@TOBO:
Ist es nun möglich, egal welchen View das Touchpanel gerade anzeigt auf die CAM umzuschalten ? `
Ja ! Du kannst vis mit command ansteuern also mach dir ein script was bei turklingel die gewuenste view in die enstprechende objecte schreibt:
Erst instan, dan view, dan commando (changeview):
https://github.com/ioBroker/ioBroker.vis
` > Commands:
alert - show alert window in vis. "control.data" has following format "message;title;jquery-icon". Title and jquery-icon are optional. Icon names can be found here. To show icon "ui-icon-info" write Message;;info.
changeView - switch to desired view. "control.data" must have name of view. You can specify project name too as "project/view". Default project is "main".
If user changes the view or at start the variables will be filled by vis with
"control.instance": browser instance and ack=true
"control.data": project and view name in form "project/view", e.g. "main/view" (and ack=true)
"control.command": "changedView" and ack=true
You can write the JSON-string or Object into control.command as {instance: 'AABBCCDD', command: 'cmd', data: 'ddd'}. In this case the instance and data will be taken from JSON object. `
