    4. Test Adapter Awtrix-Light (Awtrix 3)
    • Elektroniker86
      Elektroniker86 @Thomas Braun last edited by
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.0
      /usr/bin/node           v18.16.0
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
       *** 18.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.9~dfsg-1ubuntu3 500
              500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.admin.1                  : admin                 : iobroker-slave-wp                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.canbus.0                 : canbus                : iobroker-slave-wp                        -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 - disabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.1.240
      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1889, bind: 0.0.0.0
      + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
      + system.adapter.s7.1                     : s7                    : iobroker                                 -  enabled
      + system.adapter.s7.2                     : s7                    : iobroker                                 -  enabled
      + system.adapter.s7.3                     : s7                    : iobroker                                 -  enabled
      + system.adapter.s7.4                     : s7                    : iobroker                                 -  enabled
      + system.adapter.s7.5                     : s7                    : iobroker                                 -  enabled
      + system.adapter.s7.6                     : s7                    : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.1.240
      + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
      + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      + instance is alive
      Möchtest du noch etwas sehen?
        Thomas Braun Most Active @Elektroniker86 last edited by
        @elektroniker86
        daikin-cloud aktualisieren.
        Elektroniker86 1 Reply Last reply Reply Quote 1
        • Elektroniker86
          Alles klar, ich habe es gerade bemerkt das der daikin.cloud Probleme macht und nicht läuft.
          Da gibts auch ein Thread dazu. So wie ich sehe muss ich den auch von Github aus updaten da wäre er für Nodejs 18 angepasst.
          Danke für deine Hilfe!!!
            @elektroniker86
            Ja, ist nur im GitHub gefixt im Moment:
            https://github.com/Apollon77/ioBroker.daikin-cloud/commit/4eff1929cbddfeeadd4d45e6a04ea285c7f48f4b
            0 Apollon77 committed to Apollon77/ioBroker.daikin-cloud
            * update deps
              peer69 Forum Testing last edited by
              Wenn die Uhr nicht erreichbar ist (ausgeschaltet, WLAN verloren, Akku leer), wird alle 2 Sekunden ein Log-Entry geschrieben. Kann man den Adapter vielleicht weniger gesprächig gestalten? Ein Eintrag als Warn oder Error, wenn das Gerät nicht mehr gefunden wird ist sicher gut, alle 2 Sekunden scheint mir aber übertrieben :).
              awtrix-light.0
              2023-06-07 09:30:18.004	error	Unable to perform action for 0_userdata.0.PV-Anlage.0_Hausverbrauch - API is not connected (device not reachable?)
              awtrix-light.0
              2023-06-07 09:30:16.002	error	Unable to perform action for 0_userdata.0.PV-Anlage.0_Hausverbrauch - API is not connected (device not reachable?)
              awtrix-light.0
              2023-06-07 09:30:14.001	error	Unable to perform action for 0_userdata.0.PV-Anlage.0_Hausverbrauch - API is not connected (device not reachable?)
              awtrix-light.0
              2023-06-07 09:30:12.003	error	Unable to perform action for 0_userdata.0.PV-Anlage.0_Hausverbrauch - API is not connected (device not reachable?)
              awtrix-light.0
              2023-06-07 09:30:10.002	error	Unable to perform action for 0_userdata.0.PV-Anlage.0_Hausverbrauch - API is not connected (device not reachable?)
              awtrix-light.0
              2023-06-07 09:30:08.002	error	Unable to perform action for 0_userdata.0.PV-Anlage.0_Hausverbrauch - API is not connected (device not reachable?)
              awtrix-light.0
              2023-06-07 09:30:06.004	error	Unable to perform action for 0_userdata.0.PV-Anlage.0_Hausverbrauch - API is not connected (device not reachable?)
                arteck Developer Most Active @peer69 last edited by
                @peer69 garnicht aufgefallen... würder eher sagen als error object im tree
                würde reichen.. im log evtl. als warning..
                  pfeiferj12 @haus-automatisierung last edited by pfeiferj12
                  @haus-automatisierung Hallo, hab eben auf 0.0.10 aktualisert und kann jetzt aber keine Änderungen mehr bei den Custom Apps speichern:
                  Hat jemand einen Tip für mich?
                  • U
                    umichel last edited by
                    So ... meine Ulanzi ist auch gestern gekommen.
                    Vielleicht noch ein paar Tips zum Flashen und der Firmware:
                    1. Unter Windows ist ein Treiber nötig (Link dazu gab es hier schon)
                    2. USB Datenkabel verwenden (das mitgelieferte fuktionierte bei mir dafür nicht)
                    3. USB Kabel in eine USB Port auf dem Motherboard (bei mir funktionierte ein Front-USB Port am Gehäude nicht)
                    4. Firmware Update geht über das Gerät selbst (Menütaste halten und die Option Update auswählen)
                    Jetzt aber zum Adpater:
                    Bisher habe ich MQTT nur über die Sonoff Adapter genutzt.
                    Dazu brauchte ich keinne zusätzlichen MQTT Broker Adapter oder ähnliches.
                    Jetzt habe ich den Adpater von Matthias installiert und erscheint lediglich ein leerer admin Eintrag unter Objekte.
                    Keine Instanz ... nichts.
                    Gibt es irgendwelche voraussetzungen für den awtrix Adapter?
                    Und wie muss ich in der Firmware MQTT konfigurieren?
                    LG
                      holgerwolf @pfeiferj12 last edited by
                      @pfeiferj12 Schreib die App Namen mal in kleinen Buchstaben
                        cacherwolf @umichel last edited by cacherwolf
                        @umichel
                        Du brauchst den MQTT Broker/Client Adapter und den dann als Server/Broker einrichten.
                        Die Werte aus dem Adapter dann unter MQTT in der AWTRIX eintragen.
                          pfeiferj12 @holgerwolf last edited by
                          @holgerwolf Hey Danke für den Tip. Das war je einfach und hat funktioniert! Kannst du mir den Grund sagen warum Großschreibung das Problem macht??
                          Thomas Braun haus-automatisierung 2 Replies Last reply Reply Quote 0
                            Thomas Braun Most Active @pfeiferj12 last edited by
                            @pfeiferj12 sagte in Test Adapter Awtrix-Light:
                            Weil Pfade unter Linux eigentlich grundsätzlich kleingeschrieben werden. Und keine Sonderzeichen enthalten.
                            P 1 Reply Last reply Reply Quote 2
                              pfeiferj12 @Thomas Braun last edited by
                              @thomas-braun said in Test Adapter Awtrix-Light:
                              • haus-automatisierung
                                haus-automatisierung Developer Most Active @pfeiferj12 last edited by haus-automatisierung
                                Du kannst ja gerne alle Zeichen für Appnamen testen und sagen was funktioniert. Dann passe ich den RexEx für die Validierung an. Ich habe z.B. nicht getestet ob die case sensitive sind auf der Uhr. Also ob test und Test die gleiche App anspricht oder ob es zwei verschiedene sind.
                                Also habe ich es mir einfach gemacht und möglichst alles ausgeschlossen - außer Kleinbuchstaben. Bietet ja auch keinen Mehrwert dort Großbuchstaben und Sonderzeichen zu verwenden.
                                  @haus-automatisierung said in Test Adapter Awtrix-Light:
                                  Ist ja völlig o.k. so wie es ist. Ich brauche keine Großbuchstaben hab nur den Zusammenhang mit meinem Probelm nicht erkannt. Ich hatte in der Version 0.0.9 die Custom Apps mit Großbuchstaben konfiguriert und es hat alles funktioniert. Heute Morgen dann der update auf 0.0.10 und wollte eigentlich nur den Haken für "Unbekannte Apps automatisch löschen" setzen konnte aber nicht speichern.....
                                  • Elektroniker86
                                    Elektroniker86 last edited by Elektroniker86
                                    Habe eine Custom App hinzugefügt.
                                    Aktueller PV Bezug (kaufen) Bei mir momentan 0W.
                                    Angezeigt wird leider nur "W" die 0 fehlt.
                                      haus-automatisierung Developer Most Active @Elektroniker86 last edited by haus-automatisierung
                                      @elektroniker86 sagte in Test Adapter Awtrix-Light:
                                      Ah das habe ich nicht bedacht. Danke!
                                      EDIT: Fixed
                                        cacherwolf last edited by
                                        Bei mir wird jetzt auf einmal ein Komma statt eines Punkt angezeigt, ist das gewollt?IMG_20230607_161819[1].jpg
                                        • Ben1983
                                          Ben1983 last edited by
                                          @haus-automatisierung Könnte man die 5s updatezeit einstellbar machen?
                                          Ps. sollte wirklich im Log (debug) immer jede aktualisierung als "zu früh" geloggt werden?`
                                          Ps. hast Du meinen früheren Post gesehen, dass es den Wert doppelt geupdaten hatte ? Jedes 2. mal.
                                            MCU last edited by
                                            Man kann auch Kurven und Bars darstellen:
                                            Ben1983 haus-automatisierung 2 Replies Last reply Reply Quote 0
                                            81.1k
                                            2160
                                            1217042
