@homoran leider hat es etwas länger gedauert, hier der iob diag:
Skript v.2024-04-21
*** BASE SYSTEM ***
Static hostname: iobroker
Icon name: computer
Kernel: Linux 6.6.28+rpt-rpi-v8
Architecture: arm64
Model : Raspberry Pi 4 Model B Rev 1.4
Docker : false
Virtualization : none
Kernel : aarch64
Userland : 64 bit
Systemuptime and Load:
20:52:28 up 3 days, 2:59, 2 users, load average: 0.40, 0.30, 0.30
CPU threads: 4
*** RASPBERRY THROTTLING ***
Current issues:
Previously detected issues:
*** Time and Time Zones ***
Local time: Tue 2024-05-07 20:52:29 CEST
Universal time: Tue 2024-05-07 18:52:29 UTC
RTC time: n/a
NTP service: active
RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
pi
HOME=/home/pi
GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
iobroker
HOME=/home/iobroker
GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
*** Display-Server-Setup ***
pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
Try `pgrep -f' option to match against the complete command line.
Display-Server: false
Desktop:
Terminal: tty
Boot Target: multi-user.target
*** MEMORY ***
total used free shared buff/cache available
Mem: 8.2G 3.9G 2.5G 1.2G 3.1G 4.3G
Swap: 0B 0B 0B
Total: 8.2G 3.9G 2.5G
Active iob-Instances: 25
7809 M total memory
3729 M used memory
3740 M active memory
1392 M inactive memory
2404 M free memory
70 M buffer memory
2916 M swap cache
0 M total swap
0 M used swap
0 M free swap
*** top - Table Of Processes ***
top - 20:52:29 up 3 days, 2:59, 2 users, load average: 0.40, 0.30, 0.30
Tasks: 187 total, 1 running, 186 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.0 us, 20.0 sy, 0.0 ni, 80.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
MiB Mem : 7809.0 total, 2402.7 free, 3730.8 used, 2987.2 buff/cache
MiB Swap: 0.0 total, 0.0 free, 0.0 used. 4078.2 avail Mem
*** FAILED SERVICES ***
0 loaded units listed.
*** FILESYSTEM ***
Filesystem Type Size Used Avail Use% Mounted on
udev devtmpfs 3.6G 0 3.6G 0% /dev
tmpfs tmpfs 781M 1.2M 780M 1% /run
/dev/sda2 ext4 117G 6.1G 105G 6% /media/root-ro
tmpfs-root tmpfs 3.9G 1.2G 2.7G 31% /media/root-rw
overlayroot overlay 3.9G 1.2G 2.7G 31% /
tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock
/dev/sda1 vfat 510M 65M 446M 13% /boot/firmware
tmpfs tmpfs 781M 0 781M 0% /run/user/1000
[Sat May 4 17:52:35 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:CC:8A:26 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 overlayroot=tmpfs console=ttyS0,115200 console=tty1 root=PARTUUID=18d56978-02 rootfstype=ext4 fsck.repair=yes rootwait
[Sat May 4 17:52:38 2024] EXT4-fs (sda2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
Show mounted filesystems:
TARGET SOURCE FSTYPE OPTIONS
/ overlayroot overlay rw,relatime,lowerdir=/media/root-ro,upperdir=/media/root-rw/overlay,workdir=/media/root-rw/overlay-workdir/_,uuid=on
|-/sys sysfs sysfs rw,nosuid,nodev,noexec,relatime
| |-/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime
| |-/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
| |-/sys/fs/pstore pstore pstore rw,nosuid,nodev,noexec,relatime
| |-/sys/fs/bpf bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700
| |-/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime
| |-/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime
| |-/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime
| `-/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime
|-/proc proc proc rw,relatime
| `-/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5103
| `-/proc/sys/fs/binfmt_misc binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
|-/dev udev devtmpfs rw,nosuid,relatime,size=3727756k,nr_inodes=931939,mode=755
| |-/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
| |-/dev/shm tmpfs tmpfs rw,nosuid,nodev
| `-/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime
|-/run tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=799648k,mode=755
| |-/run/lock tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k
| |-/run/credentials/systemd-sysusers.service ramfs ramfs ro,nosuid,nodev,noexec,relatime,mode=700
| |-/run/credentials/systemd-sysctl.service ramfs ramfs ro,nosuid,nodev,noexec,relatime,mode=700
| |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs ramfs ro,nosuid,nodev,noexec,relatime,mode=700
| |-/run/rpc_pipefs sunrpc rpc_pipefs rw,relatime
| |-/run/credentials/systemd-tmpfiles-setup.service ramfs ramfs ro,nosuid,nodev,noexec,relatime,mode=700
| `-/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=799644k,nr_inodes=199911,mode=700,uid=1000,gid=1000
|-/media/root-ro /dev/sda2 ext4 ro,relatime
|-/media/root-rw tmpfs-root tmpfs rw,relatime
`-/boot/firmware /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
/var:
890M /var/
370M /var/log/journal/1dd69d72b10b476d84246cd7693434f0
370M /var/log
213M /var/lib
Archived and active journals take up 369.7M in the file system.
/opt/iobroker/backups:
35M /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
543M /opt/iobroker/iobroker-data/
414M /opt/iobroker/iobroker-data/files
142M /opt/iobroker/iobroker-data/files/vis-2
98M /opt/iobroker/iobroker-data/backup-objects
81M /opt/iobroker/iobroker-data/files/vis-2/static
33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
26M /opt/iobroker/iobroker-data/objects.jsonl
24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
19M /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
19M /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
USB-Devices by-id:
USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D9A500-if00
HINT:
Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
/dev/ttyACM0
*** NodeJS-Installation ***
/usr/bin/nodejs v18.20.2
/usr/bin/node v18.20.2
/usr/bin/npm 10.5.0
/usr/bin/npx 10.5.0
/usr/bin/corepack 0.25.2
nodejs:
Installed: 18.20.2-1nodesource1
Candidate: 18.20.2-1nodesource1
Version table:
*** 18.20.2-1nodesource1 1001
100 /var/lib/dpkg/status
18.20.1-1nodesource1 1001
18.20.0-1nodesource1 1001
18.19.1-1nodesource1 1001
18.19.0+dfsg-6~deb12u1 500
18.19.0-1nodesource1 1001
18.18.2-1nodesource1 1001
18.18.1-1nodesource1 1001
18.18.0-1nodesource1 1001
18.17.1-1nodesource1 1001
18.17.0-1nodesource1 1001
18.16.1-1nodesource1 1001
18.16.0-1nodesource1 1001
18.15.0-1nodesource1 1001
18.14.2-1nodesource1 1001
18.14.1-1nodesource1 1001
18.14.0-1nodesource1 1001
18.13.0+dfsg1-1 500
18.13.0-1nodesource1 1001
18.12.0-1nodesource1 1001
18.11.0-1nodesource1 1001
18.10.0-1nodesource1 1001
18.9.1-1nodesource1 1001
18.9.0-1nodesource1 1001
18.8.0-1nodesource1 1001
18.7.0-1nodesource1 1001
18.6.0-1nodesource1 1001
18.5.0-1nodesource1 1001
18.4.0-1nodesource1 1001
18.3.0-1nodesource1 1001
18.2.0-1nodesource1 1001
18.1.0-1nodesource1 1001
18.0.0-1nodesource1 1001
No problems detected
Errors in npm tree:
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States type: jsonl
Core adapters versions
js-controller: 5.0.19
admin: 6.13.16
javascript: 7.8.0
nodejs modules from github: 0
Adapter State
+ system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 127.0.0.1, run as: admin
+ system.adapter.admin.1 : admin : iobroker - enabled, port: 8085, bind: 0.0.0.0 (SSL), run as: admin
+ system.adapter.alexa2.0 : alexa2 : iobroker - enabled
+ system.adapter.backitup.0 : backitup : iobroker - enabled
+ system.adapter.cloud.0 : cloud : iobroker - enabled
system.adapter.daswetter.0 : daswetter : iobroker - enabled
system.adapter.discovery.0 : discovery : iobroker - disabled
+ system.adapter.ems-esp.0 : ems-esp : iobroker - enabled
system.adapter.flot.0 : flot : iobroker - disabled
+ system.adapter.gruenbeck.0 : gruenbeck : iobroker - enabled
+ system.adapter.homeconnect.0 : homeconnect : iobroker - enabled
system.adapter.ical.0 : ical : iobroker - enabled
system.adapter.ical.1 : ical : iobroker - enabled
system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - disabled
+ system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086
system.adapter.info.0 : info : iobroker - disabled
+ system.adapter.iot.0 : iot : iobroker - enabled
+ system.adapter.iqontrol.0 : iqontrol : iobroker - enabled
+ system.adapter.javascript.0 : javascript : iobroker - enabled
+ system.adapter.klf200.0 : klf200 : iobroker - enabled
+ system.adapter.knx.0 : knx : iobroker - enabled, bind: 192.168.55.17
+ system.adapter.logparser.0 : logparser : iobroker - enabled
+ system.adapter.nuki-extended.0 : nuki-extended : iobroker - enabled
system.adapter.owntracks.0 : owntracks : iobroker - disabled, port: 1883, bind: 0.0.0.0
+ system.adapter.ping.0 : ping : iobroker - enabled
system.adapter.schoolfree.0 : schoolfree : iobroker - enabled
+ system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: 0.0.0.0
+ system.adapter.shuttercontrol.0 : shuttercontrol : iobroker - enabled
system.adapter.sql.0 : sql : iobroker - disabled
+ system.adapter.time-switch.0 : time-switch : iobroker - enabled
system.adapter.tr-064.0 : tr-064 : iobroker - disabled
+ system.adapter.trashschedule.0 : trashschedule : iobroker - enabled
system.adapter.vis-2.0 : vis-2 : iobroker - disabled
system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - disabled
system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - disabled
system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - disabled
system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker - disabled
system.adapter.vis-map.0 : vis-map : iobroker - disabled
system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker - disabled
system.adapter.vis-metro.0 : vis-metro : iobroker - disabled
system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - disabled
system.adapter.vis-weather.0 : vis-weather : iobroker - disabled
system.adapter.vis.0 : vis : iobroker - disabled
+ system.adapter.web.0 : web : iobroker - enabled, port: 8083, bind: 127.0.0.1, run as: admin
+ system.adapter.web.1 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker - disabled
system.adapter.whatsapp-cmb.1 : whatsapp-cmb : iobroker - disabled
system.adapter.whatsapp-cmb.2 : whatsapp-cmb : iobroker - disabled
system.adapter.whatsapp-cmb.3 : whatsapp-cmb : iobroker - disabled
+ system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyACM0
+ instance is alive
ioBroker-Repositories
Stable (default): http://download.iobroker.net/sources-dist.json
Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
github : https://github.com/walli545/ioBroker.time-switch/tree/master
__ :
Active repo(s): Stable (default)
Installed ioBroker-Instances
Used repository: Stable (default)
Adapter "admin" : 6.13.16 , installed 6.13.16
Adapter "alexa2" : 3.26.5 , installed 3.26.5
Adapter "backitup" : 2.11.0 , installed 2.11.0
Adapter "cloud" : 5.0.1 , installed 5.0.1
Adapter "daswetter" : 3.1.13 , installed 3.1.13
Adapter "discovery" : 4.4.0 , installed 4.4.0
Adapter "ems-esp" : 3.0.3 , installed 3.0.3
Adapter "flot" : 1.12.0 , installed 1.12.0
Adapter "gruenbeck" : 0.0.42 , installed 0.0.42
Adapter "homeconnect" : 1.3.0 , installed 1.3.0
Adapter "ical" : 1.14.3 , installed 1.14.3
Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1
Adapter "influxdb" : 4.0.2 , installed 4.0.2
Adapter "iot" : 2.0.11 , installed 2.0.11
Adapter "iqontrol" : 2.3.0 , installed 2.3.0
Adapter "javascript" : 7.8.0 , installed 7.8.0
Controller "js-controller": 5.0.19 , installed 5.0.19
Adapter "klf200" : 1.2.0 , installed 1.2.0
Adapter "knx" : 2.0.24 , installed 2.0.24
Adapter "logparser" : 2.2.2 , installed 2.2.2
Adapter "nuki-extended": 2.6.5 , installed 2.6.5
Adapter "owntracks" : 1.0.5 , installed 1.0.5
Adapter "ping" : 1.6.2 , installed 1.6.2
Adapter "schoolfree" : 1.1.4 , installed 1.1.4
Adapter "shelly" : 6.9.0 , installed 6.9.0
Adapter "shuttercontrol": 1.7.0 , installed 1.7.0
Adapter "simple-api" : 2.7.2 , installed 2.7.2
Adapter "socketio" : 6.7.0 , installed 6.7.0
Adapter "sql" : 2.2.0 , installed 2.2.0
Adapter "tr-064" : 4.2.18 , installed 4.2.18
Adapter "trashschedule": 3.2.0 , installed 3.2.0
Adapter "vis" : 1.5.4 , installed 1.5.4
Adapter "vis-2" : 2.9.32 , installed 2.9.32
Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1
Adapter "vis-icontwo" : 1.5.0 , installed 1.5.0
Adapter "vis-inventwo" : 3.3.4 , installed 3.3.4
Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1
Adapter "vis-map" : 1.0.5 , installed 1.0.5
Adapter "vis-materialdesign": 0.5.9, installed 0.5.9
Adapter "vis-metro" : 1.2.0 , installed 1.2.0
Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
Adapter "vis-weather" : 2.5.9 , installed 2.5.9
Adapter "web" : 6.2.5 , installed 6.2.5
Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3
Adapter "ws" : 2.6.1 , installed 2.6.1
Adapter "zigbee" : 1.10.3 , installed 1.10.3
Objects and States
Objects: 8119
States: 6831
Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
Hit:5 https://repos.influxdata.com/debian stable InRelease
Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
Pending Updates: 8
*** Listening Ports ***
Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 16673 1821/io.shelly.0
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 664 692/sshd: /usr/sbin
tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 6448 801/iobroker.js-con
tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 5791 801/iobroker.js-con
tcp 0 0 127.0.0.1:8081 0.0.0.0:* LISTEN 1001 854 820/io.admin.0
tcp 0 0 127.0.0.1:8083 0.0.0.0:* LISTEN 1001 20265 2459/io.web.0
tcp6 0 0 :::22 :::* LISTEN 0 666 692/sshd: /usr/sbin
tcp6 0 0 :::8082 :::* LISTEN 1001 18269 2460/io.web.1
tcp6 0 0 :::8085 :::* LISTEN 1001 3012 831/io.admin.1
tcp6 0 0 :::8086 :::* LISTEN 999 5773 758/influxd
tcp6 0 0 :::51989 :::* LISTEN 1001 24333 3126/io.nuki-extend
udp 0 0 192.168.55.17:53585 0.0.0.0:* 1001 1320214 1129/io.knx.0
udp 0 0 192.168.55.17:45435 0.0.0.0:* 1001 1434273 1129/io.knx.0
udp 0 0 192.168.55.17:49588 0.0.0.0:* 1001 1484760 1129/io.knx.0
udp 0 0 192.168.55.17:37321 0.0.0.0:* 1001 1539987 1129/io.knx.0
udp 0 0 192.168.55.17:41424 0.0.0.0:* 1001 1077398 1129/io.knx.0
udp 0 0 192.168.55.17:57813 0.0.0.0:* 1001 204741 1129/io.knx.0
udp 0 0 192.168.55.17:41468 0.0.0.0:* 1001 850401 1129/io.knx.0
udp 0 0 192.168.55.17:49725 0.0.0.0:* 1001 1417821 1129/io.knx.0
udp 0 0 192.168.55.17:33347 0.0.0.0:* 1001 346810 1129/io.knx.0
udp 0 0 192.168.55.17:53835 0.0.0.0:* 1001 219024 1129/io.knx.0
udp 0 0 192.168.55.17:45669 0.0.0.0:* 1001 1164554 1129/io.knx.0
udp 0 0 192.168.55.17:37496 0.0.0.0:* 1001 1343074 1129/io.knx.0
udp 0 0 192.168.55.17:33482 0.0.0.0:* 1001 191416 1129/io.knx.0
udp 0 0 192.168.55.17:37595 0.0.0.0:* 1001 737244 1129/io.knx.0
udp 0 0 192.168.55.17:33500 0.0.0.0:* 1001 1542501 1129/io.knx.0
udp 0 0 192.168.55.17:37620 0.0.0.0:* 1001 1038356 1129/io.knx.0
udp 0 0 192.168.55.17:33551 0.0.0.0:* 1001 215142 1129/io.knx.0
udp 0 0 192.168.55.17:37667 0.0.0.0:* 1001 859309 1129/io.knx.0
udp 0 0 192.168.55.17:41765 0.0.0.0:* 1001 1065449 1129/io.knx.0
udp 0 0 192.168.55.17:58308 0.0.0.0:* 1001 751430 1129/io.knx.0
udp 0 0 192.168.55.17:41954 0.0.0.0:* 1001 893307 1129/io.knx.0
udp 0 0 192.168.55.17:41972 0.0.0.0:* 1001 1703380 1129/io.knx.0
udp 0 0 192.168.55.17:33784 0.0.0.0:* 1001 824551 1129/io.knx.0
udp 0 0 192.168.55.17:58426 0.0.0.0:* 1001 919253 1129/io.knx.0
udp 0 0 192.168.55.17:54366 0.0.0.0:* 1001 280124 1129/io.knx.0
udp 0 0 192.168.55.17:42094 0.0.0.0:* 1001 213971 1129/io.knx.0
udp 0 0 192.168.55.17:58480 0.0.0.0:* 1001 1167122 1129/io.knx.0
udp 0 0 192.168.55.17:58489 0.0.0.0:* 1001 1511231 1129/io.knx.0
udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 5660 553/avahi-daemon: r
udp 0 0 192.168.55.17:58629 0.0.0.0:* 1001 787357 1129/io.knx.0
udp 0 0 192.168.55.17:42252 0.0.0.0:* 1001 1082958 1129/io.knx.0
udp 0 0 192.168.55.17:38182 0.0.0.0:* 1001 692861 1129/io.knx.0
udp 0 0 192.168.55.17:42280 0.0.0.0:* 1001 846776 1129/io.knx.0
udp 0 0 192.168.55.17:58696 0.0.0.0:* 1001 1135843 1129/io.knx.0
udp 0 0 192.168.55.17:50506 0.0.0.0:* 1001 1611503 1129/io.knx.0
udp 0 0 192.168.55.17:38224 0.0.0.0:* 1001 1774543 1129/io.knx.0
udp 0 0 192.168.55.17:38267 0.0.0.0:* 1001 203032 1129/io.knx.0
udp 0 0 192.168.55.17:34188 0.0.0.0:* 1001 811069 1129/io.knx.0
udp 0 0 192.168.55.17:50587 0.0.0.0:* 1001 732947 1129/io.knx.0
udp 0 0 192.168.55.17:58811 0.0.0.0:* 1001 1150193 1129/io.knx.0
udp 0 0 192.168.55.17:42493 0.0.0.0:* 1001 828994 1129/io.knx.0
udp 0 0 192.168.55.17:34327 0.0.0.0:* 1001 389317 1129/io.knx.0
udp 0 0 192.168.55.17:58925 0.0.0.0:* 1001 1073005 1129/io.knx.0
udp 0 0 192.168.55.17:46641 0.0.0.0:* 1001 1489545 1129/io.knx.0
udp 0 0 192.168.55.17:42570 0.0.0.0:* 1001 921832 1129/io.knx.0
udp 0 0 192.168.55.17:50770 0.0.0.0:* 1001 1426866 1129/io.knx.0
udp 0 0 192.168.55.17:34396 0.0.0.0:* 1001 929389 1129/io.knx.0
udp 0 0 192.168.55.17:50829 0.0.0.0:* 1001 1643163 1129/io.knx.0
udp 0 0 192.168.55.17:46738 0.0.0.0:* 1001 1449648 1129/io.knx.0
udp 0 0 192.168.55.17:34487 0.0.0.0:* 1001 892383 1129/io.knx.0
udp 0 0 192.168.55.17:46801 0.0.0.0:* 1001 201499 1129/io.knx.0
udp 0 0 192.168.55.17:38624 0.0.0.0:* 1001 900793 1129/io.knx.0
udp 0 0 192.168.55.17:34566 0.0.0.0:* 1001 1426576 1129/io.knx.0
udp 0 0 192.168.55.17:42771 0.0.0.0:* 1001 866449 1129/io.knx.0
udp 0 0 192.168.55.17:50975 0.0.0.0:* 1001 1125010 1129/io.knx.0
udp 0 0 192.168.55.17:38756 0.0.0.0:* 1001 1529996 1129/io.knx.0
udp 0 0 192.168.55.17:42858 0.0.0.0:* 1001 264601 1129/io.knx.0
udp 0 0 0.0.0.0:38818 0.0.0.0:* 104 5662 553/avahi-daemon: r
udp 0 0 192.168.55.17:59325 0.0.0.0:* 1001 905584 1129/io.knx.0
udp 0 0 192.168.55.17:55244 0.0.0.0:* 1001 838999 1129/io.knx.0
udp 0 0 192.168.55.17:38870 0.0.0.0:* 1001 1176214 1129/io.knx.0
udp 0 0 192.168.55.17:38889 0.0.0.0:* 1001 1527594 1129/io.knx.0
udp 0 0 192.168.55.17:43000 0.0.0.0:* 1001 1469221 1129/io.knx.0
udp 0 0 192.168.55.17:43004 0.0.0.0:* 1001 1601686 1129/io.knx.0
udp 0 0 192.168.55.17:51240 0.0.0.0:* 1001 250634 1129/io.knx.0
udp 0 0 192.168.55.17:38968 0.0.0.0:* 1001 1634424 1129/io.knx.0
udp 0 0 192.168.55.17:55352 0.0.0.0:* 1001 1131335 1129/io.knx.0
udp 0 0 192.168.55.17:34883 0.0.0.0:* 1001 1343870 1129/io.knx.0
udp 0 0 192.168.55.17:39021 0.0.0.0:* 1001 1036375 1129/io.knx.0
udp 0 0 192.168.55.17:43134 0.0.0.0:* 1001 1499164 1129/io.knx.0
udp 0 0 192.168.55.17:34951 0.0.0.0:* 1001 836713 1129/io.knx.0
udp 0 0 192.168.55.17:59534 0.0.0.0:* 1001 1442563 1129/io.knx.0
udp 0 0 192.168.55.17:51348 0.0.0.0:* 1001 1143042 1129/io.knx.0
udp 0 0 192.168.55.17:47253 0.0.0.0:* 1001 858543 1129/io.knx.0
udp 0 0 192.168.55.17:47334 0.0.0.0:* 1001 1384621 1129/io.knx.0
udp 0 0 192.168.55.17:51457 0.0.0.0:* 1001 200608 1129/io.knx.0
udp 0 0 192.168.55.17:51483 0.0.0.0:* 1001 1003730 1129/io.knx.0
udp 0 0 192.168.55.17:55693 0.0.0.0:* 1001 288090 1129/io.knx.0
udp 0 0 192.168.55.17:59790 0.0.0.0:* 1001 910422 1129/io.knx.0
udp 0 0 192.168.55.17:59828 0.0.0.0:* 1001 730841 1129/io.knx.0
udp 0 0 192.168.55.17:47553 0.0.0.0:* 1001 1404587 1129/io.knx.0
udp 0 0 192.168.55.17:59850 0.0.0.0:* 1001 94894 1129/io.knx.0
udp 0 0 192.168.55.17:47624 0.0.0.0:* 1001 1353853 1129/io.knx.0
udp 0 0 192.168.55.17:51750 0.0.0.0:* 1001 220651 1129/io.knx.0
udp 0 0 192.168.55.17:55888 0.0.0.0:* 1001 844428 1129/io.knx.0
udp 0 0 192.168.55.17:47696 0.0.0.0:* 1001 302055 1129/io.knx.0
udp 0 0 192.168.55.17:47750 0.0.0.0:* 1001 1587640 1129/io.knx.0
udp 0 0 192.168.55.17:39588 0.0.0.0:* 1001 1000137 1129/io.knx.0
udp 0 0 192.168.55.17:47815 0.0.0.0:* 1001 1684948 1129/io.knx.0
udp 0 0 192.168.55.17:51955 0.0.0.0:* 1001 1625452 1129/io.knx.0
udp 0 0 192.168.55.17:39708 0.0.0.0:* 1001 1293233 1129/io.knx.0
udp 0 0 192.168.55.17:52040 0.0.0.0:* 1001 848201 1129/io.knx.0
udp 0 0 192.168.55.17:43892 0.0.0.0:* 1001 1350819 1129/io.knx.0
udp 0 0 192.168.55.17:48016 0.0.0.0:* 1001 830410 1129/io.knx.0
udp 0 0 192.168.55.17:60313 0.0.0.0:* 1001 207649 1129/io.knx.0
udp 0 0 192.168.55.17:39881 0.0.0.0:* 1001 1127407 1129/io.knx.0
udp 0 0 192.168.55.17:35812 0.0.0.0:* 1001 1072708 1129/io.knx.0
udp 0 0 192.168.55.17:44008 0.0.0.0:* 1001 1171986 1129/io.knx.0
udp 0 0 192.168.55.17:52218 0.0.0.0:* 1001 1240533 1129/io.knx.0
udp 0 0 192.168.55.17:44064 0.0.0.0:* 1001 1352068 1129/io.knx.0
udp 0 0 192.168.55.17:44082 0.0.0.0:* 1001 212683 1129/io.knx.0
udp 0 0 192.168.55.17:44096 0.0.0.0:* 1001 913030 1129/io.knx.0
udp 0 0 192.168.55.17:48317 0.0.0.0:* 1001 718416 1129/io.knx.0
udp 0 0 192.168.55.17:44249 0.0.0.0:* 1001 1504903 1129/io.knx.0
udp 0 0 192.168.55.17:48348 0.0.0.0:* 1001 1433253 1129/io.knx.0
udp 0 0 192.168.55.17:60710 0.0.0.0:* 1001 221685 1129/io.knx.0
udp 0 0 192.168.55.17:56655 0.0.0.0:* 1001 1297823 1129/io.knx.0
udp 0 0 192.168.55.17:56660 0.0.0.0:* 1001 882317 1129/io.knx.0
udp 0 0 192.168.55.17:40290 0.0.0.0:* 1001 243494 1129/io.knx.0
udp 0 0 192.168.55.17:40351 0.0.0.0:* 1001 1468108 1129/io.knx.0
udp 0 0 192.168.55.17:36280 0.0.0.0:* 1001 993512 1129/io.knx.0
udp 0 0 192.168.55.17:40407 0.0.0.0:* 1001 1021380 1129/io.knx.0
udp 0 0 192.168.55.17:56835 0.0.0.0:* 1001 1472320 1129/io.knx.0
udp 0 0 192.168.55.17:40496 0.0.0.0:* 1001 815858 1129/io.knx.0
udp 0 0 192.168.55.17:40539 0.0.0.0:* 1001 1367423 1129/io.knx.0
udp 0 0 192.168.55.17:52931 0.0.0.0:* 1001 851510 1129/io.knx.0
udp 0 0 192.168.55.17:57038 0.0.0.0:* 1001 1311859 1129/io.knx.0
udp 0 0 192.168.55.17:48849 0.0.0.0:* 1001 843148 1129/io.knx.0
udp 0 0 192.168.55.17:44776 0.0.0.0:* 1001 842499 1129/io.knx.0
udp 0 0 192.168.55.17:57093 0.0.0.0:* 1001 1486392 1129/io.knx.0
udp 0 0 192.168.55.17:53003 0.0.0.0:* 1001 292774 1129/io.knx.0
udp 0 0 192.168.55.17:53102 0.0.0.0:* 1001 1329649 1129/io.knx.0
udp 0 0 192.168.55.17:36734 0.0.0.0:* 1001 781743 1129/io.knx.0
udp 0 0 192.168.55.17:40839 0.0.0.0:* 1001 791084 1129/io.knx.0
udp 0 0 192.168.55.17:49054 0.0.0.0:* 1001 74435 1129/io.knx.0
udp 0 0 192.168.55.17:45023 0.0.0.0:* 1001 1305166 1129/io.knx.0
udp 0 0 192.168.55.17:57312 0.0.0.0:* 1001 7095 1129/io.knx.0
udp 0 0 192.168.55.17:57316 0.0.0.0:* 1001 868884 1129/io.knx.0
udp 0 0 192.168.55.17:32795 0.0.0.0:* 1001 862693 1129/io.knx.0
udp 0 0 192.168.55.17:53278 0.0.0.0:* 1001 840310 1129/io.knx.0
udp 0 0 192.168.55.17:40999 0.0.0.0:* 1001 903110 1129/io.knx.0
udp 0 0 192.168.55.17:57406 0.0.0.0:* 1001 1423931 1129/io.knx.0
udp 0 0 192.168.55.17:57411 0.0.0.0:* 1001 1295027 1129/io.knx.0
udp 0 0 192.168.55.17:41029 0.0.0.0:* 1001 806693 1129/io.knx.0
udp 0 0 192.168.55.17:36972 0.0.0.0:* 1001 1776997 1129/io.knx.0
udp 0 0 192.168.55.17:41071 0.0.0.0:* 1001 1444901 1129/io.knx.0
udp 0 0 192.168.55.17:37041 0.0.0.0:* 1001 621235 1129/io.knx.0
udp 0 0 192.168.55.17:41167 0.0.0.0:* 1001 838581 1129/io.knx.0
udp 0 0 192.168.55.17:37085 0.0.0.0:* 1001 200911 1129/io.knx.0
udp 0 0 192.168.55.17:49384 0.0.0.0:* 1001 218997 1129/io.knx.0
udp 0 0 192.168.55.17:57597 0.0.0.0:* 1001 820923 1129/io.knx.0
udp 0 0 192.168.55.17:37150 0.0.0.0:* 1001 1399003 1129/io.knx.0
udp6 0 0 fe80::10d:4f40:ebc0:546 :::* 0 6384 634/NetworkManager
udp6 0 0 :::37485 :::* 104 5663 553/avahi-daemon: r
udp6 0 0 :::5353 :::* 104 5661 553/avahi-daemon: r
2024-05-07 20:30:08.080 - warn: ical.0 (85931) Error reading "https://calendar.google.com/calendar/ical/xxxxxxxxgroup.calendar.google.com/private-xxxxxxxxxbasic.ics": Cannot read URL: "https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxgroup.calendar.google.com/privatexxxxxxxxxxxxxbasic.ics"
2024-05-07 20:30:08.154 - info: ical.0 (85931) processing URL: Sina https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxbasic.ics
2024-05-07 20:30:08.183 - info: host.iobroker instance system.adapter.ical.1 started with pid 85948
2024-05-07 20:30:09.990 - info: ical.0 (85931) processing URL: Bastian xxxxxxxxx basic.ics
2024-05-07 20:30:12.059 - info: ical.1 (85948) starting. Version 1.14.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 5.0.19
2024-05-07 20:30:12.961 - info: ical.0 (85931) processing URL: Anke https://caxxxxxxxxx/basic.ics
2024-05-07 20:30:13.204 - info: ical.1 (85948) processing URL: Abfall https://xxxxxxxxxxxx/basic.ics
2024-05-07 20:30:13.803 - info: daswetter.0 (85913) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
2024-05-07 20:30:14.328 - info: daswetter.0 (85913) cleaned everything up...
2024-05-07 20:30:14.364 - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2024-05-07 20:30:18.764 - info: ical.1 (85948) Terminated (NO_ERROR): Without reason
2024-05-07 20:30:19.294 - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
2024-05-07 20:30:22.501 - info: ical.0 (85931) Terminated (NO_ERROR): Without reason
2024-05-07 20:30:23.039 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
2024-05-07 20:31:56.280 - info: knx.0 (1129) Value received on unknown GA : 0/4/104
2024-05-07 20:38:54.936 - warn: zigbee.0 (47821) DeviceAvailability:Stopping to ping 0x84182600000f2bda Plug 01 after 128 ping attempts
2024-05-07 20:39:15.174 - warn: zigbee.0 (47821) DeviceAvailability:Stopping to ping 0x7cb03eaa00a73e93 Plug 01 after 129 ping attempts
2024-05-07 20:41:49.294 - info: knx.0 (1129) Value received on unknown GA : 0/4/104
2024-05-07 20:45:00.049 - info: host.iobroker instance system.adapter.daswetter.0 started with pid 86182
2024-05-07 20:45:02.224 - info: daswetter.0 (86182) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.20.2, js-controller: 5.0.19
2024-05-07 20:45:09.381 - info: daswetter.0 (86182) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
2024-05-07 20:45:09.900 - info: daswetter.0 (86182) cleaned everything up...
2024-05-07 20:45:09.918 - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2024-05-07 20:45:20.326 - info: admin.1 (831) ==> Connected system.user.admin from ::ffff:192.168.55.28
2024-05-07 20:51:42.195 - info: knx.0 (1129) Value received on unknown GA : 0/4/104
iob diag has finished.
Press any key for a summary
WOW, ich sehe das zum ersten mal. Wahnsinn. Ich hoffe du siehst da mehr wie ich 🙂
