leider ist es nicht möglich das HomeKit zu installieren.
Folgende Fehlermeldung kommt:
$ ./iobroker add homekit2
npm install iobroker.homekit2 –production --prefix "/opt/iobroker" (System call)
In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
#include <dns_sd.h>^
compilation terminated.
make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
gyp
ERR! build error
gyp ERR! stack Error: make failed with exit code: 2gyp
ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
gyp
ERR! System Linux 4.9.24-v7+gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp
ERR! cwd /opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/mdnsgyp ERR! node -v v4.8.3
gyp ERR! node-gyp -v v3.4.0
gyp ERR! not ok
npm
ERR!
Linux 4.9.24-v7+npm
ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit2" "–production" "--prefix" "/opt/iobroker"npm ERR! node v4.8.3
npm ERR! npm v2.15.11
npm ERR! code ELIFECYCLE
npm ERR! mdns@2.3.3 install: node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm
ERR! Failed at the mdns@2.3.3 install script 'node-gyp rebuild'.npm ERR! This is most likely a problem with the mdns package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node-gyp rebuild
npm ERR! You can get information on how to open an issue for this project with:
npm ERR! npm bugs mdnsnpm ERR! Or if that isn't available, you can get their info via:
npm ERR!
npm ERR! npm owner ls mdns
npm ERR! There is likely additional logging output above.
npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
Was muss ich machen ???</dns_sd.h> `
