nach js update Iobroker tot ;)
@wurschtbrot sagte in nach js update Iobroker tot
Timezone: Europe/London (BST, +0100)
Vermutlich schon mal falsch.
Pending OS-Updates: 166
Das ist MEGA falsch. Halt das Ding auf Stand. Bei 166 Updates ist da wohl noch nicht geputzt worden?
hier einmal neu======== Start marking the full check here =========
Skript v.2023-04-16 *** BASE SYSTEM *** Model : Raspberry Pi 4 Model B Rev 1.4 Architecture : armv7l Docker : false Virtualization : none Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)" NAME="Raspbian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs" Systemuptime and Load: 20:42:02 up 2:06, 1 user, load average: 3.79, 3.68, 3.36 CPU threads: 4 Raspberry only: throttled=0x0 Other values than 0x0 hint to temperature/voltage problems temp=52.1'C volt=0.9060V *** Time and Time Zones *** Local time: Sun 2023-06-11 20:42:02 BST Universal time: Sun 2023-06-11 19:42:02 UTC RTC time: n/a Time zone: Europe/London (BST, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 1.9G 1.2G 167M 0.0K 534M 754M Swap: 99M 14M 85M Total: 2.0G 1.2G 253M 1872 M total memory 1171 M used memory 172 M active memory 1409 M inactive memory 167 M free memory 91 M buffer memory 442 M swap cache 99 M total swap 14 M used swap 85 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 59G 7.3G 49G 13% / devtmpfs devtmpfs 776M 0 776M 0% /dev tmpfs tmpfs 937M 0 937M 0% /dev/shm tmpfs tmpfs 375M 812K 374M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 188M 0 188M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sun Jun 11 18:35:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:34:2C:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=7177a16e-02 rootfstype=ext4 fsck.repair=yes rootwait [Sun Jun 11 18:35:41 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [Sun Jun 11 18:35:41 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Sun Jun 11 18:35:43 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 1.2G /var/ 795M /var/log 793M /var/log/journal/d283fbb865d54e58ad2494ba594a26a4 793M /var/log/journal 167M /var/cache Archived and active journals take up 792.2M in the file system. /opt/iobroker/backups: 26M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 591M /opt/iobroker/iobroker-data/ 267M /opt/iobroker/iobroker-data/files 187M /opt/iobroker/iobroker-data/sonosCache 96M /opt/iobroker/iobroker-data/backup-objects 78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png The five largest files in iobroker-data are: 15M /opt/iobroker/iobroker-data/objects.jsonl 9.1M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map 8.9M /opt/iobroker/iobroker-data/objects.json.migrated 8.9M /opt/iobroker/iobroker-data/objects.json.bak.migrated 8.9M /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map *** NodeJS-Installation *** /usr/bin/nodejs v16.20.0 /usr/bin/node v16.20.0 /usr/bin/npm 8.19.4 /usr/bin/npx 8.19.4 nodejs: Installed: 16.20.0-deb-1nodesource1 Candidate: 16.20.0-deb-1nodesource1 Version table: *** 16.20.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl MULTIHOSTSERVICE/enabled: false Core adapters versions js-controller: 4.0.24 admin: 6.3.5 javascript: 6.1.4 Adapters from github: 0 Adapter State + system.adapter.adguard.1 : adguard : iobr22 - enabled system.adapter.admin.0 : admin : iobr22 - disabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : iobr22 - enabled system.adapter.backitup.0 : backitup : iobr22 - disabled + system.adapter.bosch-ebike.0 : bosch-ebike : iobr22 - enabled + system.adapter.bring.0 : bring : iobr22 - enabled + system.adapter.bshb.0 : bshb : iobr22 - enabled + system.adapter.chromecast.0 : chromecast : iobr22 - enabled + system.adapter.discovery.0 : discovery : iobr22 - enabled system.adapter.dwd.0 : dwd : iobr22 - enabled + system.adapter.echarts.0 : echarts : iobr22 - enabled system.adapter.fb-checkpresence.0 : fb-checkpresence : iobr22 - disabled + system.adapter.followthesun.0 : followthesun : iobr22 - enabled + system.adapter.heizoel.0 : heizoel : iobr22 - enabled + system.adapter.history.0 : history : iobr22 - enabled + system.adapter.hmip.0 : hmip : iobr22 - enabled + system.adapter.hue-extended.0 : hue-extended : iobr22 - enabled system.adapter.ical.0 : ical : iobr22 - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobr22 - enabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobr22 - enabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobr22 - enabled + system.adapter.jarvis.0 : jarvis : iobr22 - enabled + system.adapter.javascript.0 : javascript : iobr22 - enabled + system.adapter.lg-thinq.0 : lg-thinq : iobr22 - enabled + system.adapter.mqtt.0 : mqtt : iobr22 - enabled, port: 1883, bind: 192.168.178.141 + system.adapter.net-tools.0 : net-tools : iobr22 - enabled system.adapter.nina.0 : nina : iobr22 - enabled + system.adapter.node-red.0 : node-red : iobr22 - enabled, port: 1880, bind: 0.0.0.0 system.adapter.nut.0 : nut : iobr22 - disabled system.adapter.octoprint.0 : octoprint : iobr22 - enabled system.adapter.philips-tv.0 : philips-tv : iobr22 - enabled + system.adapter.ping.0 : ping : iobr22 - enabled + system.adapter.rpi2.0 : rpi2 : iobr22 - enabled + system.adapter.shelly.0 : shelly : iobr22 - enabled, port: 1882, bind: 0.0.0.0 system.adapter.snmp.0 : snmp : iobr22 - disabled + system.adapter.sonos.0 : sonos : iobr22 - enabled system.adapter.systeminfo.0 : systeminfo : iobr22 - enabled + system.adapter.tr-064.0 : tr-064 : iobr22 - enabled + system.adapter.tr-064.1 : tr-064 : iobr22 - enabled + system.adapter.tr-064.2 : tr-064 : iobr22 - enabled system.adapter.vis-bars.0 : vis-bars : iobr22 - enabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobr22 - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobr22 - enabled system.adapter.vis-history.0 : vis-history : iobr22 - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobr22 - enabled system.adapter.vis-icontwo.0 : vis-icontwo : iobr22 - enabled system.adapter.vis-inventwo.0 : vis-inventwo : iobr22 - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobr22 - enabled system.adapter.vis-keyboard.0 : vis-keyboard : iobr22 - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : iobr22 - enabled system.adapter.vis-plumb.0 : vis-plumb : iobr22 - enabled system.adapter.vis-rgraph.0 : vis-rgraph : iobr22 - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobr22 - enabled system.adapter.vis.0 : vis : iobr22 - enabled system.adapter.weatherunderground.0 : weatherunderground : iobr22 - enabled system.adapter.web.0 : web : iobr22 - disabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobr22 - enabled + instance is alive Enabled adapters with bindings + system.adapter.mqtt.0 : mqtt : iobr22 - enabled, port: 1883, bind: 192.168.178.141 + system.adapter.node-red.0 : node-red : iobr22 - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : iobr22 - enabled, port: 1882, bind: 0.0.0.0 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "adguard" : 0.0.8 , installed 0.0.8 Adapter "admin" : 6.3.5 , installed 6.3.5 Adapter "alexa2" : 3.23.2 , installed 3.23.2 Adapter "backitup" : 2.6.19 , installed 2.6.19 Adapter "bosch-ebike" : 0.0.3 , installed 0.0.3 Adapter "bring" : 1.8.1 , installed 1.8.1 Adapter "bshb" : 0.2.4 , installed 0.2.4 Adapter "chromecast" : 3.0.3 , installed 3.0.3 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "echarts" : 1.0.12 , installed 1.0.12 Adapter "fb-checkpresence": 1.1.26, installed 1.1.26 Adapter "followthesun" : 0.4.1 , installed 0.4.1 Adapter "heizoel" : 1.0.3 , installed 1.0.3 Adapter "history" : 2.2.4 , installed 2.2.4 Adapter "hmip" : 1.20.0 , installed 1.20.0 Adapter "hue-extended" : 2.0.0 , installed 2.0.0 Adapter "ical" : 1.13.2 , installed 1.13.2 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "jarvis" : 3.1.2 , installed 3.1.2 Adapter "javascript" : 6.1.4 , installed 6.1.4 Controller "js-controller": 4.0.24 , installed 4.0.24 Adapter "lg-thinq" : 0.1.4 , installed 0.1.4 Adapter "mqtt" : 4.0.7 , installed 4.0.7 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "nina" : 0.0.25 , installed 0.0.25 Adapter "nut" : 1.6.0 , installed 1.6.0 Adapter "ping" : 1.5.3 , installed 1.5.3 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "shelly" : 6.4.1 , installed 6.4.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "snmp" : 2.4.7 , installed 2.4.7 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonos" : 2.2.3 , installed 2.2.3 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "vis-icontwo" : 0.93.0 , installed 0.93.0 Adapter "weatherunderground": 3.4.2, installed 3.4.2 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3 Adapter "ws" : 1.3.0 , installed 1.3.0 Objects and States Please stand by - This may take a while Objects: 19018 States: 15908 *** OS-Repositories and Updates *** Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease Reading package lists... Pending Updates: 166 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 192.168.178.141:1883 0.0.0.0:* LISTEN 1001 40343 9055/io.mqtt.0 tcp 0 0 192.168.178.141:1884 0.0.0.0:* LISTEN 1001 40344 9055/io.mqtt.0 tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 37347 8389/iobroker.js-co tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 38196 8389/iobroker.js-co tcp 0 0 0.0.0.0:8400 0.0.0.0:* LISTEN 1001 71371 12782/io.jarvis.0 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 9770 539/sshd: /usr/sbin tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 37434 8486/node-red tcp6 0 0 :::3500 :::* LISTEN 1001 47219 10182/io.sonos.0 tcp6 0 0 :::22 :::* LISTEN 0 9772 539/sshd: /usr/sbin udp 0 0 0.0.0.0:68 0.0.0.0:* 0 13766 700/dhcpcd udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 40158 8893/io.chromecast. udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 9655 391/avahi-daemon: r udp 0 0 0.0.0.0:50429 0.0.0.0:* 108 9657 391/avahi-daemon: r udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 44427 9781/io.shelly.0 udp6 0 0 :::5353 :::* 108 9656 391/avahi-daemon: r udp6 0 0 :::40791 :::* 108 9658 391/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-06-11 20:43:50.445 - warn: shelly.0 (9781) [authEnabled] 192.168.178.156 (shelly1 / shelly1-58BF25D8700A / SHSW-1#58BF25D8700A#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:50.682 - warn: shelly.0 (9781) [authEnabled] 192.168.178.161 (shelly1 / shelly1-E8DB84AB7C26 / SHSW-1#E8DB84AB7C26#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:51.018 - warn: shelly.0 (9781) [authEnabled] 192.168.178.172 (shelly1pm / shelly1pm-34945472B5A9 / SHSW-PM#34945472B5A9#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:51.316 - warn: shelly.0 (9781) [authEnabled] 192.168.178.151 (shellyswitch25 / shellyswitch25-3C6105E553A4 / SHSW-25#3C6105E553A4#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:51.530 - warn: shelly.0 (9781) [authEnabled] 192.168.178.166 (shellyswitch25 / shellyswitch25-98CDAC2D0858 / SHSW-25#98CDAC2D0858#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:51.572 - warn: shelly.0 (9781) [authEnabled] 192.168.178.150 (shellyswitch25 / shellyswitch25-E8DB84A1B284 / SHSW-25#E8DB84A1B284#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:51.580 - warn: shelly.0 (9781) [authEnabled] 192.168.178.154 (shellyswitch25 / shellyswitch25-E8DB84AAB39C / SHSW-25#E8DB84AAB39C#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:51.584 - warn: shelly.0 (9781) [authEnabled] 192.168.178.152 (shellyswitch25 / shellyswitch25-84CCA89FF0A5 / SHSW-25#84CCA89FF0A5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:51.591 - warn: shelly.0 (9781) [authEnabled] 192.168.178.155 (shellyswitch25 / shellyswitch25-C8C9A375029E / SHSW-25#C8C9A375029E#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:51.646 - warn: shelly.0 (9781) [authEnabled] 192.168.178.158 (shellyem3 / shellyem3-E8DB84D72806 / SHEM-3#E8DB84D72806#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:51.649 - warn: shelly.0 (9781) [authEnabled] 192.168.178.173 (shellyem3 / shellyem3-485519DC0AEF / SHEM-3#485519DC0AEF#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:51.766 - warn: shelly.0 (9781) [authEnabled] 192.168.178.153 (shellyswitch25 / shellyswitch25-D8BFC01A558C / SHSW-25#D8BFC01A558C#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:52.354 - info: octoprint.0 (13661) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.octoprint, node: v16.20.0, js-controller: 4.0.24 2023-06-11 20:43:52.860 - warn: adguard.1 (10779) No connection to the server could be established. (Error: connect ECONNREFUSED 192.168.178.141:80) 2023-06-11 20:43:53.423 - info: host.iobr22 iobroker npm-install: NPM version: 8.19.4 2023-06-11 20:43:53.425 - info: host.iobr22 iobroker npm-install: Installing iobroker.philips-tv@0.5.3... (System call) 2023-06-11 20:43:54.614 - info: octoprint.0 (13661) error ECONNABORTED from /api/version: timeout of 2000ms exceeded 2023-06-11 20:43:55.273 - warn: shelly.0 (9781) [authEnabled] 192.168.178.170 (shellyplug-s / shellyplug-s-4022D882E3C5 / SHPLG-S#4022D882E3C5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:55.288 - warn: shelly.0 (9781) [authEnabled] 192.168.178.169 (shellyplug-s / shellyplug-s-4022D881CACB / SHPLG-S#4022D881CACB#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:55.699 - warn: shelly.0 (9781) [authEnabled] 192.168.178.157 (shelly1pm / shelly1pm-8CAAB574CB6C / SHSW-PM#8CAAB574CB6C#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:55.710 - warn: shelly.0 (9781) [authEnabled] 192.168.178.164 (shelly1 / shelly1-E8DB84AB993A / SHSW-1#E8DB84AB993A#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:55.719 - warn: shelly.0 (9781) [authEnabled] 192.168.178.165 (shelly1 / shelly1-E89F6D860650 / SHSW-1#E89F6D860650#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:55.745 - warn: shelly.0 (9781) [authEnabled] 192.168.178.156 (shelly1 / shelly1-58BF25D8700A / SHSW-1#58BF25D8700A#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:56.098 - warn: shelly.0 (9781) [authEnabled] 192.168.178.161 (shelly1 / shelly1-E8DB84AB7C26 / SHSW-1#E8DB84AB7C26#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 20:43:56.232 - warn: shelly.0 (9781) [authEnabled] 192.168.178.172 (shelly1pm / shelly1pm-34945472B5A9 / SHSW-PM#34945472B5A9#1): This device is not protected via restricted login (see adapter documentation for details)
iob diag has finished.
Press any key for a summary
======================= SUMMARY ======================= v.2023-04-16 Operatingsystem: Raspbian GNU/Linux 11 (bullseye) Kernel: 5.10.92-v7l+ Installation: Native Timezone: Europe/London (BST, +0100) User-ID: 1000 X-Server: false Boot Target: graphical.target Pending OS-Updates: 166 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v16.20.0 /usr/bin/node v16.20.0 /usr/bin/npm 8.19.4 /usr/bin/npx 8.19.4 Recommended versions are nodejs 18.x.y and npm 9.x.y Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 1.9G 1.3G 111M 0.0K 484M 668M Swap: 99M 54M 45M Total: 2.0G 1.3G 156M Active iob-Instances: 31 Active repo(s): stable ioBroker Core: js-controller 4.0.24 admin 6.3.5 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: system.adapter.admin.0 : admin : iobr22 - disabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.web.0 : web : iobr22 - disabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 19018 States: 15908 Size of iob-Database: 15M /opt/iobroker/iobroker-data/objects.jsonl 8.9M /opt/iobroker/iobroker-data/objects.json.migrated 8.9M /opt/iobroker/iobroker-data/objects.json.bak.migrated 4.0K /opt/iobroker/iobroker-data/objects.json.old 0 /opt/iobroker/iobroker-data/objects.json.broken 6.5M /opt/iobroker/iobroker-data/states.jsonl 2.4M /opt/iobroker/iobroker-data/states.json.migrated 2.4M /opt/iobroker/iobroker-data/states.json.bak.migrated 4.0K /opt/iobroker/iobroker-data/states.json.old 0 /opt/iobroker/iobroker-data/states.json.broken =================== END OF SUMMARY ====================
jetzt aber oder
Das mit den update kann ich mir nicht erklären die waren gestern alle auf den neusten Stand. -
Bestimmt falsch. Stell deine lokale Zeitzone ein.
Betriebssystem aktuell halten! Nicht nur den ioBroker.
Dem würde ich auch folgen.
Der admin läuft nicht.
iob start web iob start admin
pi@iobr22:~ $ iob start admin The adapter "admin.0" was started.
und kommst du auf die Admin Oberfläche per Browser
Warum hast du das Backup überhaupt über die Kommandozeile reingebügelt, wenn du einen laufenden Backitup-Adapter hast?
@glasfaser
nein ging gar nichts jezt mit dem befehlt iob start admin
läuft es wieder
danke euch habt ihr ne Anleitung um die Updates vom Os zu machen -
@wurschtbrot wie schafft man es die code-tags mitten aus dem damit vorbereiteten Code herauszuoperieren?
hab sie wieder re-implantiert!
Setz die Zeitzone zunächst mal richtig. Das ist wichtig und keine Kosmetik.
Geht insudo raspi-config
Anschließend
iob stop sudo apt update sudo apt full-upgrade sudo reboot
@homoran sagte in nach js update Iobroker tot
Sorry ... konnte ich mir nicht verkneifen ..
das sind die Wurstfinger von @wurschtbrot
Und dann mach den Sprung auf nodejs@18 noch. nodejs@16 ist in der Auslaufphase. EOL im September 23.
@glasfaser ;=)
@Thomas-Braun gibts da eine Anleitung will nicht wieder was falsches aus dem Internet ziehen
1000 Dank euch....
aktuell laufen noch die Updates durch.... -
steht in seiner Signatur
Zun nodejs updates? Steht in meiner Signatur drin.
ich glaube es ist heute schon zu spät,
aber bei mir kommt nach diesem Befehl nichtspi@iobr22:~ $ cd /opt/iobroker pi@iobr22:/opt/iobroker $ npm ls | grep -E 'github|ERR' pi@iobr22:/opt/iobroker
Das ist doch prima.
Im Idealfall wird nichts zurückgeliefert
Also keine Fehler und auch nix aus dem GitHub geangelt.
Weiter machen. -
hat sich erledigt manchmal hilft denken auch..... -
nach den ganzen update Zeugs sollte alles wieder gut sein oder.....
Skript v.2023-04-16 *** BASE SYSTEM *** Model : Raspberry Pi 4 Model B Rev 1.4 Architecture : aarch64 Docker : false Virtualization : none Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)" NAME="Raspbian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs" Systemuptime and Load: 22:47:10 up 22 min, 1 user, load average: 4.54, 2.64, 1.27 CPU threads: 4 Raspberry only: throttled=0x0 Other values than 0x0 hint to temperature/voltage problems temp=51.1'C volt=0.9060V *** Time and Time Zones *** Local time: Sun 2023-06-11 22:47:10 CEST Universal time: Sun 2023-06-11 20:47:10 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 1.8G 1.0G 70M 0.0K 752M 754M Swap: 99M 0B 99M Total: 1.9G 1.0G 170M 1849 M total memory 1026 M used memory 1016 M active memory 450 M inactive memory 70 M free memory 157 M buffer memory 595 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 59G 7.5G 49G 14% / devtmpfs devtmpfs 667M 0 667M 0% /dev tmpfs tmpfs 925M 0 925M 0% /dev/shm tmpfs tmpfs 370M 804K 370M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 253M 51M 202M 20% /boot tmpfs tmpfs 185M 0 185M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sun Jun 11 22:25:04 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:34:2C:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=7177a16e-02 rootfstype=ext4 fsck.repair=yes rootwait [Sun Jun 11 22:25:05 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none. [Sun Jun 11 22:25:05 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Sun Jun 11 22:25:07 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none. Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro Files in neuralgic directories: /var: 1.2G /var/ 812M /var/log 809M /var/log/journal/d283fbb865d54e58ad2494ba594a26a4 809M /var/log/journal 169M /var/cache Archived and active journals take up 808.2M in the file system. /opt/iobroker/backups: 26M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 589M /opt/iobroker/iobroker-data/ 267M /opt/iobroker/iobroker-data/files 187M /opt/iobroker/iobroker-data/sonosCache 96M /opt/iobroker/iobroker-data/backup-objects 78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png The five largest files in iobroker-data are: 14M /opt/iobroker/iobroker-data/objects.jsonl 9.1M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map 8.9M /opt/iobroker/iobroker-data/objects.json.migrated 8.9M /opt/iobroker/iobroker-data/objects.json.bak.migrated 8.9M /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map *** NodeJS-Installation *** /usr/bin/nodejs v18.16.0 /usr/bin/node v18.16.0 /usr/bin/npm 9.5.1 /usr/bin/npx 9.5.1 nodejs: Installed: 18.16.0-deb-1nodesource1 Candidate: 18.16.0-deb-1nodesource1 Version table: *** 18.16.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl MULTIHOSTSERVICE/enabled: false Core adapters versions js-controller: 4.0.24 admin: 6.3.5 javascript: 6.1.4 Adapters from github: 0 Adapter State + system.adapter.adguard.1 : adguard : iobr22 - enabled + system.adapter.admin.0 : admin : iobr22 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : iobr22 - enabled system.adapter.backitup.0 : backitup : iobr22 - disabled + system.adapter.bosch-ebike.0 : bosch-ebike : iobr22 - enabled + system.adapter.bring.0 : bring : iobr22 - enabled + system.adapter.bshb.0 : bshb : iobr22 - enabled + system.adapter.chromecast.0 : chromecast : iobr22 - enabled + system.adapter.discovery.0 : discovery : iobr22 - enabled system.adapter.dwd.0 : dwd : iobr22 - enabled + system.adapter.echarts.0 : echarts : iobr22 - enabled system.adapter.fb-checkpresence.0 : fb-checkpresence : iobr22 - disabled + system.adapter.followthesun.0 : followthesun : iobr22 - enabled + system.adapter.heizoel.0 : heizoel : iobr22 - enabled + system.adapter.history.0 : history : iobr22 - enabled + system.adapter.hmip.0 : hmip : iobr22 - enabled + system.adapter.hue-extended.0 : hue-extended : iobr22 - enabled system.adapter.ical.0 : ical : iobr22 - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobr22 - enabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobr22 - enabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobr22 - enabled + system.adapter.jarvis.0 : jarvis : iobr22 - enabled + system.adapter.javascript.0 : javascript : iobr22 - enabled + system.adapter.lg-thinq.0 : lg-thinq : iobr22 - enabled + system.adapter.mqtt.0 : mqtt : iobr22 - enabled, port: 1883, bind: 192.168.178.141 + system.adapter.net-tools.0 : net-tools : iobr22 - enabled + system.adapter.nina.0 : nina : iobr22 - enabled + system.adapter.node-red.0 : node-red : iobr22 - enabled, port: 1880, bind: 0.0.0.0 system.adapter.nut.0 : nut : iobr22 - disabled + system.adapter.octoprint.0 : octoprint : iobr22 - enabled + system.adapter.philips-tv.0 : philips-tv : iobr22 - enabled + system.adapter.ping.0 : ping : iobr22 - enabled + system.adapter.rpi2.0 : rpi2 : iobr22 - enabled + system.adapter.shelly.0 : shelly : iobr22 - enabled, port: 1882, bind: 0.0.0.0 system.adapter.snmp.0 : snmp : iobr22 - disabled + system.adapter.sonos.0 : sonos : iobr22 - enabled system.adapter.systeminfo.0 : systeminfo : iobr22 - enabled + system.adapter.tr-064.0 : tr-064 : iobr22 - enabled + system.adapter.tr-064.1 : tr-064 : iobr22 - enabled + system.adapter.tr-064.2 : tr-064 : iobr22 - enabled system.adapter.vis-bars.0 : vis-bars : iobr22 - enabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobr22 - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobr22 - enabled system.adapter.vis-history.0 : vis-history : iobr22 - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobr22 - enabled system.adapter.vis-icontwo.0 : vis-icontwo : iobr22 - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : iobr22 - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobr22 - enabled system.adapter.vis-keyboard.0 : vis-keyboard : iobr22 - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : iobr22 - enabled system.adapter.vis-plumb.0 : vis-plumb : iobr22 - enabled system.adapter.vis-rgraph.0 : vis-rgraph : iobr22 - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobr22 - enabled system.adapter.vis.0 : vis : iobr22 - enabled system.adapter.weatherunderground.0 : weatherunderground : iobr22 - enabled + system.adapter.web.0 : web : iobr22 - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobr22 - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobr22 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.mqtt.0 : mqtt : iobr22 - enabled, port: 1883, bind: 192.168.178.141 + system.adapter.node-red.0 : node-red : iobr22 - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : iobr22 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.web.0 : web : iobr22 - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "adguard" : 0.0.8 , installed 0.0.8 Adapter "admin" : 6.3.5 , installed 6.3.5 Adapter "alexa2" : 3.23.2 , installed 3.23.2 Adapter "backitup" : 2.6.19 , installed 2.6.19 Adapter "bosch-ebike" : 0.0.3 , installed 0.0.3 Adapter "bring" : 1.8.1 , installed 1.8.1 Adapter "bshb" : 0.2.4 , installed 0.2.4 Adapter "chromecast" : 3.0.3 , installed 3.0.3 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "echarts" : 1.0.12 , installed 1.0.12 Adapter "fb-checkpresence": 1.1.26, installed 1.1.26 Adapter "followthesun" : 0.4.1 , installed 0.4.1 Adapter "heizoel" : 1.0.3 , installed 1.0.3 Adapter "history" : 2.2.4 , installed 2.2.4 Adapter "hmip" : 1.20.0 , installed 1.20.0 Adapter "hue-extended" : 2.0.0 , installed 2.0.0 Adapter "ical" : 1.13.2 , installed 1.13.2 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "jarvis" : 3.1.2 , installed 3.1.2 Adapter "javascript" : 6.1.4 , installed 6.1.4 Controller "js-controller": 4.0.24 , installed 4.0.24 Adapter "lg-thinq" : 0.1.4 , installed 0.1.4 Adapter "mqtt" : 4.0.7 , installed 4.0.7 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "nina" : 0.0.25 , installed 0.0.25 Adapter "node-red" : 4.0.0 , installed 4.0.0 Adapter "nut" : 1.6.0 , installed 1.6.0 Adapter "octoprint" : 4.0.0 , installed 4.0.0 Adapter "philips-tv" : 0.5.3 , installed 0.5.3 Adapter "ping" : 1.5.3 , installed 1.5.3 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "shelly" : 6.4.1 , installed 6.4.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "snmp" : 2.4.7 , installed 2.4.7 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonos" : 2.2.3 , installed 2.2.3 Adapter "systeminfo" : 0.3.1 , installed 0.3.1 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.3.0 , installed 1.3.0 Adapter "vis-icontwo" : 0.93.0 , installed 0.93.0 Adapter "vis-inventwo" : 3.3.1 , installed 3.3.1 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2 Adapter "vis-material-advanced": 1.7.2, installed 1.7.2 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "weatherunderground": 3.4.2, installed 3.4.2 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3 Adapter "ws" : 1.3.0 , installed 1.3.0 Objects and States Please stand by - This may take a while Objects: 19024 States: 15935 *** OS-Repositories and Updates *** Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 24185 2414/iobroker.js-co tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 26674 2414/iobroker.js-co tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 1777 524/sshd: /usr/sbin tcp 0 0 0.0.0.0:8400 0.0.0.0:* LISTEN 1001 30801 3098/io.jarvis.0 tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 26174 2510/node-red tcp 0 0 192.168.178.141:1884 0.0.0.0:* LISTEN 1001 24340 2595/io.mqtt.0 tcp 0 0 192.168.178.141:1883 0.0.0.0:* LISTEN 1001 24339 2595/io.mqtt.0 tcp6 0 0 :::3500 :::* LISTEN 1001 27745 2721/io.sonos.0 tcp6 0 0 :::22 :::* LISTEN 0 1779 524/sshd: /usr/sbin tcp6 0 0 :::8082 :::* LISTEN 1001 30590 3328/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 24240 2435/io.admin.0 udp 0 0 0.0.0.0:45194 0.0.0.0:* 1001 33675 - udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 26866 2548/io.chromecast. udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 13065 379/avahi-daemon: r udp 0 0 0.0.0.0:48514 0.0.0.0:* 108 13067 379/avahi-daemon: r udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 24486 2701/io.shelly.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 3864 662/dhcpcd udp6 0 0 :::5353 :::* 108 13066 379/avahi-daemon: r udp6 0 0 :::45079 :::* 108 13068 379/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-06-11 22:49:01.573 - warn: shelly.0 (2701) [authEnabled] 192.168.178.166 (shellyswitch25 / shellyswitch25-98CDAC2D0858 / SHSW-25#98CDAC2D0858#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:01.756 - warn: shelly.0 (2701) [authEnabled] 192.168.178.154 (shellyswitch25 / shellyswitch25-E8DB84AAB39C / SHSW-25#E8DB84AAB39C#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:01.933 - warn: shelly.0 (2701) [authEnabled] 192.168.178.161 (shelly1 / shelly1-E8DB84AB7C26 / SHSW-1#E8DB84AB7C26#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:03.378 - info: host.iobr22 instance system.adapter.systeminfo.0 started with pid 3781 2023-06-11 22:49:03.474 - warn: shelly.0 (2701) [authEnabled] 192.168.178.150 (shellyswitch25 / shellyswitch25-E8DB84A1B284 / SHSW-25#E8DB84A1B284#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:03.524 - warn: shelly.0 (2701) [authEnabled] 192.168.178.169 (shellyplug-s / shellyplug-s-4022D881CACB / SHPLG-S#4022D881CACB#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:04.150 - warn: shelly.0 (2701) [authEnabled] 192.168.178.170 (shellyplug-s / shellyplug-s-4022D882E3C5 / SHPLG-S#4022D882E3C5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:04.331 - warn: shelly.0 (2701) [authEnabled] 192.168.178.172 (shelly1pm / shelly1pm-34945472B5A9 / SHSW-PM#34945472B5A9#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:04.679 - warn: shelly.0 (2701) [authEnabled] 192.168.178.151 (shellyswitch25 / shellyswitch25-3C6105E553A4 / SHSW-25#3C6105E553A4#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:04.811 - warn: shelly.0 (2701) [authEnabled] 192.168.178.164 (shelly1 / shelly1-E8DB84AB993A / SHSW-1#E8DB84AB993A#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:05.047 - warn: shelly.0 (2701) [authEnabled] 192.168.178.165 (shelly1 / shelly1-E89F6D860650 / SHSW-1#E89F6D860650#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:05.271 - warn: shelly.0 (2701) [authEnabled] 192.168.178.152 (shellyswitch25 / shellyswitch25-84CCA89FF0A5 / SHSW-25#84CCA89FF0A5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:05.521 - warn: shelly.0 (2701) [authEnabled] 192.168.178.158 (shellyem3 / shellyem3-E8DB84D72806 / SHEM-3#E8DB84D72806#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:05.711 - warn: shelly.0 (2701) [authEnabled] 192.168.178.173 (shellyem3 / shellyem3-485519DC0AEF / SHEM-3#485519DC0AEF#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:05.940 - warn: shelly.0 (2701) [authEnabled] 192.168.178.157 (shelly1pm / shelly1pm-8CAAB574CB6C / SHSW-PM#8CAAB574CB6C#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:06.096 - warn: shelly.0 (2701) [authEnabled] 192.168.178.156 (shelly1 / shelly1-58BF25D8700A / SHSW-1#58BF25D8700A#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:06.671 - warn: shelly.0 (2701) [authEnabled] 192.168.178.153 (shellyswitch25 / shellyswitch25-D8BFC01A558C / SHSW-25#D8BFC01A558C#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:06.773 - warn: shelly.0 (2701) [authEnabled] 192.168.178.155 (shellyswitch25 / shellyswitch25-C8C9A375029E / SHSW-25#C8C9A375029E#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:06.835 - warn: shelly.0 (2701) [authEnabled] 192.168.178.166 (shellyswitch25 / shellyswitch25-98CDAC2D0858 / SHSW-25#98CDAC2D0858#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:06.886 - warn: adguard.1 (2793) No connection to the server could be established. (Error: connect ECONNREFUSED 192.168.178.141:80) 2023-06-11 22:49:06.951 - warn: shelly.0 (2701) [authEnabled] 192.168.178.154 (shellyswitch25 / shellyswitch25-E8DB84AAB39C / SHSW-25#E8DB84AAB39C#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:07.203 - warn: shelly.0 (2701) [authEnabled] 192.168.178.161 (shelly1 / shelly1-E8DB84AB7C26 / SHSW-1#E8DB84AB7C26#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:08.677 - warn: shelly.0 (2701) [authEnabled] 192.168.178.169 (shellyplug-s / shellyplug-s-4022D881CACB / SHPLG-S#4022D881CACB#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:08.732 - warn: shelly.0 (2701) [authEnabled] 192.168.178.150 (shellyswitch25 / shellyswitch25-E8DB84A1B284 / SHSW-25#E8DB84A1B284#1): This device is not protected via restricted login (see adapter documentation for details) 2023-06-11 22:49:09.366 - warn: shelly.0 (2701) [authEnabled] 192.168.178.170 (shellyplug-s / shellyplug-s-4022D882E3C5 / SHPLG-S#4022D882E3C5#1): This device is not protected via restricted login (see adapter documentation for details)
Copy text starting here:
======================= SUMMARY ======================= v.2023-04-16 Operatingsystem: Raspbian GNU/Linux 11 (bullseye) Kernel: 6.1.21-v8+ Installation: Native Timezone: Europe/Berlin (CEST, +0200) User-ID: 1000 X-Server: false Boot Target: graphical.target Pending OS-Updates: 0 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.16.0 /usr/bin/node v18.16.0 /usr/bin/npm 9.5.1 /usr/bin/npx 9.5.1 Recommended versions are nodejs 18.x.y and npm 9.x.y Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 1.8G 1.2G 240M 0.0K 371M 543M Swap: 99M 1.0M 98M Total: 1.9G 1.2G 338M Active iob-Instances: 34 Active repo(s): stable ioBroker Core: js-controller 4.0.24 admin 6.3.5 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : iobr22 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : iobr22 - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 19024 States: 15935 Size of iob-Database: 15M /opt/iobroker/iobroker-data/objects.jsonl 8.9M /opt/iobroker/iobroker-data/objects.json.migrated 8.9M /opt/iobroker/iobroker-data/objects.json.bak.migrated 4.0K /opt/iobroker/iobroker-data/objects.json.old 0 /opt/iobroker/iobroker-data/objects.json.broken 6.1M /opt/iobroker/iobroker-data/states.jsonl 2.4M /opt/iobroker/iobroker-data/states.json.migrated 2.4M /opt/iobroker/iobroker-data/states.json.bak.migrated 4.0K /opt/iobroker/iobroker-data/states.json.old 0 /opt/iobroker/iobroker-data/states.json.broken =================== END OF SUMMARY ====================
