    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev)
      Joel @Thomas Braun last edited by
      @thomas-braun Mach ich. Danke!
        JensBHB last edited by
        Irgendwie klappt es bei mir nicht. Liegt wohl daran, dass ich Raspbian installiert habe?
        udev:
          Installed: 247.3-7+rpi1+deb11u2
          Candidate: 247.3-7+rpi1+deb11u2
          Version table:
         *** 247.3-7+rpi1+deb11u2 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                100 /var/lib/dpkg/status
        Jemand eine Idee wie ich an die "proposed-updates" von Raspbian rankomme? Oder habe ich einen Denkfehler?
        pi@iobroker-master:/etc/apt/sources.list.d $ sudo apt update
        Get:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54.0 kB]
        Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
        Hit:3 http://phoscon.de/apt/deconz bullseye InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
        Err:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
        Reading package lists... Done
        W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
        E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
        pi@iobroker-master:/etc/apt/sources.list.d $ sudo apt -t bullseye-proposed-updates install udev
        E: The value 'bullseye-proposed-updates' is invalid for APT::Default-Release as such a release is not available in the sources
          Thomas Braun Most Active last edited by
          @jensbhb
          Da muss der Schlüssel angelegt werden. Steht aber irgendwo hier im Thread schon drin.
            JensBHB @Thomas Braun last edited by
            @thomas-braun Vielen Dank. Ich hab das überlesen... Der Wald - lauter Bäume 🙂
              Thomas Braun Most Active @JensBHB last edited by
              @jensbhb
              sudo apt update
              apt policy udev
              wirft nun was raus?
                @thomas-braun Ich hab die Nerven verloren und ein Image eingespielt und die 1. Variante genutzt. Danke für die Hilfe!
                  @jensbhb sagte in Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev):
                  Warum?
                    @thomas-braun Naja ich hab das Image eingespielt bevor Du mir den Hinweis auf den Schlüssel gegeben hast.
                      Thomas Braun Most Active @JensBHB last edited by Thomas Braun
                      @jensbhb
                      Image einspielen ist halt irgendwie immer nur die hilfloseste Aktion. Lernste nix bei und bei der nächsten Meldung stehste dann genauso im kurzen Hemd da
                      Gilt genauso für die tapferen Ritter von der Beta-Tafelrunde. 'Oh, da klemmt irgendwas... Schnell ein Image einspielen'
                      Bringt halt nur keinem was.
                        JensBHB @Thomas Braun last edited by JensBHB
                        @thomas-braun Das sehe ich schon anders. Mein Raspi läuft im Produktiveinsatz, da ging es um eine schnelle Abhilfe. Bin ja froh, dass ich hier schon eine Menge gelernt habe - aber ich gebe zu, ich profitiere von Experten hier. Bei diesem Fehler war es ja schon fast ein Zufall, dass ich hier einen Lösungsansatz gefunden habe. Ich dachte es lag an meinem Umzug auf eine SSD (in dessen Folge ist der Fehler bei mir aufgetreten, weil ich da apt update / upgrade gemacht habe). Und es war für mich nicht zu erkennen, dass mir hier ein Schlüssel fehlen könnte, damit der vorgeschlagene 2. Lösungsweg funktioniert.
                          Deswegen steht der Hinweis auch sehr eindeutig in der Meldung.
                          Der Key ist auch sehr bekannt, da kommt beim ersten Treffer bei deiner bevorzugten Suchmaschine schon was bei herum. Und hier im Forum findet sich der auch bereits in diversen Einträgen. Also weniger Panik schieben, mehr Struktur bei der Suche.
                            @thomas-braun sagte in Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev):
                            Natürlich habe ich gesucht und bei Stack Overflow eine Lösung für den fehlenden Public Key gefunden. Und dann hab ich halt danach den hier vorgeschlagenen 1. Lösungsweg verfolgt und nicht den zweiten. Ich bin halt davon ausgegangen, dass der zweite Lösungsweg für meine Konfig nicht passt, aufgrund der abweichenden Quelle. Den Zusammenhang habe ich erst durch Deinen Hinweis realisiert. Somit habe ich etwas dazu gelernt, falls es erneut Probleme mit UDEV gibt.
                            Vielleicht findet der OP die Zeit die Thematik des Public Keys im Eingangspost unterzubringen, das wäre ja zumindest hilfreich für Andere, die wie ich den Zusammenhang nicht gleich erkennen, aber den zweiten Lösungsweg verfolgen.
                            • mickym
                              mickym Most Active @JensBHB last edited by
                              Habe ich gestern bereits gemacht. 🙂
                                kleh58 last edited by
                                Moin aus Hamburg.
                                Auch ich bin von diesem Update betroffen und bekomme den Conbee nicht wieder zum laufen.
                                Da ich das Update schon ausgeführt hatte, bin ich nach Punkt 2 vorgegangen. Auch die Geschichte mit dem Schlüssel habe ich befolgt. Alles erfolglos.
                                Ich bin noch Einsteiger und nicht so bewandert.
                                Kann da mal Jemand drüber Schauen.
                                MfG```
                                code_text
                                ```pi@raspberrypi:~ $ sudo apt update
                                OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                Holen:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54,0 kB]
                                OK:3 http://phoscon.de/apt/deconz bullseye InRelease
                                OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                Holen:5 https://repos.influxdata.com/debian stretch InRelease [7.039 B]
                                OK:6 https://deb.nodesource.com/node_18.x bullseye InRelease
                                Holen:7 https://packages.grafana.com/oss/deb stable InRelease [5.984 B]
                                Fehl:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                                  Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                                Fehl:5 https://repos.influxdata.com/debian stretch InRelease
                                  Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                Fehl:7 https://packages.grafana.com/oss/deb stable InRelease
                                  Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9E439B102CF3C0C6
                                Paketlisten werden gelesen… Fertig
                                W: GPG-Fehler: http://deb.debian.org/debian bullseye-proposed-updates InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                                E: Das Depot »http://deb.debian.org/debian bullseye-proposed-updates InRelease« ist nicht signiert.
                                N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                                N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                                W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian stretch InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://packages.grafana.com/oss/deb stable InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9E439B102CF3C0C6
                                pi@raspberrypi:~ $ ^C
                                  Thomas Braun Most Active @kleh58 last edited by
                                  @kleh58
                                  Da sind insgesamt 3 Schlüssel nicht richtig. Für Grafana + Influx siehe:
                                  https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
                                  Wenn die drin sind schau nochmal nach dem key für die proposed-updates
                                    @kleh58 sagte in Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev):
                                    Bitte dann auch die vollständigen Ein- wie Ausgaben zu den Aktionen sehen lassen. So kann man nur raten was du da gemacht hast.
                                      kleh58 @Thomas Braun last edited by
                                      @thomas-braun Danke für die schnelle Antwort. Außer dem hier beschriebenen Befehl für den Schlüssel, habe ich null Ahnung wo und wie ich die beiden Anderen her bekomme.
                                      MfG
                                        Hatte ich nicht einen Thread verlinkt, wo das alles drin steht? Egal, kann ich auch nochmal aus dem Hut zaubern:
                                          @thomas-braun Danke, ich glaube es hat hingehauen.```
                                          code_text
                                          Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                                          0
                                          ****Fettschrift****
                                            Woran machst du das fest?
                                            Die Zeile sagt eigentlich nur aus, das es da noch irgendwo klemmt, sonst würde die nämlich nicht ausgegeben.
                                            conbee 2 usb port zigbee2mqtt
                                            42
                                            361
                                            85083
