@glasfaser
@glasfaser
Danke, der Tipp mit dem Hostname hat mir geholfen.
Konnte die Wiederherstellung durchführen.
Den Original Container konnte ich auch mit debug=true nicht zum Laufen bekommen. Der bleibt bei Script will exit now.
Hier mal noch der Output aus dem LOG:
2023-12-23 18:11:40.768 - [32minfo[39m: host.693e7e55261d iobroker.js-controller version 5.0.17 js-controller starting
2023-12-23 18:11:40.775 - [32minfo[39m: host.693e7e55261d Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
2023-12-23 18:11:40.776 - [32minfo[39m: host.693e7e55261d hostname: 693e7e55261d, node: v18.19.0
2023-12-23 18:11:40.777 - [32minfo[39m: host.693e7e55261d ip addresses: 192.168.0.139
2023-12-23 18:11:43.187 - [32minfo[39m: host.693e7e55261d connected to Objects and States
2023-12-23 18:11:43.299 - [32minfo[39m: host.693e7e55261d added notifications configuration of host
2023-12-23 18:11:43.305 - [32minfo[39m: host.693e7e55261d Node.js version has changed from unknown to 18.19.0
2023-12-23 18:11:43.350 - [32minfo[39m: host.693e7e55261d Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
2023-12-23 18:11:44.136 - [32minfo[39m: host.693e7e55261d Delete host system.host.693e7e55261d
2023-12-23 18:11:44.413 - [32minfo[39m: host.693e7e55261d 29 instances found
2023-12-23 18:11:44.466 - [32minfo[39m: host.693e7e55261d starting 2 instances
2023-12-23 18:11:44.693 - [32minfo[39m: host.693e7e55261d instance scheduled system.adapter.ical.0 0,30 * * * *
2023-12-23 18:11:44.707 - [32minfo[39m: host.693e7e55261d instance system.adapter.ical.0 started with pid 420
2023-12-23 18:11:47.377 - [32minfo[39m: ical.0 (420) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
2023-12-23 18:11:48.384 - [32minfo[39m: ical.0 (420) processing URL: Abfallkalender http://www.50morgen.de/Muellabfuhrkalender/ICS/muellabfuhr_2023_mit_alarm.ics
2023-12-23 18:11:48.586 - [32minfo[39m: host.693e7e55261d instance system.adapter.mihome-vacuum.0 started with pid 447
2023-12-23 18:11:51.375 - [32minfo[39m: mihome-vacuum.0 (447) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v18.19.0, js-controller: 5.0.17
2023-12-23 18:11:51.497 - [32minfo[39m: mihome-vacuum.0 (447) IOT enabled, create state
2023-12-23 18:11:53.640 - [32minfo[39m: ical.0 (420) Terminated (NO_ERROR): Without reason
2023-12-23 18:11:54.308 - [32minfo[39m: host.693e7e55261d instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
2023-12-23 18:30:00.034 - [32minfo[39m: host.693e7e55261d instance system.adapter.ical.0 started with pid 1336
2023-12-23 18:30:03.595 - [32minfo[39m: ical.0 (1336) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
2023-12-23 18:30:04.396 - [32minfo[39m: ical.0 (1336) processing URL: Abfallkalender http://www.50morgen.de/Muellabfuhrkalender/ICS/muellabfuhr_2023_mit_alarm.ics
2023-12-23 18:30:09.618 - [32minfo[39m: ical.0 (1336) Terminated (NO_ERROR): Without reason
2023-12-23 18:30:10.154 - [32minfo[39m: host.693e7e55261d instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
2023-12-23 19:00:00.033 - [32minfo[39m: host.693e7e55261d instance system.adapter.ical.0 started with pid 2783
2023-12-23 19:00:06.927 - [32minfo[39m: ical.0 (2783) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
2023-12-23 19:00:07.719 - [32minfo[39m: ical.0 (2783) processing URL: Abfallkalender http://www.50morgen.de/Muellabfuhrkalender/ICS/muellabfuhr_2023_mit_alarm.ics
2023-12-23 19:00:13.003 - [32minfo[39m: ical.0 (2783) Terminated (NO_ERROR): Without reason
2023-12-23 19:00:13.542 - [32minfo[39m: host.693e7e55261d instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
2023-12-23 19:00:20.629 - [32minfo[39m: host.693e7e55261d received SIGTERM
2023-12-23 19:00:20.632 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.admin.0 (force=false, process=false)
2023-12-23 19:00:20.632 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.history.0 (force=false, process=false)
2023-12-23 19:00:20.633 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.javascript.0 (force=false, process=false)
2023-12-23 19:00:20.633 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.whatsapp-cmb.0 (force=false, process=false)
2023-12-23 19:00:20.633 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.ping.0 (force=false, process=false)
2023-12-23 19:00:20.633 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.hue.0 (force=false, process=false)
2023-12-23 19:00:20.634 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.hmip.0 (force=false, process=false)
2023-12-23 19:00:20.634 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.alexa2.0 (force=false, process=false)
2023-12-23 19:00:20.634 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.openweathermap.0 (force=false, process=false)
2023-12-23 19:00:20.634 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.sony-bravia.0 (force=false, process=false)
2023-12-23 19:00:20.634 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.ical.0 (force=false, process=false)
2023-12-23 19:00:20.639 - [32minfo[39m: host.693e7e55261d stopInstance canceled schedule system.adapter.ical.0
2023-12-23 19:00:20.639 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
2023-12-23 19:00:20.640 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.zigbee.0 (force=false, process=false)
2023-12-23 19:00:20.640 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.discovery.0 (force=false, process=false)
2023-12-23 19:00:20.640 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.backitup.0 (force=false, process=false)
2023-12-23 19:00:20.640 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.net-tools.0 (force=false, process=false)
2023-12-23 19:00:20.641 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.hue-extended.0 (force=false, process=false)
2023-12-23 19:00:20.641 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.web.0 (force=false, process=false)
2023-12-23 19:00:20.641 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.jarvis.0 (force=false, process=false)
2023-12-23 19:00:20.641 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.vis.0 (force=false, process=false)
2023-12-23 19:00:20.642 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.habpanel.0 (force=false, process=false)
2023-12-23 19:00:20.642 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.cloud.0 (force=false, process=false)
2023-12-23 19:00:20.643 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.iot.0 (force=false, process=false)
2023-12-23 19:00:20.643 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.fullcalendar.0 (force=false, process=false)
2023-12-23 19:00:20.643 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.trashschedule.0 (force=false, process=false)
2023-12-23 19:00:20.643 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.device-watcher.0 (force=false, process=false)
2023-12-23 19:00:20.643 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.homeconnect.0 (force=false, process=false)
2023-12-23 19:00:20.644 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.sourceanalytix.0 (force=false, process=false)
2023-12-23 19:00:20.651 - [32minfo[39m: host.693e7e55261d stopInstance system.adapter.mihome-vacuum.0 send kill signal
2023-12-23 19:00:20.651 - [32minfo[39m: mihome-vacuum.0 (447) Got terminate signal TERMINATE_YOURSELF
2023-12-23 19:00:20.658 - [31merror[39m: mihome-vacuum.0 (447) Socket Close
2023-12-23 19:00:20.660 - [32minfo[39m: mihome-vacuum.0 (447) terminating
2023-12-23 19:00:20.661 - [32minfo[39m: mihome-vacuum.0 (447) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2023-12-23 19:00:21.161 - [32minfo[39m: mihome-vacuum.0 (447) terminating
2023-12-23 19:00:21.365 - [32minfo[39m: host.693e7e55261d instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2023-12-23 19:00:21.366 - [32minfo[39m: host.693e7e55261d All instances are stopped.
2023-12-23 19:00:21.671 - [32minfo[39m: host.693e7e55261d terminated
