Ich komme hier einfach nicht weiter.
Wo kommt der Fehler mit der konstanten Variable her?
javascript.0
2021-10-13 11:39:33.891 die Info script.js.telegram.Kanaltest: 0 Abos und 0 Fahrpläne registriert
javascript.0
2021-10-13 11:39:33.880 die Info script.js.telegram.Kanaltest: sendTo(adapter=telegram.0, cmd=call, msg={"text":"Hallo","user":"","lang":"de-DE-Standard-B ","wiederholt":"1"})
telegram.0
2021-10-13 11:39:33.883 warnen TypeError: Zuweisung an konstante Variable. at callUsers (/opt/iobroker/node_modules/iobroker.telegram/main.js:1262:15) at processMessage (/opt/iobroker/node_modules/iobroker.telegram/main.js:1247:21) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/main.js:155:17) bei Adapter.emit (events.js:314:20) bei Änderung (/opt/iobroker/node_modules/iobroker.js-controller/lib /adapter.js:5634:34) bei Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37) bei processImmediate (internal/timers.js .) :461:21)
telegram.0
2021-10-13 11:39:33.883 warnen Status System pmessage io.messagebox.system.adapter.telegram.0 {"command":"call","message":{"text":"Hallo","user":"","lang":"de- DE-Standard-B","repeats":"1","users":[],"message":"Hallo"},"from":"system.adapter.javascript.0","_id":95753937 } Zuweisung an konstante Variable.
javascript.0
2021-10-13 11:39:33.874 die Info Start javascript script.js.telegram.Kanaltest
javascript.0
2021-10-13 11:39:30.635 die Info Skript stoppen script.js.telegram.Kanaltest
