    4. Test Adapter Awtrix-Light (Awtrix 3)
    • Ben1983
      Ben1983 @marlan99 last edited by
      @marlan99 die dezimalstellen sind fix auf 3 gesetzt.
      • Ben1983
        Ben1983 @haus-automatisierung last edited by Ben1983
        @haus-automatisierung Jetzt kommt der Fehler nicht mehr,
        aber es wird trotzdem kein Graph angezeigt.
        Debug - Log:
        2023-06-08 09:19:00.899 - info: host.buanet-iobroker "system.adapter.awtrix-light.0" enabled
        2023-06-08 09:19:00.966 - info: host.buanet-iobroker instance system.adapter.awtrix-light.0 started with pid 13553
        2023-06-08 09:19:01.578 - debug: awtrix-light.0 (13553) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2023-06-08 09:19:01.624 - debug: awtrix-light.0 (13553) Objects client ready ... initialize now
        2023-06-08 09:19:01.666 - debug: awtrix-light.0 (13553) Objects create System PubSub Client
        2023-06-08 09:19:01.669 - debug: awtrix-light.0 (13553) Objects create User PubSub Client
        2023-06-08 09:19:01.702 - debug: awtrix-light.0 (13553) Objects client initialize lua scripts
        2023-06-08 09:19:01.708 - debug: awtrix-light.0 (13553) Objects connected to redis: 127.0.0.1:9001
        2023-06-08 09:19:01.747 - debug: awtrix-light.0 (13553) Redis States: Use Redis connection: 127.0.0.1:9000
        2023-06-08 09:19:01.819 - debug: awtrix-light.0 (13553) States create System PubSub Client
        2023-06-08 09:19:01.820 - debug: awtrix-light.0 (13553) States create User PubSub Client
        2023-06-08 09:19:01.878 - debug: awtrix-light.0 (13553) States connected to redis: 127.0.0.1:9000
        2023-06-08 09:19:02.511 - info: awtrix-light.0 (13553) starting. Version 0.0.11 (non-npm: klein0r/ioBroker.awtrix-light) in /opt/iobroker/node_modules/iobroker.awtrix-light, node: v18.16.0, js-controller: 4.0.24
        2023-06-08 09:19:02.531 - debug: awtrix-light.0 (13553) API is offline
        2023-06-08 09:19:02.532 - debug: awtrix-light.0 (13553) refreshing device state
        2023-06-08 09:19:02.532 - debug: awtrix-light.0 (13553) re-creating refresh state timeout
        2023-06-08 09:19:02.533 - debug: awtrix-light.0 (13553) sending "GET" request to "/api/stats" without data
        2023-06-08 09:19:02.618 - debug: awtrix-light.0 (13553) received 200 response from "/api/stats" with content: {"bat":81,"bat_raw":629,"lux":"17","ldr_raw":664,"ram":137340,"bri":120,"temp":"26","hum":"27","uptime":"3179","wifi_signal":-59,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
        2023-06-08 09:19:02.619 - warn: awtrix-light.0 (13553) You should update your Awtrix Light - supported version of this adapter is 0.68 (or later). Your current version is 0.67
        2023-06-08 09:19:02.675 - debug: awtrix-light.0 (13553) sending "GET" request to "/api/settings" without data
        2023-06-08 09:19:02.705 - debug: awtrix-light.0 (13553) received 200 response from "/api/settings" with content: {"FPS":23,"ABRI":true,"BRI":120,"ATRANS":true,"TCOL":65535,"TSPEED":400,"ATIME":7000,"TFORMAT":"%H:%M:%S","DFORMAT":"%d.%m.%y","SOM":true,"CEL":true,"BLOCKN":false,"MAT":0,"SOUND":true,"GAMMA":0,"UPPERCASE":true,"CCORRECTION":"","CTEMP":"","WD":true,"WDCA":7327,"WDCI":27501,"TIME_COL":0,"DATE_COL":0,"HUM_COL":0,"TEMP_COL":0,"BAT_COL":0}
        2023-06-08 09:19:02.766 - debug: awtrix-light.0 (13553) [initCustomApps] Found custom app "gridpower" with objId 0_userdata.0.Produktiv.awtrix.wirkleistungNetz - subscribed to changes
        2023-06-08 09:19:02.771 - debug: awtrix-light.0 (13553) [initCustomApps] Found custom app "externaltemperature" with objId 0_userdata.0.Produktiv.awtrix.Außentemperatur - subscribed to changes
        2023-06-08 09:19:02.774 - debug: awtrix-light.0 (13553) [initCustomApps] Found custom app "pvpower" with objId 0_userdata.0.Produktiv.awtrix.wirkleistungPv - subscribed to changes
        2023-06-08 09:19:02.777 - debug: awtrix-light.0 (13553) [initCustomApps] Found custom app "storagesoc" with objId 0_userdata.0.Produktiv.awtrix.SOC - subscribed to changes
        2023-06-08 09:19:02.780 - debug: awtrix-light.0 (13553) [initCustomApps] Found custom app "storagepower" with objId 0_userdata.0.Produktiv.awtrix.wirkleistungSpeicher - subscribed to changes
        2023-06-08 09:19:02.781 - debug: awtrix-light.0 (13553) [refreshCustomApp] Refreshing custom app "gridpower" with icon "49243" and text "%s %u"
        2023-06-08 09:19:02.781 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/custom?name=gridpower" with data: {"text":"546 W","icon":"49243","duration":5}
        2023-06-08 09:19:02.924 - debug: awtrix-light.0 (13553) received 200 response from "/api/custom?name=gridpower" with content: "OK"
        2023-06-08 09:19:02.925 - debug: awtrix-light.0 (13553) [refreshCustomApp] Refreshing custom app "externaltemperature" with icon "38231" and text "%s %u"
        2023-06-08 09:19:02.925 - debug: awtrix-light.0 (13553) [refreshCustomApp] formatted value of "0_userdata.0.Produktiv.awtrix.Außentemperatur" from 25.3 to 25,3 (1 decimals)
        2023-06-08 09:19:02.925 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/custom?name=externaltemperature" with data: {"text":"25,3 °C","icon":"38231","duration":5}
        2023-06-08 09:19:02.961 - debug: awtrix-light.0 (13553) received 200 response from "/api/custom?name=externaltemperature" with content: "OK"
        2023-06-08 09:19:02.961 - debug: awtrix-light.0 (13553) [refreshCustomApp] Refreshing custom app "pvpower" with icon "15124" and text "%s %u"
        2023-06-08 09:19:02.962 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/custom?name=pvpower" with data: {"text":"403 W","icon":"15124","duration":5}
        2023-06-08 09:19:03.022 - debug: awtrix-light.0 (13553) received 200 response from "/api/custom?name=pvpower" with content: "OK"
        2023-06-08 09:19:03.022 - debug: awtrix-light.0 (13553) [refreshCustomApp] Refreshing custom app "storagesoc" with icon "49520" and text "%s %u"
        2023-06-08 09:19:03.022 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/custom?name=storagesoc" with data: {"text":"11 %","icon":"49520","duration":5}
        2023-06-08 09:19:03.049 - debug: awtrix-light.0 (13553) received 200 response from "/api/custom?name=storagesoc" with content: "OK"
        2023-06-08 09:19:03.050 - debug: awtrix-light.0 (13553) [refreshCustomApp] Refreshing custom app "storagepower" with icon "49520" and text "%s %u"
        2023-06-08 09:19:03.050 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/custom?name=storagepower" with data: {"text":"2 W","icon":"49520","duration":5}
        2023-06-08 09:19:03.085 - debug: awtrix-light.0 (13553) received 200 response from "/api/custom?name=storagepower" with content: "OK"
        2023-06-08 09:19:03.086 - debug: awtrix-light.0 (13553) [initHistoryApps] getting history data for app "netz" of "alias.0.Allgemein.Leistung.WirkleistungGesamt" from influxdb.0
        2023-06-08 09:19:04.176 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 543 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:06.177 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 543 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:06.213 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 402 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:06.216 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungSpeicher" to 3 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:06.218 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 25.5 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:08.045 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2591 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:08.135 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 25.4 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:10.131 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2592 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:12.068 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2589 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:12.097 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 402 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:12.101 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 25.1 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:14.129 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2589 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:14.164 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 404 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:14.169 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 25 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:16.171 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2589 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:16.198 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 24.8 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:18.129 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2590 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:18.192 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 402 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:18.197 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 24.7 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:20.166 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2585 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:20.174 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 404 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:20.176 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungSpeicher" to 3 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:22.173 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2585 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:22.180 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 24.6 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:24.069 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2586 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:24.119 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 402 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:26.177 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2580 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:26.201 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 404 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:26.205 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 24.6 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:28.069 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2580 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:28.153 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 404 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:30.074 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2577 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:30.104 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 24.8 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:32.126 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2570 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:32.134 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 404 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:32.136 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 24.8 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:33.094 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/custom?name=netz" without data
        2023-06-08 09:19:33.214 - debug: awtrix-light.0 (13553) received 200 response from "/api/custom?name=netz" with content: "OK"
        2023-06-08 09:19:33.214 - debug: awtrix-light.0 (13553) re-creating history apps timeout (60 seconds)
        2023-06-08 09:19:33.215 - debug: awtrix-light.0 (13553) sending "GET" request to "/api/apps" without data
        2023-06-08 09:19:33.217 - debug: awtrix-light.0 (13553) Updating indicator with index 1
        2023-06-08 09:19:33.233 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/indicator1" without data
        2023-06-08 09:19:33.247 - debug: awtrix-light.0 (13553) received 200 response from "/api/apps" with content: [{"name":"time"},{"name":"date"},{"name":"gridpower","icon":"49243.gif"},{"name":"externaltemperature","icon":"38231.jpg"},{"name":"pvpower","icon":"15124.gif"},{"name":"storagesoc","icon":"49520.jpg"},{"name":"storagepower","icon":"49520.jpg"}]
        2023-06-08 09:19:33.248 - debug: awtrix-light.0 (13553) [createAppObjects] existing apps on awtrix light: ["time","date","gridpower","externaltemperature","pvpower","storagesoc","storagepower"]
        2023-06-08 09:19:33.268 - debug: awtrix-light.0 (13553) received 200 response from "/api/indicator1" with content: "OK"
        2023-06-08 09:19:33.269 - debug: awtrix-light.0 (13553) Updating indicator with index 2
        2023-06-08 09:19:33.270 - debug: awtrix-light.0 (13553) [createAppObjects] found (keep): apps.time
        2023-06-08 09:19:33.324 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/indicator2" without data
        2023-06-08 09:19:33.333 - debug: awtrix-light.0 (13553) [createAppObjects] found (keep): apps.eyes
        2023-06-08 09:19:33.344 - debug: awtrix-light.0 (13553) [createAppObjects] found (keep): apps.date
        2023-06-08 09:19:33.346 - debug: awtrix-light.0 (13553) received 200 response from "/api/indicator2" with content: "OK"
        2023-06-08 09:19:33.346 - debug: awtrix-light.0 (13553) Updating indicator with index 3
        2023-06-08 09:19:33.404 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/indicator3" without data
        2023-06-08 09:19:33.406 - debug: awtrix-light.0 (13553) [createAppObjects] found (keep): apps.temp
        2023-06-08 09:19:33.428 - debug: awtrix-light.0 (13553) received 200 response from "/api/indicator3" with content: "OK"
        2023-06-08 09:19:33.429 - debug: awtrix-light.0 (13553) Updating moodlight
        2023-06-08 09:19:33.431 - debug: awtrix-light.0 (13553) [createAppObjects] found (keep): apps.hum
        2023-06-08 09:19:33.483 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/moodlight" without data
        2023-06-08 09:19:33.496 - debug: awtrix-light.0 (13553) [createAppObjects] found (keep): apps.bat
        2023-06-08 09:19:33.506 - debug: awtrix-light.0 (13553) [createAppObjects] found (keep): apps.gridpower
        2023-06-08 09:19:33.510 - debug: awtrix-light.0 (13553) received 200 response from "/api/moodlight" with content: "OK"
        2023-06-08 09:19:33.526 - debug: awtrix-light.0 (13553) [createAppObjects] found (keep): apps.externaltemperature
        2023-06-08 09:19:33.535 - debug: awtrix-light.0 (13553) [createAppObjects] found (keep): apps.pvpower
        2023-06-08 09:19:33.545 - debug: awtrix-light.0 (13553) [createAppObjects] found (keep): apps.storagesoc
        2023-06-08 09:19:33.554 - debug: awtrix-light.0 (13553) [createAppObjects] found (keep): apps.storagepower
        2023-06-08 09:19:33.563 - debug: awtrix-light.0 (13553) [createAppObjects] found (keep): apps.netz
        2023-06-08 09:19:34.093 - debug: awtrix-light.0 (13553) [refreshCustomApp] Refreshing custom app "gridpower" with icon "49243" and text "%s %u"
        2023-06-08 09:19:34.093 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/custom?name=gridpower" with data: {"text":"2571 W","icon":"49243","duration":5}
        2023-06-08 09:19:34.136 - debug: awtrix-light.0 (13553) received 200 response from "/api/custom?name=gridpower" with content: "OK"
        2023-06-08 09:19:34.162 - debug: awtrix-light.0 (13553) [refreshCustomApp] Refreshing custom app "pvpower" with icon "15124" and text "%s %u"
        2023-06-08 09:19:34.162 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/custom?name=pvpower" with data: {"text":"404 W","icon":"15124","duration":5}
        2023-06-08 09:19:34.184 - debug: awtrix-light.0 (13553) received 200 response from "/api/custom?name=pvpower" with content: "OK"
        2023-06-08 09:19:36.104 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2572 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:36.142 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 403 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:36.147 - debug: awtrix-light.0 (13553) [refreshCustomApp] Refreshing custom app "externaltemperature" with icon "38231" and text "%s %u"
        2023-06-08 09:19:36.147 - debug: awtrix-light.0 (13553) [refreshCustomApp] formatted value of "0_userdata.0.Produktiv.awtrix.Außentemperatur" from 24.9 to 24,9 (1 decimals)
        2023-06-08 09:19:36.148 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/custom?name=externaltemperature" with data: {"text":"24,9 °C","icon":"38231","duration":5}
        2023-06-08 09:19:36.284 - debug: awtrix-light.0 (13553) received 200 response from "/api/custom?name=externaltemperature" with content: "OK"
        2023-06-08 09:19:38.117 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2568 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:40.117 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2561 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:40.148 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 25 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:42.181 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2569 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:42.224 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 430 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:44.180 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2566 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:44.278 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 409 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:44.284 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 25.1 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:46.182 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2614 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:46.244 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 402 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:48.110 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2564 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:48.112 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 400 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:48.115 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 25.1 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:50.098 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2560 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:50.171 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 400 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:52.096 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2561 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:52.121 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 400 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:54.137 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2555 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:54.159 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 398 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:54.163 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 25 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:56.108 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2574 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:56.113 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 403 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:58.058 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2599 - refreshes too fast (within 30 seconds)
        2023-06-08 09:19:58.115 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 380 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:00.125 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2602 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:00.132 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 375 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:00.134 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 25.1 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:02.187 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2591 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:02.189 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 396 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:02.191 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 25 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:02.532 - debug: awtrix-light.0 (13553) refreshing device state
        2023-06-08 09:20:02.533 - debug: awtrix-light.0 (13553) re-creating refresh state timeout
        2023-06-08 09:20:02.533 - debug: awtrix-light.0 (13553) sending "GET" request to "/api/stats" without data
        2023-06-08 09:20:02.585 - debug: awtrix-light.0 (13553) received 200 response from "/api/stats" with content: {"bat":82,"bat_raw":632,"lux":"17","ldr_raw":663,"ram":137384,"bri":120,"temp":"26","hum":"27","uptime":"3239","wifi_signal":-58,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
        2023-06-08 09:20:02.634 - debug: awtrix-light.0 (13553) sending "GET" request to "/api/settings" without data
        2023-06-08 09:20:02.659 - debug: awtrix-light.0 (13553) received 200 response from "/api/settings" with content: {"FPS":23,"ABRI":true,"BRI":120,"ATRANS":true,"TCOL":65535,"TSPEED":400,"ATIME":7000,"TFORMAT":"%H:%M:%S","DFORMAT":"%d.%m.%y","SOM":true,"CEL":true,"BLOCKN":false,"MAT":0,"SOUND":true,"GAMMA":0,"UPPERCASE":true,"CCORRECTION":"","CTEMP":"","WD":true,"WDCA":7327,"WDCI":27501,"TIME_COL":0,"DATE_COL":0,"HUM_COL":0,"TEMP_COL":0,"BAT_COL":0}
        2023-06-08 09:20:04.048 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2589 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:04.127 - debug: awtrix-light.0 (13553) [refreshCustomApp] Refreshing custom app "storagepower" with icon "49520" and text "%s %u"
        2023-06-08 09:20:04.127 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/custom?name=storagepower" with data: {"text":"3 W","icon":"49520","duration":5}
        2023-06-08 09:20:04.229 - debug: awtrix-light.0 (13553) received 200 response from "/api/custom?name=storagepower" with content: "OK"
        2023-06-08 09:20:06.067 - debug: awtrix-light.0 (13553) [refreshCustomApp] Refreshing custom app "gridpower" with icon "49243" and text "%s %u"
        2023-06-08 09:20:06.067 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/custom?name=gridpower" with data: {"text":"2588 W","icon":"49243","duration":5}
        2023-06-08 09:20:06.107 - debug: awtrix-light.0 (13553) [refreshCustomApp] Refreshing custom app "pvpower" with icon "15124" and text "%s %u"
        2023-06-08 09:20:06.107 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/custom?name=pvpower" with data: {"text":"403 W","icon":"15124","duration":5}
        2023-06-08 09:20:06.110 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungSpeicher" to 2 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:06.173 - debug: awtrix-light.0 (13553) received 200 response from "/api/custom?name=gridpower" with content: "OK"
        2023-06-08 09:20:06.193 - debug: awtrix-light.0 (13553) received 200 response from "/api/custom?name=pvpower" with content: "OK"
        2023-06-08 09:20:08.096 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2541 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:08.158 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungSpeicher" to 2 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:08.159 - debug: awtrix-light.0 (13553) [refreshCustomApp] Refreshing custom app "externaltemperature" with icon "38231" and text "%s %u"
        2023-06-08 09:20:08.159 - debug: awtrix-light.0 (13553) [refreshCustomApp] formatted value of "0_userdata.0.Produktiv.awtrix.Außentemperatur" from 24.7 to 24,7 (1 decimals)
        2023-06-08 09:20:08.159 - debug: awtrix-light.0 (13553) sending "POST" request to "/api/custom?name=externaltemperature" with data: {"text":"24,7 °C","icon":"38231","duration":5}
        2023-06-08 09:20:08.214 - debug: awtrix-light.0 (13553) received 200 response from "/api/custom?name=externaltemperature" with content: "OK"
        2023-06-08 09:20:10.063 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2566 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:10.130 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 404 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:10.131 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungSpeicher" to 2 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:12.108 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2562 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:12.113 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungSpeicher" to 2 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:14.064 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2546 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:14.114 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 393 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:16.112 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2537 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:16.147 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 24.5 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:18.063 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2534 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:20.169 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2531 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:20.172 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 404 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:22.088 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2528 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:22.144 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 404 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:22.147 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 24.4 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:24.073 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2532 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:24.136 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 405 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:24.137 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungSpeicher" to 2 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:24.138 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 24.5 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:26.063 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungNetz" to 2533 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:26.117 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungPv" to 399 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:26.130 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.wirkleistungSpeicher" to 2 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:26.182 - debug: awtrix-light.0 (13553) [onStateChange] ignoring customApps state change of "0_userdata.0.Produktiv.awtrix.Außentemperatur" to 24.6 - refreshes too fast (within 30 seconds)
        2023-06-08 09:20:27.553 - info: host.buanet-iobroker "system.adapter.awtrix-light.0" disabled
        2023-06-08 09:20:27.554 - info: host.buanet-iobroker stopInstance system.adapter.awtrix-light.0 (force=false, process=true)
        2023-06-08 09:20:27.555 - info: awtrix-light.0 (13553) Adapter is disabled => stop
        2023-06-08 09:20:27.556 - debug: awtrix-light.0 (13553) API is offline
        2023-06-08 09:20:27.556 - debug: awtrix-light.0 (13553) clearing refresh state timeout
        2023-06-08 09:20:27.556 - debug: awtrix-light.0 (13553) clearing history apps timeout
        2023-06-08 09:20:27.603 - info: awtrix-light.0 (13553) Got terminate signal TERMINATE_YOURSELF
        2023-06-08 09:20:27.631 - info: host.buanet-iobroker stopInstance system.adapter.awtrix-light.0 send kill signal
        2023-06-08 09:20:27.649 - info: awtrix-light.0 (13553) terminating
        2023-06-08 09:20:27.649 - info: awtrix-light.0 (13553) Terminated (NO_ERROR): Without reason
        2023-06-08 09:20:28.195 - info: host.buanet-iobroker instance system.adapter.awtrix-light.0 terminated with code 0 (NO_ERROR)
        Es steht öffter "without data" dort und bspw.
        ist das korrekt? also sollte es nicht:
        "/api/custom/netz"
        heissen?
        • Ben1983
          Ben1983 last edited by
          Ich habe von blueforcer diesen github Eintrag zu den Sichtbarkeiten der Apps:
          https://github.com/Blueforcer/awtrix-light/issues/178#issuecomment-1582069512
          BenAhrdt created this issue in Blueforcer/awtrix-light
          closed [BUG] Apps state after restart always true #178
          haus-automatisierung 1 Reply Last reply Reply Quote 1
            cacherwolf last edited by cacherwolf
            Bei mir wird ein Wert (Wasser) in der Uhr nicht aktualisiert, in Grafana wird der gleiche Datenpunkt richtig dargestellt. Keine Fehlermeldungen.
            Hat jemand einen Idee waran das liegen könnte?
            Wäre es möglich das Komma wieder in einen Punkt zu ändern oder habe ich das was verstellt?
            • haus-automatisierung
              haus-automatisierung Developer Most Active @cacherwolf last edited by haus-automatisierung
              @cacherwolf sagte in Test Adapter Awtrix-Light:
              Loglevel des Adapters auf Debug stellen und Du siehst genau was passiert. Gerne auch hier teilen falls das nicht der Fall ist 🙂
              Der Wert wird so formatiert, wie im ioBroker konfiguriert. Wenn Du ein Komma als Trennzeichen festgelegt hast (was für Deutschland / Europa wohl normal sein sollte), dann wird da ein Komma statt ein Punkt verwendet.
                haus-automatisierung Developer Most Active @Ben1983 last edited by haus-automatisierung
                @ben1983 sagte in Test Adapter Awtrix-Light:
                Gut, dann werfe ich die Datenpunkte komplett aus dem ioBroker raus. Macht ja dann keinen Sinn die Sichtbarkeit darüber einstellen zu können (wenn es eh deprecated ist).
                I Ben1983 2 Replies Last reply Reply Quote 0
                • I
                  infinity @haus-automatisierung last edited by
                  Mittlerweile kann ich den Adapter über die URL installieren.
                  Ich sehe ihn in der Adapterübersicht, auch in den Objekten aber ich habe keine Instanz und kann somit auch nix einstellen.
                  Was habe ich da für ein Problem/Denkfehler?
                  DJMarc75 haus-automatisierung 2 Replies Last reply Reply Quote 0
                  • DJMarc75
                    DJMarc75 @infinity last edited by
                    @infinity über das + eine Instanz erstellen !
                      haus-automatisierung Developer Most Active @infinity last edited by
                      @infinity sagte in Test Adapter Awtrix-Light:
                      Dass Adapter und Instanz zwei paar Schuhe sind 🙂 Grundlagen anschauen
                        Thomas Braun Most Active @haus-automatisierung last edited by
                        Warum kann ich denn hier nicht speichern?
                        Hag rot umrandete Icons auch noch nie gesehen...
                        Version:
                        iobroker.awtrix-light@0.0.11 (git+ssh://git@github.com/klein0r/ioBroker.awtrix-light.git#0adc8447124a5d26f0d37c395f6712d1917e5f12)
                        B M 2 Replies Last reply Reply Quote 0
                        • Ben1983
                          @haus-automatisierung sagte in Test Adapter Awtrix-Light:
                          deprecated
                          Ich glaube es sollte nur anders gemacht werden, denn er schrieb in dem issue, dass es normal persistent ist.
                          Ich denke das ist schon sinnvoll, denn man möchte ja bspw. nicht die app bat und hub und temp sehen.
                          wie gesagt, es soll persistet sein.
                          Siehe:
                          https://github.com/Blueforcer/awtrix-light/issues/178#:~:text=3 hours ago-,It is stored.,-How you deactivate
                          • Ben1983
                            Ben1983 @Ben1983 last edited by
                            @haus-automatisierung hast Du mein Log zum Thema Graphen gesehen?
                              benbensimpson2204 @Thomas Braun last edited by
                              @thomas-braun said in Test Adapter Awtrix-Light:
                              Version:
                              schau mal bei den Namen nach die müssen alle klein geschrieben sein
                              hatte auch das problem das ich dann nicht speichern konnte
                              Olli_M 1 Reply Last reply Reply Quote 0
                                Er schrieb dass man die Apps am besten über das Onscreen menu ausschalten soll - dann ist es persistent
                                  marlan99 @Thomas Braun last edited by marlan99
                                  Die Namen der App erlauben nur noch Kleinbuchstaben und keine Leerzeichen.
                                  Dann ist das Speichern auch möglich
                                    Thomas Braun Most Active @marlan99 last edited by Thomas Braun
                                    @marlan99
                                    Oder stört der Unterstrich da auch? Das sollte aber eigentlich ein zugelassenes Zeichen sein.
                                    [Edit:] Es war der Unterstrich.
                                    • Ben1983
                                      @haus-automatisierung ach direkt an der Uhr. ok
                                      OK, das scheint zu funktionieren.
                                      Ps. Konntest DU was bezüglich der Graphen finden in dem Log?
                                      haus-automatisierung DJMarc75 2 Replies Last reply Reply Quote 0
                                        Da kamen scheinbar keine Daten zurück... daher wird nix angezeigt. Bitte mit der nächsten Version testen.
                                        • DJMarc75
                                          DJMarc75 @Ben1983 last edited by
                                          Welche Knöpfle muss man dazu drücken ??
                                          Ben1983 haus-automatisierung 2 Replies Last reply Reply Quote 0
                                          • Ben1983
                                            @haus-automatisierung OK. Ich werde es Testen
                                            81.1k
                                            2160
                                            1216938
