@thomas-braun said in Nodejs Update von 16.x auf 18.x geht nicht:
Sieht alles gut aus
pi@raspberrypi:~ $ sudo apt update
Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:3 https://repos.influxdata.com/debian stable InRelease
Hit:4 https://apt.grafana.com stable InRelease
Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
Get:6 https://dl.cloudsmith.io/public/evcc/stable/deb/raspbian bullseye InRelease [5127 B]
Fetched 5127 B in 2s (3278 B/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
pi@raspberrypi:~ $
apt policy grafana grafana-rpi
grafana:
Installed: 10.1.2
Candidate: 10.1.2
Version table:
*** 10.1.2 500
500 https://apt.grafana.com stable/main armhf Packages
100 /var/lib/dpkg/status
10.1.1 500
10.0.6 500
10.0.5 500
10.0.3 500
10.0.2 500
10.0.1 500
10.0.0 500
9.5.10 500
Skript v.2023-06-20
*** BASE SYSTEM ***
Static hostname: raspberrypi
Icon name: computer
Machine ID: 576f358b250c4617b98a23b9a999219a
Boot ID: 7dd3841f94324e6f83a87f578cc41588
Operating System: Raspbian GNU/Linux 11 (bullseye)
Kernel: Linux 6.1.21-v8+
Architecture: arm64
Model : Raspberry Pi 4 Model B Rev 1.1
Docker : false
Virtualization : none
Kernel : aarch64
Userland : armhf
Systemuptime and Load:
21:20:26 up 14 min, 1 user, load average: 0.42, 0.59, 0.66
CPU threads: 4
Raspberry only:
throttled=0x0
Other values than 0x0 hint to temperature/voltage problems
temp=47.2'C
volt=0.8375V
*** Time and Time Zones ***
Local time: Mon 2023-10-09 21:20:27 CEST
Universal time: Mon 2023-10-09 19:20:27 UTC
RTC time: n/a
Time zone: Europe/Vienna (CEST, +0200)
NTP service: active
RTC in local TZ: no
*** User and Groups ***
pi
/home/pi
pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
*** X-Server-Setup ***
X-Server: false
Desktop:
Terminal: tty
Boot Target: multi-user.target
*** MEMORY ***
total used free shared buff/cache available
Mem: 3.8G 1.0G 1.9G 1.0M 912M 2.8G
Swap: 99M 0B 99M
Total: 3.9G 1.0G 2.0G
3793 M total memory
1016 M used memory
1262 M active memory
512 M inactive memory
1864 M free memory
84 M buffer memory
828 M swap cache
99 M total swap
0 M used swap
99 M free swap
Raspberry only:
oom events: 0
*** FILESYSTEM ***
Filesystem Type Size Used Avail Use% Mounted on
/dev/root ext4 117G 56G 55G 51% /
devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev
tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs tmpfs 759M 1.2M 758M 1% /run
tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
/dev/sda1 vfat 253M 51M 202M 20% /boot
tmpfs tmpfs 380M 16K 380M 1% /run/user/1000
[Mon Oct 9 21:05:36 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:64:1F:3C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=bcf4838c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[Mon Oct 9 21:05:38 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
[Mon Oct 9 21:05:38 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
[Mon Oct 9 21:05:40 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
Show mounted filesystems (real ones only):
TARGET SOURCE FSTYPE OPTIONS
/ /dev/sda2 ext4 rw,noatime
`-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
/var:
6.2G /var/
4.8G /var/log
3.7G /var/log/journal/576f358b250c4617b98a23b9a999219a
924M /var/lib
Archived and active journals take up 3.6G in the file system.
/opt/iobroker/backups:
43G /opt/iobroker/backups/
4.0K /opt/iobroker/backups/scripte
/opt/iobroker/iobroker-data:
621M /opt/iobroker/iobroker-data/
538M /opt/iobroker/iobroker-data/files
88M /opt/iobroker/iobroker-data/files/echarts.admin
68M /opt/iobroker/iobroker-data/backup-objects
57M /opt/iobroker/iobroker-data/files/echarts
41M /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
23M /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
23M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
23M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
*** NodeJS-Installation ***
/usr/bin/nodejs v18.18.0
/usr/bin/node v18.18.0
/usr/bin/npm 9.8.1
/usr/bin/npx 9.8.1
nodejs:
Installed: 18.18.0-1nodesource1
Candidate: 18.18.0-1nodesource1
Version table:
*** 18.18.0-1nodesource1 1001
500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
18.17.1-1nodesource1 1001
18.17.0-1nodesource1 1001
18.16.1-1nodesource1 1001
18.16.0-1nodesource1 1001
18.15.0-1nodesource1 1001
18.14.2-1nodesource1 1001
18.14.1-1nodesource1 1001
18.14.0-1nodesource1 1001
18.13.0-1nodesource1 1001
18.12.0-1nodesource1 1001
18.11.0-1nodesource1 1001
18.10.0-1nodesource1 1001
18.9.1-1nodesource1 1001
18.9.0-1nodesource1 1001
18.8.0-1nodesource1 1001
18.7.0-1nodesource1 1001
18.6.0-1nodesource1 1001
18.5.0-1nodesource1 1001
18.4.0-1nodesource1 1001
18.3.0-1nodesource1 1001
18.2.0-1nodesource1 1001
18.1.0-1nodesource1 1001
18.0.0-1nodesource1 1001
12.22.12~dfsg-1~deb11u4 500
500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
No problems detected
Errors in npm tree: 0
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States type: redis
No configuration change needed.
Multihost discovery server: disabled
Discovery authentication: enabled
Persistent activation: disabled
Objects: jsonl on 127.0.0.1
States: redis on 127.0.0.1
Core adapters versions
js-controller: 5.0.12
admin: 6.10.1
javascript: 7.1.4
Adapters from github: 1
Adapter State
+ system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
+ system.adapter.alexa2.0 : alexa2 : raspberrypi - enabled
system.adapter.alias-manager.0 : alias-manager : raspberrypi - disabled
+ system.adapter.backitup.0 : backitup : raspberrypi - enabled
+ system.adapter.denon.0 : denon : raspberrypi - enabled
system.adapter.devices.0 : devices : raspberrypi - disabled
system.adapter.discovery.0 : discovery : raspberrypi - disabled
+ system.adapter.echarts.0 : echarts : raspberrypi - enabled
+ system.adapter.energiefluss.0 : energiefluss : raspberrypi - enabled
+ system.adapter.evcc.1 : evcc : raspberrypi - enabled, port: 7070
system.adapter.flot.0 : flot : raspberrypi - disabled
system.adapter.habpanel.0 : habpanel : raspberrypi - enabled
+ system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086
system.adapter.info.0 : info : raspberrypi - disabled
system.adapter.iot.0 : iot : raspberrypi - disabled
system.adapter.iqontrol.0 : iqontrol : raspberrypi - disabled
system.adapter.jarvis.0 : jarvis : raspberrypi - disabled
+ system.adapter.javascript.0 : javascript : raspberrypi - enabled
system.adapter.material.0 : material : raspberrypi - disabled
+ system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1886, bind: 0.0.0.0
system.adapter.net-tools.0 : net-tools : raspberrypi - disabled
system.adapter.ping.0 : ping : raspberrypi - disabled
+ system.adapter.rpi2.0 : rpi2 : raspberrypi - enabled
+ system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1500, bind: 0.0.0.0
+ system.adapter.telegram.1 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0
+ system.adapter.text2command.0 : text2command : raspberrypi - enabled
system.adapter.tr-064.0 : tr-064 : raspberrypi - disabled
system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi - enabled
+ system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled
system.adapter.vis.0 : vis : raspberrypi - enabled
+ system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
+ instance is alive
ioBroker-Repositories
live-stable : http://iobroker.live/repo/sources-dist.json
live-beta : http://iobroker.live/repo/sources-dist-latest.json
stable : http://download.iobroker.net/sources-dist.json
beta : http://download.iobroker.net/sources-dist-latest.json
Active repo(s): stable
Installed ioBroker-Instances
Used repository: stable
Adapter "admin" : 6.10.1 , installed 6.10.1
Adapter "alexa2" : 3.25.2 , installed 3.25.2
Adapter "alias-manager": 1.2.6 , installed 1.2.6
Adapter "awattar" : 1.0.6 , installed 1.0.6
Adapter "backitup" : 2.8.1 , installed 2.8.1
Adapter "denon" : 1.15.4 , installed 1.15.4
Adapter "devices" : 1.1.5 , installed 1.1.5
Adapter "discovery" : 3.1.0 , installed 3.1.0
Adapter "echarts" : 1.5.1 , installed 1.5.1
Adapter "email" : 1.2.0 , installed 1.2.0
Adapter "evcc" : 0.0.10 , installed 0.0.10
Adapter "flot" : 1.12.0 , installed 1.12.0
Adapter "habpanel" : 0.5.0 , installed 0.5.0
Adapter "history" : 2.2.6 , installed 2.2.6
Adapter "influxdb" : 3.2.0 , installed 3.2.0
Adapter "info" : 2.0.0 , installed 2.0.0
Adapter "iot" : 1.14.5 , installed 1.14.5
Adapter "iqontrol" : 2.3.0 , installed 2.3.0
Adapter "jarvis" : 3.1.2 , installed 3.1.2
Adapter "javascript" : 7.1.4 , installed 7.1.4
Controller "js-controller": 5.0.12 , installed 5.0.12
Adapter "material" : 1.3.1 , installed 1.3.1
Adapter "mqtt" : 4.1.1 , installed 4.1.1
Adapter "net-tools" : 0.2.0 , installed 0.2.0
Adapter "node-red" : 4.0.3 , installed 4.0.3
Adapter "openhab" : 1.1.0 , installed 1.1.0
Adapter "ping" : 1.6.2 , installed 1.6.2
Adapter "pushover" : 3.0.3 , installed 3.0.3
Adapter "rpi2" : 1.3.2 , installed 1.3.2
Adapter "simple-api" : 2.7.2 , installed 2.7.2
Adapter "smart-eq" : 0.0.4 , installed 0.0.4
Adapter "socketio" : 6.5.5 , installed 6.5.5
Adapter "sonoff" : 2.5.3 , installed 2.5.3
Adapter "telegram" : 1.16.0 , installed 1.16.0
Adapter "text2command" : 3.0.2 , installed 3.0.2
Adapter "tr-064" : 4.2.18 , installed 4.2.18
Adapter "vis" : 1.4.16 , installed 1.4.16
Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
Adapter "vis-icontwo" : 0.96.0 , installed 0.96.0
Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
Adapter "web" : 6.1.2 , installed 6.1.2
Adapter "ws" : 2.5.5 , installed 2.5.5
Objects and States
Objects: 4651
States: 3804
Fetched 5127 B in 1s (3460 B/s)
Pending Updates: 0
*** Listening Ports ***
Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 15083 1139/iobroker.js-co
tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 16438 527/cupsd
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 16403 586/sshd: /usr/sbin
tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 115 14100 546/redis-server 12
tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 16446 551/influxd
tcp 0 0 0.0.0.0:1887 0.0.0.0:* LISTEN 1001 19477 1280/io.mqtt.0
tcp 0 0 0.0.0.0:1886 0.0.0.0:* LISTEN 1001 19476 1280/io.mqtt.0
tcp 0 0 0.0.0.0:5900 0.0.0.0:* LISTEN 0 14145 576/vncserver-x11-c
tcp 0 0 0.0.0.0:1500 0.0.0.0:* LISTEN 1001 19596 1352/io.sonoff.0
tcp6 0 0 ::1:6379 :::* LISTEN 115 14101 546/redis-server 12
tcp6 0 0 :::3000 :::* LISTEN 116 16320 1138/grafana
tcp6 0 0 :::7070 :::* LISTEN 117 27426 3269/evcc
tcp6 0 0 ::1:631 :::* LISTEN 0 16437 527/cupsd
tcp6 0 0 :::22 :::* LISTEN 0 16405 586/sshd: /usr/sbin
tcp6 0 0 :::8086 :::* LISTEN 999 15916 551/influxd
tcp6 0 0 :::8081 :::* LISTEN 1001 16035 1173/io.admin.0
tcp6 0 0 :::8082 :::* LISTEN 1001 21068 1641/io.web.0
tcp6 0 0 :::5900 :::* LISTEN 0 14144 576/vncserver-x11-c
udp 0 0 0.0.0.0:5353 0.0.0.0:* 117 27420 3269/evcc
udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 14543 408/avahi-daemon: r
udp 0 0 0.0.0.0:42221 0.0.0.0:* 108 14545 408/avahi-daemon: r
udp 0 0 0.0.0.0:68 0.0.0.0:* 0 16470 476/dhcpcd
udp 0 0 0.0.0.0:631 0.0.0.0:* 0 14148 622/cups-browsed
udp6 0 0 :::5353 :::* 117 27421 3269/evcc
udp6 0 0 :::5353 :::* 108 14544 408/avahi-daemon: r
udp6 0 0 :::58746 :::* 108 14546 408/avahi-daemon: r
udp6 0 0 :::546 :::* 0 16490 476/dhcpcd
2023-10-09 21:21:28.167 - info: javascript.0 (1215) script.js.common.Hauptzähler.StromkostenSumme: Momentanleistung =1276 Zählerstand = 39074954 Zählerstand kalk = 39048.88005552497 Verbrauch 5 sec = 0.001772224683645394 x Strompreis 25.9896 + Kosten5sec 0.00046059410638070333 = Stromkostensumme = 440.4125182320077
2023-10-09 21:21:28.216 - info: javascript.0 (1215) script.js.common.Hauptzähler.TagesstromKosten: 440.4125182320077Kosten Vortag 430.3448959772219 Tagesstromkosten 10.067622254785817
2023-10-09 21:21:33.163 - info: javascript.0 (1215) script.js.common.Hauptzähler.Tagesverbrauch: Tagesverbrauch = 45.34100000000035 1.8.0 = 39074956
2023-10-09 21:21:33.171 - info: javascript.0 (1215) script.js.common.Hauptzähler.Momentanleistung: Momentan 1979 1.7.0 1224 Wirk 755
2023-10-09 21:21:33.171 - info: javascript.0 (1215) script.js.common.Hauptzähler.StromkostenSumme: Momentanleistung =1224 Zählerstand = 39074956 Zählerstand kalk = 39048.88175552733 Verbrauch 5 sec = 0.0017000023611143905 x Strompreis 25.9896 + Kosten5sec 0.00044182381364418565 = Stromkostensumme = 440.4129600558213
2023-10-09 21:21:33.184 - info: javascript.0 (1215) script.js.common.Hauptzähler.TagesstromKosten: 440.4129600558213Kosten Vortag 430.3448959772219 Tagesstromkosten 10.068064078599434
2023-10-09 21:21:38.171 - info: javascript.0 (1215) script.js.common.Hauptzähler.Tagesverbrauch: Tagesverbrauch = 45.34300000000076 1.8.0 = 39074958
2023-10-09 21:21:38.188 - info: javascript.0 (1215) script.js.common.Hauptzähler.Momentanleistung: Momentan 1983 1.7.0 1228 Wirk 755
2023-10-09 21:21:38.189 - info: javascript.0 (1215) script.js.common.Hauptzähler.StromkostenSumme: Momentanleistung =1228 Zählerstand = 39074958 Zählerstand kalk = 39048.88346108525 Verbrauch 5 sec = 0.001705557924386006 x Strompreis 25.9896 + Kosten5sec 0.00044326768231622545 = Stromkostensumme = 440.41340332350364
2023-10-09 21:21:38.198 - info: javascript.0 (1215) script.js.common.Hauptzähler.TagesstromKosten: 440.41340332350364Kosten Vortag 430.3448959772219 Tagesstromkosten 10.068507346281763
2023-10-09 21:21:43.169 - info: javascript.0 (1215) script.js.common.Hauptzähler.Tagesverbrauch: Tagesverbrauch = 45.3440000000046 1.8.0 = 39074959
2023-10-09 21:21:43.222 - info: javascript.0 (1215) script.js.common.Hauptzähler.Momentanleistung: Momentan 1997 1.7.0 1242 Wirk 755
2023-10-09 21:21:43.223 - info: javascript.0 (1215) script.js.common.Hauptzähler.StromkostenSumme: Momentanleistung =1242 Zählerstand = 39074959 Zählerstand kalk = 39048.885186087646 Verbrauch 5 sec = 0.001725002395836661 x Strompreis 25.9896 + Kosten5sec 0.00044832122266836487 = Stromkostensumme = 440.4138516447263
2023-10-09 21:21:43.233 - info: javascript.0 (1215) script.js.common.Hauptzähler.TagesstromKosten: 440.4138516447263Kosten Vortag 430.3448959772219 Tagesstromkosten 10.06895566750444
2023-10-09 21:21:43.513 - info: javascript.0 (1215) script.js.common.Haus22.BattNachladung: Nachladung aus Spannung ist 26.73
2023-10-09 21:21:43.513 - warn: javascript.0 (1215) getState "mqtt.0.ESP_EasyPV1.NachladungD7.State" not found (3)
2023-10-09 21:21:43.516 - warn: javascript.0 (1215) at Object.<anonymous> (script.js.common.Haus22.BattNachladung:26:10)
2023-10-09 21:21:43.517 - warn: javascript.0 (1215) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
2023-10-09 21:21:43.518 - warn: javascript.0 (1215) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
2023-10-09 21:21:43.518 - warn: javascript.0 (1215) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11178:62)
2023-10-09 21:21:43.518 - warn: javascript.0 (1215) at processImmediate (node:internal/timers:476:21)
2023-10-09 21:21:48.166 - info: javascript.0 (1215) script.js.common.Hauptzähler.Tagesverbrauch: Tagesverbrauch = 45.346000000005006 1.8.0 = 39074961
2023-10-09 21:21:48.182 - info: javascript.0 (1215) script.js.common.Hauptzähler.Momentanleistung: Momentan 1985 1.7.0 1230 Wirk 755
2023-10-09 21:21:48.182 - info: javascript.0 (1215) script.js.common.Hauptzähler.StromkostenSumme: Momentanleistung =1230 Zählerstand = 39074961 Zählerstand kalk = 39048.886894423355 Verbrauch 5 sec = 0.001708335706021814 x Strompreis 25.9896 + Kosten5sec 0.0004439896166522454 = Stromkostensumme = 440.414295634343
2023-10-09 21:21:48.187 - info: javascript.0 (1215) script.js.common.Hauptzähler.TagesstromKosten: 440.414295634343Kosten Vortag 430.3448959772219 Tagesstromkosten 10.069399657121096
Danke und noch eine schönen Abend
Gerhard
