<variable type="interval" id="Intervall">Intervall</variable>
<variable id="RM}IB6Haie0KqfAXGP9h">text</variable>
<variable id="IHwL`AB66?q8*B9ffsZn">feed2</variable>
<variable type="interval" id="Intervall2">Intervall2</variable>
<variable id="3[9HDT:}lPudZkmmX8Z+">msg2</variable>
<variable type="interval" id="Intervall3">Intervall3</variable>
<variable id="e.Hw9-61~#@h3527|TvQ">msg3</variable>
<variable type="interval" id="Intervall4">Intervall4</variable>
<variable id="K%NN~D}hP}$Wn~CV(CYi">msg4</variable>
<variable type="interval" id="Intervall5">Intervall5</variable>
<variable id="QMuC}2I,^YHovnMvw,(*">msg5</variable>
<variable type="interval" id="Intervall6">Intervall6</variable>
<variable id="3@_dL%UAv#T-OBIMFwzc">msg6</variable>
<variable type="interval" id="Intervall7">Intervall7</variable>
<variable id="h@=Z[:(D[Y52lvDl??TD">msg7</variable>
<variable type="interval" id="Intervall8">Intervall8</variable>
<variable id="_1=`UCG+wMA.pRQ/W*8a">msg8</variable>
<variable type="interval" id="Intervall9">Intervall9</variable>
<variable id="8M;I;?+;RU|^GtLDqU$(">msg9</variable>
<variable id="AM4NVDx!nhvka?#7fc)z">msg10</variable>
<variable id="f]q]qDe]0?U|71;nt4a5">msg11</variable>
<variable id="m28LI:=Y|qQk0pM2HJ3p">msg12</variable>
<variable id="[e-s1w?g[g|xi!1:1_Kp">msg13</variable>
<block type="schedule" id="J?PnjF3?REEOG5UtM" x="13" y="338">
<field name="SCHEDULE">*/5 * * * * *</field>
<block type="control" id="SxFI)QFztwO4GT)8d{IM">
<field name="OID">mqtt.0.jeedom.message</field>
<block type="variables_get" id=":wr0:6Uk*Y;9xtKPRx?*">
<field name="VAR" id="3[9HDT:}lPudZkmmX8Z+">msg2</field>
<block type="control" id="OvJA|E{qY}6!MzOfu+T|">
<block type="variables_get" id="9UX*y@LjP%.Q-IR^_;4t">
<field name="VAR" id="e.Hw9-61~#@h3527|TvQ">msg3</field>
<block type="control" id="|o]YbF*?1{XZfH!s9:yZ">
<block type="variables_get" id="uN#_R#]/_VNBn5){c%J;">
<field name="VAR" id="K%NN~D}hP}$Wn~CV(CYi">msg4</field>
<block type="control" id="S(BCqYirB`BB7n-{Hp%S">
<block type="variables_get" id="N`5$hc]K9RKZS:CDAtYm">
<field name="VAR" id="QMuC}2I,^YHovnMvw,(*">msg5</field>
<block type="control" id="N{Iwt^%yG`@.OE,U78I0">
<block type="variables_get" id="8[MR+t506iS[GC0xU(nq">
<field name="VAR" id="3@_dL%UAv#T-OBIMFwzc">msg6</field>
<block type="control" id="CdhdWx2]btRc(a.yabQc">
<block type="variables_get" id="}.wR]T`xBD5Ql.x)_|6c">
<field name="VAR" id="h@=Z[:(D[Y52lvDl??TD">msg7</field>
<block type="control" id="Z8a_sz)~m,~ogjT6QSfw">
<block type="variables_get" id="s?s0v7ziOlT]C!4f,;V$">
<field name="VAR" id="_1=`UCG+wMA.pRQ/W*8a">msg8</field>
<block type="control" id="oq2g]F^cC^?[R!urF5#U">
<block type="variables_get" id="sl#Q,]m{9u[MF[?G?]/u">
<field name="VAR" id="8M;I;?+;RU|^GtLDqU$(">msg9</field>
<block type="control" id="@U=-Nbny#Ge?PfHplda4">
<block type="variables_get" id="t^qS:[VwY-PP$j}?}:Yj">
<field name="VAR" id="AM4NVDx!nhvka?#7fc)z">msg10</field>
<block type="control" id="b%|-5WZ`:1U9ysH$Tz(+">
<block type="variables_get" id="Ow!]K^Kg[rll,K7,M2~L">
<field name="VAR" id="f]q]qDe]0?U|71;nt4a5">msg11</field>
<block type="control" id="K#l--2M2!G[@0t_+yz:J">
<block type="variables_get" id="dE1-jJd:#+ujS)3++I`F">
<field name="VAR" id="m28LI:=Y|qQk0pM2HJ3p">msg12</field>
<block type="control" id="|iV`!G;,Q.w4gDRWXR#]">
<block type="variables_get" id="st^S!{N1=Kn)UR#(=6cA">
<field name="VAR" id="[e-s1w?g[g|xi!1:1_Kp">msg13</field>
<block type="procedures_defcustomreturn" id="4{wZ;wP0O+/-$wM%$P1." x="112" y="337">
<mutation statements="false">
<arg name="text" varid="RM}IB6Haie0KqfAXGP9h"></arg>
</mutation>
<field name="NAME">text2JSON</field>
<field name="SCRIPT">Y29uc3Qgb2JqID0gew0KICAgIHRleHQ6IHRleHQsDQogICAgcHJpb3JpdGU6IDEsDQogICAgbHVtOiAwLA0KICAgIHBvczogMSwNCiAgICBlZmZfaW46IDEsDQogICAgZWZmX291dDogMSwNCiAgICBzcGVlZDogMTAsDQogICAgcGF1c2U6IDEsDQoNCn07DQpyZXR1cm4gSlNPTi5zdHJpbmdpZnkob2JqKTs=</field>
<block type="timeouts_setinterval" id="~AQfW;08uFMkA/r:vWky" collapsed="true" x="538" y="388">
<field name="NAME">Intervall</field>
<field name="INTERVAL">3000</field>
<field name="UNIT">ms</field>
<block type="variables_set" id="t3P.K|R118on88q-AGKp">
<field name="VAR" id="IHwL`AB66?q8*B9ffsZn">feed2</field>
<block type="get_value" id="zAfg#3F(7PXSrY$-Mv+z">
<field name="OID">rssfeed.0.Topnews.Bild</field>
<block type="variables_set" id="^O{2B[~jZFu.wAH|^C#z">
<block type="procedures_callcustomreturn" id="5-0N.n+^gIK0|JB=`==?">
<mutation name="text2JSON">
<arg name="text"></arg>
</mutation>
<value name="ARG0">
<block type="text_join" id="Yn)6kw5Cy]sBjf?{NLS[">
<value name="ADD0">
<block type="text_getSubstring" id="b}F?wFKH4K`n/QT-pz%h">
<mutation at1="false" at2="true"></mutation>
<field name="WHERE1">FIRST</field>
<field name="WHERE2">FROM_START</field>
<value name="STRING">
<block type="get_attr" id="D3`x-l`0K7I-8i~Y,Ej@">
<value name="PATH">
<shadow type="text" id=";06dHh(XBlbn{00/2w^_">
<field name="TEXT">articles.0.title</field>
<value name="OBJECT">
<block type="get_value" id=";%cs(_e~DnV9~Cgj01Oh">
<value name="AT2">
<block type="math_number" id=")w$yFsDd}0J.;`q))W3q">
<field name="NUM">600</field>
<block type="timeouts_setinterval" id="pLD}e@86ybWXF+{+qZ[M" collapsed="true">
<field name="NAME">Intervall2</field>
<block type="variables_set" id="FJJ=`SXZNZgtwx3jTeg-">
<block type="get_value" id="2n|lOh7xU6w2kBaqAjQ0">
<block type="variables_set" id="xrZu%O(C5q(Levg{8Io^">
<block type="procedures_callcustomreturn" id="M0$aTl2)FUG_7l=5SyP*">
</mutation>
<value name="ARG0">
<block type="text_join" id="FlxD98mT7lNtQ[#TeM]x">
<value name="ADD0">
<block type="text_getSubstring" id=".~hZaLSUpG)!r_UAtSPO">
<block type="get_attr" id="/2:gaT.TjXQZ8MM,n53%">
<value name="PATH">
<shadow type="text" id="qhtJrf8AEuc`|/O.tLv(">
<field name="TEXT">articles.1.title</field>
<block type="get_value" id="gBN!^DoA*L21+5D)sY9E">
<value name="AT2">
<block type="math_number" id="#RE$y1bj,WlwC3j9qQl]">
<field name="NUM">1000</field>
<block type="timeouts_setinterval" id="eMd:mse5)I,e9L_Itni2" collapsed="true">
<field name="NAME">Intervall3</field>
<block type="variables_set" id="n-YjsLR$HWN_.xcpWtkV">
<block type="get_value" id="g#-%3.=jmm[`{nqG_v{X">
<block type="variables_set" id="!5YVJG^AZGfO8^]c24PY">
<block type="procedures_callcustomreturn" id="aII6qX;JeVc`FdJ1f~ez">
</mutation>
<value name="ARG0">
<block type="text_join" id="c_U?1]hHW}l|Vj3QycA4">
<value name="ADD0">
<block type="text_getSubstring" id="_6%Kx]UIp]:(aT?%9*y1">
<block type="get_attr" id="wFsauTibIp-VB4bRUov(">
<value name="PATH">
<shadow type="text" id="@Hzk04i-xlaNx?B8aoeA">
<field name="TEXT">articles.2.title</field>
<block type="get_value" id="}FezL~LO@uGFOcgx2Sf#">
<value name="AT2">
<block type="math_number" id="N],Z=@}x5`pVBM0Irqoy">
<block type="timeouts_setinterval" id="@}n!E*#?h+hyZ$/)mOcc" collapsed="true">
<field name="NAME">Intervall4</field>
<block type="variables_set" id="5Ga[#}?ux+ZX-Q4wXYeZ">
<block type="get_value" id="pPLI6eq/Wqk#(iXN2x}b">
<block type="variables_set" id="d/InR34eG9LrWtGsU6fd">
<block type="procedures_callcustomreturn" id="aKMKSRKDh7.Nau[S.}63">
</mutation>
<value name="ARG0">
<block type="text_join" id="tqn?F6oqd4HI8X)4Efc+">
<value name="ADD0">
<block type="text_getSubstring" id="LeeE+)yv6:Gn.;Z(K@(Q">
<block type="get_attr" id="eaXIO1KhQSbhRPH%dfK`">
<value name="PATH">
<shadow type="text" id="Uln7x}Ea@z_#Tb?wZCPl">
<field name="TEXT">articles.3.title</field>
<block type="get_value" id="W#WJ|tP*7;k-tUp58lSt">
<value name="AT2">
<block type="math_number" id="%-d/5r/D`]I~KJE{KTa9">
<block type="timeouts_setinterval" id="?r0I=(yT.]sOOvXaxFDa" collapsed="true">
<field name="NAME">Intervall5</field>
<block type="variables_set" id="5j`YkHsEO}^csH+n`WDL">
<block type="get_value" id="|qN_P@/=Vk+1M:utN0.P">
<block type="variables_set" id="L[1Qsw0C#3keE6iHnbKy">
<block type="procedures_callcustomreturn" id="n_Fa3v-bPG@ytEMaw6AK">
</mutation>
<value name="ARG0">
<block type="text_join" id="I2Tb(~VqrHn`_@g(JzU|">
<value name="ADD0">
<block type="text_getSubstring" id="-kG]{c$%+j%4oU%O|[@w">
<block type="get_attr" id="pVRa~w5EQA3co%s`1S;v">
<value name="PATH">
<shadow type="text" id="^BE6(3w%z7Y#qyH#]C)o">
<field name="TEXT">articles.4.title</field>
<block type="get_value" id="sCgCx:V,[MqsX^Pjp99X">
<value name="AT2">
<block type="math_number" id="Masxd=s|AW@D)X:JAbR;">
<block type="timeouts_setinterval" id="~[@T/HQVT-r5SegAhT.p" collapsed="true">
<field name="NAME">Intervall6</field>
<block type="variables_set" id="k]x%3DxoO`=RExyY0L[{">
<block type="get_value" id="6~gjSod}-$J)|dM{70`a">
<block type="variables_set" id=",m+0ivzS%+~kT9SJ*k.c">
<block type="procedures_callcustomreturn" id="^:-8s.LKWylb:Qp,X^~3">
</mutation>
<value name="ARG0">
<block type="text_join" id="rhNv5]p-gCKRl_Kqz2pj">
<value name="ADD0">
<block type="text_getSubstring" id="-Ch5BrADf8P;ml4lBA2u">
<block type="get_attr" id="#oJrR=J@m@)NEk)grF4L">
<value name="PATH">
<shadow type="text" id="9-BG8,e8le(/(]-Jg/w2">
<field name="TEXT">articles.5.title</field>
<block type="get_value" id="mR_s_ask/{n~GuLk|~^P">
<value name="AT2">
<block type="math_number" id="ByyFC{m?S[v!J:Q`G*$X">
<block type="timeouts_setinterval" id=":$iaPc/?t`tqu0M0f+m," collapsed="true">
<field name="NAME">Intervall7</field>
<block type="variables_set" id="X_gmym_/I3!9D[5ylw?#">
<block type="get_value" id="Y1#212lUlg,U)x}j7uhG">
<block type="variables_set" id="@+MR%xFW:VoOJ:ZdfZ=T">
<block type="procedures_callcustomreturn" id="B=C{|xWE!DJu`6Of%@Ot">
</mutation>
<value name="ARG0">
<block type="text_join" id="$9wD?i2FDxp#K-56*!Qe">
<value name="ADD0">
<block type="text_getSubstring" id="/v(lj[xRa0F~8|2mHili">
<block type="get_attr" id="u^s,.8UY!ec1_jFSfuXP">
<value name="PATH">
<shadow type="text" id="P~oHa1;z*#_d$%dN,[@g">
<field name="TEXT">articles.6.title</field>
<block type="get_value" id="a#Qb@a4V@bLg$Sl1J#/D">
<value name="AT2">
<block type="math_number" id="`NG2VYu%8Fa1P8x3):8t">
<block type="timeouts_setinterval" id="pMmM.9Fu6N}h![]3^EP`" collapsed="true">
<field name="NAME">Intervall8</field>
<block type="variables_set" id="%k]qQGfW-IrRO|VQ$T!e">
<block type="get_value" id="HV%6WQ}Px$,e1NUF3D}/">
<block type="variables_set" id="Ry57^x9w|wkh9%{oWeaL">
<block type="procedures_callcustomreturn" id="-;k4Oc89p8}t4UGkxL8[">
</mutation>
<value name="ARG0">
<block type="text_join" id="Y2OZ`Ig#lgAqMvaSdn;4">
<value name="ADD0">
<block type="text_getSubstring" id="as^!@?.bc1@b[puDixnF">
<block type="get_attr" id="{9EP+wM,Gl,Rg/Nm(S;v">
<value name="PATH">
<shadow type="text" id=";dC1S]rt{F~}9laS$Rtb">
<field name="TEXT">articles.7.title</field>
<block type="get_value" id="+L@77GIsOKJhaN($7xQa">
<value name="AT2">
<block type="math_number" id="z!3xP%;SRVZ`9oWSh27I">
<block type="timeouts_setinterval" id="G3To1/oz-*S$9NOzrC|~" collapsed="true">
<field name="NAME">Intervall9</field>
<block type="variables_set" id="bWB%77Z{k~08I37lqCp!">
<block type="get_value" id="z0PO;=bLo2A+)zp({/OF">
<block type="variables_set" id="m8V_i!M.Mkbd:[FbC15V">
<block type="procedures_callcustomreturn" id="(D!$hB-PJCdri/WiAUP9">
</mutation>
<value name="ARG0">
<block type="text_join" id="OH)~JB#t,;=;lw3X$P@!">
<value name="ADD0">
<block type="text_getSubstring" id=".GS03gzu;VPo0xx{kSN%">
<block type="get_attr" id="bh$,-ZQkrpK6/@q50-Hh">
<value name="PATH">
<shadow type="text" id="888qpD{87b=x*jyA97FY">
<field name="TEXT">articles.8.title</field>
<block type="get_value" id="4:Tm}Z?vXy)3]eBG.BCo">
<value name="AT2">
<block type="math_number" id="_v}aOm,b)~VQEmf~[IC*">
