Skript v.2024-05-22 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.103-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.2 Docker : false Virtualization : none Kernel : armv7l Userland : 32 bit Systemuptime and Load: 22:06:13 up 21 min, 1 user, load average: 1.62, 2.20, 1.63 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Mon 2024-09-09 22:06:13 CEST Universal time: Mon 2024-09-09 20:06:13 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** Display-Server-Setup *** Display-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 1.1G 1.7G 8.0M 1.0G 2.7G Swap: 99M 0B 99M Total: 3.9G 1.1G 1.8G Active iob-Instances: 21 3838 M total memory 1090 M used memory 472 M active memory 1496 M inactive memory 1732 M free memory 185 M buffer memory 830 M swap cache 99 M total swap 0 M used swap 99 M free swap *** top - Table Of Processes *** top - 22:06:14 up 21 min, 1 user, load average: 1.62, 2.20, 1.63 Tasks: 148 total, 1 running, 147 sleeping, 0 stopped, 0 zombie %Cpu(s): 2.9 us, 2.9 sy, 0.0 ni, 94.2 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 3838.7 total, 1732.9 free, 1090.2 used, 1015.6 buff/cache MiB Swap: 100.0 total, 100.0 free, 0.0 used. 2671.4 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * rc-local.service loaded failed failed /etc/rc.local Compatibility LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. Pass --all to see loaded but inactive units, too. To show all installed unit files use 'systemctl list-unit-files'. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 14G 14G 49% / devtmpfs devtmpfs 1.8G 0 1.8G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 1.9G 8.5M 1.9G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 384M 0 384M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Mon Sep 9 21:44:55 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC:A6:32:EA:20:D4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=55190a09-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [Mon Sep 9 21:44:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [Mon Sep 9 21:44:56 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Mon Sep 9 21:44:59 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/dev devtmpfs devtmpfs rw,relatime,size=1800568k,nr_inodes=84157,mode=755 | |-/dev/shm tmpfs tmpfs rw,nosuid,nodev | |-/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 | `-/dev/mqueue mqueue mqueue rw,relatime |-/sys sysfs sysfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/cgroup tmpfs tmpfs ro,nosuid,nodev,noexec,mode=755 | | |-/sys/fs/cgroup/unified cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate | | |-/sys/fs/cgroup/systemd cgroup cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd | | |-/sys/fs/cgroup/freezer cgroup cgroup rw,nosuid,nodev,noexec,relatime,freezer | | |-/sys/fs/cgroup/net_cls,net_prio cgroup cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio | | |-/sys/fs/cgroup/cpu,cpuacct cgroup cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct | | |-/sys/fs/cgroup/devices cgroup cgroup rw,nosuid,nodev,noexec,relatime,devices | | |-/sys/fs/cgroup/blkio cgroup cgroup rw,nosuid,nodev,noexec,relatime,blkio | | |-/sys/fs/cgroup/perf_event cgroup cgroup rw,nosuid,nodev,noexec,relatime,perf_event | | |-/sys/fs/cgroup/cpuset cgroup cgroup rw,nosuid,nodev,noexec,relatime,cpuset | | `-/sys/fs/cgroup/pids cgroup cgroup rw,nosuid,nodev,noexec,relatime,pids | |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700 | |-/sys/kernel/debug debugfs debugfs rw,relatime | `-/sys/kernel/config configfs configfs rw,relatime |-/proc proc proc rw,relatime | `-/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct |-/run tmpfs tmpfs rw,nosuid,nodev,mode=755 | |-/run/lock tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k | |-/run/rpc_pipefs sunrpc rpc_pipefs rw,relatime | `-/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=393084k,mode=700,uid=1000,gid=1000 `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 1005M /var/ 477M /var/cache 472M /var/cache/apt 413M /var/cache/apt/archives 346M /var/lib Archived and active journals take up 8.0M in the file system. /opt/iobroker/backups: 1.3G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 820M /opt/iobroker/iobroker-data/ 720M /opt/iobroker/iobroker-data/files 441M /opt/iobroker/iobroker-data/files/javascript.admin 409M /opt/iobroker/iobroker-data/files/javascript.admin/static 408M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map 24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map 24M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map 23M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map 17M /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** NodeJS-Installation *** /usr/bin/nodejs v18.20.4 /usr/bin/node v18.20.4 /usr/bin/npm 10.7.0 /usr/bin/npx 10.7.0 /usr/bin/corepack 0.28.0 nodejs: Installed: 18.20.4-1nodesource1 Candidate: 18.20.4-1nodesource1 Version table: *** 18.20.4-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.20.3-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.20.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.20.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 10.24.0~dfsg-1~deb10u3 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 6.0.11 admin: 7.0.23 javascript: 8.7.6 nodejs modules from github: 0 Adapter State + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin system.adapter.backitup.0 : backitup : raspberrypi - disabled + system.adapter.discovery.0 : discovery : raspberrypi - enabled + system.adapter.ds18b20.0 : ds18b20 : raspberrypi - enabled system.adapter.echarts.0 : echarts : raspberrypi - enabled system.adapter.flot.0 : flot : raspberrypi - enabled + system.adapter.fritzdect.0 : fritzdect : raspberrypi - enabled + system.adapter.fronius-wattpilot.0 : fronius-wattpilot : raspberrypi - enabled + system.adapter.fronius-wattpilot.1 : fronius-wattpilot : raspberrypi - enabled + system.adapter.fronius.0 : fronius : raspberrypi - enabled + system.adapter.history.0 : history : raspberrypi - enabled + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.info.0 : info : raspberrypi - enabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled system.adapter.mqtt-client.0 : mqtt-client : raspberrypi - disabled, port: 1883 + system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1884, bind: 192.168.178.22 + system.adapter.netatmo.0 : netatmo : raspberrypi - enabled system.adapter.ocpp.0 : ocpp : raspberrypi - disabled, port: 9220 system.adapter.onvif.0 : onvif : raspberrypi - disabled + system.adapter.parser.0 : parser : raspberrypi - enabled + system.adapter.ping.0 : ping : raspberrypi - enabled + system.adapter.rpi2.0 : rpi2 : raspberrypi - enabled + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.tr-064.0 : tr-064 : raspberrypi - enabled + system.adapter.tuya.0 : tuya : raspberrypi - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - enabled system.adapter.vis.0 : vis : raspberrypi - enabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1884, bind: 192.168.178.22 + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Instances Used repository: stable Adapter "admin" : 7.0.23 , installed 7.0.23 Adapter "backitup" : 3.0.22 , installed 3.0.22 Adapter "discovery" : 4.5.0 , installed 4.5.0 Adapter "ds18b20" : 2.0.5 , installed 2.0.5 Adapter "echarts" : 1.7.2 , installed 1.7.2 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzdect" : 2.5.9 , installed 2.5.9 Adapter "fronius" : 2.1.1 , installed 2.1.1 Adapter "fronius-wattpilot": 4.6.3, installed 4.6.3 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "homekit-controller": 0.5.10, installed 0.5.10 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "javascript" : 8.7.6 , installed 8.7.6 Controller "js-controller": 6.0.11 , installed 6.0.11 Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "mqtt-client" : 2.0.0 , installed 2.0.0 Adapter "netatmo" : 3.1.0 , installed 3.1.0 Adapter "ocpp" : 0.12.5 , installed 0.12.5 Adapter "onvif" : 1.1.4 , installed 1.1.4 Adapter "parser" : 2.2.2 , installed 2.2.2 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "sonoff" : 3.1.0 , installed 3.1.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "tuya" : 3.16.0 , installed 3.16.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "ws" : 2.6.2 , installed 2.6.2 Objects and States Please stand by - This may take a while Objects: 2318 States: 1778 *** OS-Repositories and Updates *** W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Some index files failed to download. They have been ignored, or old ones used instead. Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Get:3 https://repos.influxdata.com/debian buster InRelease [12.9 kB] Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease Err:3 https://repos.influxdata.com/debian buster InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E Fetched 12.9 kB in 2s (6051 B/s) Reading package lists... W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Some index files failed to download. They have been ignored, or old ones used instead. Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14259 653/sshd tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 14708 365/influxd tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 48207 3339/io.sonoff.0 tcp 0 0 192.168.178.22:1884 0.0.0.0:* LISTEN 1001 46484 3288/io.mqtt.0 tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 46201 3089/iobroker.js-co tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 45213 3089/iobroker.js-co tcp6 0 0 :::8081 :::* LISTEN 1001 43798 3110/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 50205 3531/io.web.0 tcp6 0 0 :::8086 :::* LISTEN 999 17181 365/influxd tcp6 0 0 :::22 :::* LISTEN 0 14261 653/sshd udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 46542 3306/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 46543 3306/io.tuya.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 17077 644/dhcpcd udp 0 0 0.0.0.0:39564 0.0.0.0:* 108 15844 332/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 15842 332/avahi-daemon: r udp6 0 0 :::546 :::* 0 17100 644/dhcpcd udp6 0 0 :::44593 :::* 108 15845 332/avahi-daemon: r udp6 0 0 :::5353 :::* 108 15843 332/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-09-09 22:05:00.028 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 3.1 2024-09-09 22:05:20.013 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: WW-Merker0 2024-09-09 22:05:20.014 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab AUTO 2 2024-09-09 22:05:20.015 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab aus 2024-09-09 22:05:20.015 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 3.3 2024-09-09 22:05:40.010 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: WW-Merker0 2024-09-09 22:05:40.011 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab AUTO 2 2024-09-09 22:05:40.011 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab aus 2024-09-09 22:05:40.011 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 0.8 2024-09-09 22:06:00.009 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: WW-Merker0 2024-09-09 22:06:00.010 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab AUTO 2 2024-09-09 22:06:00.010 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab aus 2024-09-09 22:06:00.010 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 0.6 2024-09-09 22:06:20.012 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: WW-Merker0 2024-09-09 22:06:20.012 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab AUTO 2 2024-09-09 22:06:20.013 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab aus 2024-09-09 22:06:20.013 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 1 2024-09-09 22:06:40.007 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: WW-Merker0 2024-09-09 22:06:40.008 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab AUTO 2 2024-09-09 22:06:40.008 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab aus 2024-09-09 22:06:40.009 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 2.3 2024-09-09 22:07:00.027 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: WW-Merker0 2024-09-09 22:07:00.028 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab AUTO 2 2024-09-09 22:07:00.029 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab aus 2024-09-09 22:07:00.029 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 0.6============ Mark until here for C&P =============
iob diag has finished.
