    4. Daikin Cloud Adapter nodejs18 [gelöst]
    • Elektroniker86
      Elektroniker86 @Thomas Braun last edited by Elektroniker86
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 3 Model B Plus Rev 1.3
      Architecture    : armv7l
      Docker          : false
      Virtualization  : none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       10:10:13 up 2 days, 22:23,  1 user,  load average: 0.93, 0.81, 0.77
      CPU threads: 4
      Raspberry only:
      throttled=0x80008
      Other values than 0x0 hint to temperature/voltage problems
      temp=60.1'C
      volt=1.2625V
      *** Time and Time Zones ***
                     Local time: Wed 2023-06-07 10:10:13 CEST
                 Universal time: Wed 2023-06-07 08:10:13 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            921M        236M        440M        0.0K        244M        628M
      Swap:            99M          0B         99M
      Total:          1.0G        236M        540M
                921 M total memory
                237 M used memory
                153 M active memory
                264 M inactive memory
                440 M free memory
                 37 M buffer memory
                206 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       29G  3.5G   25G  13% /
      devtmpfs       devtmpfs  333M     0  333M   0% /dev
      tmpfs          tmpfs     461M     0  461M   0% /dev/shm
      tmpfs          tmpfs     185M  696K  184M   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
      sudo: unable to resolve host iobroker-slave-wp: Name or service not known
      [Sun Jun  4 11:46:35 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c1772fc4-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun Jun  4 11:46:38 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Jun  4 11:46:38 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun Jun  4 11:46:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      1.3G    /var/
      973M    /var/log
      969M    /var/log/journal/f100f43d07a54920922b8472f114b5d9
      107M    /var/cache
      Archived and active journals take up 968.2M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      3.7M    /opt/iobroker/iobroker-data/
      1.1M    /opt/iobroker/iobroker-data/files
      472K    /opt/iobroker/iobroker-data/files/discovery.admin
      384K    /opt/iobroker/iobroker-data/files/backitup.admin
      252K    /opt/iobroker/iobroker-data/files/admin.admin
      2.5M    /opt/iobroker/iobroker-data/objects.jsonl
      200K    /opt/iobroker/iobroker-data/files/discovery.admin/words.js
      148K    /opt/iobroker/iobroker-data/files/backitup.admin/words.js
      128K    /opt/iobroker/iobroker-data/states.jsonl
      120K    /opt/iobroker/iobroker-data/files/discovery.admin/index_m.html
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.0
      /usr/bin/node           v18.16.0
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
       *** 18.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.admin.1                  : admin                 : iobroker-slave-wp                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.canbus.0                 : canbus                : iobroker-slave-wp                        -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.1.240
      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1889, bind: 0.0.0.0
      + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
      + system.adapter.s7.1                     : s7                    : iobroker                                 -  enabled
      + system.adapter.s7.2                     : s7                    : iobroker                                 -  enabled
      + system.adapter.s7.3                     : s7                    : iobroker                                 -  enabled
      + system.adapter.s7.4                     : s7                    : iobroker                                 -  enabled
      + system.adapter.s7.5                     : s7                    : iobroker                                 -  enabled
      + system.adapter.s7.6                     : s7                    : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.1.240
      + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
      + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "backitup"     : 2.6.19   , installed 2.5.9  [Updatable]
      Adapter    "canbus"       : 1.3.1    , installed 1.3.1
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "tuya"         : 3.13.1   , installed 3.12.1 [Updatable]
      Objects and States
      Objects:        18779
      States:         12462
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12851      566/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16833      1052/io.admin.1
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12853      566/sshd: /usr/sbin
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14246      348/avahi-daemon: r
      udp        0      0 0.0.0.0:53596           0.0.0.0:*                           108        14248      348/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          600        683/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        14247      348/avahi-daemon: r
      udp6       0      0 :::57442                :::*                                108        14249      348/avahi-daemon: r
      2023-06-07 02:32:58.747  - info: host.iobroker-slave-wp Delete log file iobroker.2023-05-30.log.gz
      2023-06-07 07:38:35.973  - error: host.iobroker-slave-wp Invalid request getRepository. "callback" or "from" is null
      2023-06-07 07:42:32.860  - info: host.iobroker-slave-wp Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
      2023-06-07 09:53:08.279  - error: host.iobroker-slave-wp Invalid request getRepository. "callback" or "from" is null
      iob diag has finished.
      Press any key for a summary
      Hab jetzt gesehen das auf dem Host backitup und Tuya installiert ist. Kann ich das per kommandozeile deinstallieren? In der GUI geht das glaub garnicht.
        Thomas Braun Most Active @Elektroniker86 last edited by
        @elektroniker86 sagte in Daikin Cloud Adapter nodejs18 [gelöst]:
        throttled=0x80008
        temp=60.1'C
        volt=1.2625V
        Der Kiste wird wohl zu warm, die wird heruntergeregelt.
        Und eine admin-Instanz. Bei richtigen Setup eines Multihosts braucht es nur einen Admin.
        iobroker del admin.1 --host iobroker-slave-wp
        Der gibt mir mehr zu denken:
        Da stimmt was mit den sudo-Rechten nicht.
        Elektroniker86 1 Reply Last reply Reply Quote 0
        • Elektroniker86
          @thomas-braun sagte in Daikin Cloud Adapter nodejs18 [gelöst]:
          Das wusste ich auch nicht, wird auch soviel ich weiß in keiner Doku erwähnt.
          -> hab ich deinstalliert.
          Kann ich das andere zeug auch deinstallieren? Tuya und backitup ?
          Temperaturproblem werde ich noch angehen.
          Wie kann ich das lösen?
            Ich sehe da keine Instanzen auf dem Host.
            Schau dir die Gruppen der user auf dem Host an:
            groups
            sudo -u iobroker groups
            • Elektroniker86
              Ich dachte weil das hier steht ??
              pi@iobroker-slave-wp:~ $ groups
              sudo: Hostname iobroker-slave-wp kann nicht aufgelöst werden: Der Name oder der Dienst ist nicht bekannt
              iobroker tty dialout audio video bluetooth gpio i2c
                Hast du den Hostname iobroker-slave-wp mal nachträglich irgendwie angepasst? Das ist offenbar nicht vollständig/richtig gemacht worden.
                Die updatebaren Instanzen liegen auf dem Hauptsystem. Solltest du aber natürlich auch aktualisieren.
                • Elektroniker86
                  Ja, bei der Installation habe ich bei raspi-config den hostnamen geändert und bestätigt. Warum der da meckert weiß ich ehrlichgesagt nicht.
                  Hier zeigt er mir keine Updates an?
                    Das muss auch noch an anderen Stellen geändert werden. Müsste ich jetzt aber auch nachlesen, so oft mache ich das nicht.
                      Hatte ich nicht schon mal gesagt, das GUIs lügen?
                      iobroker update
                      sagt?
                      • Elektroniker86
                        ok, dann wird es daran liegen. Ich kenne nur die Option, das in dem config Menü vom Pi zu machen.
                          Homoran Global Moderator Administrators @Elektroniker86 last edited by
                          ...und anschließend die Änderung iobroker bekannt geben mit iobroker host this bevor iobroker neu gestartet wird.
                          • Elektroniker86
                            Ok, ich sehe keine Updates. Oder ich interpretiere da etwas falsch?
                            Auf dem Hauptsystem ausgeführt:
                            iobroker@iobroker:~$ iobroker update
                            Adapter    "alarm"        : 3.3.11   , installed 3.3.11
                            Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                            Adapter    "backitup"     : 2.6.19   , installed 2.6.19
                            Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                            Adapter    "daikin-cloud" : 0.2.3    , installed 0.2.3
                            Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                            Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                            Adapter    "ical"         : 1.13.2   , installed 1.13.2
                            Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                            Adapter    "info"         : 1.9.26   , installed 1.9.26
                            Adapter    "iot"          : 1.14.2   , installed 1.14.2
                            Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
                            Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                            Adapter    "linux-control": 1.1.3    , installed 1.1.3
                            Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
                            Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                            Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                            Adapter    "ping"         : 1.5.3    , installed 1.5.3
                            Adapter    "pixelit"      : 0.2.0    , installed 0.2.0
                            Adapter    "s7"           : 1.3.14   , installed 1.3.14
                            Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                            Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                            Adapter    "sonos"        : 2.2.3    , installed 2.2.3
                            Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                            Adapter    "tuya"         : 3.13.1   , installed 3.13.1
                            Adapter    "unifi"        : 0.5.10   , installed 0.6.3
                            Adapter    "vis"          : 1.4.16   , installed 1.4.16
                            Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                            Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
                            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                            Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                            Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                            Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                            Adapter    "wled"         : 0.6.7    , installed 0.6.7
                            • Elektroniker86
                              Elektroniker86 @Homoran last edited by
                              @homoran sagte in Daikin Cloud Adapter nodejs18 [gelöst]:
                              iobroker host this
                              Läuft nicht so?
                              pi@iobroker-slave-wp:~ $ iobroker host this
                              Cannot execute changes on running system. Stop iobroker first.
                              pi@iobroker-slave-wp:~ $ iob stop
                                @elektroniker86 was sagt iobroker status?
                                • Elektroniker86
                                  Elektroniker86 @Homoran last edited by Elektroniker86
                                  Ich bin ein wenig verwirrt über die Ausgabe ....
                                  pi@iobroker-slave-wp:~ $ sudo iobroker status
                                  iobroker is not running on this host.
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects type: jsonl
                                  States  type: jsonl
                                  pi@iobroker-slave-wp:~ $ sudo iobroker stop
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Er sagt das ich iobroker erst stoppen soll obwohl der Dienst gestoppt ist im Webif sehe ich auch das der Host nicht läuft.
                                  sudo: Hostname iobroker-slave kann nicht aufgelöst werden: Der Name oder der Dienst ist nicht bekannt
                                    @elektroniker86
                                    Niemals das Kommando iobroker zusammen mit sudo ausführen.
                                    cat /etc/hosts
                                    sagt?
                                    • Elektroniker86
                                      cat /etc/hosts
                                      pi@iobroker-slave-wp:~ $ cat /etc/hosts
                                      127.0.0.1       localhost
                                      ::1             localhost ip6-localhost ip6-loopback
                                      ff02::1         ip6-allnodes
                                      ff02::2         ip6-allrouters
                                      127.0.1.1       ioBroker slave
                                        Da liegt der Hund begraben. Da muss
                                        127.0.1.1       iobroker-slave-wp
                                        rein. Nach der Änderung einmal das Netzwerk neustarten, alternativ den ganzen Rechner.
                                        • Elektroniker86
                                          Ok, dann muss ich das mit Sicherheit irgendwo in einer config Datei mit nano ändern?
                                            normal nicht!
                                            Da scheint aber einiges bei dir verbogen zu sein.
                                            4958
