    4. Historywerte auf FritzNas speichern
      esp @esp last edited by Homoran
      @esp
      Leider konnte mir bis jetzt keiner helfen. Ein neuer Versuch Unterstützung zu bekommen.
      Das Script:
      // Historywerte speichern
      const objId = '0_userdata.0.Netz.EinspwertStunde';
      const csvDateFormat = 'DD.MM.YYYY hh:mm:ss';
      //const fileName = 'http:\\\\IOBroker:Iedc3sx2wB@FritzBox\\FritzNas\\SAVE\\Sicherungen\\Netz_EinspwertStunde.csv';
      const fileName = '\\\\IOBroker:Iedc3sx2wB@FritzBox\\FritzNas\\SAVE\\Sicherungen\\Netz_EinspwertStunde.csv';
      var fs = require('fs');
      // Save every monday @ 00:00
      //schedule('0 0 * * 1', async () => {
          const end = new Date().getTime();
          const start = end - (60 * 60 * 24 * 2 * 1000);      // last 2 days
          getHistory('history.0', {
              start: start,
              end: end,
              aggregate: 'none',
              timeout: 2000
          }, (err, result) => {
              if (err) {
                  console.error(`Unable to get history of ${objId}: ${err}`);
              } else if (result) {
                  let csvData = ['timestamp;value'];
                  for (var i = 0; i < result.length; i++) {
                      csvData.push('${formatDate(result[i].ts, csvDateFormat)};${result[i].val}');
                  fs.writeFile(fileName, csvData.join("\n"),"utf8", function(err) {
                      if(err) {
                          return console.log(err);
                      console.log(fileName);
                      console.log("  --> was saved");
      Das Script läuft, aber es wird keine Datei geschrieben!
      11.6.2023, 09:45:00.321	[info ]: javascript.0 (810) Start javascript script.js.common._Hist_SaveAsCsvToFile
      11.6.2023, 09:45:00.334	[info ]: javascript.0 (810) script.js.common._Hist_SaveAsCsvToFile: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      11.6.2023, 09:45:00.354	[info ]: javascript.0 (810) script.js.common._Hist_SaveAsCsvToFile: http:\\IOBroker:Iedc3sx2wB@FritzBox\FritzNas\SAVE\Sicherungen\Netz_EinspwertStunde.csv
      11.6.2023, 09:45:00.355	[info ]: javascript.0 (810) script.js.common._Hist_SaveAsCsvToFile:   --> was saved
      11.6.2023, 09:45:02.513	[info ]: javascript.0 (810) Stop script script.js.common._Hist_SaveAsCsvToFile
      11.6.2023, 09:49:02.575	[info ]: javascript.0 (810) Start javascript script.js.common._Hist_SaveAsCsvToFile
      11.6.2023, 09:49:02.587	[info ]: javascript.0 (810) script.js.common._Hist_SaveAsCsvToFile: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      11.6.2023, 09:49:02.608	[info ]: javascript.0 (810) script.js.common._Hist_SaveAsCsvToFile: \\IOBroker:Iedc3sx2wB@FritzBox\FritzNas\SAVE\Sicherungen\Netz_EinspwertStunde.csv
      11.6.2023, 09:49:02.609	[info ]: javascript.0 (810) script.js.common._Hist_SaveAsCsvToFile:   --> was saved
      11.6.2023, 09:49:03.893	[info ]: javascript.0 (810) Stop script script.js.common._Hist_SaveAsCsvToFile
      Das Backup auf FritzNas funktioniert.
      Brauche dringend Hilfe!
      DJMarc75 ? 3 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @esp last edited by
        @esp Nochmals die Bitte, Texte in Codetags hier setzen ... dann fällt das Helfen leichter 😉
        • DJMarc75
          @esp sagte in Historywerte auf FritzNas speichern:
          Bitte mal den Pfad zur Fritzbox aus dem Backitup-Adapter hier zeigen.
            A Former User @esp last edited by A Former User
            Moin,
            wenn ich BackItUp richtig verstehe, dann bindest Du ja das Verzeichnis, auf das Du die Backups ablegst in ioBroker ein, als SMB/NFS oder so, wieso bindest Du dann nicht auch FritzBox\FritzNas\SAVE\Sicherungen\ nicht als SMB/NFS ein und schreibst dann da direkt rein?
            Dann umgehst Du das http usw.
            Zudem sollte der Hostname der Fritte nicht Fritz.Box sein?
            VG
            Bernd
            Edit: Rechtschreibfehler korrigiert
            @DJMarc75 😸👌
            DJMarc75 1 Reply Last reply Reply Quote 1
            • DJMarc75
              DJMarc75 @Guest last edited by
              @dp20eic sagte in Historywerte auf FritzNas speichern:
              Genau darauf wollte ich abzielen 🙂
                esp last edited by
                im 'BACKITUP' verwende ich folgende Einstellungen:
                Verbindungstyp: 'CIFS'
                Server: 'FritzBox'
                Pfad: 'FritzNas/SAVE/Sicherungen/backupDir'
                In der 'FritzBox' ist eingetragen
                FRITZ!Box-Name: 'FritzBox'
                Der Benutzer ist der, der auch im BACKITUP verwendet wird.
                Was muss ich eintragen, um das Verzeichnis einzubinden?
                Grüße aus Franken
                Erwin
                • DJMarc75
                  DJMarc75 @esp last edited by DJMarc75
                  @esp und ob Du vll auch mal einen Screenshot zeigen magst ?
                  @djmarc75 sagte in Historywerte auf FritzNas speichern:
                  edit: am Besten einen Screenshot von der ganzen Seite !
                    Moin,
                    na wie hast Du den das CIFS eingerichtet?
                    Wenn Du da nicht weiter trennen möchtest, also mit mehreren CIFS Mounts, dann kannst Du das Verzeichnis einfach nur mit diesem Pfad in ioBroker einhängen
                    Dann sollten alle anderen Verzeichnisse, die innerhalb Sicherung zu sehen sein, also auch das Verzeichnis backupDir, dann könntest Du Dir ja noch ein Verzeichnis history erstellen und dann direkt dort mit Deinem Skript hineinschreiben.
                    Zeig mal die Ausgabe, in Code Tags </>
                    mount
                    VG
                    Bernd
                    Edit
                    Ach jetzt, hab ich es glaube ich verstanden, manchmal fällt der Groschen halt einfach nicht 🙂
                    Im BackitUp wird das Verzeichnis zur Laufzeit gemountet, dann hilft das nicht, dann musst Du den Mount doch aus Deinem Skript machen, dann bin ich mir auch sicher, dass die Namen nicht wirklich passen, ich habe nichts an meiner Fritz.Box geändert da bekomme ich http://fritz.box/nas#/ und wenn ich mit SMB, vom Office PC das einhänge, dann sieht das so aus smb://admin_fritz.box@fritz.box/Mittelerde/
                    Wenn ich das per cifs mache, auf meinem Office PC, dann
                    sudo mount -t cifs -o username=admin_fritz.box //fritz.box/Mittelerde /mnt/austausch
                    Password for admin_fritz.box@//fritz.box/Mittelerde:
                    Ergebnis
                    //fritz.box/Mittelerde on /mnt/austausch type cifs (rw,relatime,vers=3.1.1,cache=strict,username=admin_fritz.box,uid=0,noforceuid,gid=0,noforcegid,addr=2a01:0586:8c92:0001:b2f2:08ff:fe10:2cc0,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1)
                    • DJMarc75
                      der Pfad im Backitup kann so schonmal nicht korrekt sein da dieser mit einem "/" beginnen muss.
                      Ebenso glaub ich auch nicht dass "FritzNas" in dem Pfad steht weil FritzNas folgend aussieht und auch nicht geändert werden kann:
                      "fritz.nas"
                      also z.B.
                      /fritz.nas/SAVE/Sicherung/backupDir
                      und "SAVE" ist der Name Deines Laufwerks (Stick oder HDD) welchen Du dafür vergeben hast ??
                        esp last edited by
                        Als 80-jähriger Raspi/IObroker-Neuling bin ich in vielen Dingen noch nicht in die Tiefen vorgedrungen. Mein EnergieManagementSystem habe ich schon gut hinbekommen und das Laden meines E-Auto sowie die Schaltung einiger Steckdosen incl, Visualisierung funktioniert prima.
                        Zum Thema BACKITUP habe ich Screenshots gemacht (am PC bin ich halt besser drauf). So funktioniert es.
                        capture_001_11062023_194713_f.jpg capture_002_11062023_194931.jpg capture_001_11062023_195125_f.jpg
                        SAVE ist der USB-Speicher (SD-Karte) an der FritzBox, den am PC als Laufwerk mounte.
                          Thomas Braun Most Active @esp last edited by Thomas Braun
                          @esp
                          FritzNAS muss mit der Option 'noserverino' sowie smb v 3.1.1. gemountet werden. Jedenfalls aktuelle Versionen von FritzOS.
                          Und bei Server setz mal die IP ein. Oder fritz.box
                          Oder hast du den Namen der FritzBox geändert?
                            @esp
                            Warum eigentlich so ein Hantier?
                            Ich verwende im IOBroker fürs Backup die FritzNas. Funktioniert prima.
                            Jetzt möchte ich Historywerte über 'fs.WriteFile' ebenfalls in der FritzNas speichern.
                            Die History wird doch eh von Backitup gesichert?
                              @thomas-braun sagte in Historywerte auf FritzNas speichern:
                              @esp
                              ich denke er will das History Verzeichnis auf frotz.nas auslagern.
                              Aber auch das geht nicht per Skript
                                @homoran sagte in Historywerte auf FritzNas speichern:
                                Und dann direkt auf die Fritzbox, nicht auf ein angedocktes USB-Medium?
                                Würde ich dem Flash-Speicher der Box eh nicht zumuten.
                                  esp @Thomas Braun last edited by
                                  Meine NAS ist ein USB-Laufwerk (USB 3.0) und ist seit jahren im (problemlosen) Einsatz.
                                  Zum Hintergrund: Ich möchte die Historywerte auf den PC (dort liegt mein Zentralarchiv) übernehmen und sie dort langfristig speichern, auswerten und mit anderen Daten verknüpfen. D.h. ist ein Monat rum, dann den vergangenen Monat übernehmen und in der History löschen. Die historywerte kann man ja auch mit 'DOWNLOAD' (=manuell) auf dem PC speichern. Das ist doch bei diesen Systemmöglichkeiten eine Primitiv-Lösung.
                                  Es geht doch nur darum, wie schreibt man Daten auf die NAS (mit Username und Passwort). Sowa muss doch das 'FileSystem' hergeben.
                                    Unter Umständen. Wenn man es richtig macht. Bislang sehe ich aber nur wenig und das was ich sehe ist höchstwahrscheinlich falsch.
                                      esp @DJMarc75 last edited by
                                      @djmarc75
                                      Das 'BACKITUP' funktioniert so, wie ich es geschrieben habe. Die bereits erfolgten Backups sind auf der NAS im entsprechendem Verzeichnis vorhanden. Das Protokoll des Backups bestätigt die korrekte Durchführung.
                                      Die NAS ist am USB-Anschluss der FritzBox, der Name ist 'SAVE'. Das Laufwerk wird am PC mit diesen Namen gemountet.
                                        @esp
                                        Dann kannst du es ja mit den gleichen Optionen temporär einhängen, auf das gemountete Dateisystem schreiben und dann wieder aushängen.
                                          Wie macht man es denn richtig?
                                          Das was du siehst ist es falsch, wenn ja an welcher Stelle?
                                            @esp
                                            Welches FritzOS läuft da?
                                            1220
