@rewenode sagte in Node-Red Programmabschnitte aktivieren/deaktivieren:
Beispiel flow
Was immer da schief lief, der Export läßt sich nicht importieren.
Nun sollte es gehen.
Spoiler
        "id": "3fba4b65.667e1c",
        "type": "ui_switch",
        "z": "6a5f248f.c43fe4",
        "name": "",
        "label": "Alexa warnen lassen",
        "tooltip": "",
        "group": "e5a09358.c99e4",
        "order": 4,
        "width": 0,
        "height": 0,
        "passthru": true,
        "decouple": "false",
        "topic": "AlexaWarnSwitch",
        "style": "",
        "onvalue": "true",
        "onvalueType": "bool",
        "onicon": "",
        "oncolor": "",
        "offvalue": "false",
        "offvalueType": "bool",
        "officon": "",
        "offcolor": "",
        "x": 280,
        "y": 700,
        "wires": [
                "5161df40.dd73"
        "id": "5161df40.dd73",
        "type": "function",
        "name": "Gate für Sensor",
        "func": "// init/set context variable\nif (typeof context.get(\"AlexaWarnSwitch\") === \"undefined\") context.set(\"AlexaWarnSwitch\",\"0\");\n\n//if Switch, set context variable \nif (msg.topic == \"AlexaWarnSwitch\") {\n    context.set(\"AlexaWarnSwitch\", msg.payload);\n    node.status({fill: (msg.payload === true) ? \"green\" : \"red\",\n                shape:\"dot\", \n                text: (msg.payload === true) ? \"Warnung erlaubt\" : \"keine Warnung\"\n                })\n} else {  // msg comes from sensor\n    if (context.get(\"AlexaWarnSwitch\")) node.send(msg); \n}\n",
        "outputs": 1,
        "noerr": 0,
        "x": 540,
        "y": 600,
        "wires": [
                "b425223f.3fa538"
        "id": "48111ed4.b07f",
        "type": "comment",
        "name": "topic=\"AlexaWarnSwitch\"",
        "info": "",
        "x": 290,
        "y": 660,
        "wires": []
        "id": "b425223f.3fa538",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "x": 740,
        "y": 600,
        "wires": []
        "id": "39119b95.d05fbc",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "Sensorwert",
        "payloadType": "str",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 250,
        "y": 580,
        "wires": [
                "5161df40.dd73"
        "id": "25b5104b.2bddf",
        "type": "comment",
        "name": "Simuliert den Sensorwert",
        "info": "",
        "x": 290,
        "y": 540,
        "wires": []
        "id": "e5a09358.c99e4",
        "type": "ui_group",
        "name": "Click",
        "tab": "7341130f.164e84",
        "order": 1,
        "disp": true,
        "width": "5"
        "id": "7341130f.164e84",
        "type": "ui_tab",
        "name": "Home",
        "icon": "link",
        "order": 1
