    4. Test Adapter Hoover hON
      astrakid @e-i-k-e last edited by
      ich habe nun einne bakcofen, der ebenfalls über hOn gesteuert wird. der aufbau der objekte ist analog zu dem einer waschmaschine. da ich gerne einzelne parameter über iobroker starten würde (die app zickt bei mir rum, so muss ich mich jeden tag neu anmelden, was mit komplexen passwörtern etwas nervig ist), wäre eine idee, verschiedene aufrufe zu sammeln ("remote -> send"), um darüber steuerungen für einzelne teile zusammenzubauen.
      ich fange einfach mal an:
        "macAddress": "id of the device set by adapter",
        "timestamp": "2022-05-10T08:16:35.010Z",
        "commandName": "startProgram",
        "programName": "PROGRAMS.TD.CARE_45",
        "transactionId": "2022-05-10T08:16:35.011Z",
        "applianceOptions": {
          "opt1": "anticrease",
          "opt2": "dryingManager",
          "opt3": "bestIroning",
          "opt4": "hybrid"
        "device": {
          "mobileOs": "ios",
          "mobileId": "2xxxxxx3-9xxE-4xx3-Axx8-1xxxxxxxxxx8",
          "osVersion": "15.5",
          "appVersion": "1.40.2",
          "deviceModel": "iPhone10,5"
        "attributes": {
          "prStr": "Care 45",
          "energyLabel": "0",
          "channel": "mobileApp",
          "origin": "lastProgram"
        "ancillaryParameters": {
          "dryTimeMM": "45",
          "energyLabel": "0",
          "functionalId": "8",
          "programFamily": "[dashboard]",
          "programRules": {
            "opt3": {
              "dryLevel": {
                "2|3|4": {
                  "fixedValue": "0",
                  "typology": "fixed"
            "dryTime": {
              "dryTimeMM": {
                "30": {
                  "fixedValue": "1",
                  "typology": "fixed"
                "45": {
                  "fixedValue": "2",
                  "typology": "fixed"
                "59": {
                  "fixedValue": "3",
                  "typology": "fixed"
                "70": {
                  "fixedValue": "4",
                  "typology": "fixed"
                "80": {
                  "fixedValue": "5",
                  "typology": "fixed"
                "90": {
                  "fixedValue": "6",
                  "typology": "fixed"
                "100": {
                  "fixedValue": "7",
                  "typology": "fixed"
                "110": {
                  "fixedValue": "8",
                  "typology": "fixed"
                "120": {
                  "fixedValue": "9",
                  "typology": "fixed"
                "130": {
                  "fixedValue": "10",
                  "typology": "fixed"
                "140": {
                  "fixedValue": "11",
                  "typology": "fixed"
                "150": {
                  "fixedValue": "12",
                  "typology": "fixed"
                "160": {
                  "fixedValue": "13",
                  "typology": "fixed"
                "170": {
                  "fixedValue": "14",
                  "typology": "fixed"
                "180": {
                  "fixedValue": "15",
                  "typology": "fixed"
                "190": {
                  "fixedValue": "16",
                  "typology": "fixed"
                "200": {
                  "fixedValue": "17",
                  "typology": "fixed"
                "210": {
                  "fixedValue": "18",
                  "typology": "fixed"
                "220": {
                  "fixedValue": "19",
                  "typology": "fixed"
            "dryLevel": {
              "opt3": {
                "1": {
                  "fixedValue": "1",
                  "typology": "fixed"
          "remoteActionable": "1",
          "remoteVisible": "1",
          "suggestedLoadD": "2"
        "parameters": {
          "dryTime": "2",
          "dryingManager": "0",
          "hybrid": "1",
          "checkUpStatus": "0",
          "anticrease": "0",
          "delayTime": "0",
          "prCode": "54",
          "prPosition": "13",
          "dryLevel": "0",
          "bestIroning": "0",
          "onOffStatus": "1"
        "applianceType": "TD"
        astrakid @Guest last edited by
        @dp20eic sagte in Test Adapter Hoover hON:
        @astrakid sagte in Test Adapter Hoover hON:
        Wie kann ich einen Waschvorgang pausieren und wieder fortsetzen? In der App gibt es die Funktion, im Adapter habe ich den Datenpunkt noch nicht gefunden auf die Schnelle...
        schon mal in ioBroker unter Objekte in die Suche pause eingegeben?
        ich habe keine entsprechenden datenpunkte... nur einen aus der history...?!
          astrakid @astrakid last edited by
          hi,
          ich bekomme neuerdings folgende fehlermeldung:
          AxiosError: Request failed with status code 301
          die app scheint nicht mehr zu funktionieren bei mir. neue URLs?
          ? 1 Reply Last reply Reply Quote 1
            A Former User @astrakid last edited by
            Moin,
            bei mir auch, in zwei Installationen, habe ein issues aufgemacht.
            https://github.com/TA2k/ioBroker.hoover/issues/9
            VG
            Bernd
            dp20eic created this issue in TA2k/ioBroker.hoover
            open the adapter is not able to connect to hoover/hOn Server anymore #9
              tombox last edited by
              @astrakid bitte 0.1.0 testen
              ? A 3 Replies Last reply Reply Quote 0
                A Former User @tombox last edited by
                @tombox sagte in Test Adapter Hoover hON:
                Moin,
                nop, siehe neue Logs bei Github.
                VG
                Bernd
                • Palm_Maniac
                  Palm_Maniac last edited by
                  Der Fehler 301 tritt bei mir seit dem Update auf V0.1.0 auch auf. Nutze die Hoover Schnittstelle.
                    astrakid @tombox last edited by
                    @tombox wie bei meinen vorschreibern: klappt nicht.
                      Moin,
                      auf Anraten von @tombox habe ich die Version nochmals über github installiert
                      Anschließend wurde der Adapter gelb und die Fehlermeldung tauchte wieder im Log auf, siehe Github
                      Ich habe anschließend noch ein Upload aus ioBroker heraus angestoßen, danach ein Restart des Adapters und er wurde wieder Grün 🙂
                      Upload, z.B.: so:
                      VG
                      Bernd
                      Palm_Maniac 1 Reply Last reply Reply Quote 0
                      • Palm_Maniac
                        Palm_Maniac @Guest last edited by Palm_Maniac
                        @dp20eic Ich habs mal nach deiner Anleitung versucht, brachte aber nichts. Der Adapter bleibt gelb und im Log steht weiterhin Fehlercode 301.
                        PS: Jetzt läuft auch die Vorgängerversion V0.0.7 nicht mehr, die vor dem Update perfekt funktionierte. Das hier steht im Log:
                        hoover.0 2023-06-06 16:01:03.789	error	""
                        hoover.0 2023-06-06 16:01:03.788	error	AxiosError: Request failed with status code 301
                          A Former User @Palm_Maniac last edited by
                          @palm_maniac sagte in Test Adapter Hoover hON:
                          Moin,
                          das ist seltsam, in beiden ioBroker Installationen, die ich betreibe, hat es genau so funktioniert 🤔
                          Hast Du mal mit einer zweiten Instanz versucht, ist das Passwort auch wirklich korrekt?
                          VG
                          Bernd
                          Installation debian:
                          Installation arch linux
                          • Palm_Maniac
                            @dp20eic Die Zugangsdaten funktionieren in der App. Hab gerade mal ne neue Instanz versucht mit dem gleichen Ergebnis und Fehlercode. Alles erst seit dem Update von V0.0.7 auf V0.1.0.
                              Moin,
                              ah, da könnte der Hund auch noch begraben liegen.
                              Bei mir ist es die hOn-APP bei Dir auch?
                              VG
                              Bernd
                              P.S.: Sollte es bei Dir der Hoover-Wiz sein, dann musst Du mal bei Github bei meinem Issues Deine Daten mit anhängen, sodass @tombox sich das anschauen kann, vielleicht haben sich die Logins der beiden APPs verändert und sind nicht mehr kompatibel.
                              • Palm_Maniac
                                @dp20eic ja, ich nutze den Hover-Wizard Zugang, nicht hON. Hab mich mal an den Issue in Github rangehängt.
                                  tombox @Palm_Maniac last edited by
                                  @palm_maniac für hover wizard brauch ich nochmal Zugangsdaten um das zu fixen
                                  Palm_Maniac sigi234 2 Replies Last reply Reply Quote 0
                                  • Palm_Maniac
                                    Palm_Maniac @tombox last edited by
                                    @tombox Hab dir ne PN geschickt.
                                      sigi234 Forum Testing Most Active @tombox last edited by sigi234
                                      Hallo, geht bei mir auch nicht? [hover wizard]
                                      hoover.0
                                      2023-06-14 20:55:22.986	info	starting login
                                      hoover.0
                                      2023-06-14 20:55:22.975	info	starting. Version 0.1.1 (non-npm: TA2k/ioBroker.hoover#7deb12caf1e561fde36b85d4a8afd7016896095e) in C:/ioBroker/_iob_Test/node_modules/iobroker.hoover, node: v18.16.0, js-controller: 4.0.24
                                      hoover.0
                                      2023-06-14 20:55:23.746	error	AxiosError: Unsupported protocol javascript:
                                      hoover.0
                                      2023-06-14 20:55:23.746	error	Login step #3 failed
                                      Version: 0.1.1
                                        Dave83 @astrakid last edited by
                                        @astrakid said in Test Adapter Hoover hON:
                                        Hast du es erfolgreich schaffen können, deine Waschmaschine mit ioBroker zu automatisieren? Ich denke gerade darüber nach, ebenfalls dort ein Model zu kaufen. Preislich sind die sehr attraktiv. Über deine Rückmeldung würde ich mich freuen.
                                        Insgesamt, ist es schwierig, eine smarte Waschmaschine mit Unterstützung für ioBroker zu finden.
                                          astrakid @Dave83 last edited by
                                          @dave83 nein. momentan kann ich den adapter nur als monitor benutzen.
                                            CarpeNoctem last edited by
                                            Juhu es geht !
                                            Ich habe heute auf den Adapter 0.1.1 gewechselt.
                                            Im ersten Moment erfolglos.
                                            Danach lies es mir keine Ruhe und ich habe ein anderes Passwort gewählt, seither sind die Fehlermeldungen weg und ich sehe mein Gerät.
                                            Vermutlich lag es an der Länge oder den Sonderzeichen.
                                            Hoffe ich kann damit dem/der ein oder anderen helfen.
                                            CarpeNoctem
                                            31.7k
                                            79.8k
                                            184
                                            18914
