@razor88w
anbei ein Blockly:Blockly.jpg
<block type="comment" id="N3OGf^,|*UPnjx.jqL1G" x="13" y="38">
<field name="COMMENT">Sender: Antenne Bayern: s42824, RPR1. Aprés Ski: s267508</field>
<block type="on_ext" id="r-nlIeYfQsB!7hW8z)n/">
<value name="OID0">
<shadow type="field_oid" id="ZH5Fq?HHGR2tM0D(3@+w">
<field name="oid">zigbee.0.000d6ffffe463925.occupancy</field>
<block type="controls_if" id="8x[QmC/L=v)5,3EL]k((">
<block type="logic_operation" id="%YWl/m6hY]Vfxff_/ng?" inline="false">
<field name="OP">AND</field>
<block type="on_source" id="jCA,k#ie!DDYa}CnEF)m">
<block type="time_compare_ex" id="SxaKx-sfWwm)oNM%6^R{">
<mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
<value name="START_TIME">
<shadow type="text" id="id/^ZerlywV_wIRA]#`m">
<field name="TEXT">07:00</field>
<value name="END_TIME">
<shadow type="text" id="|MH-Z)!3tFj$V8E9s,DT">
<field name="TEXT">22:00</field>
<block type="controls_if" id="L;@=Ez;mZ^}XSYEExb?v">
<block type="logic_compare" id="=PeRV]/r@(dZ3KpGje?C">
<field name="OP">EQ</field>
<block type="get_value" id="@?Gijn,PeSpCUVZ#lFbe">
<field name="OID">alexa2.0.Echo-Devices.G091AA0805261KP7.Player.currentState</field>
<block type="logic_boolean" id=";_7+c$*k,%QISpT7fcTd">
<block type="control" id=":p7PIMWML.C,BD|8]Q}.">
<field name="OID">alexa2.0.Echo-Devices.G091AA0805261KP7.Player.volume</field>
<block type="math_number" id="gw2v75oTJ,U[9.7]O6VV">
<field name="NUM">30</field>
<block type="control" id=".7Tp[*pw%Qj=OW(I9wg=">
<field name="OID">alexa2.0.Echo-Devices.G091AA0805261KP7.Player.TuneIn-Station</field>
<block type="text" id="}y;pL{Gd2~ccmb{(`O|3">
<field name="TEXT">s78909</field>
<block type="control" id="J8RA#_wQlv+N@b=~/!z!">
<field name="OID">alexa2.0.Echo-Devices.G091AA0805261KP7.Player.controlPlay</field>
<block type="logic_boolean" id="$3aey$27;saj82+E7G@;">
<statement name="ELSE">
<block type="timeouts_cleartimeout" id="q|-p2?k`?,pDxba#s-;e">
<block type="timeouts_settimeout" id="M?fSimc$R_kHs7PWfJOd">
<field name="DELAY">10</field>
<block type="control" id="sUs/n(4vP|~T16G0._$a">
<field name="OID">alexa2.0.Echo-Devices.G091AA0805261KP7.Player.controlPause</field>
<block type="logic_boolean" id="v-hsBwQx=u62s?(Qa19#">
<block type="control" id="e#req-Va$-RRC]G4EF5%">
<field name="DELAY_MS">1</field>
<block type="get_value" id="F0tV)OA^/%r:sD9f#f3T">
<field name="OID">javascript.0.Datenpunkte.Alexa-Ansagelautstaerke</field>
<block type="comment" id="4ZgiF`(t;!7x+-_{~X~x">
<field name="COMMENT">Bei Licht aus Alexa Pause</field>
<block type="on_ext" id="bS.RTS}#aherAC9VKf0,">
<value name="OID0">
<shadow type="field_oid" id="^NAcbo4~IqH@HyCn941@">
<field name="oid">shelly.0.SHSW-1#E0E6AC#1.Relay0.Switch</field>
<block type="controls_if" id="_X5d5ivFma..7LKz|[.*">
<block type="logic_compare" id=",PB]@y@8]*-JzZh1yLQ,">
<block type="get_value" id="NZ)8p{{ifm{mPllMQ5q)">
<field name="OID">shelly.0.SHSW-1#E0E6AC#1.Relay0.Switch</field>
<block type="logic_boolean" id="]f-~o^E/rFK7?khfQW;u">
<block type="control" id="/_d])~A7bjgy(K?:HNt*">
<block type="logic_boolean" id="4pnA(X^vlE]9B[`%m:t1">
<block type="control" id="Z?6NfP4||+DP`G$wKpy^">
<field name="DELAY_MS">2</field>
<block type="get_value" id="yfLNvDGub_^!w/T(eNJo">
