<block type="procedures_defnoreturn" id="(Sj+T^+i4P]N+Y7l[%DO" x="862" y="-6512">
<field name="NAME">Felder nullen</field>
<comment pinned="false" h="80" w="160">Beschreibe diese Funktion
</comment>
<statement name="STACK">
<block type="update" id="om|6AO/2`RWapU+*!=%-">
<field name="OID">javascript.0.0_userdata.0.VIS.VISAnzeige.Büro</field>
<block type="logic_boolean" id="`C^(g(wgAuLS.*V5jhhm">
<block type="update" id="w^akPuYsEinPZE;r=Dvc">
<field name="OID">javascript.0.0_userdata.0.VIS.VISAnzeige.Paketverfolgung</field>
<block type="logic_boolean" id="W4Jy*!T!DQ!*!sU{(lNA">
<block type="update" id="GD`RdWWvq_S)d#[m~s?-">
<field name="OID">javascript.0.0_userdata.0.VIS.VISAnzeige.Regenradar</field>
<block type="logic_boolean" id="Y4,sR:P8:)CWW/1n}`a#">
<block type="update" id="4qA}DuHRAsjkCi8789d1">
<field name="OID">javascript.0.0_userdata.0.VIS.VISAnzeige.Wetter</field>
<block type="logic_boolean" id=",rwfh:tr^]U4bZ-k9d{t">
<block type="update" id="X/Q0/?P8bY.v4Z|N1exV">
<field name="OID">javascript.0.0_userdata.0.VIS.VISAnzeige.Wohnzimmer</field>
<block type="logic_boolean" id="A7)x/X7-h1r+RQwbX,c]">
<block type="update" id="#GZNmvJ*$+T/(Pj*Bv!8">
<field name="OID">javascript.0.0_userdata.0.VIS.VISAnzeige.Übersicht</field>
<block type="logic_boolean" id="h@P1x%8;hGj[84]~K0T:">
<block type="update" id="51fK7,mlj1kJYaFCDlwY">
<field name="OID">javascript.0.0_userdata.0.VIS.VISAnzeige.CamBriefkasten</field>
<block type="logic_boolean" id="|vtA@cXBR/ABX0G!)6%p">
<block type="update" id="Ot!w3=RPpV{c``m-+|Sl">
<field name="OID">javascript.0.0_userdata.0.VIS.VISAnzeige.CamKlingelhinten</field>
<block type="logic_boolean" id="aRaY(C^HOhC^{CoL[jul">
<block type="update" id="vz(:%NTRh]8oI#R:iL-a">
<field name="OID">javascript.0.0_userdata.0.VIS.VISAnzeige.CamKlingelvorne</field>
<block type="logic_boolean" id="rnSgC-=9e[racunAU.)V">
<block type="update" id="E[:SQXnY^2}L4c]au1@A">
<field name="OID">javascript.0.0_userdata.0.VIS.VISAnzeige.Camküche</field>
<block type="logic_boolean" id="Cz7xlO0te.D~WQMxFJ%L">
<block type="update" id="HVEw5nc:C4$W+l|/:wZX">
<field name="OID">javascript.0.0_userdata.0.VIS.VISAnzeige.Camparkplatz</field>
<block type="logic_boolean" id="r,{w?1f.*!1(=/qZ-omK">
<block type="update" id="v-j@XJN^VX_ms8TH(e=T">
<field name="OID">javascript.0.0_userdata.0.VIS.VISAnzeige.Camparkplatzmüll</field>
<block type="logic_boolean" id="v5Z2Rlz7k#!E}nCu;Mf0">
<block type="on_ext" id="?!~Qrp~T{DtymBQI0E+^" x="38" y="-6462">
<mutation xmlns="http://www.w3.org/1999/xhtml" items="12"></mutation>
<value name="OID0">
<shadow type="field_oid" id="p]rX(={%HO:.!r:Lj|_N">
<field name="oid">javascript.0.0_userdata.0.VIS.VISAnzeige.Büro</field>
<value name="OID1">
<shadow type="field_oid" id="Nk=m#C:,W%D*SSa1Jiz}">
<field name="oid">javascript.0.0_userdata.0.VIS.VISAnzeige.Paketverfolgung</field>
<value name="OID2">
<shadow type="field_oid" id="wZBJEZwPIl`/QvyYuRov">
<field name="oid">javascript.0.0_userdata.0.VIS.VISAnzeige.Regenradar</field>
<value name="OID3">
<shadow type="field_oid" id=":j]VdIq{+;ET+##7|;Rf">
<field name="oid">javascript.0.0_userdata.0.VIS.VISAnzeige.Wetter</field>
<value name="OID4">
<shadow type="field_oid" id="@-LK(Zxsn:`yOi6SWf3K">
<field name="oid">javascript.0.0_userdata.0.VIS.VISAnzeige.Wohnzimmer</field>
<value name="OID5">
<shadow type="field_oid" id="/CEG+.*%pOjCkpa{T)WQ">
<field name="oid">javascript.0.0_userdata.0.VIS.VISAnzeige.Übersicht</field>
<value name="OID6">
<shadow type="field_oid" id="4ku;U-ZJoH5gcE5~yg{8">
<field name="oid">javascript.0.0_userdata.0.VIS.VISAnzeige.CamBriefkasten</field>
<value name="OID7">
<shadow type="field_oid" id="7VOpjE0Vi?GPbEa_mJ*=">
<field name="oid">javascript.0.0_userdata.0.VIS.VISAnzeige.CamKlingelhinten</field>
<value name="OID8">
<shadow type="field_oid" id="*bRWBx#t@R%0i6OogRSh">
<field name="oid">javascript.0.0_userdata.0.VIS.VISAnzeige.CamKlingelvorne</field>
<value name="OID9">
<shadow type="field_oid" id="0q_0OWX*^h|VU2C2{%%O">
<field name="oid">javascript.0.0_userdata.0.VIS.VISAnzeige.Camküche</field>
<value name="OID10">
<shadow type="field_oid" id="/y$pPl7V^iq:]T0YQv}h">
<field name="oid">javascript.0.0_userdata.0.VIS.VISAnzeige.Camparkplatz</field>
<value name="OID11">
<shadow type="field_oid" id="U)o!aa3,95|OU/OG;e|h">
<field name="oid">javascript.0.0_userdata.0.VIS.VISAnzeige.Camparkplatzmüll</field>
<block type="controls_if" id="ehguxhiZg8%4VkLOpjs!">
<mutation elseif="11"></mutation>
<block type="logic_compare" id="G0D!YqMRY]Zklp,D^#fJ">
<field name="OP">EQ</field>
<block type="get_value" id="RD.J,T:P{Uu;X+{iPx!E">
<block type="logic_boolean" id="rg)wc1nrkf!bXiUVOB|M">
<block type="update" id=":ihXqr*9nuk.G.(zr3zp">
<field name="OID">vis.0.control.data</field>
<block type="text" id="@hSu_O2NJFx=*.y/p~QF">
<field name="TEXT">home/Buero</field>
<block type="control" id="cul/((/OCKV*z9iAd68L">
<field name="OID">vis.0.control.command</field>
<block type="text" id="VhDb+`s9;1n#cjRv+E@A">
<field name="TEXT">changeView</field>
<block type="control" id="4zQ;Xw_ViW=G}=B*EP^}">
<field name="OID">fullybrowser.0.192_168_178_230.Commands.loadURL</field>
<block type="text" id="_$Q)UjS1|Ox:`I7w}t3{">
<field name="TEXT">http://192.168.178.73:8082/vis/index.html?home#Buero</field>
<block type="control" id="e)uH_mhJ(-F+Eiip01^E">
<field name="OID">fullybrowser.0.192_168_178_251.Commands.loadURL</field>
<block type="text" id="9DHq@BC5KY1feIc?4N-H">
<block type="procedures_callnoreturn" id="j;h{fHKK(E?2|H.Xj7}h">
<mutation name="Felder nullen"></mutation>
<value name="IF1">
<block type="logic_compare" id="*h3+iZS:2ex1:/iba@F(">
<block type="get_value" id="j(:Gxf4)/D}xK.Z69(wB">
<block type="logic_boolean" id="4C_|9XkK0tMmo|CK58zy">
<statement name="DO1">
<block type="update" id="0/Y.vh~@-6+`2e,wL(bY">
<block type="text" id="Tjn?gy.P4tqA]UJo+]+x">
<field name="TEXT">home/Paketverfolgung</field>
<block type="control" id="x~:5SxOq@7u0dk9Ng`r_">
<block type="text" id="`_!2b|tg};2V?7B9Bo4q">
<block type="control" id="kCtB/1|?(w[vL@LA2J.k">
<block type="text" id="u8m-B*9Eq?Og179{K2u8">
<field name="TEXT">http://192.168.178.73:8082/vis/index.html?home#Paketverlauf</field>
<block type="control" id="?wk1rcKB;z|%^$-gAi9p">
<block type="text" id="wAOzx151aUi%mxgX,9]P">
<block type="procedures_callnoreturn" id="=F,)nb7)v[+M-v1r!]2D">
<value name="IF2">
<block type="logic_compare" id="}U#IjgJx%?7T?m*am/4[">
<block type="get_value" id="rj,!wwy]M%xz-mq@NTo0">
<block type="logic_boolean" id=":sf%Tn}NZvsOzd;{1wd8">
<statement name="DO2">
<block type="update" id="t7}Y?p1o5qZ8*vF_S7}Q">
<block type="text" id="D.C.itsL[irzk!M5MFmr">
<field name="TEXT">home/Regenradar</field>
<block type="control" id="Q9[R0vU1;I(f%NTMB]z2">
<block type="text" id="}wK.!FV4/L.dSa?FPR01">
<block type="control" id="T~sMyY}.=l.K)E[{cTXD">
<block type="text" id="Z8)djx#:?/w+9EM(wgS[">
<field name="TEXT">http://192.168.178.73:8082/vis/index.html?home#Regenradar</field>
<block type="control" id="*HIG:3INaQ|?oxL[VC{@">
<block type="text" id="-|h`K?U}!,xOV#r9}evR">
<block type="procedures_callnoreturn" id="wvAcOdcB2l**P,,.x!q-">
<value name="IF3">
<block type="logic_compare" id="J%oW3Cvg3+cxmjDji055">
<block type="get_value" id="BT8n2-z9UY]Nb58/9^0M">
<block type="logic_boolean" id="YHQ!nlf#Y7lc0P|V!^#+">
<statement name="DO3">
<block type="update" id="Ewf4[.K`%H3!+x2g(V,1">
<block type="text" id="L?pc`[VNhHT,#dYd#mlt">
<field name="TEXT">home/Wetter</field>
<block type="control" id="}bZm!6#P~5U/w[,usR1,">
<block type="text" id="E*LqNEDK|#{U:EaPVt+I">
<block type="control" id="Uv88_D}o/J.yQI_a8vr4">
<block type="text" id="CTj?~2aC{?Ad$o[Qf4ku">
<field name="TEXT">http://192.168.178.73:8082/vis/index.html?home#Wetter</field>
<block type="control" id="@+RtV:Y=MUeN{J`(m]Ri">
<block type="text" id="v%dviHjvze[VVa.Zedy)">
<block type="procedures_callnoreturn" id="YSe8{I]n)PMO8h^g@PyG">
<value name="IF4">
<block type="logic_compare" id="#9#;TZ~h7HTg^KZhuQPB">
<block type="get_value" id="-;VzfK`YZadr)ARUTU*X">
<block type="logic_boolean" id="2Eep`a5{I.J0q(TALhD~">
<statement name="DO4">
<block type="update" id="wD@|TIE@!Bo|ai9Q#k:U">
<block type="text" id="`hljT!:ip:=.*Jps3Z/I">
<field name="TEXT">home/Wohnzimmer</field>
<block type="control" id="~hL#wz0Noe#itqd!}hx;">
<block type="text" id="pOmK~5}dOEr;0@16+W[Z">
<block type="control" id="iT$9!xj+_1N0PSe[)Sxs">
<block type="text" id="CJ7x#6R!=ICY)QRz04Xb">
<field name="TEXT">http://192.168.178.73:8082/vis/index.html?home#Wohnzimmer</field>
<block type="control" id="=%Ug:/Nlnfo.sUUyk^uK">
<block type="text" id="pGO]KJ(/+B=5w4{/)aTu">
<block type="procedures_callnoreturn" id="%=xo;PqtR3GY|pByR[Md">
<value name="IF5">
<block type="logic_compare" id="!J;9Rl@_7UuLw5^%Z+@/">
<block type="get_value" id="*0@{K$tn%v|_hr]e_=eM">
<block type="logic_boolean" id="tXYyll}(#YS98U7:M3dF">
<statement name="DO5">
<block type="control" id="D=(,o@$=/5kThn84xm_E">
<block type="text" id="hUv(o49M9kdeVZ4*]9PO">
<field name="TEXT">http://192.168.178.73:8082/vis/index.html?home#Büro</field>
<block type="control" id=".]zFsbkbM*UF{+KZ^;7^">
<block type="text" id="ZgFc)_Aci3Q,8)lFDL~/">
<block type="procedures_callnoreturn" id="QoZpub+h5Qpe[}(1~H3;">
<value name="IF6">
<block type="logic_compare" id="3Kt.tWd74AW8fXoVV?m|">
<block type="get_value" id="n:|ZcAXiw)^VspR=[b0L">
<block type="logic_boolean" id="RbvSu4G_7^Lp@^};K,:}">
<statement name="DO6">
<block type="control" id="sZA5U,x?ELHV9Ez|J!yq">
<block type="text" id="T2E3PBtlg;};:1;B1lK7">
<field name="TEXT">http://192.168.178.73:8082/vis/index.html?home#CamBriefkasten</field>
<block type="control" id="dj.BjWwXn?q7V@5V{5i@">
<block type="text" id="^.o+`Qlz?e~J;pIyfAao">
<block type="procedures_callnoreturn" id="ygKE7:W@$O()NA8,swZ`">
<value name="IF7">
<block type="logic_compare" id=")(^8!]z~A?_lD0H!i5!B">
<block type="get_value" id=".nKwTp]/LQ/=CK1Ur:+4">
<block type="logic_boolean" id="U=`Q6/^OZt%WM$~~)#Hs">
<statement name="DO7">
<block type="control" id="k3q=U.o0`:Z~!Q!`D0!V">
<block type="text" id="u]Z.~6a=cQ}gZZ3A-dH;">
<field name="TEXT">http://192.168.178.73:8082/vis/index.html?home#Camkueche</field>
<block type="control" id="njc.{@oG_dMNNO,4H3es">
<block type="text" id="EMAVylcmt*:}v4K8pdG6">
<block type="procedures_callnoreturn" id="l83YmgX-dXs@qSK`I{hf">
<value name="IF8">
<block type="logic_compare" id="otf~[^}|Wk{EU4W4Avt_">
<block type="get_value" id="?E^SYf-eqbRCu9Z9y8h]">
<block type="logic_boolean" id="[L=+spUkdNp8U*(KOs!4">
<statement name="DO8">
<block type="control" id="aRun.ns%,hd@h]h!mW2L">
<block type="text" id="s^,u5z!9bm([u`Z[@gDl">
<field name="TEXT">http://192.168.178.73:8082/vis/index.html?home#CamParkplatz</field>
<block type="control" id="Nxc3)LWn=Ie1xU_t)[B-">
<block type="text" id="5up?.[o_CO.dZoBfd+WA">
<block type="procedures_callnoreturn" id="hHu+[VV?M8*-asjY`[rl">
<value name="IF9">
<block type="logic_compare" id="IVc$QadA5V)6iDT+[8}W">
<block type="get_value" id="L+i?W.kk1Lk/1MxWw0/A">
<block type="logic_boolean" id="Ix_u5.oq||dY::|q~m^D">
<statement name="DO9">
<block type="control" id="8w%?AD;5-iuF~i[%Zx3C">
<block type="text" id="@fL!;n52:2#EBDQM]cMV">
<field name="TEXT">http://192.168.178.73:8082/vis/index.html?home#CamParkplatzmuell</field>
<block type="control" id="G96@MUD+G7Z]#TH~;ngq">
<block type="text" id="b6x0K~2(_gQe@oq0BZFU">
<block type="procedures_callnoreturn" id="pe^!]C8ETCAPd_u9o~|y">
<value name="IF10">
<block type="logic_compare" id="W:UP8:Wn3WGk?ek6a[hU">
<block type="get_value" id="s!=+5mlQyMPP_hS#7vW~">
<block type="logic_boolean" id="aS4{s(#TURX-ELNVw_n3">
<statement name="DO10">
<block type="control" id="I%W-qL7J/G)]$@CxBnzG">
<block type="text" id="XgLp|KNjuY00FnjlCRtz">
<field name="TEXT">http://192.168.178.73:8082/vis/index.html?home#CamKlingelhinten</field>
<block type="control" id="jX^j0;c!=WX_*NgXyJED">
<block type="text" id="Jhd9h7y0W!L2lT=97]_O">
<block type="procedures_callnoreturn" id="LLwh{n6%tXR8W~|3^p5s">
<value name="IF11">
<block type="logic_compare" id="7ogsCkH9h-3T4fQu{7[$">
<block type="get_value" id="uIB`MAfw)nyx/7BtF5_}">
<block type="logic_boolean" id="Y;N)sWJ(DU`/gwF)IFI@">
<statement name="DO11">
<block type="control" id="g!;[IfcXpbRAvmc_k^c(">
<block type="text" id="Bs0bV?q`VR^Cmq9-TdG{">
<field name="TEXT">http://192.168.178.73:8082/vis/index.html?home#CamKlingelvorne</field>
<block type="control" id="aNv)nNSmB~7^nbG]_5.5">
<block type="text" id="+B%Gw^{x6JEp;*z#OXK*">
<block type="procedures_callnoreturn" id="uNxi|9V#MTyAR8/DxICP">
Habe ne lösung für mich gefunden. Steuere die Tablets per Fully und für den Echo Show muss ich eh ne andere VIS benutzen.
