Also VIS Startet nicht seit update auf JS-controller 5.x und der Solarlog Adapter
host.raspberrypi4-iob
2023-09-18 14:59:00.339 error instance system.adapter.solarlog.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
solarlog.0
2023-09-18 14:58:59.618 error undefined is not a valid state value
solarlog.0
2023-09-18 14:58:59.618 error Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2037:16 at new Promise (<anonymous>) at AdapterClass.setStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2036:16) at setDeviceInfo (/opt/iobroker/node_modules/iobroker.solarlog/main.js:2155:19) at test (/opt/iobroker/node_modules/iobroker.solarlog/main.js:291:13) at async Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.solarlog/main.js:231:39)
solarlog.0
2023-09-18 14:58:59.612 error unhandled promise rejection: undefined is not a valid state value
solarlog.0
2023-09-18 14:58:59.612 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
2023-09-18 14:58:26.271 error instance system.adapter.solarlog.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
solarlog.0
2023-09-18 14:58:25.555 error undefined is not a valid state value
solarlog.0
2023-09-18 14:58:25.554 error Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2037:16 at new Promise (<anonymous>) at AdapterClass.setStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2036:16) at setDeviceInfo (/opt/iobroker/node_modules/iobroker.solarlog/main.js:2155:19) at test (/opt/iobroker/node_modules/iobroker.solarlog/main.js:291:13) at async Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.solarlog/main.js:231:39)
solarlog.0
2023-09-18 14:58:25.545 error unhandled promise rejection: undefined is not a valid state value
solarlog.0
2023-09-18 14:58:25.543 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
