@jhuebner1 falls blockly gewünscht ? damit geht's bei mir
sendTo("pushbullet.0", "send", {
"message": 'von iobroker',
"title": 'alarm',
"type": 'note',
"receiver": 'ujC6xxxxxxxxxxUvRI'
wie es mit nicknames funktioniert, weiß ich nicht - die id's der geräte bekomme ich über :
der curl befehl benötigt den api key von pushbullet
curl --header 'Access-Token: o.YKeXkxxxxxxxxxxxxxxxxxxxxxxxxxpi9v' \https://api.pushbullet.com/v2/devices
import blockly- get ids:
Spoiler
<variable type="" id="X9`at:-6IX;0sDS`vu/E">helferlein</variable>
<variable type="" id="QLuvwmsEww5Fznot.S{!">j</variable>
<variable type="undefined" id="timeout">timeout</variable>
<variable type="" id="-K|h*y)J9|h*rDQQ%e|P">result</variable>
<block type="variables_set" id="gnns*UySjAihC$AX;b3w" x="-1112" y="-362">
<field name="VAR" id="X9`at:-6IX;0sDS`vu/E" variabletype="">helferlein</field>
<block type="text" id="{I`+g`T[I@zENqX;;o!0">
<field name="TEXT"></field>
<block type="exec" id=";yZH3#4j@m)x(t!KuStM">
<mutation with_statement="true"></mutation>
<field name="WITH_STATEMENT">TRUE</field>
<field name="LOG"></field>
<value name="COMMAND">
<shadow type="text" id="K*pR(O]dqF1O(}@!LIev">
<field name="TEXT">curl --header 'Access-Token: o.YxxxxxxxxxxxxxxxxxxePpi9v' \https://api.pushbullet.com/v2/devices</field>
<block type="controls_forEach" id="}45?^T}515sMBQ[9+rp#">
<field name="VAR" id="QLuvwmsEww5Fznot.S{!" variabletype="">j</field>
<value name="LIST">
<block type="get_attr" id="g#}Mg=I#s(4vWWq(II2(">
<value name="PATH">
<shadow type="text" id="lvy#gM@GMJmU6sqK4;Au">
<field name="TEXT">devices</field>
<value name="OBJECT">
<block type="convert_json2object" id="^e-2X)-]Dl8)KBIeQ+vt">
<block type="variables_get" id="=y9:hJMk$HLBGLvwB`OF">
<field name="VAR" id="-K|h*y)J9|h*rDQQ%e|P" variabletype="">result</field>
<statement name="DO">
<block type="variables_set" id="5u9~XTcCx{}}7Q:J=k0A">
<block type="text_join" id="gpsM_T@}yjr45rdzKK.m">
<mutation items="5"></mutation>
<value name="ADD0">
<block type="variables_get" id="h:0p@OQ`@JvUV}u^Y1mB">
<value name="ADD1">
<block type="get_attr" id="tnYkgo0?Tt1Qb|2j6Ml0">
<value name="PATH">
<shadow type="text" id="k7N];QQ5LG{H{T,|Ds~0">
<field name="TEXT">nickname</field>
<block type="variables_get" id="{Wz7*Z$egMShSYfjw.T)">
<value name="ADD2">
<block type="text" id="56*eie?xG4]zM1BL.(NL">
<field name="TEXT"> --- </field>
<value name="ADD3">
<block type="get_attr" id="Smr3j5NG,YL*VhcsYZmK">
<value name="PATH">
<shadow type="text" id="Aof*I9O]2!PwmVoCZ#mh">
<field name="TEXT">iden</field>
<block type="variables_get" id="FL/:*P7N$CoEn~xKYRix">
<value name="ADD4">
<block type="text" id="K9fBFZ.(:3$h*8DM|U=v">
<field name="TEXT">:</field>
<block type="debug" id="gLB@GV}#T*q:rTg5K@}P">
<value name="TEXT">
<shadow type="text" id="qyF=Jns;Wi3ZK3iLx}1N">
<block type="variables_get" id="96)S72)K=mhT{tZRyEb-">
<block type="timeouts_settimeout" id="KCcV{V~[8)Z8+}hiyTev">
<field name="DELAY">2</field>
<block type="control" id="WqE+|K=ofWlAr`Xh38a_">
<field name="OID">controll-own.0.PUSHBULLET.ClientIDs</field>
<block type="variables_get" id="GHNwY(=_htqEeECE7}Lm">
