    3. Einsteigerfragen
    4. Deconz neu installieren
      Thomas Braun Most Active @Qax1 last edited by
      @qax1
      Sollte? Schau halt nach.
      Rückmeldung zu
      sudo systemctl start deconz.service
      schaut wie aus?
      • Q
        Qax1 @Thomas Braun last edited by
        Da kommt gar nix :
        pi@raspy-io:~ $ sudo systemctl start deconz.service
        pi@raspy-io:~ $
          @qax1
          Dann nochmal den Status prüfen
          systemctl status deconz deconz-gui
            @qax1
            sudo systemctl enable deconz.service
            • Q
              @thomas-braun sagte in Deconz neu installieren:
              pi@raspy-io:~ $ systemctl status deconz deconz-gui
              ● deconz.service - deCONZ: ZigBee gateway -- REST API
                   Loaded: loaded (/lib/systemd/system/deconz.service; disabled; vendor prese>
                   Active: inactive (dead)
              ● deconz-gui.service - deCONZ: ZigBee gateway -- GUI/REST API
                   Loaded: loaded (/lib/systemd/system/deconz-gui.service; disabled; vendor p>
              Jun 11 11:16:25 raspy-io systemd[1]: /lib/systemd/system/deconz-gui.service:11:>
              lines 1-9/9 (END)...skipping...
                   Loaded: loaded (/lib/systemd/system/deconz.service; disabled; vendor preset: enabled)
                   Loaded: loaded (/lib/systemd/system/deconz-gui.service; disabled; vendor preset: enabled)
              Jun 11 11:16:25 raspy-io systemd[1]: /lib/systemd/system/deconz-gui.service:11: Unknown key name 'StartLimitIntervalSec' in section 'Service', ignoring.
              • Q
                Qax1 @Qax1 last edited by
                @qax1
                pi@raspy-io:~ $ sudo systemctl enable deconz.service
                Created symlink /etc/systemd/system/multi-user.target.wants/deconz.service → /li                       b/systemd/system/deconz.service.
                pi@raspy-io:~ $
                  @qax1
                  Mach bitte dein puTTY Mäusekino breiter, damit nicht die Hälfte abgeschnitten wird. Oder verwende ein richtiges Terminal.
                  journalctl -u deconz.service
                  sagt?
                  • Q
                    pi@raspy-io:~ $ ^C
                    pi@raspy-io:~ $ journalctl -u deconz.service
                    -- Journal begins at Wed 2023-05-03 05:11:24 CEST, ends at Sun 2023-06-11 11:18:06 CEST. --
                    Jun 11 11:06:07 raspy-io systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
                    Jun 11 11:06:08 raspy-io deCONZ[2787]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
                    Jun 11 11:06:09 raspy-io deCONZ[2787]: libpng warning: iCCP: known incorrect sRGB profile
                    Jun 11 11:06:13 raspy-io deCONZ[2787]: This plugin does not support propagateSizeHints()
                    Jun 11 11:15:46 raspy-io systemd[1]: Stopping deCONZ: ZigBee gateway -- REST API...
                    Jun 11 11:15:50 raspy-io systemd[1]: deconz.service: Main process exited, code=exited, status=143/n/a
                    Jun 11 11:15:50 raspy-io systemd[1]: deconz.service: Failed with result 'exit-code'.
                    Jun 11 11:15:50 raspy-io systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
                    Jun 11 11:15:50 raspy-io systemd[1]: deconz.service: Consumed 9min 34.081s CPU time.
                    pi@raspy-io:~ $
                      @qax1
                      sudo systemctl restart deconz
                      • Q
                        pi@raspy-io:~ $ sudo systemctl restart deconz
                        -- Journal begins at Wed 2023-05-03 05:11:24 CEST, ends at Sun 2023-06-11 11:28:58 CEST. --
                        -- Boot 9be28b290cf247fcbc6504d71473c838 --
                        Jun 11 11:28:54 raspy-io systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
                        Jun 11 11:28:55 raspy-io deCONZ[830]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
                        Jun 11 11:28:55 raspy-io deCONZ[830]: libpng warning: iCCP: known incorrect sRGB profile
                        Jun 11 11:28:58 raspy-io deCONZ[830]: This plugin does not support propagateSizeHints()
                        pi@raspy-io:~ $
                          @qax1
                          • Q
                            pi@raspy-io:~ $ ^C
                                 Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled)
                                 Active: active (running) since Sun 2023-06-11 11:28:54 CEST; 4min 18s ago
                               Main PID: 830 (deCONZ)
                                  Tasks: 4 (limit: 3933)
                                    CPU: 4min 13.767s
                                 CGroup: /system.slice/deconz.service
                                         └─830 /usr/bin/deCONZ -platform minimal --http-port=80
                            pi@raspy-io:~ $
                              @qax1
                              Läuft also.
                              • Q
                                Findet aber das Gateway nicht....
                                  @qax1 sagte in Deconz neu installieren:
                                  Wer oder was?
                                  Der iobroker.deconz-Adapter?
                                  • Q
                                    Qax1 @Thomas Braun last edited by Qax1
                                    Die Phoscon-App finde den ConBee2 nicht.
                                    Beim IObroker bin ich noch gar nicht.
                                    Ich brauch erst mal n Kaffe ...
                                      Thomas Braun Most Active @Qax1 last edited by Thomas Braun
                                      @qax1
                                      Redest du von der web-Oberfläche oder von dem Deconz-GUI?
                                      • Q
                                        Nein, die hatte ich noch nie installiert,
                                        hab schon immer Paspyan ohne Desktop, und DeCONZ ohne GUI.
                                        Nun können die ersten Zigbee Geräte über die Phoscon App angelernt werden. Weitere Informationen hierzu gibt es in der Phoscon App Dokumentation.
                                        Über die Phoscon APP dann die Geräte angelernt.
                                        Das Ding ...
                                          @qax1
                                          Starte die Kiste mal sauber durch.
                                          • Q
                                            So, nach Raspy und Rechner Neustart finde ich wenigstens das Gatewax wieder.
                                            Aber die Lichtersuche bleibt erfolglos.
                                            Wenn ich jetzt eine Karte mit dem fertigen Image flashe
                                            finde ich inerhalb 1 Minute 4-5 Geräte..
                                            Eine andere Karte mit IObroker und Zigbee Adapter funktioniert auch.
                                            Ist das eine schei... wenn man keine Ahnung hat.
                                            1647
