Ich hab mal einen Flow mit vis oder NR dashboard gemacht. Letztlich brauchst Du nur einen Taster, der beim Loslassen false und beim Drücken true liefert.
Spoiler
       "id": "9485df68.fd8ba",
       "type": "tab",
       "label": "Tutorial vis Taster",
       "disabled": false,
       "info": ""
       "id": "b0c81813.4154f8",
       "type": "ioBroker in",
       "z": "9485df68.fd8ba",
       "d": true,
       "name": "taster",
       "attrname": "",
       "topic": "0_userdata.0.dimmer.taster",
       "payloadType": "value",
       "onlyack": "",
       "func": "rbe",
       "gap": "",
       "fireOnStart": "false",
       "x": 130,
       "y": 100,
       "wires": [
               "16e2170a.87ef89"
       "id": "dc014311.a8d3f",
       "type": "debug",
       "name": "Taste gedrückt",
       "active": false,
       "tosidebar": true,
       "console": false,
       "tostatus": false,
       "complete": "payload",
       "targetType": "msg",
       "statusVal": "",
       "statusType": "auto",
       "x": 600,
       "y": 60,
       "wires": []
       "id": "16e2170a.87ef89",
       "type": "trigger",
       "name": "",
       "op1": "true",
       "op2": "",
       "op1type": "bool",
       "op2type": "payl",
       "duration": "-250",
       "extend": true,
       "overrideDelay": false,
       "units": "ms",
       "reset": "false",
       "bytopic": "all",
       "topic": "topic",
       "outputs": 1,
       "x": 370,
       "y": 100,
       "wires": [
               "dc014311.a8d3f",
               "a123b62d.af5fa8"
       "id": "9982d6c4.29e058",
       "type": "switch",
       "name": "",
       "property": "payload",
       "propertyType": "msg",
       "rules": [
               "t": "false"
       "checkall": "true",
       "repair": false,
       "outputs": 1,
       "x": 310,
       "y": 220,
       "wires": [
               "d38eb95d.854638",
               "a123b62d.af5fa8"
       "id": "d38eb95d.854638",
       "type": "debug",
       "name": "Taste losgelassen",
       "active": false,
       "tosidebar": true,
       "console": false,
       "tostatus": false,
       "statusVal": "",
       "x": 490,
       "y": 280,
       "wires": []
       "id": "a123b62d.af5fa8",
       "type": "function",
       "name": "",
       "func": "var count = context.get('count') || 0;\nvar longpress = context.get('longpress') || false;\nif (msg.payload){\n    count += 1;\n    context.set('count',count);\n    if (count > 5) { // Wert erhöhen wenn Longpress zu früh erkannt wird\n        longpress = true;\n        context.set('longpress',longpress);\n        return [null,msg];\n    }\n} else {\n    msg.payload=true;\n    count = 0;\n    context.set('count',count);    \n    if (!longpress) return [msg,null];\n    longpress = false;\n    context.set('longpress',longpress);\n}\n",
       "outputs": 2,
       "timeout": "",
       "noerr": 0,
       "initialize": "",
       "finalize": "",
       "libs": [],
       "x": 590,
       "y": 180,
       "wires": [
               "65393650.6cfcd8",
               "1dbf19e0.f8af96"
               "faaddc42.671cf",
               "c5e2ef2d.6e447"
       "outputLabels": [
           "shortpress",
           "longpress"
       "id": "65393650.6cfcd8",
       "type": "debug",
       "name": "shortpress",
       "active": false,
       "tosidebar": true,
       "console": false,
       "tostatus": false,
       "statusVal": "",
       "x": 810,
       "y": 100,
       "wires": []
       "id": "faaddc42.671cf",
       "type": "debug",
       "name": "longpress",
       "active": false,
       "tosidebar": true,
       "console": false,
       "tostatus": false,
       "statusVal": "",
       "x": 800,
       "y": 340,
       "wires": []
       "id": "a9311da5.e0c66",
       "d": true,
       "name": "status",
       "attrname": "",
       "topic": "mqtt.1.shellies.shellydimmer.light.0.status",
       "onlyack": "",
       "func": "rbe",
       "gap": "",
       "x": 130,
       "y": 520,
       "wires": [
               "15d1fa89.761575"
       "id": "35413631.c8570a",
       "type": "debug",
       "name": "status",
       "active": false,
       "tosidebar": true,
       "console": false,
       "tostatus": false,
       "statusVal": "",
       "x": 430,
       "y": 460,
       "wires": []
       "id": "15d1fa89.761575",
       "type": "json",
       "name": "",
       "action": "",
       "pretty": false,
       "x": 270,
       "y": 520,
       "wires": [
               "35413631.c8570a",
               "eeebcf13.9b2fd",
               "af96a9a1.7e48c8"
       "id": "eeebcf13.9b2fd",
       "type": "change",
       "name": "setze flow Variablen",
       "rules": [
               "t": "set",
               "p": "ison",
               "pt": "flow",
               "to": "payload.ison",
               "tot": "msg"
               "t": "set",
               "p": "brightness",
               "pt": "flow",
               "to": "payload.brightness",
               "tot": "msg"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 480,
       "y": 520,
       "wires": [
       "id": "1dbf19e0.f8af96",
       "type": "change",
       "name": "switch (toggle)",
       "rules": [
               "t": "set",
               "p": "payload",
               "pt": "msg",
               "to": "ison",
               "tot": "flow"
               "t": "set",
               "p": "payload",
               "pt": "msg",
               "to": "$not(payload)\t",
               "tot": "jsonata"
               "t": "set",
               "p": "ison",
               "pt": "flow",
               "to": "payload",
               "tot": "msg"
               "t": "set",
               "p": "down",
               "pt": "flow",
               "to": "payload",
               "tot": "msg"
               "t": "change",
               "p": "payload",
               "pt": "msg",
               "from": "true",
               "fromt": "bool",
               "to": "on",
               "tot": "str"
               "t": "change",
               "p": "payload",
               "pt": "msg",
               "from": "false",
               "fromt": "bool",
               "to": "off",
               "tot": "str"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 800,
       "y": 140,
       "wires": [
               "f48be0e6.d432f",
               "c4574d9a.44f53",
               "f2909e1e.20a93"
       "id": "f48be0e6.d432f",
       "type": "debug",
       "name": "command",
       "active": true,
       "tosidebar": true,
       "console": false,
       "tostatus": false,
       "statusVal": "",
       "x": 1040,
       "y": 200,
       "wires": []
       "id": "c4574d9a.44f53",
       "type": "ioBroker out",
       "d": true,
       "name": "command",
       "topic": "mqtt.1.shellies.shellydimmer.light.0.command",
       "ack": "false",
       "autoCreate": "false",
       "stateName": "",
       "role": "",
       "payloadType": "",
       "readonly": "",
       "stateUnit": "",
       "stateMin": "",
       "stateMax": "",
       "x": 1040,
       "y": 140,
       "wires": []
       "id": "f2909e1e.20a93",
       "type": "change",
       "name": "",
       "rules": [
               "t": "change",
               "p": "payload",
               "pt": "msg",
               "from": "off",
               "fromt": "str",
               "to": "0",
               "tot": "num"
               "t": "change",
               "p": "payload",
               "pt": "msg",
               "from": "on",
               "fromt": "str",
               "to": "brightness",
               "tot": "flow"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 1050,
       "y": 80,
       "wires": [
               "6d903925.3ff818"
       "id": "6d903925.3ff818",
       "d": true,
       "name": "brightness",
       "topic": "0_userdata.0.dimmer.brightness",
       "ack": "true",
       "stateName": "",
       "role": "",
       "payloadType": "",
       "readonly": "",
       "stateUnit": "",
       "stateMin": "",
       "stateMax": "",
       "x": 1240,
       "y": 80,
       "wires": []
       "id": "88d6e66a.ddb258",
       "type": "inject",
       "name": "",
       "props": [
               "p": "payload"
       "repeat": "",
       "crontab": "",
       "once": true,
       "onceDelay": 0.1,
       "topic": "",
       "payload": "false",
       "payloadType": "bool",
       "x": 110,
       "y": 720,
       "wires": [
               "e9fb15f5.98b588"
       "id": "e9fb15f5.98b588",
       "type": "change",
       "name": "",
       "rules": [
               "t": "set",
               "p": "down",
               "pt": "flow",
               "to": "payload",
               "tot": "msg"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 290,
       "y": 720,
       "wires": [
       "id": "c5e2ef2d.6e447",
       "type": "switch",
       "name": "",
       "rules": [
               "t": "istype",
               "v": "boolean",
               "vt": "boolean"
               "t": "istype",
               "v": "number",
               "vt": "number"
       "checkall": "true",
       "repair": false,
       "outputs": 2,
       "x": 810,
       "y": 300,
       "wires": [
               "ca4f99bd.cfa6f8"
               "ff1bde73.7c88"
       "id": "ca4f99bd.cfa6f8",
       "type": "change",
       "name": "",
       "rules": [
               "t": "set",
               "p": "payload",
               "pt": "msg",
               "to": "brightness",
               "tot": "flow"
               "t": "change",
               "p": "payload",
               "pt": "msg",
               "from": "100",
               "fromt": "num",
               "to": "98",
               "tot": "num"
               "t": "change",
               "p": "payload",
               "pt": "msg",
               "from": "0",
               "fromt": "num",
               "to": "2",
               "tot": "num"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 1020,
       "y": 240,
       "wires": [
               "c5e2ef2d.6e447"
       "id": "ff1bde73.7c88",
       "type": "switch",
       "name": "brightness zwischen 2 und 98",
       "rules": [
               "t": "btwn",
               "v": "2",
               "vt": "num",
               "v2": "98",
               "v2t": "num"
       "checkall": "true",
       "repair": false,
       "outputs": 1,
       "x": 1050,
       "y": 320,
       "wires": [
               "4f962993.612978"
       "id": "4f962993.612978",
       "type": "switch",
       "name": "",
       "property": "down",
       "propertyType": "flow",
       "rules": [
               "t": "true"
               "t": "false"
       "checkall": "true",
       "repair": false,
       "outputs": 2,
       "x": 1270,
       "y": 320,
       "wires": [
               "ece0bc1e.1d06c"
               "a0118b8f.a7ca18"
       "id": "ece0bc1e.1d06c",
       "type": "change",
       "name": "Verringere Brightness um 2",
       "rules": [
               "t": "set",
               "p": "payload",
               "pt": "msg",
               "to": "payload - 2",
               "tot": "jsonata"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 1510,
       "y": 280,
       "wires": [
               "71a8a0f2.c1756"
       "id": "a0118b8f.a7ca18",
       "type": "change",
       "name": "Erhöhe Brightness um 2",
       "rules": [
               "t": "set",
               "p": "payload",
               "pt": "msg",
               "to": "payload + 2",
               "tot": "jsonata"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 1500,
       "y": 340,
       "wires": [
               "71a8a0f2.c1756"
       "id": "71a8a0f2.c1756",
       "type": "switch",
       "name": "",
       "rules": [
               "t": "gt",
               "v": "98",
               "vt": "num"
               "t": "lt",
               "v": "2",
               "vt": "str"
               "t": "else"
       "checkall": "true",
       "repair": false,
       "outputs": 3,
       "x": 1740,
       "y": 300,
       "wires": [
               "879502b2.7de07"
               "f57bd65b.705688"
               "58308d21.de8e84"
       "id": "879502b2.7de07",
       "type": "change",
       "name": "= 100",
       "rules": [
               "t": "set",
               "p": "payload",
               "pt": "msg",
               "to": "100",
               "tot": "num"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 1900,
       "y": 260,
       "wires": [
               "58308d21.de8e84"
       "id": "f57bd65b.705688",
       "type": "change",
       "name": "= 0",
       "rules": [
               "t": "set",
               "p": "payload",
               "pt": "msg",
               "to": "0",
               "tot": "num"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 1900,
       "y": 300,
       "wires": [
               "58308d21.de8e84"
       "id": "58308d21.de8e84",
       "type": "change",
       "name": "Update flow.brightness",
       "rules": [
               "t": "set",
               "p": "brightness",
               "pt": "flow",
               "to": "payload",
               "tot": "msg"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 2120,
       "y": 340,
       "wires": [
               "33d29b3d.a84344",
               "fb67d520.bc8208"
       "id": "33d29b3d.a84344",
       "type": "rbe",
       "name": "",
       "func": "rbe",
       "gap": "",
       "start": "",
       "inout": "out",
       "septopics": true,
       "topi": "topic",
       "x": 2330,
       "y": 340,
       "wires": [
               "8ef3400d.e495",
               "d66fdb59.ee3d88"
       "id": "fb67d520.bc8208",
       "type": "trigger",
       "name": "",
       "op1": "",
       "op2": "true",
       "op1type": "nul",
       "op2type": "bool",
       "duration": "1",
       "extend": true,
       "units": "s",
       "reset": "",
       "bytopic": "all",
       "topic": "topic",
       "outputs": 1,
       "x": 2350,
       "y": 420,
       "wires": [
               "1110ff6a.6c0661"
       "id": "1110ff6a.6c0661",
       "type": "change",
       "name": "",
       "rules": [
               "t": "set",
               "p": "down",
               "pt": "flow",
               "to": "$not($flowContext('down'))\t",
               "tot": "jsonata"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 2550,
       "y": 420,
       "wires": [
       "id": "8ef3400d.e495",
       "d": true,
       "ack": "false",
       "stateName": "",
       "role": "",
       "payloadType": "",
       "readonly": "",
       "stateUnit": "",
       "stateMin": "",
       "stateMax": "",
       "x": 2510,
       "y": 340,
       "wires": []
       "id": "b2d86076.b0a04",
       "type": "change",
       "name": "",
       "rules": [
               "t": "move",
               "p": "payload",
               "pt": "msg",
               "to": "brightness",
               "tot": "msg"
               "t": "set",
               "p": "payload",
               "pt": "msg",
               "to": "{\"brightness\":70,\"turn\":\"on\"}",
               "tot": "json"
               "t": "move",
               "p": "brightness",
               "pt": "msg",
               "tot": "msg"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 2680,
       "y": 280,
       "wires": [
               "3fe9eb1.ff60414"
       "id": "d66fdb59.ee3d88",
       "type": "switch",
       "name": "",
       "rules": [
               "t": "eq",
               "v": "0",
               "vt": "num"
               "t": "gt",
               "v": "0",
               "vt": "num"
       "checkall": "true",
       "repair": false,
       "outputs": 2,
       "x": 2490,
       "y": 260,
       "wires": [
               "b3cabeb1.02f96"
               "b2d86076.b0a04"
       "id": "b3cabeb1.02f96",
       "type": "change",
       "name": "",
       "rules": [
               "t": "set",
               "p": "payload",
               "pt": "msg",
               "to": "{\"brightness\":0,\"turn\":\"off\"}",
               "tot": "json"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 2690,
       "y": 240,
       "wires": [
               "3fe9eb1.ff60414"
       "id": "3fe9eb1.ff60414",
       "type": "json",
       "name": "",
       "action": "",
       "pretty": false,
       "x": 2890,
       "y": 260,
       "wires": [
               "583ee091.d82b2"
       "id": "583ee091.d82b2",
       "d": true,
       "name": "",
       "topic": "mqtt.1.shellies.light.0.set",
       "ack": "false",
       "stateName": "",
       "role": "",
       "payloadType": "",
       "readonly": "",
       "stateUnit": "",
       "stateMin": "",
       "stateMax": "",
       "x": 3110,
       "y": 260,
       "wires": []
       "id": "98936af7.b84158",
       "d": true,
       "name": "taster",
       "attrname": "",
       "onlyack": "",
       "func": "rbe",
       "gap": "",
       "x": 130,
       "y": 220,
       "wires": [
               "9982d6c4.29e058"
       "id": "af96a9a1.7e48c8",
       "type": "change",
       "name": "",
       "rules": [
               "t": "move",
               "p": "payload",
               "pt": "msg",
               "to": "status",
               "tot": "msg"
               "t": "change",
               "p": "status.ison",
               "pt": "msg",
               "from": "false",
               "fromt": "bool",
               "to": "0",
               "tot": "num"
               "t": "change",
               "p": "status.ison",
               "pt": "msg",
               "from": "true",
               "fromt": "bool",
               "to": "status.brightness",
               "tot": "msg"
               "t": "set",
               "p": "payload",
               "pt": "msg",
               "to": "status.ison",
               "tot": "msg"
               "t": "delete",
               "p": "status",
               "pt": "msg"
       "action": "",
       "property": "",
       "from": "",
       "to": "",
       "reg": false,
       "x": 460,
       "y": 580,
       "wires": [
               "c281079b.e9e728"
       "id": "c281079b.e9e728",
       "d": true,
       "ack": "false",
       "stateName": "",
       "role": "",
       "payloadType": "",
       "readonly": "",
       "stateUnit": "",
       "stateMin": "",
       "stateMax": "",
       "x": 670,
       "y": 580,
       "wires": []
       "id": "b9b257e.70ef5a8",
       "type": "ui_template",
       "group": "57f13d6f733e5c9d",
       "name": "momentary",
       "order": 17,
       "width": 3,
       "height": 1,
       "format": "<style>\n.nr-dashboard-template {\n    padding: 0px;\n}\n</style>\n<div class=\"momentary_1\">\n   <md-button style=\"width:100%; height:48px; margin: 0px; background-color: var(--nr-dashboard-widgetBackgroundColor); padding-top: 10px;\" ><i class=\"fa fa-lightbulb-o fa-2x\"> </i></md-button>\n</div>\n\n<script>\n\n(function($scope) {\n\n$('.momentary_1').on('touchstart mousedown', function(e) {\n   // e.preventDefault(); //prevent default behavior\n   $scope.send({\"payload\": true});\n});\n\n$('.momentary_1').on('touchend mouseup', function(e) {\n    // e.preventDefault(); //prevent default behavior\n    $scope.send({\"payload\": false});\n});\n    \n})(scope);\n</script>",
       "storeOutMessages": false,
       "fwdInMessages": true,
       "resendOnRefresh": false,
       "templateScope": "local",
       "className": "",
       "x": 130,
       "y": 160,
       "wires": [
               "16e2170a.87ef89",
               "9982d6c4.29e058"
       "id": "bd9be677d25dbd6b",
       "type": "inject",
       "name": "Test",
       "props": [
               "p": "payload"
       "repeat": "",
       "crontab": "",
       "once": false,
       "onceDelay": 0.1,
       "topic": "",
       "payload": "{\"ison\":false,\"brightness\":0}",
       "payloadType": "json",
       "x": 230,
       "y": 460,
       "wires": [
               "eeebcf13.9b2fd"
       "id": "57f13d6f733e5c9d",
       "type": "ui_group",
       "name": "Test",
       "tab": "20b3095113f94d70",
       "order": 1,
       "disp": true,
       "width": "6",
       "collapse": false,
       "className": ""
       "id": "20b3095113f94d70",
       "type": "ui_tab",
       "name": "Home",
       "icon": "dashboard",
       "order": 2,
       "disabled": false,
       "hidden": false
