@meckii
So habe jetzt noch ein bisschen daran rumgespielt und erweitert.
Nun wird auch noch die absolute Feuchte [g/m³] berechnet.
<variable id="3Z$x1{!vu;(:9*^Og4Mr">SDD</variable>
<variable id="sMuyz@sFD?~GL7Pbp0m">tp</variable>
<variable id="f-+??FgK=EkG;Jx.E4Uh">r</variable>
<variable id="M$gd;on{YS_4sZS7%v5;">T</variable>
<variable id="mX4kA._w3Vj3Gb{T/zN_">DD</variable>
<variable id="{B56Lv3ul+5edI:{Uc]3">abshum</variable>
<variable id="{NP4D8gJ;3K@K(4++fqR">eln</variable>
<variable id="UL:4GF)A];9++Y79).sv">td</variable>
<variable id="YgLQFsamPgYe~I1PeN#y">AF</variable>
<block type="comment" id="QJ%/9PRR1k?`fCY}3%Z:" x="-112" y="-912">
<field name="COMMENT">https://www.wetterochs.de/wetter/feuchte.html</field>
<block type="create" id="QbX9ckz3P;Fh,UosB(;1">
<field name="NAME">Raumname.Taupunkt</field>
<block type="math_number" id="y{{fts?WuZ~z_q;3:DFm">
<field name="NUM">0</field>
<value name="COMMON">
<block type="text" id="!(-PlK^yPa682SlW#8qg">
<field name="TEXT">{"type": "number", "unit": "°C"}</field>
<block type="create" id="uKlSigcT.:5Z}gVd*#n|">
<field name="NAME">Raumname.AbsoluteFeuchte</field>
<block type="math_number" id="E}?m$]NS(R%g!Cm_*Jj:">
<block type="text" id="p+/5H*I2b(?T7Z)Cm]g2">
<field name="TEXT">{"type": "number", "unit": "g/m³"}</field>
<block type="comment" id="$cuDkNb4J4KqW9QrpvU^">
<field name="COMMENT">relative Luftfeuchte</field>
<block type="variables_set" id="oH)8#Ny}tiOVyB|WA+b}">
<field name="VAR" id="f-+??FgK=EkG;Jx.E4Uh">r</field>
<block type="math_number" id="d3zGbkmOpnzPIrwfo4v^">
<block type="comment" id="M9ao7w{!8GJAHxHanrVO">
<field name="COMMENT">Temperatur in °C</field>
<block type="variables_set" id="NSXa`/DW*7QOWsQ^rQE{">
<field name="VAR" id="M$gd;on{YS_4sZS7%v5;">T</field>
<block type="math_number" id="cn8n?6GrD$4]+Fw:`UFu">
<block type="comment" id=":[cdj,}!;|Cx/^?!H;`.">
<field name="COMMENT">Dampfdruck in hPa</field>
<block type="variables_set" id=";#g0JZzbb=rdh1X28kG$">
<field name="VAR" id="mX4kA._w3Vj3Gb{T/zN_">DD</field>
<block type="math_number" id="OvsSA;~PwG9IF_Ep7iFI">
<block type="comment" id="[{HN9D[v3Iy#eyR`=Z=0">
<field name="COMMENT">Sättigungsdampfdruck in hPa</field>
<block type="variables_set" id="#(tqP_1!X}A`jdEaT-q#">
<field name="VAR" id="3Z$x1{!vu;(:9*^Og4Mr">SDD</field>
<block type="math_number" id=";zSk*;X;3n)tp:{?cg*(">
<block type="comment" id="hbdsrN!],S_15N@:l}hY">
<field name="COMMENT">Kommentar</field>
<block type="variables_set" id="[?K/:+U+Jxfz)k)mb!Z/">
<field name="VAR" id="{NP4D8gJ;3K@K(4++fqR">eln</field>
<block type="math_number" id="#NuXt{~?ssF8t$)^M]Tb">
<block type="comment" id="Jo4a8%9{c|vwvVnQ5+AU">
<field name="COMMENT">Taupunkttemperatur in °C</field>
<block type="variables_set" id="P8WyPT`-=ZPwnF!3a0A1">
<field name="VAR" id="sMuyz@sFD?~GL7Pbp0m">tp</field>
<block type="math_number" id="p.P1W%Xp-{!64dV92|#T">
<block type="comment" id="qgYelVPLa_kt$a-x}1;%">
<field name="COMMENT">Taupunkttemperatur in °C (gerundet)</field>
<block type="variables_set" id="2|v*9}Y4aD)W]aCsd07,">
<field name="VAR" id="UL:4GF)A];9++Y79).sv">td</field>
<block type="math_number" id="ig,b[/+=dU*v[V:;@u-.">
<block type="comment" id="xns9vGd$=a2h`e*;mD!v">
<field name="COMMENT">Absolute Feurchte in g/m³ (gerundet)</field>
<block type="variables_set" id="rUSwM8u/[A#aUAehe(Rb">
<field name="VAR" id="{B56Lv3ul+5edI:{Uc]3">abshum</field>
<block type="math_number" id="]xv^l:wP{R9aq$.d/Ey_">
<block type="comment" id="ndKR~-IJm/HMq4#npK/I">
<field name="COMMENT">Wohnzimmer</field>
<block type="on_ext" id="49IX5uyvrT9iH8;jyoUj">
<value name="OID0">
<shadow type="field_oid" id="0~LsZgL?g)):4O4+-B$i">
<value name="OID1">
<shadow type="field_oid" id="w9`*ap97SIBqRWe|Pa~W">
<block type="comment" id="F)a,EHKl]/s3Q/@LDWWn">
<field name="COMMENT">Sensorobjekt Luftfeuchte</field>
<block type="variables_set" id=")RW^T+IaJ@+?R6QuC">
<block type="get_value" id="jdi6Rqo;:-{axFE!H7?#">
<field name="OID">ID auswählen</field>
<block type="comment" id="qV~LJcUnNE#0Unq@1B6q">
<field name="COMMENT">Sensorobjekt Temperatur</field>
<block type="variables_set" id="(EycjR);Qux[)/Z^n@[h">
<block type="get_value" id="B_a#!RBL/*fiJ(4fN9Q*">
<block type="procedures_callnoreturn" id="DYa}UxDWp2sN,mGUb8HK">
<mutation name="Taupunkt"></mutation>
<block type="update" id="lRF2qapOYsx)t{MfqY(B">
<field name="OID">javascript.0.Raumname.Taupunkt</field>
<block type="variables_get" id="BXVaB~y0dn7~%]1/k`dO">
<block type="update" id="9rW{;%GvO1Nw~WL~~#[A">
<field name="OID">javascript.0.Raumname.AbsoluteFeuchte</field>
<block type="variables_get" id="CDyvchN=r;uV8[b=0Vzp">
<block type="procedures_defnoreturn" id="|2Q(bPHLjrKvd#z+tq@4" x="763" y="-812">
<field name="NAME">Taupunkt</field>
<statement name="STACK">
<block type="comment" id="1|c5Iv?gF{%IA,@Iu.">
<field name="COMMENT">Taupunktberechnung</field>
<block type="controls_if" id="ByEzI2A#1Vw!g@6y=x.">
<block type="logic_compare" id="E*0IXU=pu|YoyJf0{uqc">
<field name="OP">GTE</field>
<block type="variables_get" id="l-k/?s0QhUS/(;J_vucT">
<block type="math_number" id="@Os^%3xlb/TZfH@oH^Q">
<block type="variables_set" id="[:r[+m)b/$FQWtV[t)#">
<block type="math_arithmetic" id="jAo9H:ZALCR1L9eCZ.Il" inline="false">
<shadow type="math_number" id="G6Q_]:vF;i~j7:Pi8-#t">
<block type="math_number" id="fOllHl|_Bzz)TCbkR#qg">
<field name="NUM">6.1078</field>
<shadow type="math_number" id="665S^yxD[xGW4Inm4Mr,">
<block type="math_single" id="$cG@3m(JoL4w3HkfhiS">
<field name="OP">POW10</field>
<value name="NUM">
<shadow type="math_number" id="PRQST8q8yV]Fw_W3/x:z">
<field name="NUM">9</field>
<block type="math_arithmetic" id="(?IN@H@;V[kL!``q_2$" inline="false">
<field name="OP">DIVIDE</field>
<shadow type="math_number" id="QyD0sMCD3#C](G$}r@_">
<block type="math_arithmetic" id="a;!+nAsao:y,^/1|@jsY">
<shadow type="math_number" id="]RltYj4L;^qa317_M$=">
<field name="NUM">7.5</field>
<shadow type="math_number" id="EWFJRA-hdkJh0QPc.Qv?">
<block type="variables_get" id="nmLg;c|0$9+iucY..=L">
<shadow type="math_number" id="ub!sba|dcBnu#IqUX}1r">
<block type="math_arithmetic" id="hQ?]Y6c.Z;z~rbp9#WC$">
<field name="OP">ADD</field>
<shadow type="math_number" id="XRheb5t8I6;)aQkJ2lYT">
<field name="NUM">237.3</field>
<shadow type="math_number" id="m_@iDRZdJy,p|B,-m{O(">
<block type="variables_get" id="AcSL3eS]mbdzUDxMcsY0">
<block type="variables_set" id="5OQF=sBxj^$C(cPHO[y">
<block type="math_arithmetic" id="LOO1_uCB2yObhF(3Ao.h" inline="false">
<shadow type="math_number" id="cy!FphPD6@UZo^!N5eo|">
<block type="math_arithmetic" id="oB:4|Fi*KYE^3FjGkMP1">
<shadow type="math_number" id="HNz*b-.(QrpGncmL$bmH">
<field name="NUM">7.6</field>
<block type="variables_get" id="wijqrStadbe_On+gkU4n">
<shadow type="math_number" id="N~_=GJQhkjzh2h[C9nWu">
<field name="NUM">100</field>
<shadow type="math_number" id="f]XaZasgJhFAf$z/8n@k">
<block type="variables_get" id="q8=SL{BuR[EAHn(]:Hq">
<block type="variables_set" id="V.LWooF4=WgvA1LGfkBP">
<block type="math_single" id="ZS@~m80I{rE{yD.bFAVW">
<field name="OP">LOG10</field>
<value name="NUM">
<shadow type="math_number" id="=5E=naN@`7NdrxneG$y5">
<block type="math_arithmetic" id="ozDO$-;H}.0A@Yod[_b" inline="false">
<shadow type="math_number" id="c:}sw2_;B]H[?gPr^g0">
<block type="variables_get" id="x@kg5Wf;VpLbn-0z(so;">
<shadow type="math_number" id="sEtqixSVh@rW/|O^cbET">
<block type="variables_set" id="J;ubZ2|r/nw^jdXyKr3L">
<block type="math_arithmetic" id="kIefD#q5wDGn+i4Z]:w" inline="false">
<shadow type="math_number" id="PHt0V{{d0iijFXw@ldg0">
<block type="math_arithmetic" id="s-_(SzYRKU@FPCmSJj0I">
<shadow type="math_number" id="NA+=G8*WO(Y8E.RUE5.=">
<shadow type="math_number" id="c?|Td:?KmUuuBUEKtE~%">
<block type="variables_get" id="qFxw]#bth0/miCmcPu@|">
<shadow type="math_number" id="A^):KB{[ss]U#]}u=%;R">
<block type="math_arithmetic" id="~n^jByV/9B7}/g~y+,)">
<shadow type="math_number" id="2tg8805p7f|=_pB0L].">
<shadow type="math_number" id="K+E6u=IT-@_p=/;Hz0!A">
<block type="variables_get" id="UBF{jeWYsA|!~8fRHDz7">
<block type="variables_set" id="x:x3SBT[x8nA(-u@c2@O">
<field name="VAR" id="YgLQFsamPgYe~I1PeN#y">AF</field>
<block type="math_arithmetic" id="W}XrDu_jow[X-jW8|QWS" inline="false">
<shadow type="math_number" id="lVM969lnfAohb4E/jBjX">
<block type="math_single" id="G$!#u*N#05MD7UTDhmL#">
<value name="NUM">
<shadow type="math_number" id="G|/T/U,^:l2WZpVG5*i.">
<block type="math_number" id="Fn(]jpd{zgZu7hw|Rc:a">
<field name="NUM">5</field>
<shadow type="math_number" id="#{*K8HG5ThmW5hpco3Gp">
<block type="math_arithmetic" id="o#|@Zbl6#k=rPN*CLU$S" inline="false">
<block type="math_arithmetic" id="v}$Nwh2S)~McMT2DKjaQ">
<shadow type="math_number" id="wQCZVw$gs!VjpCB|0#3!">
<block type="math_number" id="Z.QElI(:)Y7fj,^M`2ry">
<field name="NUM">18.016</field>
<shadow type="math_number" id="/;F7=XL2@v?@*$x2%05;">
<block type="math_number" id="i?,:KALxujs=+39KBjf4">
<field name="NUM">8314.3</field>
<block type="math_arithmetic" id="#Z7XpzSwsn[/[d#8)3TZ">
<shadow type="math_number" id="j]h2O^6j0fTrhSX[_fTk">
<block type="variables_get" id="$TD|6D/|nxrAcuXO*W5M">
<shadow type="math_number" id="Js~pQ7Ka?tH6J,ZV.u]K">
<block type="math_arithmetic" id="byJHCM*Qlxf..1;uS_/i">
<shadow type="math_number" id="([g~X(b7N*3U2/urt.2t">
<block type="variables_get" id="JpEpX7}A|Eol=G%~`B7q">
<shadow type="math_number" id="uyi=,e=TWw3|JS.xj;Fz">
<block type="math_number" id="lJJs#^4T24r:kN[o{(:v">
<field name="NUM">273.15</field>
<statement name="ELSE">
<block type="variables_set" id="g$QTSdGTy+T-aFZX9$wp">
<block type="math_arithmetic" id="g$P^tql^~WUAamw8k7n" inline="false">
<shadow type="math_number" id="(c1.KCn%}THJH{W5Bkmz">
<shadow type="math_number" id="~o$m6RO}2R:QE#qY$*x@">
<block type="math_single" id="/1T#,u#%)1#jT)HCV=9J">
<value name="NUM">
<shadow type="math_number" id="!Vsle})Ppwf7LAK~5jNE">
<block type="math_arithmetic" id="vp8rg(E,B,YS,I%ug)[Q" inline="false">
<shadow type="math_number" id="V@9?0%ZKgBRFgHxC-hK6">
<block type="math_arithmetic" id="8HB}OAR3P8F:?w7qE22-">
<shadow type="math_number" id="}Ln*)/CqQr4MyM(c#EjH">
<shadow type="math_number" id="k:za[:pRTVY:hUTn6wfY">
<block type="variables_get" id="o+w;;K}Q|%_n/Etl/gl9">
<shadow type="math_number" id="dIcy);mcrC@N4Np0zd{S">
<block type="math_arithmetic" id="G?GFHbIe}%)q$lz:Bz?c">
<shadow type="math_number" id="Q||2_A,%@XWwv5CCKFk#">
<field name="NUM">240.7</field>
<shadow type="math_number" id="4yQP(LpM-*Ew-vN6f799">
<block type="variables_get" id="@}]UG%@}P.HPSrz]iHgC">
<block type="variables_set" id="g/N;f_%f8Cn|9kuyE{(F">
<block type="math_arithmetic" id="u69dXBrq66BCLE^M{]V2" inline="false">
<shadow type="math_number" id="J0lJ2u^IQu9boEc1aa$Z">
<block type="math_arithmetic" id="{A]Yj,E@@tC7=?3vy.{G">
<shadow type="math_number" id="}_|z]Pr1Ms^k+Gh6_FVS">
<block type="variables_get" id="^hq}Dvu!rIQB{R*$6mt">
<shadow type="math_number" id="}p=-XZ~(js#}jeqwsdn">
<shadow type="math_number" id="pJlcaR:BP9^@(gw$(RtG">
<block type="variables_get" id="uMHVhIUx1FQ-Lvu$l^])">
<block type="variables_set" id="jjt:t%m%BfYT3Zap=M;">
<block type="math_single" id="+99f$xJ)^XL:a,7onGF,">
<value name="NUM">
<shadow type="math_number" id="!r7$@7$_Gk)wd#~mA3[@">
<block type="math_arithmetic" id="xW02mthV|YNG5nwYvynh" inline="false">
<shadow type="math_number" id="7W~%P^(^P2Q8O5R%:zwN">
<block type="variables_get" id="E6#c7WR_4V%m=z{p)MPZ">
<shadow type="math_number" id=";uRP3BRr7?n|n~5lmTJ/">
<block type="variables_set" id="R[tn_(Y0qqH~W~+.puY-">
<block type="math_arithmetic" id="aS/=lAk=ZQ#dpFbE+QDx" inline="false">
<shadow type="math_number" id="#z8,O$RDtUXL_oNq%u$g">
<block type="math_arithmetic" id="laq*gf7u+IX8+!!x-R5d">
<shadow type="math_number" id="XLNI074{%m0%e0[cIMlp">
<shadow type="math_number" id="Z2DOS_z+//E%gT#)WKyu">
<block type="variables_get" id="EL2YKNTNBS5sQG+pBf@i">
<shadow type="math_number" id="N-$+a[!HV(?r8hwU@V-s">
<block type="math_arithmetic" id=".hEJ#RYdL%zb+4Hjr6|I">
<shadow type="math_number" id="?b;^}jKWg7j)IMPTuo?">
<shadow type="math_number" id="Tqw?pTUN!2JRCx)~VZay">
<block type="variables_get" id=":0Nxo1iLv@ng5s_g)o9)">
<block type="variables_set" id="c?+b,%4=ESdv$P_!BUD0">
<block type="math_arithmetic" id="oxx#gfE`xNeG@#wh!6@g" inline="false">
<block type="math_single" id="b,*:|yqAN7Bj9BYz{x*/">
<value name="NUM">
<block type="math_number" id="xCJYAZ?4OfZg(RY$LUIK">
<block type="math_arithmetic" id="y$k4f+`(5f=?fwPoXHP." inline="false">
<block type="math_arithmetic" id="l=I0V!ruOqY?PvYrg_GM">
<block type="math_number" id="#;O*;Y[,@4S?J$CPg=/R">
<block type="math_number" id="EnK}xc|q=o9rrEYlM.{O">
<block type="math_arithmetic" id="82Q_9{WGh~?aw#GQ{YFH">
<block type="variables_get" id=")8{pT%AD.Kw7wT+~_ywn">
<block type="math_arithmetic" id="0[218DIn${p`=BivzTr.">
<block type="variables_get" id="J:;1W(tL7|klowQ~C3a[">
<block type="math_number" id="W?0z)upz5n}SI$$2Hqc@">
<block type="variables_set" id=")8/1GENxlDMsoC-~NmZR">
<block type="math_rndfixed" id="ss$V$R-Lv=/XIzX@$EAS">
<field name="n">1</field>
<value name="x">
<shadow type="math_number" id="+$_x@enw?zJVQC2:3JV">
<field name="NUM">3.1234</field>
<block type="variables_get" id="YrIu}OINL[7w1/KQihT">
<block type="variables_set" id="5xzQCjh1ANgXAuiT/:42">
<block type="math_rndfixed" id="*KB]BZszZ,o:opR7w!kp">
<value name="x">
<block type="variables_get" id="]*:.36Vi*#[^umGb1e,8">
