    4. Daikin Cloud Adapter nodejs18 [gelöst]
      Thomas Braun Most Active @Elektroniker86 last edited by
      @elektroniker86
      Hat deine Maus kein Scrollrad? Dann kann man da durch scrollen.
      Elektroniker86 1 Reply Last reply Reply Quote 0
        @elektroniker86
        cd /opt/iobroker && npm prune && npm ls
        • Elektroniker86
          Elektroniker86 @Thomas Braun last edited by
          Na klar, jedoch sagt das Forum das es zu groß ist und kann es hier nicht abschicken.
            @elektroniker86
            prune das. Siehe oben.
            • Elektroniker86
              iobroker@iobroker:~$ cd /opt/iobroker && npm prune && npm ls
              npm ERR! code EBADENGINE
              npm ERR! engine Unsupported engine
              npm ERR! engine Not compatible with your version of node/npm: iobroker.daikin-cloud@0.2.3
              npm ERR! notsup Not compatible with your version of node/npm: iobroker.daikin-cloud@0.2.3
              npm ERR! notsup Required: {"node":"^12.19.0 || ^14.15.0 || ^16.13.0"}
              npm ERR! notsup Actual:   {"npm":"9.5.1","node":"v18.16.0"}
              npm ERR!     /home/iobroker/.npm/_logs/2023-06-07T07_42_42_607Z-debug-0.log
              iobroker@iobroker:/opt/iobroker$
                @elektroniker86 sagte in Daikin Cloud Adapter nodejs18 [gelöst]:
                Lösch den Adapter iobroker.daikin-cloud mal komplett. Und dann eine direkte Installation via GitHub.
                • Elektroniker86
                  $ iobroker del daikin-cloud --debug
                  host.iobroker Counted 87 states (io.daikin-cloud.*) from states
                  host.iobroker Counted 16 states (system.adapter.daikin-cloud.*) from states
                  host.iobroker Counted 21 objects of daikin-cloud
                  host.iobroker file daikin-cloud.admin deleted
                  host.iobroker Deleting 168 object(s).
                  host.iobroker Deleting 103 state(s).
                  removed 889 packages in 4s
                  150 packages are looking for funding run `npm fund` for details
                  Process exited with code 0
                  $ iobroker url Apollon77/ioBroker.daikin-cloud --host iobroker --debug
                  NPM version: 9.5.1Installing Apollon77/ioBroker.daikin-cloud... (System call)
                  upload [6] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/admin.d.ts admin.d.ts video/mp2t
                  upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
                    @elektroniker86
                    Sollte jetzt passsen.
                    iobroker update
                    sagt?
                    • Elektroniker86
                      Elektroniker86 @Thomas Braun last edited by Elektroniker86
                      @thomas-braun sagte in Daikin Cloud Adapter nodejs18 [gelöst]:
                      iobroker update
                      iobroker@iobroker:~$ iobroker update
                      Used repository: Stable (default)
                      Adapter    "admin"        : 6.3.5    , installed 6.3.5
                      Adapter    "alarm"        : 3.3.11   , installed 3.3.11
                      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                      Adapter    "backitup"     : 2.6.19   , installed 2.6.19
                      Adapter    "canbus"       : 1.3.1    , installed 1.3.1
                      Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                      Adapter    "daikin-cloud" : 0.2.3    , installed 0.2.3
                      Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                      Adapter    "ical"         : 1.13.2   , installed 1.13.2
                      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                      Adapter    "info"         : 1.9.26   , installed 1.9.26
                      Adapter    "iot"          : 1.14.2   , installed 1.14.2
                      Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
                      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                      Controller "js-controller": 4.0.24   , installed 4.0.24
                      Adapter    "linux-control": 1.1.3    , installed 1.1.3
                      Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
                      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                      Adapter    "ping"         : 1.5.3    , installed 1.5.3
                      Adapter    "pixelit"      : 0.2.0    , installed 0.2.0
                      Adapter    "s7"           : 1.3.14   , installed 1.3.14
                      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                      Adapter    "sonos"        : 2.2.3    , installed 2.2.3
                      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                      Adapter    "tuya"         : 3.13.1   , installed 3.13.1
                      Adapter    "unifi"        : 0.5.10   , installed 0.6.3
                      Adapter    "vis"          : 1.4.16   , installed 1.4.16
                      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                      Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
                      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                      Adapter    "wled"         : 0.6.7    , installed 0.6.7
                      Was ist jetzt mit dem openid.client ? Muss ich das jetzt noch updaten ? Oder was muss ich machen damit das in zukunft nicht mehr passiert?
                      Eine Instanz lässt sich nicht hinzufügen:
                        Das ist eine Dependency vom daikin-cloud und kommt mit dem zusammen auf das System. Kannste mit
                        cd /opt/iobroker && npm ls openid-client
                        prüfen.
                          Mach es über die Kommandozeile...
                          GUIs nerven.
                          • Elektroniker86
                            Das passt jetzt nehm ich mal an....
                            iobroker@iobroker:~$ cd /opt/iobroker && npm ls openid-client
                            iobroker.inst@3.0.0 /opt/iobroker
                            └─┬ iobroker.daikin-cloud@0.2.3 (git+ssh://git@github.com/Apollon77/ioBroker.daikin-cloud.git#03b831dac009b1d9cd0a7399f7e9a38486d06d19)
                              └─┬ daikin-controller-cloud@1.0.4
                                └── openid-client@5.4.2
                            Welchen Befehl muss ich für die Instanzinstallation ausführen?
                              Thomas Braun Most Active @Elektroniker86 last edited by Thomas Braun
                              @elektroniker86
                              iobroker add daikin-cloud
                              Elektroniker86 1 Reply Last reply Reply Quote 1
                                @elektroniker86
                                Da ist doch auch noch ein anderer Host im Spiel? Ist dessen npm tree auch so strubbelig?
                                • Elektroniker86
                                  Super hat geklappt! Vielen Dank für deine schnelle Hilfe.
                                  Ich bin gelernter Elektroniker und bin Linux technisch leider nicht so affin.
                                  Aber man lernt immer ein bisschen was dazu.
                                  Nochmals DANKE!
                                    @elektroniker86
                                    War doch kaum 'Linuxisch', nur 'iobrokerisch' und ein paar Brocken 'npm'.
                                    • Elektroniker86
                                      Keine Ahnung ? Wie sehe ich das ? Laut GUI passt alles/ kann keine Fehler feststellen. Auf dem 2. Host habe ich nur ein Adapter laufen für meine Wärmepumpe (CANbus)
                                        @elektroniker86
                                        Auf dem 2. Host einloggen und
                                        anschauen. Oder per
                                        iob diag
                                        den etwas größeren Überblick verschaffen.
                                        • Elektroniker86
                                          @elektroniker86
                                          Schon, aber ohne Linux Basics ist das schon ziemlich komplex. Ich kann linux nur die Basic Befehle zum updaten der Maschine und das wars schon. Beim Rest muss ich immer lesen und Anleitungen anschauen. Bin froh das hier Leute sind die einem bei sowas helfen ich hätte das nie und nimmer hin bekommen. Da ich nicht weiß wonach ich suchen soll.....
                                            🙂 Anleitungen liest man besser...
                                            5312
