    4. Test Adapter Awtrix-Light (Awtrix 3)
    • haus-automatisierung
      haus-automatisierung Developer Most Active @AtomicIX last edited by
      @atomicix sagte in Test Adapter Awtrix-Light:
      und dann wir immer immer nur "undefined °C" angezeigt. Also wird nur die Zahl nicht übertragen.
      Bitte ein Debug-Log teilen.
      M AtomicIX 2 Replies Last reply Reply Quote 0
        mrjeschke @haus-automatisierung last edited by
        Bei mir ist es die app temperature. Die anderen beiden laufen über alias.
        2023-06-08 19:52:14.235 - debug: awtrix-light.0 (7415) sending "GET" request to "/api/stats" without data
        2023-06-08 19:52:14.290 - debug: awtrix-light.0 (7415) received 200 response from "/api/stats" with content: {"bat":97,"bat_raw":660,"lux":"8","ldr_raw":547,"ram":152948,"bri":120,"temp":"25","hum":"29","uptime":"76","wifi_signal":-41,"up_available":false,"messages":1,"version":"0.68","indicator1":true,"indicator2":false,"indicator3":true}
        2023-06-08 19:52:14.342 - debug: awtrix-light.0 (7415) sending "GET" request to "/api/settings" without data
        2023-06-08 19:52:14.389 - debug: awtrix-light.0 (7415) received 200 response from "/api/settings" with content: {"FPS":23,"ABRI":true,"BRI":120,"ATRANS":true,"TCOL":31,"TSPEED":400,"ATIME":7000,"TFORMAT":"%H:%M:%S","DFORMAT":"%d.%m.%y","SOM":true,"CEL":true,"BLOCKN":false,"MAT":0,"SOUND":true,"GAMMA":0,"UPPERCASE":true,"CCORRECTION":"","CTEMP":"","WD":true,"WDCA":65535,"WDCI":27501,"TIME_COL":0,"DATE_COL":0,"HUM_COL":0,"TEMP_COL":0,"BAT_COL":0}
        2023-06-08 19:53:00.624 - debug: awtrix-light.0 (7415) [refreshCustomApp] Refreshing custom app "temperatur" with icon "6157" and text "%s"
        2023-06-08 19:53:00.625 - debug: awtrix-light.0 (7415) sending "POST" request to "/api/custom?name=temperatur" with data: {"text":"undefined","icon":"6157","duration":5}
        2023-06-08 19:53:00.753 - debug: awtrix-light.0 (7415) received 200 response from "/api/custom?name=temperatur" with content: "OK"
        2023-06-08 19:53:08.038 - warn: javascript.0 (479) script.js.common.Awtrix-Test: Neuer Wert: 18.95
        2023-06-08 19:53:08.038 - warn: javascript.0 (479) script.js.common.Awtrix-Test: Zeitstempel: 19:53:08.036
        2023-06-08 19:53:08.038 - debug: awtrix-light.0 (7415) [refreshCustomApp] Refreshing custom app "test" with icon "6157" and text "%s"
        2023-06-08 19:53:08.038 - debug: awtrix-light.0 (7415) sending "POST" request to "/api/custom?name=test" with data: {"text":"18.95","icon":"6157","duration":5}
        2023-06-08 19:53:08.039 - debug: awtrix-light.0 (7415) [refreshCustomApp] Refreshing custom app "nocheintest" with icon "null" and text "%s %u"
        2023-06-08 19:53:08.039 - debug: awtrix-light.0 (7415) [refreshCustomApp] formatted value of "alias.0.Wetter.Wetter2" from 18.95 to 18,95 (2 decimals)
        2023-06-08 19:53:08.039 - debug: awtrix-light.0 (7415) sending "POST" request to "/api/custom?name=nocheintest" with data: {"text":"18,95 °C","icon":null,"duration":5}
        2023-06-08 19:53:08.040 - debug: awtrix-light.0 (7415) [onStateChange] ignoring customApps state change of "openweathermap.0.forecast.current.temperature" to 18.95 - refreshes too fast (within 0 seconds)
        2023-06-08 19:53:08.124 - debug: awtrix-light.0 (7415) received 200 response from "/api/custom?name=test" with content: "OK"
        2023-06-08 19:53:08.179 - debug: awtrix-light.0 (7415) received 200 response from "/api/custom?name=nocheintest" with content: "OK"
        2023-06-08 19:53:14.235 - debug: awtrix-light.0 (7415) refreshing device state
        2023-06-08 19:53:14.236 - debug: awtrix-light.0 (7415) re-creating refresh state timeout
        2023-06-08 19:53:14.236 - debug: awtrix-light.0 (7415) sending "GET" request to "/api/stats" without data
        2023-06-08 19:53:14.363 - debug: awtrix-light.0 (7415) received 200 response from "/api/stats" with content: {"bat":97,"bat_raw":660,"lux":"8","ldr_raw":539,"ram":151340,"bri":120,"temp":"25","hum":"29","uptime":"137","wifi_signal":-38,"up_available":false,"messages":3,"version":"0.68","indicator1":true,"indicator2":false,"indicator3":true}
        2023-06-08 19:53:14.412 - debug: awtrix-light.0 (7415) sending "GET" request to "/api/settings" without data
        2023-06-08 19:53:14.432 - debug: awtrix-light.0 (7415) received 200 response from "/api/settings" with content: {"FPS":23,"ABRI":true,"BRI":120,"ATRANS":true,"TCOL":31,"TSPEED":400,"ATIME":7000,"TFORMAT":"%H:%M:%S","DFORMAT":"%d.%m.%y","SOM":true,"CEL":true,"BLOCKN":false,"MAT":0,"SOUND":true,"GAMMA":0,"UPPERCASE":true,"CCORRECTION":"","CTEMP":"","WD":true,"WDCA":65535,"WDCI":27501,"TIME_COL":0,"DATE_COL":0,"HUM_COL":0,"TEMP_COL":0,"BAT_COL":0}
        • DJMarc75
          DJMarc75 @reini last edited by
          @reini
          • ebenfalls Anrufer per Fritzbox
          • wenn mein Zwerghamster "aktiv" wird 🙂
          • aktueller Filmtitel über PLEX
          • Begrüßungen wenn eine bekannte Person dem Netzwerk beitritt
          • wenns an der Tür klingelt
          • usw... 😉
          • AtomicIX
            AtomicIX @haus-automatisierung last edited by AtomicIX
            awtrix-light.0
            2023-06-09 14:32:50.974	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
            awtrix-light.0
            2023-06-09 14:32:50.909	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"49°C","icon":"9840","duration":5}
            awtrix-light.0
            2023-06-09 14:32:50.909	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.6 to 49 (0 decimals)
            awtrix-light.0
            2023-06-09 14:32:50.909	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
            awtrix-light.0
            2023-06-09 14:32:31.633	debug	received 200 response from "/api/stats" with content: {"bat":65,"bat_raw":600,"lux":"1289","ldr_raw":1019,"ram":150840,"bri":120,"temp":"36","hum":"14","uptime":"2474","wifi_signal":-85,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
            awtrix-light.0
            2023-06-09 14:32:31.559	debug	re-creating refresh state timeout
            awtrix-light.0
            2023-06-09 14:32:31.558	debug	sending "GET" request to "/api/stats" without data
            awtrix-light.0
            2023-06-09 14:32:31.558	debug	refreshing device state
            awtrix-light.0
            2023-06-09 14:31:50.966	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
            awtrix-light.0
            2023-06-09 14:31:50.852	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"48°C","icon":"9840","duration":5}
            awtrix-light.0
            2023-06-09 14:31:50.851	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.4 to 48 (0 decimals)
            awtrix-light.0
            2023-06-09 14:31:50.851	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
            awtrix-light.0
            2023-06-09 14:31:35.915	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
            awtrix-light.0
            2023-06-09 14:31:35.882	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"49°C","icon":"9840","duration":5}
            awtrix-light.0
            2023-06-09 14:31:35.882	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.5 to 49 (0 decimals)
            awtrix-light.0
            2023-06-09 14:31:35.881	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
            awtrix-light.0
            2023-06-09 14:31:31.614	debug	received 200 response from "/api/stats" with content: {"bat":67,"bat_raw":603,"lux":"2814","ldr_raw":1021,"ram":151068,"bri":120,"temp":"36","hum":"14","uptime":"2414","wifi_signal":-82,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
            awtrix-light.0
            2023-06-09 14:31:31.558	debug	re-creating refresh state timeout
            awtrix-light.0
            2023-06-09 14:31:31.558	debug	sending "GET" request to "/api/stats" without data
            awtrix-light.0
            2023-06-09 14:31:31.557	debug	refreshing device state
            awtrix-light.0
            2023-06-09 14:31:03.249	debug	received 200 response from "/api/custom?name=aussen" with content: "OK"
            awtrix-light.0
            2023-06-09 14:31:03.136	debug	[onStateChange] ignoring customApps state change of "netatmo.0.5f451b174be7c35c0a5ef69f.70-ee-50-5e-d1-d4.02-00-00-8d-d2-46.Temperature.Temperature" to 29.2 - refreshes too fast (within 1 seconds)
            awtrix-light.0
            2023-06-09 14:31:03.132	debug	sending "POST" request to "/api/custom?name=aussen" with data: {"text":"undefined °C","icon":"4285","duration":5}
            awtrix-light.0
            2023-06-09 14:31:03.132	debug	[refreshCustomApp] Refreshing custom app "aussen" with icon "4285" and text "%s %u"
            admin.0
            2023-06-09 14:30:45.262	info	<== Disconnect system.user.admin from ::ffff:192.168.222.155 admin
            awtrix-light.0
            2023-06-09 14:30:31.606	debug	received 200 response from "/api/stats" with content: {"bat":66,"bat_raw":601,"lux":"7572","ldr_raw":1022,"ram":150844,"bri":120,"temp":"36","hum":"14","uptime":"2354","wifi_signal":-82,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
            awtrix-light.0
            2023-06-09 14:30:31.557	debug	re-creating refresh state timeout
            awtrix-light.0
            2023-06-09 14:30:31.556	debug	sending "GET" request to "/api/stats" without data
            awtrix-light.0
            2023-06-09 14:30:31.556	debug	refreshing device state
            awtrix-light.0
            2023-06-09 14:30:20.960	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
            awtrix-light.0
            2023-06-09 14:30:20.858	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"48°C","icon":"9840","duration":5}
            awtrix-light.0
            2023-06-09 14:30:20.858	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.4 to 48 (0 decimals)
            awtrix-light.0
            2023-06-09 14:30:20.857	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
            awtrix-light.0
            2023-06-09 14:29:31.604	debug	received 200 response from "/api/stats" with content: {"bat":64,"bat_raw":598,"lux":"7033","ldr_raw":1022,"ram":151112,"bri":120,"temp":"36","hum":"14","uptime":"2294","wifi_signal":-83,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
            awtrix-light.0
            2023-06-09 14:29:31.556	debug	re-creating refresh state timeout
            awtrix-light.0
            2023-06-09 14:29:31.555	debug	sending "GET" request to "/api/stats" without data
            awtrix-light.0
            2023-06-09 14:29:31.555	debug	refreshing device state
            awtrix-light.0
            2023-06-09 14:28:50.947	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
            awtrix-light.0
            2023-06-09 14:28:50.854	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"48°C","icon":"9840","duration":5}
            awtrix-light.0
            2023-06-09 14:28:50.853	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.3 to 48 (0 decimals)
            awtrix-light.0
            2023-06-09 14:28:50.853	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
            awtrix-light.0
            2023-06-09 14:28:35.999	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
            awtrix-light.0
            2023-06-09 14:28:35.878	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"48°C","icon":"9840","duration":5}
            awtrix-light.0
            2023-06-09 14:28:35.878	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.2 to 48 (0 decimals)
            awtrix-light.0
            2023-06-09 14:28:35.878	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
            awtrix-light.0
            2023-06-09 14:28:32.028	debug	re-creating history apps timeout (300 seconds)
            awtrix-light.0
            2023-06-09 14:28:31.600	debug	received 200 response from "/api/stats" with content: {"bat":64,"bat_raw":598,"lux":"7572","ldr_raw":1022,"ram":151116,"bri":120,"temp":"36","hum":"14","uptime":"2234","wifi_signal":-83,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
            awtrix-light.0
            2023-06-09 14:28:31.554	debug	re-creating refresh state timeout
            awtrix-light.0
            2023-06-09 14:28:31.553	debug	sending "GET" request to "/api/stats" without data
            awtrix-light.0
            2023-06-09 14:28:31.553	debug	refreshing device state
            awtrix-light.0
            2023-06-09 14:27:31.589	debug	received 200 response from "/api/stats" with content: {"bat":65,"bat_raw":600,"lux":"7572","ldr_raw":1022,"ram":151112,"bri":120,"temp":"36","hum":"14","uptime":"2174","wifi_signal":-81,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
            awtrix-light.0
            2023-06-09 14:27:31.552	debug	re-creating refresh state timeout
            awtrix-light.0
            2023-06-09 14:27:31.551	debug	sending "GET" request to "/api/stats" without data
            awtrix-light.0
            2023-06-09 14:27:31.551	debug	refreshing device state
            awtrix-light.0
            2023-06-09 14:27:20.937	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
            awtrix-light.0
            2023-06-09 14:27:20.872	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"48°C","icon":"9840","duration":5}
            awtrix-light.0
            2023-06-09 14:27:20.872	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.3 to 48 (0 decimals)
            awtrix-light.0
            2023-06-09 14:27:20.872	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
            awtrix-light.0
            2023-06-09 14:27:05.999	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
            awtrix-light.0
            2023-06-09 14:27:05.866	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"48°C","icon":"9840","duration":5}
            awtrix-light.0
            2023-06-09 14:27:05.866	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.2 to 48 (0 decimals)
            awtrix-light.0
            2023-06-09 14:27:05.866	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
            awtrix-light.0
            2023-06-09 14:26:31.695	debug	received 200 response from "/api/stats" with content: {"bat":66,"bat_raw":601,"lux":"7033","ldr_raw":1022,"ram":151564,"bri":120,"temp":"36","hum":"13","uptime":"2114","wifi_signal":-85,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
            awtrix-light.0
            2023-06-09 14:26:31.550	debug	re-creating refresh state timeout
            awtrix-light.0
            2023-06-09 14:26:31.549	debug	sending "GET" request to "/api/stats" without data
            awtrix-light.0
            2023-06-09 14:26:31.549	debug	refreshing device state```
              MCU last edited by MCU
              @nordlicht67 Es gibt trotzdem weiterhin die Möglichkeit die Standard-Apps per javascript auszuschalten, wenn man sie nicht im Menu dauerhaft ausstellen möchte.
              Ein Bespiel:
              let ipaddress = '192.168.178.xxx';
              // show: false -> aus; true -> an
              // name anpassen : time, date, temp, hum, bat, eyes
              exec((['curl -X POST ','-d  "[{ name: \'time\', show: false }]" ','-H \'Content-Type: application/json\' ','\'http://'+ipaddress+'/api/apps\''].join('')));
                reini last edited by reini
                würde es noch Sinn machen jeder benutzerdefinierten App einen eigenen Farbcode mitgeben zu können? Kann das der Adapter aussteuern?
                  haus-automatisierung Developer Most Active @reini last edited by
                  @reini sagte in Test Adapter Awtrix-Light:
                  Ich brauche es nicht, daher habe ich die Fleißarbeit erstmal nicht gemacht 🙂 Aber ja, kann ich noch einbauen
                    @atomicix Mh, das sieht aber erstmal so aus als ob alles klappt? Kam in dem Durchlauf wieder ein "undefined"?
                      noch ne blöde Frage, was macht Ihr am Abend mit den Ding? Ein setzen von Display/Power auf false hat bei mir keinerlei Auswirkung?! Möchte das Gerät ja nicht die ganze Nacht on haben sondern per Skript steuern..
                      DJMarc75 haus-automatisierung 2 Replies Last reply Reply Quote 0
                      • AtomicIX
                        Ja, wenn es erst mal da ist, bleibt es, bis zum Neustart. Dann ist wieder kurz alles gut, und dann bleibt es. Aber nur bei aussen (netatmo), die Dusche (sonoff) ist alles super.
                        • DJMarc75
                          Dann machst Du halt was falsch. Wie setzt Du den DP genau ?
                            Auch hier: Debug-Log bitte 🙂 Dass Du States unbestätigt (ack: false) schreiben musst ist hoffentlich klar?
                              erfggi @Thomas Braun last edited by
                              @thomas-braun sagte in Test Adapter Awtrix-Light:
                              Anrufer auf der FritzBox laufen hier bei mir durch.
                              hast du einen Tipp wie das als App geht? ich bekomme das nicht hin.
                                Thomas Braun Most Active @erfggi last edited by
                                @erfggi
                                Nicht als App, sondern als Blockly. Gibt einen passenden Baustein zu awtrix.
                                  Danke! gefunden und funktioniert.
                                  tobasium 1 Reply Last reply Reply Quote 0
                                  • AtomicIX
                                    Hier noch mal ein auszug aus dem Log, Also Netatmo aktualisiert alle 10 min
                                    Gefiltert nur auf Netatmo
                                    awtrix-light.0
                                    2023-06-09 21:41:03.042	debug	[onStateChange] ignoring customApps state change of "netatmo.0.5f451b174be7c35c0a5ef69f.70-ee-50-5e-d1-d4.02-00-00-8d-d2-46.Temperature.Temperature" to 21.2 - refreshes too fast (within 1 seconds)
                                    awtrix-light.0
                                    2023-06-09 21:31:03.010	debug	[onStateChange] ignoring customApps state change of "netatmo.0.5f451b174be7c35c0a5ef69f.70-ee-50-5e-d1-d4.02-00-00-8d-d2-46.Temperature.Temperature" to 21.5 - refreshes too fast (within 1 seconds)
                                    awtrix-light.0
                                    2023-06-09 21:21:03.005	debug	[onStateChange] ignoring customApps state change of "netatmo.0.5f451b174be7c35c0a5ef69f.70-ee-50-5e-d1-d4.02-00-00-8d-d2-46.Temperature.Temperature" to 21.8 - refreshes too fast (within 1 seconds)
                                    EDIT:
                                    Also das mit dem zusätzlichen Datenpunkt als Merker, wo die Temperaturen übertragen werden, läuft ohne Probleme. Was mir da nur aufgefallen ist, ich habe die Dezimal Stellen für die Cutom App auf 0 stehen.
                                    Wenn ich den original Netatmo Datenpunkt nehme, wird das auch so angezeigt, wenn ich den Merker Datenpunkt nehme, habe ich eine Dezimal Stelle, ohne die Einstellungen zu ändern. Es wird ein "Punkt" angezeigt. Der Netatmo Datenpunkt ein ein Komma
                                      ich kann die standard apps nicht mehr auschalten..
                                      batt, date, eyes brauch ich nicht..
                                      • Ben1983
                                        Ben1983 @arteck last edited by
                                        @arteck Mach es am besten direkt über die Uhr an den Tasten, funktioniert top.
                                          arteck Developer Most Active @Ben1983 last edited by
                                          @ben1983 das hab ich gerade auch gemacht.... danke
                                            Ich verstehe nicht ganz? Dann ist das eine wohl vom Objekttyp string und das andere eine number? Generell werden numerische Werte immer mit einem Punkt als Trennzeichen gespeichert, aber der Admin zeigt das entsprechend deiner Konfiguration an (also macht aus dem Punkt dann ein Komma falls so in den Einstellungen festgelegt). Zeig mal bitte wie die beiden Objekte definierte sind.
                                            AtomicIX 1 Reply Last reply Reply Quote 0
                                            81.1k
                                            2160
                                            1216489
