08-11 19:55:50.647 debug redis pmessage io.* io.system.adapter.hue.0.memRss {"val":36.92,"ack":true,"ts":1502474150586,"q":0,"from":"system.adapter.hue.0","lc":1502474150586}
mqtt.0 2017-08-11 19:55:50.634 debug redis pmessage io.* io.system.adapter.hue.0.connected {"val":true,"ack":true,"ts":1502474150586,"q":0,"from":"system.adapter.hue.0","lc":1502299354519}
mqtt.0 2017-08-11 19:55:50.633 debug redis pmessage io.* io.system.adapter.hue.0.alive {"val":true,"ack":true,"ts":1502474150585,"q":0,"from":"system.adapter.hue.0","lc":1502299354518}
mqtt.0 2017-08-11 19:55:50.404 debug stateChange system.adapter.hm-rpc.2.outputCount: {"val":8,"ack":true,"ts":1502474150383,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502474150383}
mqtt.0 2017-08-11 19:55:50.404 debug stateChange system.adapter.hm-rpc.2.inputCount: {"val":0,"ack":true,"ts":1502474150382,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502474150382}
mqtt.0 2017-08-11 19:55:50.402 debug stateChange system.adapter.hm-rpc.2.uptime: {"val":174734,"ack":true,"ts":1502474150381,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502474150381}
mqtt.0 2017-08-11 19:55:50.402 debug stateChange system.adapter.hm-rpc.2.memHeapUsed: {"val":10.44,"ack":true,"ts":1502474150380,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502474150380}
mqtt.0 2017-08-11 19:55:50.402 debug stateChange system.adapter.hm-rpc.2.memHeapTotal: {"val":13.99,"ack":true,"ts":1502474150379,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502473610053}
mqtt.0 2017-08-11 19:55:50.401 debug stateChange system.adapter.hm-rpc.2.memRss: {"val":30.23,"ack":true,"ts":1502474150378,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502474150378}
mqtt.0 2017-08-11 19:55:50.401 debug stateChange system.adapter.hm-rpc.2.connected: {"val":true,"ack":true,"ts":1502474150376,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502299418748}
mqtt.0 2017-08-11 19:55:50.401 debug redis pmessage io.* io.system.adapter.hm-rpc.2.outputCount {"val":8,"ack":true,"ts":1502474150383,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502474150383}
mqtt.0 2017-08-11 19:55:50.400 debug redis pmessage io.* io.system.adapter.hm-rpc.2.inputCount {"val":0,"ack":true,"ts":1502474150382,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502474150382}
mqtt.0 2017-08-11 19:55:50.400 debug redis pmessage io.* io.system.adapter.hm-rpc.2.uptime {"val":174734,"ack":true,"ts":1502474150381,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502474150381}
mqtt.0 2017-08-11 19:55:50.400 debug redis pmessage io.* io.system.adapter.hm-rpc.2.memHeapUsed {"val":10.44,"ack":true,"ts":1502474150380,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502474150380}
mqtt.0 2017-08-11 19:55:50.399 debug redis pmessage io.* io.system.adapter.hm-rpc.2.memHeapTotal {"val":13.99,"ack":true,"ts":1502474150379,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502473610053}
mqtt.0 2017-08-11 19:55:50.399 debug redis pmessage io.* io.system.adapter.hm-rpc.2.memRss {"val":30.23,"ack":true,"ts":1502474150378,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502474150378}
mqtt.0 2017-08-11 19:55:50.399 debug redis pmessage io.* io.system.adapter.hm-rpc.2.connected {"val":true,"ack":true,"ts":1502474150376,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502299418748}
mqtt.0 2017-08-11 19:55:50.398 debug stateChange system.adapter.hm-rpc.2.alive: {"val":true,"ack":true,"ts":1502474150373,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502299418747}
mqtt.0 2017-08-11 19:55:50.398 debug redis pmessage io.* io.system.adapter.hm-rpc.2.alive {"val":true,"ack":true,"ts":1502474150373,"q":0,"from":"system.adapter.hm-rpc.2","lc":1502299418747}
mqtt.0 2017-08-11 19:55:49.724 debug stateChange system.adapter.mqtt.0.outputCount: {"val":8,"ack":true,"ts":1502474149687,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149687}
mqtt.0 2017-08-11 19:55:49.724 debug stateChange system.adapter.mqtt.0.inputCount: {"val":138,"ack":true,"ts":1502474149684,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149684}
mqtt.0 2017-08-11 19:55:49.723 debug stateChange system.adapter.mqtt.0.uptime: {"val":32,"ack":true,"ts":1502474149682,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149682}
mqtt.0 2017-08-11 19:55:49.723 debug stateChange system.adapter.mqtt.0.memHeapUsed: {"val":15.23,"ack":true,"ts":1502474149679,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149679}
mqtt.0 2017-08-11 19:55:49.723 debug stateChange system.adapter.mqtt.0.memHeapTotal: {"val":21.88,"ack":true,"ts":1502474149676,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149676}
mqtt.0 2017-08-11 19:55:49.723 debug stateChange system.adapter.mqtt.0.memRss: {"val":38.98,"ack":true,"ts":1502474149674,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149674}
mqtt.0 2017-08-11 19:55:49.722 debug stateChange system.adapter.mqtt.0.connected: {"val":true,"ack":true,"ts":1502474149671,"q":0,"from":"system.adapter.mqtt.0","lc":1502474119688}
mqtt.0 2017-08-11 19:55:49.722 debug stateChange system.adapter.mqtt.0.alive: {"val":true,"ack":true,"ts":1502474149670,"q":0,"from":"system.adapter.mqtt.0","lc":1502474119684}
mqtt.0 2017-08-11 19:55:49.722 debug redis pmessage io.* io.system.adapter.mqtt.0.outputCount {"val":8,"ack":true,"ts":1502474149687,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149687}
mqtt.0 2017-08-11 19:55:49.721 debug redis pmessage io.* io.system.adapter.mqtt.0.inputCount {"val":138,"ack":true,"ts":1502474149684,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149684}
mqtt.0 2017-08-11 19:55:49.706 debug redis pmessage io.* io.system.adapter.mqtt.0.uptime {"val":32,"ack":true,"ts":1502474149682,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149682}
mqtt.0 2017-08-11 19:55:49.706 debug redis pmessage io.* io.system.adapter.mqtt.0.memHeapUsed {"val":15.23,"ack":true,"ts":1502474149679,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149679}
mqtt.0 2017-08-11 19:55:49.706 debug redis pmessage io.* io.system.adapter.mqtt.0.memHeapTotal {"val":21.88,"ack":true,"ts":1502474149676,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149676}
mqtt.0 2017-08-11 19:55:49.705 debug redis pmessage io.* io.system.adapter.mqtt.0.memRss {"val":38.98,"ack":true,"ts":1502474149674,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149674}
mqtt.0 2017-08-11 19:55:49.705 debug redis pmessage io.* io.system.adapter.mqtt.0.connected {"val":true,"ack":true,"ts":1502474149671,"q":0,"from":"system.adapter.mqtt.0","lc":1502474119688}
mqtt.0 2017-08-11 19:55:49.705 debug redis pmessage io.* io.system.adapter.mqtt.0.alive {"val":true,"ack":true,"ts":1502474149670,"q":0,"from":"system.adapter.mqtt.0","lc":1502474119684}
mqtt.0 2017-08-11 19:55:49.705 debug redis publish io.system.adapter.mqtt.0.outputCount {"val":8,"ack":true,"ts":1502474149687,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149687}
mqtt.0 2017-08-11 19:55:49.704 debug redis publish io.system.adapter.mqtt.0.inputCount {"val":138,"ack":true,"ts":1502474149684,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149684}
mqtt.0 2017-08-11 19:55:49.704 debug redis publish io.system.adapter.mqtt.0.uptime {"val":32,"ack":true,"ts":1502474149682,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149682}
mqtt.0 2017-08-11 19:55:49.704 debug redis publish io.system.adapter.mqtt.0.memHeapUsed {"val":15.23,"ack":true,"ts":1502474149679,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149679}
mqtt.0 2017-08-11 19:55:49.704 debug redis publish io.system.adapter.mqtt.0.memHeapTotal {"val":21.88,"ack":true,"ts":1502474149676,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149676}
mqtt.0 2017-08-11 19:55:49.703 debug redis publish io.system.adapter.mqtt.0.memRss {"val":38.98,"ack":true,"ts":1502474149674,"q":0,"from":"system.adapter.mqtt.0","lc":1502474149674}
mqtt.0 2017-08-11 19:55:49.703 debug redis publish io.system.adapter.mqtt.0.connected {"val":true,"ack":true,"ts":1502474149671,"q":0,"from":"system.adapter.mqtt.0","lc":1502474119688}
mqtt.0 2017-08-11 19:55:49.703 debug redis publish io.system.adapter.mqtt.0.alive {"val":true,"ack":true,"ts":1502474149670,"q":0,"from":"system.adapter.mqtt.0","lc":1502474119684}
mqtt.0 2017-08-11 19:55:48.345 debug stateChange system.adapter.cloud.0.outputCount: {"val":8,"ack":true,"ts":1502474148332,"q":0,"from":"system.adapter.cloud.0","lc":1502474133357}
mqtt.0 2017-08-11 19:55:48.343 debug redis pmessage io.* io.system.adapter.cloud.0.outputCount {"val":8,"ack":true,"ts":1502474148332,"q":0,"from":"system.adapter.cloud.0","lc":1502474133357}
mqtt.0 2017-08-11 19:55:48.343 debug stateChange system.adapter.cloud.0.inputCount: {"val":0,"ack":true,"ts":1502474148328,"q":0,"from":"system.adapter.cloud.0","lc":1502299746904}
mqtt.0 2017-08-11 19:55:48.343 debug stateChange system.adapter.cloud.0.uptime: {"val":48,"ack":true,"ts":1502474148325,"q":0,"from":"system.adapter.cloud.0","lc":1502474148325}
mqtt.0 2017-08-11 19:55:48.342 debug redis pmessage io.* io.system.adapter.cloud.0.inputCount {"val":0,"ack":true,"ts":1502474148328,"q":0,"from":"system.adapter.cloud.0","lc":1502299746904}
mqtt.0 2017-08-11 19:55:48.342 debug redis pmessage io.* io.system.adapter.cloud.0.uptime {"val":48,"ack":true,"ts":1502474148325,"q":0,"from":"system.adapter.cloud.0","lc":1502474148325}
mqtt.0 2017-08-11 19:55:48.342 debug stateChange system.adapter.cloud.0.memHeapUsed: {"val":21.13,"ack":true,"ts":1502474148322,"q":0,"from":"system.adapter.cloud.0","lc":1502474148322}
mqtt.0 2017-08-11 19:55:48.342 debug stateChange system.adapter.cloud.0.memHeapTotal: {"val":34.88,"ack":true,"ts":1502474148316,"q":0,"from":"system.adapter.cloud.0","lc":1502474118272}
mqtt.0 2017-08-11 19:55:48.341 debug redis pmessage io.* io.system.adapter.cloud.0.memHeapUsed {"val":21.13,"ack":true,"ts":1502474148322,"q":0,"from":"system.adapter.cloud.0","lc":1502474148322}
mqtt.0 2017-08-11 19:55:48.341 debug redis pmessage io.* io.system.adapter.cloud.0.memHeapTotal {"val":34.88,"ack":true,"ts":1502474148316,"q":0,"from":"system.adapter.cloud.0","lc":1502474118272}
mqtt.0 2017-08-11 19:55:48.341 debug stateChange system.adapter.cloud.0.memRss: {"val":46.98,"ack":true,"ts":1502474148315,"q":0,"from":"system.adapter.cloud.0","lc":1502474148315}
mqtt.0 2017-08-11 19:55:48.341 debug stateChange system.adapter.cloud.0.connected: {"val":true,"ack":true,"ts":1502474148313,"q":0,"from":"system.adapter.cloud.0","lc":1502474103578}
mqtt.0 2017-08-11 19:55:48.340 debug redis pmessage io.* io.system.adapter.cloud.0.memRss {"val":46.98,"ack":true,"ts":1502474148315,"q":0,"from":"system.adapter.cloud.0","lc":1502474148315}
mqtt.0 2017-08-11 19:55:48.340 debug redis pmessage io.* io.system.adapter.cloud.0.connected {"val":true,"ack":true,"ts":1502474148313,"q":0,"from":"system.adapter.cloud.0","lc":1502474103578}
mqtt.0 2017-08-11 19:55:48.340 debug stateChange system.adapter.cloud.0.alive: {"val":true,"ack":true,"ts":1502474148310,"q":0,"from":"system.adapter.cloud.0","lc":1502474103574}
mqtt.0 2017-08-11 19:55:48.315 debug redis pmessage io.* io.system.adapter.cloud.0.alive {"val":true,"ack":true,"ts":1502474148310,"q":0,"from":"system.adapter.cloud.0","lc":1502474103574}
mqtt.0 2017-08-11 19:55:45.663 debug stateChange system.adapter.rpi2.0.outputCount: {"val":8,"ack":true,"ts":1502474145641,"q":0,"from":"system.adapter.rpi2.0","lc":1502474115619}
mqtt.0 2017-08-11 19:55:45.663 debug stateChange system.adapter.rpi2.0.inputCount: {"val":0,"ack":true,"ts":1502474145641,"q":0,"from":"system.adapter.rpi2.0","lc":1502474130632}
mqtt.0 2017-08-11 19:55:45.663 debug stateChange system.adapter.rpi2.0.uptime: {"val":174813,"ack":true,"ts":1502474145640,"q":0,"from":"system.adapter.rpi2.0","lc":1502474145640}
mqtt.0 2017-08-11 19:55:45.662 debug stateChange system.adapter.rpi2.0.memHeapUsed: {"val":11.99,"ack":true,"ts":1502474145639,"q":0,"from":"system.adapter.rpi2.0","lc":1502474145639}
mqtt.0 2017-08-11 19:55:45.662 debug stateChange system.adapter.rpi2.0.memHeapTotal: {"val":14.99,"ack":true,"ts":1502474145638,"q":0,"from":"system.adapter.rpi2.0","lc":1502436562659}
mqtt.0 2017-08-11 19:55:45.662 debug redis pmessage io.* io.system.adapter.rpi2.0.outputCount {"val":8,"ack":true,"ts":1502474145641,"q":0,"from":"system.adapter.rpi2.0","lc":1502474115619}
mqtt.0 2017-08-11 19:55:45.661 debug redis pmessage io.* io.system.adapter.rpi2.0.inputCount {"val":0,"ack":true,"ts":1502474145641,"q":0,"from":"system.adapter.rpi2.0","lc":1502474130632}
mqtt.0 2017-08-11 19:55:45.661 debug redis pmessage io.* io.system.adapter.rpi2.0.uptime {"val":174813,"ack":true,"ts":1502474145640,"q":0,"from":"system.adapter.rpi2.0","lc":1502474145640}
mqtt.0 2017-08-11 19:55:45.660 debug redis pmessage io.* io.system.adapter.rpi2.0.memHeapUsed {"val":11.99,"ack":true,"ts":1502474145639,"q":0,"from":"system.adapter.rpi2.0","lc":1502474145639}
mqtt.0 2017-08-11 19:55:45.660 debug redis pmessage io.* io.system.adapter.rpi2.0.memHeapTotal {"val":14.99,"ack":true,"ts":1502474145638,"q":0,"from":"system.adapter.rpi2.0","lc":1502436562659}
mqtt.0 2017-08-11 19:55:45.660 debug stateChange system.adapter.rpi2.0.memRss: {"val":34.31,"ack":true,"ts":1502474145637,"q":0,"from":"system.adapter.rpi2.0","lc":1502474145637}
mqtt.0 2017-08-11 19:55:45.660 debug stateChange system.adapter.rpi2.0.connected: {"val":true,"ack":true,"ts":1502474145634,"q":0,"from":"system.adapter.rpi2.0","lc":1502299334562}
mqtt.0 2017-08-11 19:55:45.659 debug redis pmessage io.* io.system.adapter.rpi2.0.memRss {"val":34.31,"ack":true,"ts":1502474145637,"q":0,"from":"system.adapter.rpi2.0","lc":1502474145637}
mqtt.0 2017-08-11 19:55:45.659 debug redis pmessage io.* io.system.adapter.rpi2.0.connected {"val":true,"ack":true,"ts":1502474145634,"q":0,"from":"system.adapter.rpi2.0","lc":1502299334562}
mqtt.0 2017-08-11 19:55:45.659 debug stateChange system.adapter.rpi2.0.alive: {"val":true,"ack":true,"ts":1502474145632,"q":0,"from":"system.adapter.rpi2.0","lc":1502299334561}
mqtt.0 2017-08-11 19:55:45.658 debug redis pmessage io.* io.system.adapter.rpi2.0.alive {"val":true,"ack":true,"ts":1502474145632,"q":0,"from":"system.adapter.rpi2.0","lc":1502299334561}
mqtt.0 2017-08-11 19:55:43.194 debug stateChange system.adapter.socketio.0.outputCount: {"val":8,"ack":true,"ts":1502474143148,"q":0,"from":"system.adapter.socketio.0","lc":1502299369996}
mqtt.0 2017-08-11 19:55:43.194 debug stateChange system.adapter.socketio.0.inputCount: {"val":0,"ack":true,"ts":1502474143147,"q":0,"from":"system.adapter.socketio.0","lc":1502299745285}
mqtt.0 2017-08-11 19:55:43.193 debug stateChange system.adapter.socketio.0.uptime: {"val":174807,"ack":true,"ts":1502474143147,"q":0,"from":"system.adapter.socketio.0","lc":1502474143147}
mqtt.0 2017-08-11 19:55:43.192 debug stateChange system.adapter.socketio.0.memHeapUsed: {"val":11.37,"ack":true,"ts":1502474143146,"q":0,"from":"system.adapter.socketio.0","lc":1502474143146}
mqtt.0 2017-08-11 19:55:43.191 debug stateChange system.adapter.socketio.0.memHeapTotal: {"val":14.99,"ack":true,"ts":1502474143146,"q":0,"from":"system.adapter.socketio.0","lc":1502300976229}
mqtt.0 2017-08-11 19:55:43.191 debug stateChange system.adapter.socketio.0.memRss: {"val":31.63,"ack":true,"ts":1502474143145,"q":0,"from":"system.adapter.socketio.0","lc":1502474098120}
mqtt.0 2017-08-11 19:55:43.190 debug stateChange system.adapter.socketio.0.connected: {"val":true,"ack":true,"ts":1502474143145,"q":0,"from":"system.adapter.socketio.0","lc":1502299340129}
mqtt.0 2017-08-11 19:55:43.189 debug redis pmessage io.* io.system.adapter.socketio.0.outputCount {"val":8,"ack":true,"ts":1502474143148,"q":0,"from":"system.adapter.socketio.0","lc":1502299369996}
mqtt.0 2017-08-11 19:55:43.189 debug redis pmessage io.* io.system.adapter.socketio.0.inputCount {"val":0,"ack":true,"ts":1502474143147,"q":0,"from":"system.adapter.socketio.0","lc":1502299745285}
mqtt.0 2017-08-11 19:55:43.188 debug redis pmessage io.* io.system.adapter.socketio.0.uptime {"val":174807,"ack":true,"ts":1502474143147,"q":0,"from":"system.adapter.socketio.0","lc":1502474143147}
mqtt.0 2017-08-11 19:55:43.187 debug redis pmessage io.* io.system.adapter.socketio.0.memHeapUsed {"val":11.37,"ack":true,"ts":1502474143146,"q":0,"from":"system.adapter.socketio.0","lc":1502474143146}
mqtt.0 2017-08-11 19:55:43.186 debug redis pmessage io.* io.system.adapter.socketio.0.memHeapTotal {"val":14.99,"ack":true,"ts":1502474143146,"q":0,"from":"system.adapter.socketio.0","lc":1502300976229}
mqtt.0 2017-08-11 19:55:43.185 debug redis pmessage io.* io.system.adapter.socketio.0.memRss {"val":31.63,"ack":true,"ts":1502474143145,"q":0,"from":"system.adapter.socketio.0","lc":1502474098120}
mqtt.0 2017-08-11 19:55:43.184 debug redis pmessage io.* io.system.adapter.socketio.0.connected {"val":true,"ack":true,"ts":1502474143145,"q":0,"from":"system.adapter.socketio.0","lc":1502299340129}
mqtt.0 2017-08-11 19:55:43.154 debug stateChange system.adapter.socketio.0.alive: {"val":true,"ack":true,"ts":1502474143144,"q":0,"from":"system.adapter.socketio.0","lc":1502299340127}
mqtt.0 2017-08-11 19:55:43.152 debug redis pmessage io.* io.system.adapter.socketio.0.alive {"val":true,"ack":true,"ts":1502474143144,"q":0,"from":"system.adapter.socketio.0","lc":1502299340127}
mqtt.0 2017-08-11 19:55:42.939 debug stateChange system.adapter.wifilight.0.outputCount: {"val":8,"ack":true,"ts":1502474142920,"q":0,"from":"system.adapter.wifilight.0","lc":1498997461045}
mqtt.0 2017-08-11 19:55:42.939 debug stateChange system.adapter.wifilight.0.inputCount: {"val":0,"ack":true,"ts":1502474142919,"q":0,"from":"system.adapter.wifilight.0","lc":1502299753011}
mqtt.0 2017-08-11 19:55:42.938 debug stateChange system.adapter.wifilight.0.uptime: {"val":174782,"ack":true,"ts":1502474142918,"q":0,"from":"system.adapter.wifilight.0","lc":1502474142918}
mqtt.0 2017-08-11 19:55:42.938 debug redis pmessage io.* io.system.adapter.wifilight.0.outputCount {"val":8,"ack":true,"ts":1502474142920,"q":0,"from":"system.adapter.wifilight.0","lc":1498997461045}
mqtt.0 2017-08-11 19:55:42.938 debug redis pmessage io.* io.system.adapter.wifilight.0.inputCount {"val":0,"ack":true,"ts":1502474142919,"q":0,"from":"system.adapter.wifilight.0","lc":1502299753011}
Der Log läuft im Sekundentakt. Ich weiß auch nicht, ob ich auf was spezielles achten muss.
Spike
