    4. Test Adapter Fronius 2.0.x
      diwoma last edited by
      Hi, Ich hatte jetzt ein Problem mit dem Adapter.
      Ich habe eine neue Software auf den Fronius aufgespielt und danach den Fronius restartet. Dadurch hat der Adapter natürlich seine Verbindung verloren, aber nicht wieder gefunden:
      2023-06-06 08:55:12.079 - error: fronius.0 (26028) uncaught exception: Cannot convert undefined or null to object
      2023-06-06 08:55:12.079 - error: fronius.0 (26028) TypeError: Cannot convert undefined or null to object
      at hasOwnProperty ()
      at createStates (/opt/iobroker/node_modules/iobroker.fronius/lib/devObjects.js:474:41)
      at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fronius/lib/devObjects.js:127:17)
      at listOnTimeout (node:internal/timers:561:11)
      at processTimers (node:internal/timers:502:7)
      2023-06-06 08:55:12.079 - error: fronius.0 (26028) Cannot convert undefined or null to object
      2023-06-06 08:55:12.136 - debug: fronius.0 (26028) API Objekt E_Day is null, no object created!
      2023-06-06 08:55:12.136 - debug: fronius.0 (26028) API Objekt E_Year is null, no object created!
      2023-06-06 08:55:12.137 - debug: fronius.0 (26028) API Objekt P_Akku is null, no object created!
      2023-06-06 08:55:12.137 - debug: fronius.0 (26028) API Objekt rel_SelfConsumption is null, no object created!
      2023-06-06 08:55:12.137 - debug: fronius.0 (26028) API Objekt E_Day is null, no object created!
      2023-06-06 08:55:12.137 - debug: fronius.0 (26028) API Objekt E_Year is null, no object created!
      2023-06-06 08:55:12.582 - info: fronius.0 (26028) terminating
      2023-06-06 08:55:12.582 - warn: fronius.0 (26028) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-06-06 08:55:13.098 - error: host.ioBroker-dev instance system.adapter.fronius.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-06-06 08:55:13.098 - info: host.ioBroker-dev Restart adapter system.adapter.fronius.0 because enabled
      2023-06-06 08:55:13.098 - warn: host.ioBroker-dev Do not restart adapter system.adapter.fronius.0 because restart loop detected
      2023-06-06 09:15:21.207 - info: host.ioBroker-dev "system.adapter.fronius.0" disabled
      2023-06-06 09:15:23.102 - info: host.ioBroker-dev "system.adapter.fronius.0" enabled
      2023-06-06 09:15:23.119 - info: host.ioBroker-dev instance system.adapter.fronius.0 started with pid 26043
      Ein Restart des Adapters hat ihn wieder auf Linie gebracht.
      Allerdings sollte dieser Zustand irgendwie abgefangen werden.
      mcm1957 nkleber 2 Replies Last reply Reply Quote 0
      • mcm1957
        mcm1957 @diwoma last edited by mcm1957
        @diwoma
        @nkleber
        Ich möcht nkleber nicht vorgreifen, aber ich würde bitten hier 2 Dinge zu checken bzw. zu unterscheiden:
        a) Wenn der Adapter eine unterbrochene Verbindung nicht mehr aufbauen kann, dann sollte das analysiert werden und wenn möglich behoben werden.
        Ich würde dich daher bitte - sofern es nicht allzuviel Mühe macht - deinen Fronius gelengtlich neu zu starten umd ein Reboot wie es nach dem Firmwarupdate erfolgt ist zu simulieren. Dabei wäre das Ziel festzustellen, ob sich der Adapter neu verbindet oder einen Restart braucht. Ev. wäre es auch sinnvoll VORHER den Adapter mit aktiviertem Debug Log zu starten um möglichst vile INfos mitzuloggen.
        b) Wenn es bei a) keine Probleme gibt, dann muss man schaun ob man erkennen kann, warum es bei einem FW Update Probleme gab / gibt. Wieviel Aufwand hier angebracht ist muss nkleber entscheiden, da wahrscheinlich FW Updates eher selten erfolgen.
        In jedem Fall erscheint es mir sinnvoll ein issue zu eröffnen und möglichst alle verfügbaren Daten, insbesonder vollständige Logs, dort abzulegen.
        McM
        Nachtrag:
        Das sollte jedenfalls abgefangen werden. Danke f.d. Info.
          c1olli @mcm1957 last edited by
          Ich habe den Adaper auf ein Testsystem aufgesetzt und er läuft soweit einwandfrei.
          In den nächsten Tagen muss ich dann mal gegenchecken welche Datenpunkte sich verschoben haben.
          • mcm1957
            mcm1957 @c1olli last edited by mcm1957
            @c1olli
            Wenn du das explizit checkst, könntest du die Liste bitte hier bitte posten?
            Wär ev. eine Hilfe für nkleber oder ich könnts ins Readme eintragen.
            Sorry, normalerweise sollte das vom dev zum user gehen. Aber der Adapter ist einige Zeit verstaubt, wurde parallel aufgepäppelt und jetzt gemerged. IOch bin schon froh, dass er technisch offensichtlich keine großen neuen Probleme aufreisst. DANKE an @nkleber für die sehr gute Arbeit.
              @mcm57
              Nee ist kein Thema, ich werd in den nächsten Tagen mal schauen.
                diwoma last edited by diwoma
                @nkleber
                Hi ich habe jetzt einen Restart provoziert, ohne update davor und habe folgendes Log:
                2023-06-07 05:30:24.134 - info: host.ioBroker-dev stopInstance system.adapter.fronius.0 (force=false, process=true)
                2023-06-07 05:30:24.137 - info: fronius.0 (26043) Got terminate signal TERMINATE_YOURSELF
                2023-06-07 05:30:24.181 - info: host.ioBroker-dev stopInstance system.adapter.fronius.0 send kill signal
                2023-06-07 05:30:24.638 - info: fronius.0 (26043) terminating
                2023-06-07 05:30:24.639 - info: fronius.0 (26043) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-06-07 05:30:24.833 - debug: fronius.0 (26043) GetArchiveData has thrown following error: AxiosError: Request failed with status code 404
                2023-06-07 05:30:25.159 - info: host.ioBroker-dev instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-06-07 05:30:27.198 - info: host.ioBroker-dev instance system.adapter.fronius.0 started with pid 26922
                2023-06-07 05:30:27.525 - debug: fronius.0 (26922) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2023-06-07 05:30:27.538 - debug: fronius.0 (26922) Objects client ready ... initialize now
                2023-06-07 05:30:27.539 - debug: fronius.0 (26922) Objects create System PubSub Client
                2023-06-07 05:30:27.539 - debug: fronius.0 (26922) Objects create User PubSub Client
                2023-06-07 05:30:27.544 - debug: fronius.0 (26922) Objects client initialize lua scripts
                2023-06-07 05:30:27.546 - debug: fronius.0 (26922) Objects connected to redis: 127.0.0.1:9001
                2023-06-07 05:30:27.552 - debug: fronius.0 (26922) Redis States: Use Redis connection: 127.0.0.1:9000
                2023-06-07 05:30:27.555 - debug: fronius.0 (26922) States create System PubSub Client
                2023-06-07 05:30:27.556 - debug: fronius.0 (26922) States create User PubSub Client
                2023-06-07 05:30:27.602 - debug: fronius.0 (26922) States connected to redis: 127.0.0.1:9000
                2023-06-07 05:30:27.662 - info: fronius.0 (26922) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v16.19.0, js-controller: 4.0.24
                2023-06-07 05:30:28.690 - debug: fronius.0 (26922) requestType https:// is not working! Now trying with http://
                2023-06-07 05:30:28.717 - debug: fronius.0 (26922) getLoggerInfo: v1/GetLoggerInfo.cgi request is not supported.
                2023-06-07 05:30:28.747 - debug: fronius.0 (26922) GetArchiveData has thrown following error: AxiosError: Request failed with status code 404
                2023-06-07 05:30:28.784 - debug: fronius.0 (26922) Object {} does not have a property UAC, therefore no State was created
                2023-06-07 05:30:50.167 - debug: fronius.0 (26922) Property YEAR_ENERGY is null. No object created!
                2023-06-07 05:30:58.704 - debug: fronius.0 (26922) Object creation will be done for 0 times
                2023-06-07 05:30:58.895 - error: fronius.0 (26922) uncaught exception: Cannot convert undefined or null to object
                2023-06-07 05:30:58.896 - error: fronius.0 (26922) TypeError: Cannot convert undefined or null to object
                at fillDataObject (/opt/iobroker/node_modules/iobroker.fronius/main.js:1145:41)
                at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fronius/main.js:1195:13)
                2023-06-07 05:30:58.896 - error: fronius.0 (26922) Cannot convert undefined or null to object
                2023-06-07 05:30:58.896 - error: fronius.0 (26922) uncaught exception: Cannot convert undefined or null to object
                2023-06-07 05:30:59.403 - info: fronius.0 (26922) terminating
                2023-06-07 05:30:59.404 - warn: fronius.0 (26922) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2023-06-07 05:30:59.918 - error: host.ioBroker-dev instance system.adapter.fronius.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2023-06-07 05:30:59.918 - info: host.ioBroker-dev Restart adapter system.adapter.fronius.0 because enabled
                2023-06-07 05:31:29.934 - info: host.ioBroker-dev instance system.adapter.fronius.0 started with pid 26937
                2023-06-07 05:31:30.234 - debug: fronius.0 (26937) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2023-06-07 05:31:30.248 - debug: fronius.0 (26937) Objects client ready ... initialize now
                2023-06-07 05:31:30.249 - debug: fronius.0 (26937) Objects create System PubSub Client
                2023-06-07 05:31:30.249 - debug: fronius.0 (26937) Objects create User PubSub Client
                2023-06-07 05:31:30.254 - debug: fronius.0 (26937) Objects client initialize lua scripts
                2023-06-07 05:31:30.256 - debug: fronius.0 (26937) Objects connected to redis: 127.0.0.1:9001
                2023-06-07 05:31:30.262 - debug: fronius.0 (26937) Redis States: Use Redis connection: 127.0.0.1:9000
                2023-06-07 05:31:30.264 - debug: fronius.0 (26937) States create System PubSub Client
                2023-06-07 05:31:30.265 - debug: fronius.0 (26937) States create User PubSub Client
                2023-06-07 05:31:30.314 - debug: fronius.0 (26937) States connected to redis: 127.0.0.1:9000
                2023-06-07 05:31:30.366 - info: fronius.0 (26937) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v16.19.0, js-controller: 4.0.24
                2023-06-07 05:31:31.391 - debug: fronius.0 (26937) requestType https:// is not working! Now trying with http://
                2023-06-07 05:31:31.411 - debug: fronius.0 (26937) getLoggerInfo: v1/GetLoggerInfo.cgi request is not supported.
                2023-06-07 05:31:31.422 - debug: fronius.0 (26937) GetArchiveData has thrown following error: AxiosError: Request failed with status code 404
                2023-06-07 05:31:31.429 - debug: fronius.0 (26937) Object {} does not have a property Enable, therefore no State was created
                2023-06-07 05:31:31.484 - debug: fronius.0 (26937) Property P_Akku is null. No object created!
                2023-06-07 05:31:31.484 - debug: fronius.0 (26937) Property E_Day is null. No object created!
                2023-06-07 05:31:31.484 - debug: fronius.0 (26937) Property E_Year is null. No object created!
                2023-06-07 05:31:31.484 - debug: fronius.0 (26937) Property rel_SelfConsumption is null. No object created!
                {"ErrorCode":1240,"InverterState":"Sleeping","StatusCode":13},"IAC":{"Unit":"A","Value":0},"IDC":{"Unit":"A","Value":0},"IDC_2":{"Unit":"A","Value":0},"IDC_3":{"Unit":"A","Value":null},"IDC_4":{"Unit":"A","Value":null},"PAC":{"Unit":"W","Value":0},"SAC":{"Unit":"VA","Value":0},"TOTAL_ENERGY":{"Unit":"Wh","Value":6044085.741666666},"UAC":{"Unit":"V","Value":0.027594637125730515},"UDC":{"Unit":"V","Value":146.51486206054688},"UDC_2":{"Unit":"V","Value":152.09059143066406},"UDC_3":{"Unit":"V","Value":null},"UDC_4":{"Unit":"V","Value":null},"YEAR_ENERGY":{"Unit":"Wh","Value":null}} does not have a property IAC_L1, therefore no State was created
                2023-06-07 05:31:31.858 - debug: fronius.0 (26937) Object {} does not have a property T_AMBIENT, therefore no State was created
                2023-06-07 05:31:32.432 - error: fronius.0 (26937) uncaught exception: Cannot convert undefined or null to object
                2023-06-07 05:31:32.432 - error: fronius.0 (26937) TypeError: Cannot convert undefined or null to object
                2023-06-07 05:31:32.432 - error: fronius.0 (26937) Cannot convert undefined or null to object
                2023-06-07 05:31:32.484 - debug: fronius.0 (26937) API Objekt E_Day is null, no object created!
                2023-06-07 05:31:32.485 - debug: fronius.0 (26937) API Objekt E_Year is null, no object created!
                2023-06-07 05:31:32.485 - debug: fronius.0 (26937) API Objekt P_Akku is null, no object created!
                2023-06-07 05:31:32.485 - debug: fronius.0 (26937) API Objekt rel_SelfConsumption is null, no object created!
                2023-06-07 05:31:32.485 - debug: fronius.0 (26937) API Objekt E_Day is null, no object created!
                2023-06-07 05:31:32.746 - debug: fronius.0 (26937) Property UAC_L1 is null. No object created!
                2023-06-07 05:31:32.746 - debug: fronius.0 (26937) Property UAC_L2 is null. No object created!
                2023-06-07 05:31:32.746 - debug: fronius.0 (26937) Property UAC_L3 is null. No object created!
                2023-06-07 05:31:32.822 - debug: fronius.0 (26937) Property DAY_ENERGY is null. No object created!
                2023-06-07 05:31:32.823 - debug: fronius.0 (26937) Property IDC_3 is null. No object created!
                2023-06-07 05:31:32.823 - debug: fronius.0 (26937) Property IDC_4 is null. No object created!
                2023-06-07 05:31:32.823 - debug: fronius.0 (26937) Property UDC_3 is null. No object created!
                2023-06-07 05:31:32.823 - debug: fronius.0 (26937) Property UDC_4 is null. No object created!
                2023-06-07 05:31:32.823 - debug: fronius.0 (26937) Property YEAR_ENERGY is null. No object created!
                2023-06-07 05:31:32.933 - info: fronius.0 (26937) terminating
                2023-06-07 05:31:32.934 - warn: fronius.0 (26937) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2023-06-07 05:31:33.447 - error: host.ioBroker-dev instance system.adapter.fronius.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2023-06-07 05:31:33.447 - info: host.ioBroker-dev Restart adapter system.adapter.fronius.0 because enabled
                2023-06-07 05:32:03.464 - info: host.ioBroker-dev instance system.adapter.fronius.0 started with pid 26952
                2023-06-07 05:32:03.766 - debug: fronius.0 (26952) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2023-06-07 05:32:03.780 - debug: fronius.0 (26952) Objects client ready ... initialize now
                2023-06-07 05:32:03.781 - debug: fronius.0 (26952) Objects create System PubSub Client
                2023-06-07 05:32:03.781 - debug: fronius.0 (26952) Objects create User PubSub Client
                2023-06-07 05:32:03.786 - debug: fronius.0 (26952) Objects client initialize lua scripts
                2023-06-07 05:32:03.788 - debug: fronius.0 (26952) Objects connected to redis: 127.0.0.1:9001
                2023-06-07 05:32:03.794 - debug: fronius.0 (26952) Redis States: Use Redis connection: 127.0.0.1:9000
                2023-06-07 05:32:03.796 - debug: fronius.0 (26952) States create System PubSub Client
                2023-06-07 05:32:03.796 - debug: fronius.0 (26952) States create User PubSub Client
                2023-06-07 05:32:03.841 - debug: fronius.0 (26952) States connected to redis: 127.0.0.1:9000
                2023-06-07 05:32:03.892 - info: fronius.0 (26952) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v16.19.0, js-controller: 4.0.24
                2023-06-07 05:32:04.918 - debug: fronius.0 (26952) requestType https:// is not working! Now trying with http://
                2023-06-07 05:32:05.920 - error: fronius.0 (26952) IP is not a Fronius inverter
                2023-06-07 05:32:16.198 - debug: fronius.0 (26952) checkArchiveStatus has thrown following error: Error: connect EHOSTUNREACH 192.168.1.102:80
                2023-06-07 05:32:16.198 - debug: fronius.0 (26952) checkStatus has thrown following error: Error: connect EHOSTUNREACH 192.168.1.102:80
                2023-06-07 05:32:16.199 - debug: fronius.0 (26952) getLoggerInfo has thrown following error: Error: connect EHOSTUNREACH 192.168.1.102:80
                2023-06-07 05:32:16.199 - debug: fronius.0 (26952) checkStatus has thrown following error: Error: connect EHOSTUNREACH 192.168.1.102:80
                2023-06-07 05:32:28.997 - debug: fronius.0 (26952) checkStatus has thrown following error: Error: connect EHOSTUNREACH 192.168.1.102:80
                2023-06-07 05:32:38.981 - debug: fronius.0 (26952) checkStatus has thrown following error: Error: connect EHOSTUNREACH 192.168.1.102:80
                2023-06-07 05:32:48.997 - debug: fronius.0 (26952) checkStatus has thrown following error: Error: connect EHOSTUNREACH 192.168.1.102:80
                2023-06-07 05:32:58.981 - debug: fronius.0 (26952) checkStatus has thrown following error: Error: connect EHOSTUNREACH 192.168.1.102:80
                2023-06-07 05:33:08.996 - debug: fronius.0 (26952) checkStatus has thrown following error: Error: connect EHOSTUNREACH 192.168.1.102:80
                2023-06-07 05:33:15.932 - debug: fronius.0 (26952) checkStatus has thrown following error: Error: connect ECONNREFUSED 192.168.1.102:80
                2023-06-07 05:33:25.933 - debug: fronius.0 (26952) checkStatus has thrown following error: Error: connect ECONNREFUSED 192.168.1.102:80
                2023-06-07 05:33:35.934 - debug: fronius.0 (26952) checkStatus has thrown following error: Error: connect ECONNREFUSED 192.168.1.102:80
                2023-06-07 05:33:51.993 - debug: fronius.0 (26952) Object {"IAC_L1":{"Unit":"A","Value":0},"IAC_L2":{"Unit":"A","Value":0},"IAC_L3":{"Unit":"A","Value":0},"UAC_L1":{"Unit":"V","Value":null},"UAC_L2":{"Unit":"V","Value":null},"UAC_L3":{"Unit":"V","Value":null}} does not have a property UAC, therefore no State was created
                2023-06-07 05:33:53.069 - debug: fronius.0 (26952) Property YEAR_ENERGY is null. No object created!
                2023-06-07 05:33:53.129 - error: fronius.0 (26952) uncaught exception: Cannot convert undefined or null to object
                2023-06-07 05:33:53.129 - error: fronius.0 (26952) TypeError: Cannot convert undefined or null to object
                2023-06-07 05:33:53.129 - error: fronius.0 (26952) Cannot convert undefined or null to object
                2023-06-07 05:33:53.208 - debug: fronius.0 (26952) API Objekt E_Day is null, no object created!
                2023-06-07 05:33:53.208 - debug: fronius.0 (26952) API Objekt E_Year is null, no object created!
                2023-06-07 05:33:53.209 - debug: fronius.0 (26952) API Objekt P_Akku is null, no object created!
                2023-06-07 05:33:53.209 - debug: fronius.0 (26952) API Objekt rel_SelfConsumption is null, no object created!
                2023-06-07 05:33:53.209 - debug: fronius.0 (26952) API Objekt E_Day is null, no object created!
                2023-06-07 05:33:53.209 - debug: fronius.0 (26952) API Objekt E_Year is null, no object created!
                2023-06-07 05:33:53.630 - info: fronius.0 (26952) terminating
                2023-06-07 05:33:53.630 - warn: fronius.0 (26952) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2023-06-07 05:33:54.146 - error: host.ioBroker-dev instance system.adapter.fronius.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2023-06-07 05:33:54.146 - info: host.ioBroker-dev Restart adapter system.adapter.fronius.0 because enabled
                2023-06-07 05:33:54.146 - warn: host.ioBroker-dev Do not restart adapter system.adapter.fronius.0 because restart loop detected
                Zur Erklärung:
                Für ein sauberes Protokoll habe ich zuerst das Log gelöscht und einen Restart des Adapters durchgeführt.
                Dann die Anlage runter gefahren und wieder gestartet.
                Am Ende ist der Adapter rot:
                D Homoran 2 Replies Last reply Reply Quote 0
                  diwoma @diwoma last edited by diwoma
                  @diwoma @nkleber
                  Dazu noch etwas zum Verhalten des Restart-Prozesses:
                  Das IP-Interface ist relativ schnell da, aber der Inverter selbst ist längere Zeit (mind. 30 sek) im Zustand angehalten.
                  Das könnte dazu führen, dass einige der Abfragen beantwortet werden, aber die Abfragen die den Inverter selbst betrifft, eventuell nicht korrekt zurückkommen. was dann zur
                  führen könnte. Vielleicht könntest Du im Debug noch die Abfrage mitloggen, damit man erkennen kann, welche Abfrage es ist.
                  • mcm1957
                    @diwoma
                    Danke für die ausgezeichnete Dokumentation des Problems.
                    Ich hab ein issue erstellt (https://github.com/iobroker-community-adapters/ioBroker.fronius/issues/313) und auf die Info hier verwiesen.
                    mcm1957 created this issue in iobroker-community-adapters/ioBroker.fronius
                    closed "uncaught exception: Cannot convert undefined or null to object" at fronius restart #313
                    C 1 Reply Last reply Reply Quote 1
                      c1olli @mcm1957 last edited by c1olli
                      Anbei die Gegenüberstellung der beiden Adapter in ioBroker.
                      Darstellung mit einem Inverter und einem String.
                      Beim 1.xx Adapter fällt auf, dass viele Punkte doppelt sind. Daher fällt der 2.xx etwas schlanker aus.
                      Fronius.xlsx
                      nkleber 1 Reply Last reply Reply Quote 0
                      • nkleber
                        nkleber @c1olli last edited by
                        @c1olli Kann es sein dass du bei der V1.xx schon die Version 1.1.6 oder gar die 1.2.0 drauf hattest? Die offizielle Version ohne Github war die 1.1.3 und da müsste die Struktur eigentlich noch etwas anders aussehen...
                          c1olli @nkleber last edited by c1olli
                          @nkleber
                          ich schau nochmal nach - vielleicht hab ich da was verbogen.
                          Edit:
                          Jepp da hatte ich wohl was ausprobiert.
                          Jetzt sollte es aber stimmen
                          Fronius.xlsx
                          Im oberen Beitrag habe ich auch die aktuelle Tabelle angehängt
                          D nkleber 2 Replies Last reply Reply Quote 0
                            diwoma @c1olli last edited by diwoma
                            @c1olli
                            ich glaube, da ist noch ein Fehler: die "site" hat es in 1.x nicht gegeben, die gehört zu 2.x
                              Homoran Global Moderator Administrators @diwoma last edited by
                              @diwoma ist es möglich/sinnvoll den code zu kürzen?
                              ich fürchte der lähmt den Aufruf des Threads
                              mcm1957 Negalein 2 Replies Last reply Reply Quote 0
                              • mcm1957
                                mcm1957 @Homoran last edited by
                                Welchen Code?
                                  Homoran Global Moderator Administrators @mcm1957 last edited by
                                  @mcm57 das was hier alles blockiert und in dem beantworteten Post in code-tags steht.
                                  • Negalein
                                    Negalein Global Moderator @Homoran last edited by
                                    @homoran sagte in Test Adapter Fronius 2.0.x:
                                    bei mir blockiert nichts
                                      Homoran Global Moderator Administrators @Negalein last edited by Homoran
                                      @negalein sagte in Test Adapter Fronius 2.0.x:
                                      das klingt schon wieder nicht nach mobiler Ansicht
                                        diwoma @Homoran last edited by
                                        @homoran @mcm57 @nkleber
                                        Ich habe das Log gekürzt und die nicht relevanten Messages, die nur melden, dass ein DP nicht erzeugt wurde, weil er null war, rausgelöscht.
                                        Nur mehr die meiner Meinung nach relevanten Daten zum Problem plus ein paar weitere Meldungen davor und danach habe ich gelassen, damit man sich auch das Timing beim Auftreten ansehen kann.
                                          @diwoma Danke!
                                          komme wieder auf die Seite
                                            c1olli @diwoma last edited by
                                            @diwoma
                                            Jo hast recht - hatte ich wohl vergessen zu löschen - hab die aktuelle Version oben geändert
                                            31.7k
                                            79.8k
                                            164
                                            15446
