@00000x Bitte:
<block xmlns="http://www.w3.org/1999/xhtml" type="procedures_defreturn" id="T2aJ0tb9HX@%hW^U!Z+O" x="862" y="1738">
<mutation>
<arg name="pos1" varid="@L?GM5iuc/nKas!lg|v("></arg>
<arg name="pos2" varid="gH*jS,o2+ycD)[7MEx^~"></arg>
</mutation>
<field name="NAME">Entfernung</field>
<statement name="STACK">
<block type="comment" id="2[O;MH;_SQ^Zzaoc:WGn">
<field name="COMMENT">Entfernung zwischen 2 Koordinaten berechnen</field>
<block type="variables_set" id="[$5QQne3=vP|E{oN*VTu">
<field name="VAR" id="huzpNLp1==YK4TwoO7|r" variabletype="">result</field>
<block type="lists_split" id="EGH*r.Ebsdc-8]/~xt9Z">
<mutation mode="SPLIT"></mutation>
<field name="MODE">SPLIT</field>
<value name="INPUT">
<block type="variables_get" id="cK}4svwbb6?-D$+$mQ#w">
<field name="VAR" id="@L?GM5iuc/nKas!lg|v(" variabletype="">pos1</field>
<value name="DELIM">
<shadow type="text" id="(4[(wy#`DKj$DfZ=vqUf">
<field name="TEXT">,</field>
<block type="variables_set" id="A.I8^6oW7x{`SoC5^D-u">
<field name="VAR" id="0G0mLGmH3[.Y)Ae54AaS" variabletype="">lat1</field>
<block type="lists_getIndex" id="#i5*9ITFEX!CdOaJg#`[">
<block type="variables_get" id="9sA%[*/ABx-BPqR+PAtc">
<value name="AT">
<block type="math_number" id="qPe8zfF^rn2#go;~Z-1Y">
<block type="variables_set" id="besUzW+Ew0?tMqHoxSz;">
<field name="VAR" id="}z5HG|{ai^o3:iyomfSl" variabletype="">lon1</field>
<block type="lists_getIndex" id=";,K=u!zsvJp@OvJQ1_ow">
<block type="variables_get" id="I4={ah6ne?*3sw}~,q~9">
<value name="AT">
<block type="math_number" id="(jza0yR)4BJ3}[FBAAS]">
<field name="NUM">2</field>
<block type="variables_set" id="oY6[=%SE96KkZEJ65RlR">
<block type="lists_split" id="MkS!c!Gsz0n@cp*gw6Kl">
<block type="variables_get" id="y66evFQ5^8O^-|/.ACN,">
<field name="VAR" id="gH*jS,o2+ycD)[7MEx^~" variabletype="">pos2</field>
<shadow type="text" id="!ahV6xI+*Qz6uz,s,qYI">
<block type="variables_set" id="V}-$z-=!l_[V:%A_`7Ys">
<field name="VAR" id="jOT#/LHb)e7-{Y}t}BVB" variabletype="">lat2</field>
<block type="lists_getIndex" id="q^=L%dCvtrZ7mDDzME4=">
<block type="variables_get" id="M|~p}XW{vx)cd:}OcyrM">
<value name="AT">
<block type="math_number" id="@W,[/HlPvqlMQC=b;-cm">
<block type="variables_set" id="XuP8O^n,]yT~rsNCJX^o">
<field name="VAR" id="-L[Io*#C6G8z|KDd4,fF" variabletype="">lon2</field>
<block type="lists_getIndex" id="ifqU8#ps8)_IQ=G$@t(E">
<block type="variables_get" id="n#`)KeOuy1Y!-.]w-F7Z">
<value name="AT">
<block type="math_number" id="$4)8J+Ac[;aoiXK-vd-/">
<block type="variables_set" id="$y*EEX75ZdFmp}6|o@~x">
<block type="math_round" id="-.tn4!-9J4vn;I{uW`8p">
<field name="OP">ROUND</field>
<value name="NUM">
<shadow type="math_number" id="QmXZYtjGC^ujr3LZ.j?:">
<field name="NUM">3.1</field>
<block type="math_arithmetic" id="hT-(QhU{o)Ino]ByQ,W.">
<shadow type="math_number" id="G^tm(y4VI4s)st6NsB9F">
<block type="math_arithmetic" id="k%r*%B$0ABY3JK7$?Jf_">
<shadow type="math_number" id="i/f3g_7B,k!ITta,BopC">
<field name="NUM">111.324</field>
<shadow type="math_number" id="aN90##;n0pXXvH;{|Y#X">
<block type="math_trig" id="ljE{kFpfFBHMvo0-Qi[c">
<field name="OP">ACOS</field>
<value name="NUM">
<shadow type="math_number" id="ikmVw4d2^(_MXYN)]v1j">
<field name="NUM">45</field>
<block type="math_arithmetic" id=";xSp^W(ChZZeOVah=%8T">
<field name="OP">ADD</field>
<shadow type="math_number" id="K#l!z7kO[;!qs%=Um5ov">
<block type="math_arithmetic" id="7qpTT~}-.Ee,P/iTuh5R">
<shadow type="math_number" id="{:D((C()}/y{AQrCGb2g">
<block type="math_trig" id="IvG(t!*n;{t.8S/Baqyi">
<field name="OP">SIN</field>
<value name="NUM">
<shadow type="math_number" id="X1n[H=%ziU-rBWH0v;gt">
<block type="variables_get" id="q`^eYV=Pcp[l3}+AF|n-">
<shadow type="math_number" id="A(9]a|YA`@nlb[N))[}J">
<block type="math_trig" id="NtE}O$nOP7Bkm4FrqVep">
<value name="NUM">
<block type="variables_get" id="DOMb_=FcM#GOjl=xSVX*">
<shadow type="math_number" id=":]3}I;7rf`r$0hk$7}Uf">
<block type="math_arithmetic" id="[)+iKs)1[+tpF1ohL]_m">
<shadow type="math_number" id="1kpB8L9oEKT@95p_?Mf.">
<block type="math_arithmetic" id="q$]?PprPXy$!Ur|,+_ze">
<block type="math_trig" id="(XF#NPyZ*uGqINJZF:D%">
<field name="OP">COS</field>
<value name="NUM">
<block type="variables_get" id="=~$.Ys+$SrT.RhmsYG45">
<block type="math_trig" id="DNgAR4/|g_t)Gx2}MMam">
<value name="NUM">
<block type="variables_get" id="8n{-RBpx[YKsR$AocUxD">
<shadow type="math_number" id="[,h/obEF?,02mPQUC{yj">
<block type="math_trig" id="g1D!+/4.$j[s984^ALke">
<value name="NUM">
<shadow type="math_number" id=":!exR3Jd^z9OS8nq{(zk">
<block type="math_arithmetic" id="0cF`R:.K^2n}6%gg*t#:">
<block type="variables_get" id="^_{PS_btayQ+jZqW|2e}">
<block type="variables_get" id="srvRO~):6H}h.@:T:[Px">
<shadow type="math_number" id=",46mChF+VJW1ftE!v5Sy">
<field name="NUM">1000</field>
<value name="RETURN">
<block type="variables_get" id="3t3*mh9SjUvoK0?I2Rcj">
