    4. ConBee II Stick nach Rpi Update nicht mehr erreichbar
      Trafficlight @Ro75 last edited by
      @ro75
      Hi Ro75 genau das ist das. Allerdings bekomme ich nach folgendem Schritt diese Ausgabe:
      Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
      Get:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54.0 kB]
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
      Err:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease
        The following signatures couldn't be verified because the public key is not available:                 NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
      Reading package lists... Done
      W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The follo                wing signatures couldn't be verified because the public key is not available: NO_PUBKEY 6                48ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
      E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is n                ot signed.
      N: Updating from such a repository can't be done securely, and is therefore disabled by d                efault.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      somit kann ich den Schritt:
      sudo apt -t bullseye-proposed-updates install udev
      E: The value 'bullseye-proposed-updates' is invalid for APT::Default-Release as such a release is not available in the sources
      nicht durchführen.
        Thomas Braun Most Active @Trafficlight last edited by
        @trafficlight
        Da fehlt der Key...
        @mickym Kannste das noch nachtragen in der Anleitung?
        T mickym 2 Replies Last reply Reply Quote 0
          Trafficlight @Thomas Braun last edited by
          Welcher Key? Wo finde ich diesen und wo muss ich den einfügen?
            @trafficlight
            Der Key aus der Meldung:
              Was bedeutet das nun genau? Was muss ich tun?
                @trafficlight
                sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
                sudo apt update
                apt policy udev
                  soweit hat es funktioniert leider sieht meine Ausgabe etwas anders aus:
                    Installed: 247.3-7+rpi1+deb11u2
                    Candidate: 247.3-7+rpi1+deb11u2
                    Version table:
                   *** 247.3-7+rpi1+deb11u2 500
                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                          100 /var/lib/dpkg/status
                       247.3-7+deb11u3 500
                          500 http://deb.debian.org/debian bullseye-proposed-updates/main armhf Packages
                  Phoscon zeigt immer noch "unknown"
                    Thomas Braun Most Active @Trafficlight last edited by Thomas Braun
                    @trafficlight
                    Da ist die Versionierung ungünstig. Bzw der rpi1-Patch ist nicht drin.
                    sudo apt install udev=247.3-7+deb11u3
                    Setz das danach auf hold.
                    Die gleiche Versionsnummer auch für libudev1 und udev-dev verwenden, falls das gleich um die Ecke kommt.
                      ich bekomme es einfach nicht hin…
                      Building dependency tree... Done
                      Some packages could not be installed. This may mean that you have
                      requested an impossible situation or if you are using the unstable
                      distribution that some required packages have not yet been created
                      or been moved out of Incoming.
                      The following information may help to resolve the situation:
                      The following packages have unmet dependencies:
                       udev : Depends: libudev1 (= 247.3-7+deb11u3) but 247.3-7+rpi1+deb11u2
                      is to be installed
                      E: Unable to correct problems, you have held broken packages.
                        @trafficlight
                        Deswegen sag ich ja: libudev1 in gleicher Version installieren...
                        sudo apt install udev=247.3-7+deb11u3 libudev1=247.3-7+deb11u3
                          so thomas-braun du bist mein persönlicher held 😉vielen vielen dank für deine hilfe 👍
                            @trafficlight
                            udev auf hold gesetzt?
                            apt-mark showhold
                            sudo apt update
                            in Gänze schaut wie aus?
                              Habe durchgeführt:
                              sudo apt-mark hold udev
                              bekomme dann angezeigt:
                              pi@raspberrypi:~ $ apt-mark showhold
                              udev
                              Denke sollte nun passen. Sensoren und Lichter funktionieren wieder. 👏
                                @trafficlight
                                Und der zweite Befehl?
                                • mickym
                                  mickym Most Active @Thomas Braun last edited by
                                  @thomas-braun Hab ich gemacht.
                                    welchen zweiten Befehl meinst du?
                                      @trafficlight
                                      sudo apt update
                                      Volllständig posten.
                                      1144
