    4. Test Adapter Awtrix-Light (Awtrix 3)
      Rushmed Most Active last edited by
      ich habe generell Verbinbdungsprobleme mit dem Adapter und der Ulanzi.
      Hier ein Log von mehreren Adapterneustarts:
      awtrix-light.0
      2023-06-10 12:50:43.954	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      awtrix-light.0
      2023-06-10 12:50:43.952	info	terminating
      awtrix-light.0
      2023-06-10 12:50:43.931	error	Exception-Code: ECONNABORTED: timeout of 3000ms exceeded
      awtrix-light.0
      2023-06-10 12:50:43.930	error	AxiosError: timeout of 3000ms exceeded at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.awtrix-light/node_modules/axios/dist/node/axios.cjs:3047:16) at RedirectableRequest.emit (node:events:513:28) at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:164:12) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
      awtrix-light.0
      2023-06-10 12:50:43.929	error	unhandled promise rejection: timeout of 3000ms exceeded
      awtrix-light.0
      2023-06-10 12:50:43.928	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      awtrix-light.0
      2023-06-10 12:50:43.877	info	error ECONNABORTED from /api/apps: timeout of 3000ms exceeded
      awtrix-light.0
      2023-06-10 12:50:40.744	warn	You should update your Awtrix Light - supported version of this adapter is 0.68 (or later). Your current version is 0.67
      awtrix-light.0
      2023-06-10 12:49:42.626	info	error ECONNABORTED from /api/stats: timeout of 3000ms exceeded
      awtrix-light.0
      2023-06-10 12:49:39.501	info	starting. Version 0.0.13 (non-npm: klein0r/ioBroker.awtrix-light#b8ad47fdc5391c97e3c9470d606a277322cf2777) in /opt/iobroker/node_modules/iobroker.awtrix-light, node: v18.16.0, js-controller: 4.0.24
      awtrix-light.0
      2023-06-10 12:49:03.865	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      awtrix-light.0
      2023-06-10 12:49:03.864	info	terminating
      awtrix-light.0
      2023-06-10 12:49:03.859	error	Exception-Code: ECONNABORTED: timeout of 3000ms exceeded
      awtrix-light.0
      2023-06-10 12:49:03.858	error	AxiosError: timeout of 3000ms exceeded at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.awtrix-light/node_modules/axios/dist/node/axios.cjs:3047:16) at RedirectableRequest.emit (node:events:513:28) at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:164:12) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
      awtrix-light.0
      2023-06-10 12:49:03.858	error	unhandled promise rejection: timeout of 3000ms exceeded
      awtrix-light.0
      2023-06-10 12:49:03.857	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      awtrix-light.0
      2023-06-10 12:49:03.803	info	error ECONNABORTED from /api/apps: timeout of 3000ms exceeded
      awtrix-light.0
      2023-06-10 12:49:00.693	warn	You should update your Awtrix Light - supported version of this adapter is 0.68 (or later). Your current version is 0.67
      awtrix-light.0
      2023-06-10 12:49:00.339	info	starting. Version 0.0.13 (non-npm: klein0r/ioBroker.awtrix-light#b8ad47fdc5391c97e3c9470d606a277322cf2777) in /opt/iobroker/node_modules/iobroker.awtrix-light, node: v18.16.0, js-controller: 4.0.24
      awtrix-light.0
      2023-06-10 12:48:54.009	info	starting. Version 0.0.13 (non-npm: klein0r/ioBroker.awtrix-light#b8ad47fdc5391c97e3c9470d606a277322cf2777) in /opt/iobroker/node_modules/iobroker.awtrix-light, node: v18.16.0, js-controller: 4.0.24
      awtrix-light.0
      2023-06-10 12:48:53.728	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      awtrix-light.0
      2023-06-10 12:48:53.726	info	terminating
      awtrix-light.0
      2023-06-10 12:48:53.223	info	Got terminate signal TERMINATE_YOURSELF
      awtrix-light.0
      2023-06-10 12:48:18.468	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      awtrix-light.0
      2023-06-10 12:48:18.466	info	terminating
      awtrix-light.0
      2023-06-10 12:48:18.456	error	Exception-Code: ECONNABORTED: timeout of 3000ms exceeded
      awtrix-light.0
      2023-06-10 12:48:18.456	error	AxiosError: timeout of 3000ms exceeded at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.awtrix-light/node_modules/axios/dist/node/axios.cjs:3047:16) at RedirectableRequest.emit (node:events:513:28) at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:164:12) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
      awtrix-light.0
      2023-06-10 12:48:18.455	error	unhandled promise rejection: timeout of 3000ms exceeded
      awtrix-light.0
      2023-06-10 12:48:18.455	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      awtrix-light.0
      2023-06-10 12:48:18.397	info	error ECONNABORTED from /api/apps: timeout of 3000ms exceeded
      awtrix-light.0
      2023-06-10 12:48:14.533	warn	You should update your Awtrix Light - supported version of this adapter is 0.68 (or later). Your current version is 0.67
      awtrix-light.0
      2023-06-10 12:48:14.156	info	starting. Version 0.0.13 (non-npm: klein0r/ioBroker.awtrix-light#b8ad47fdc5391c97e3c9470d606a277322cf2777) in /opt/iobroker/node_modules/iobroker.awtrix-light, node: v18.16.0, js-controller: 4.0.24
      awtrix-light.0
      2023-06-10 12:48:06.825	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      awtrix-light.0
      2023-06-10 12:48:06.823	info	terminating
      awtrix-light.0
      2023-06-10 12:48:06.818	info	Got terminate signal TERMINATE_YOURSELF
      Adapterversion 0.0.13
      AWTRIX light sollte 0.68 sein aber 0.67 wird angezeigt. Das Problem ist ja bekannt.
      Die Verbindung hat auch schonmal geklappt aber hielt dann nicht lange.
      Das WebUI von AWTRIX ist erreich- und steuerbar.
      Die Steuerung per MQTT funktioniert auch nicht aber die DPs werden erstellt.
      Was mache ich falsch? Was kann ich tun?
      • haus-automatisierung
        haus-automatisierung Developer Most Active @Rushmed last edited by
        @rushmed sagte in Test Adapter Awtrix-Light:
        Das ist ja ein Netzwerk / WLAN-Thema und da kann der Adapter ja erstmal nichts für. Ich würde mal einen anderen Standort probieren. Ansonsten hatte irgendjemand hier im Thread auch mal über Probleme gesprochen, wenn das 5GHz Netz die gleiche SSID hat. Ich habe damit keinerlei Probleme im UniFi Umfeld.
          haus-automatisierung Developer Most Active @AtomicIX last edited by
          @atomicix sagte in Test Adapter Awtrix-Light:
          Sorry, hatte ich eben aktualisiert:
          Das sieht ja richtig aus. Aber warum mixed? Muss mit number (Zahl) genauso funktionieren.
          Und was hat es jetzt mit dem Geheimnisvollen Alias auf sich? Darf den niemand sehen?
          AtomicIX 1 Reply Last reply Reply Quote 1
          • AtomicIX
            AtomicIX @haus-automatisierung last edited by
            @haus-automatisierung Wenn ich auf Zahl stelle, bekomme ich wieder "Undefined"
            Der Alias ist ein DP, der über ein Blockly einfach nur vom Netatmo DP Aktualisiert wird:
              Rushmed Most Active @haus-automatisierung last edited by Rushmed
              @haus-automatisierung Danke für die Antwort.
              Ich glaube nicht dass es ein Netzwerproblem ist. Wie geasgt, das WebUI ist erreich und steuerbar und über die Ulanzi kann ich auch Updates laden.
              Lt. UDM sieht die Verbindung auch gut aus, da habe ich deutlich schlechtere Devices ohne probleme laufen:
              Ich probier trotzdem mal mit dem Standort rum.
              Diese Meldung kommt auch häufig:
              DJMarc75 haus-automatisierung 2 Replies Last reply Reply Quote 0
              • DJMarc75
                DJMarc75 @Rushmed last edited by
                @rushmed Vertraue niemals Werten einer GUI 😉
                  Und Du hast nur die IP konfiguriert? Manche haben hier schon eine komplette URL mit http:// angegeben. Das ist natürlich falsch.
                    @haus-automatisierung Jepp, nur die IP.
                    • DJMarc75
                      @rushmed unter Umständen ist Dein System auch nicht ganz "grade" ?!
                      schau Dir mal
                      iob diag
                      an...
                      hat aber hier dann im Thread nix zu suchen 😉
                        Rushmed Most Active @DJMarc75 last edited by
                        @djmarc75 Das sieht gut aus.
                        • DJMarc75
                          Das sieht gut aus.
                          Meine Frau auch ... aber von meiner Frau poste ich hier nicht die Ausgabe 😀
                          Die Ausgabe von Dir (iob diag) wäre trotzdem interessant zu sehen aber ist hier leider nicht im Beitrag sinnvoll da hier getestet wird und jeder Tester eigentlich auf einem sauberen und aktuellem System unterwegs sein sollte - und auch weiss was er macht.
                            @djmarc75 Marc, das hab ich doch verstanden. Deswegen hab ich die Ausgabe hier nicht gepostet.
                            • tobasium
                              tobasium last edited by
                              Hallo Zusammen,
                              ich kann irgendwie die ganzen apps nicht deaktivieren.
                              Bsp:
                              App hum deaktivieren:
                              App wird nicht deaktiviert im Log erscheint:
                              Versuch 2:
                              nichts passiert im Log.
                              App bleibt aktiviert.
                              Hat hier jemand einen Tip was ich falsch mache.
                              haus-automatisierung Ben1983 2 Replies Last reply Reply Quote 0
                                haus-automatisierung Developer Most Active @tobasium last edited by haus-automatisierung
                                @tobasium true senden. Der state hat die Rolle button. Mach doch mal den Expertenmodus aus 😉
                                Und natürlich nur unbestätigte Werte setzen. ioBroker Grundlagen anschauen!
                                tobasium 1 Reply Last reply Reply Quote 1
                                • Ben1983
                                  Ben1983 @tobasium last edited by Ben1983
                                  @tobasium Das "active" aktiviert nur die anzeige auf der Uhr, also holt die App in den Vordergrund. sie wird dadurch nicht wirklich aktiviert / deaktiviert.
                                  tobasium 1 Reply Last reply Reply Quote 0
                                  • tobasium
                                    tobasium @Ben1983 last edited by
                                    @ben1983 wie deaktiviere ich die ganzen Apps dann? Da es den State visible ja nicht mehr gibt?
                                    Vielen Dank vorab.
                                    • tobasium
                                      tobasium @haus-automatisierung last edited by
                                      @haus-automatisierung Vielen Dank. Ich bin aber auch blöd. Ich wollte die Apps deaktivieren hab das mit dem visible state vertauscht. Den gibt es ja nicht mehr.
                                        @tobasium Aktivieren = in den Vordergrund holen. Es wird ja immer nur eine App angezeigt. Einfach eine andere aktivieren.
                                        Native apps komplett entfernen geht nur über das onscreen menu der uhr. Siehe doku der Firmware
                                        • tobasium
                                          @haus-automatisierung Danke. Das war dann doch relativ einfach.
                                            Michaelnorge last edited by
                                            Kurze Frage:
                                            Ist dies hier das richtige Format für eine Soundausgabe?
                                            Bei mir steht dann im Log ein 404 Fehler, auch wenn ich "20fox.txt" schreibe.
                                            Die Datei ist vorhanden:
                                            81.1k
                                            2159
                                            1214951
