    4. Test Adapter Birthdays
    • da_Woody
      da_Woody @valbuz last edited by
      @valbuz nuja, ich hab 4 ical instanzen und einen birthday.
      birthday ist entstanden, weil einige ical für geburtstage "benutzen" wollten... 😉
      V 1 Reply Last reply Reply Quote 1
      • V
        valbuz @da_Woody last edited by
        @da_woody sagte in Test Adapter Birthdays:
        So spielt das Leben 🙄 😊
        • Ben1983
          Ben1983 last edited by
          @haus-automatisierung Du hast ja mit dem letzt Update das doppelte hinzufügen von Geburtstagen verhindert.
          Nun ist aber meine Frage wieso wird bei mir dieser Geburtstag doppelt erkannt?
          Er ist nur einmal im Kalender drin:
          birthdays.0 2023-06-12 09:07:30.708	warn	[addBirthday] birthday with name "Benjamin Schmidt" has already been added (28.05.2024) - skipping
          birthdays.0 2023-06-12 09:07:30.708	debug	[ical] found birthday: Benjamin Schmidt (1983)
          birthdays.0 2023-06-12 09:07:30.708	debug	[ical] processing event: {"component":["vevent",[["dtstart",{},"date","2023-05-28"],["dtend",{},"date","2023-05-29"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T07:07:30Z"],["uid",{},"text","59p0iv4vn4crf2c544ha2jl368@google.com"],["created",{},"date-time","2023-04-10T19:53:29Z"],["description",{},"text","1983"],["last-modified",{},"date-time","2023-04-10T19:53:29Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Benjamin Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
          birthdays.0 2023-06-12 09:07:30.692	debug	[ical] found birthday: Benjamin Schmidt (1983)
          birthdays.0 2023-06-12 09:07:30.692	debug	[ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-28"],["dtend",{},"date","2022-05-29"],["dtstamp",{},"date-time","2023-06-12T07:07:30Z"],["uid",{},"text","07jehvfnu7rf2inqdqrmh94tos@google.com"],["created",{},"date-time","2022-03-11T22:47:50Z"],["description",{},"text","1983"],["last-modified",{},"date-time","2022-03-11T23:41:43Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Benjamin Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
          Was kann ich tun, um diese Warnung weg zu bekommen? Also was müsste ich am Kalender / Eintrag ändern?
          • haus-automatisierung
            haus-automatisierung Developer Most Active @Ben1983 last edited by
            @ben1983 Mh - wie genau sieht der ical Eintrag denn aus? Kannst Du die EVENT Definition aus der Datei mal teilen?
            • Ben1983
              Ben1983 @haus-automatisierung last edited by
              @haus-automatisierung ich habe gerade den Eintrag des Geburtstags gelöscht. die Warnung kommt nicht mehr, aber der Geburtstag steht trotzdem noch im Log drin als erkannt?
              Wieso stehen eigentlich nur manche Geburtstage als "found Birthday" drin?
              Welche Definition meinst Du denn? Die vom Kalender?
                haus-automatisierung Developer Most Active @Ben1983 last edited by haus-automatisierung
                @ben1983 sagte in Test Adapter Birthdays:
                Ich verstehe die Frage nicht. Wenn der Kalendereintrag den Vorgaben (siehe Doku) entspricht, dann sollte diese Meldung für alle Geburtstage auftauchen.
                Wenn Du die ical Datei mit einem Texteditor öffnest, dann suchst Du nach dem EVENT-Abschnitt, welcher den genannten Termin betrifft. Irgendwo müssen die ja doppelt her kommen. Eventuell hast Du ja auch mal einen einzelnen Termin aus einer Termin-Serie gelöscht und dadurch gibt es nun für den gleichen Geburtstag zwei Definitionen.
                Ben1983 2 Replies Last reply Reply Quote 0
                • Ben1983
                  Ben1983 @haus-automatisierung last edited by Ben1983
                  @haus-automatisierung ich habe ziemlich viele von diesen Einträgen:
                  birthdays.0
                  2023-06-12 09:30:43.597	debug	[fillPathWithBirthday] path: "month.06.stephanPanz", birthday: {"name":"Stephan Panz","birthYear":1979,"dateFormat":"03.06.2024","age":45,"daysLeft":357,"_birthday":"1979-06-02T23:00:00.000Z","_nextBirthday":"2024-06-02T22:00:00.000Z"}
                  birthdays.0
                  2023-06-12 09:30:43.593	debug	[fillPathWithBirthday] path: "month.05.maxBreuer", birthday: {"name":"Max Breuer","birthYear":1994,"dateFormat":"25.05.2024","age":30,"daysLeft":348,"_birthday":"1994-05-24T22:00:00.000Z","_nextBirthday":"2024-05-24T22:00:00.000Z"}
                  birthdays.0
                  2023-06-12 09:30:43.587	debug	[fillPathWithBirthday] path: "month.05.eddiSchmidt", birthday: {"name":"Eddi Schmidt","birthYear":1999,"dateFormat":"20.05.2024","age":25,"daysLeft":343,"_birthday":"1999-05-19T22:00:00.000Z","_nextBirthday":"2024-05-19T22:00:00.000Z"}
                  birthdays.0
                  2023-06-12 09:30:43.583	debug	[fillPathWithBirthday] path: "month.05.linaGrywnow", birthday: {"name":"Lina Grywnow","birthYear":2013,"dateFormat":"20.05.2024","age":11,"daysLeft":343,"_birthday":"2013-05-19T22:00:00.000Z","_nextBirthday":"2024-05-19T22:00:00.000Z"}
                  birthdays.0
                  2023-06-12 09:30:43.579	debug	[fillPathWithBirthday] path: "month.05.tabeaMeinhardt", birthday: {"name":"Tabea Meinhardt","birthYear":1996,"dateFormat":"18.05.2024","age":28,"daysLeft":341,"_birthday":"1996-05-17T22:00:00.000Z","_nextBirthday":"2024-05-17T22:00:00.000Z"}
                  birthdays.0
                  2023-06-12 09:30:43.575	debug	[fillPathWithBirthday] path: "month.05.constantinBreuer", birthday: {"name":"Constantin Breuer","birthYear":1989,"dateFormat":"17.05.2024","age":35,"daysLeft":340,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2024-05-16T22:00:00.000Z"}
                  birthdays.0
                  2023-06-12 09:30:43.568	debug	[fillPathWithBirthday] path: "month.05.valeskaBreuer", birthday: {"name":"Valeska Breuer","birthYear":1989,"dateFormat":"17.05.2024","age":35,"daysLeft":340,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2024-05-16T22:00:00.000Z"}
                  Der Eintrag war noch doppelt drin, stimm letztes Jahr stand er noch einzeln drin.
                  • Ben1983
                    @haus-automatisierung sagte in Test Adapter Birthdays:
                    Das zB.
                    BEGIN:VEVENT
                    DTSTART;VALUE=DATE:20220627
                    DTEND;VALUE=DATE:20220628
                    RRULE:FREQ=YEARLY
                    DTSTAMP:20230612T073725Z
                    UID:xyzblablabla@google.com
                    CREATED:20220311T233833Z
                    DESCRIPTION:1959
                    LAST-MODIFIED:20220311T233833Z
                    SEQUENCE:0
                    STATUS:CONFIRMED
                    SUMMARY:Horst Schmidt
                    TRANSP:TRANSPARENT
                    END:VEVENT
                      @ben1983 Was ist denn jetzt genau das Problem?
                      • Du löschst einzelne Einträge und plötzlich verschwindet die Meldung, aber der Termin bleibt? Also war er vorher doppelt drin und die Meldung hatte recht?
                      • Du bekommst Debug-Ausgaben, dass die entsprechenden Objekte angelegt werden (das ist doch alles richtig?)
                      • Du teilst ein EVENT von einem ganz anderen Eintrag, als zu dem doppelten vom Anfang.
                      Ich kann so nicht helfen. Bitte mal eine konkrete Problembeschreibung von A-Z mit einem Beispiel Kalendereintrag und was genau Du wartet hättest / was Deiner Meinung nach falsch läuft.
                      • Ben1983
                        Zu 1.
                        Ja, der Termin war doppelt drin und die Meldung hatte recht.
                        Zu 2.
                        Die Debug Meldungen bekomme ich für viele Geburtstage (sagen wir ca. 30 STück),
                        aber das "found Birthday" erscheint nur bei einer hand voll.
                        Zu 3.
                        Diesen Beitrag habe ich genommen, weil dies einer ist, der zwar im log steht,
                        aber ein found Birthday nicht erscheint.
                        Die Geburtstage werden ja angezeigt.
                        Ich hatte mich nur gefragt, warum das "found Birthday" nur bei manchen im log erscheint.
                          Kann ja nicht sein: https://github.com/klein0r/ioBroker.birthdays/blob/b8e239334fea3a49d692c217d906e4b87cc3b5d3/main.js#L207
                          • Ben1983
                            @haus-automatisierung Hier der komplette log:
                            da ist es jetzt öfter drin. Ich schwöre, dass es eben nur 7 mal drin war. Leider habe ich den log von eben nicht mehr.
                            2023-06-12 10:36:40.395 - info: host.buanet-iobroker_8_0_1 stopInstance system.adapter.birthdays.0 (force=false, process=false)
                            2023-06-12 10:36:40.396 - info: host.buanet-iobroker_8_0_1 stopInstance canceled schedule system.adapter.birthdays.0
                            2023-06-12 10:36:43.455 - info: host.buanet-iobroker_8_0_1 instance scheduled system.adapter.birthdays.0 0 0 * * *
                            2023-06-12 10:36:43.482 - info: host.buanet-iobroker_8_0_1 instance system.adapter.birthdays.0 started with pid 7102
                            2023-06-12 10:36:44.088 - debug: birthdays.0 (7102) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2023-06-12 10:36:44.225 - debug: birthdays.0 (7102) Objects client ready ... initialize now
                            2023-06-12 10:36:44.289 - debug: birthdays.0 (7102) Objects create System PubSub Client
                            2023-06-12 10:36:44.290 - debug: birthdays.0 (7102) Objects create User PubSub Client
                            2023-06-12 10:36:44.342 - debug: birthdays.0 (7102) Objects client initialize lua scripts
                            2023-06-12 10:36:44.349 - debug: birthdays.0 (7102) Objects connected to redis: 127.0.0.1:9001
                            2023-06-12 10:36:44.377 - debug: birthdays.0 (7102) Redis States: Use Redis connection: 127.0.0.1:9000
                            2023-06-12 10:36:44.432 - debug: birthdays.0 (7102) States create System PubSub Client
                            2023-06-12 10:36:44.433 - debug: birthdays.0 (7102) States create User PubSub Client
                            2023-06-12 10:36:44.494 - debug: birthdays.0 (7102) States connected to redis: 127.0.0.1:9000
                            2023-06-12 10:36:44.866 - info: birthdays.0 (7102) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.birthdays, node: v18.16.0, js-controller: 4.0.24
                            2023-06-12 10:36:44.985 - debug: birthdays.0 (7102) [settings] done
                            2023-06-12 10:36:44.986 - debug: birthdays.0 (7102) [ical] url/path: https://calendar.google.com/calendar/ical/qqp6g7e3v0q26ss82l5o38v2h0%40group.calendar.google.com/private-558febf6616d48bb1091ba66884d5afa/basic.ics
                            2023-06-12 10:36:44.986 - debug: birthdays.0 (7102) [ical] addByCalendar - looks like an http url, performing get request
                            2023-06-12 10:36:45.051 - debug: birthdays.0 (7102) [carddav] done - url not configured - skipped
                            2023-06-12 10:36:45.416 - debug: birthdays.0 (7102) [ical] http(s) request finished with status: 200
                            2023-06-12 10:36:45.422 - debug: birthdays.0 (7102) [ical] found 35 events
                            2023-06-12 10:36:45.424 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-17"],["dtend",{},"date","2022-05-18"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","50pbhcvqjg1vb5fujsbfg7ntae@google.com"],["created",{},"date-time","2022-03-11T23:34:25Z"],["description",{},"text","1989"],["last-modified",{},"date-time","2022-03-11T23:34:25Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Constantin Breuer"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.424 - debug: birthdays.0 (7102) [ical] found birthday: Constantin Breuer (1989)
                            2023-06-12 10:36:45.427 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-12"],["dtend",{},"date","2022-05-13"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","3j95d8maughq65lm97s86dlef4@google.com"],["created",{},"date-time","2022-03-11T23:33:28Z"],["description",{},"text","1987"],["last-modified",{},"date-time","2022-03-11T23:34:40Z"],["sequence",{},"integer",1],["status",{},"text","CONFIRMED"],["summary",{},"text","Valentina Breuer"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.428 - debug: birthdays.0 (7102) [ical] found birthday: Valentina Breuer (1987)
                            2023-06-12 10:36:45.429 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-17"],["dtend",{},"date","2022-05-18"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","60l37rgp3q8cshqoq26m2vgkho@google.com"],["created",{},"date-time","2022-03-11T23:35:11Z"],["description",{},"text","1989"],["last-modified",{},"date-time","2022-03-11T23:35:11Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Valeska Breuer"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.429 - debug: birthdays.0 (7102) [ical] found birthday: Valeska Breuer (1989)
                            2023-06-12 10:36:45.430 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-25"],["dtend",{},"date","2022-05-26"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","0kteoi2h3j2p4hmi9mtjkncqbd@google.com"],["created",{},"date-time","2022-03-11T23:36:24Z"],["description",{},"text","1994"],["last-modified",{},"date-time","2022-03-11T23:36:24Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Max Breuer"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.430 - debug: birthdays.0 (7102) [ical] found birthday: Max Breuer (1994)
                            2023-06-12 10:36:45.431 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-06-27"],["dtend",{},"date","2022-06-28"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","590ibeb90hk351kc2dn4c5a8n0@google.com"],["created",{},"date-time","2022-03-11T23:38:33Z"],["description",{},"text","1959"],["last-modified",{},"date-time","2022-03-11T23:38:33Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Horst Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.431 - debug: birthdays.0 (7102) [ical] found birthday: Horst Schmidt (1959)
                            2023-06-12 10:36:45.432 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-06-20"],["dtend",{},"date","2022-06-21"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","6nigji2q38hrqa931ajgd584cf@google.com"],["created",{},"date-time","2022-03-11T23:37:35Z"],["description",{},"text","1977"],["last-modified",{},"date-time","2022-03-11T23:38:43Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Renè Grywnow"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.432 - debug: birthdays.0 (7102) [ical] found birthday: Renè Grywnow (1977)
                            2023-06-12 10:36:45.432 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-01-15"],["dtend",{},"date","2022-01-16"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","3upmjklvmuhk9srl2jt9c72stm@google.com"],["created",{},"date-time","2022-03-11T23:39:33Z"],["description",{},"text","1999"],["last-modified",{},"date-time","2022-03-11T23:39:33Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Marick Förster"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.433 - debug: birthdays.0 (7102) [ical] found birthday: Marick Förster (1999)
                            2023-06-12 10:36:45.433 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-07-25"],["dtend",{},"date","2022-07-26"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","3hq7bbp8dm1547jd9n37ccg2kf@google.com"],["created",{},"date-time","2022-03-11T23:40:30Z"],["description",{},"text","1956"],["last-modified",{},"date-time","2022-03-11T23:40:30Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Käthe Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.433 - debug: birthdays.0 (7102) [ical] found birthday: Käthe Schmidt (1956)
                            2023-06-12 10:36:45.434 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-08-20"],["dtend",{},"date","2022-08-21"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","6lt30ui2lg9bkhu62jvs6ig4vb@google.com"],["created",{},"date-time","2022-03-11T22:55:49Z"],["description",{},"text","2017"],["last-modified",{},"date-time","2022-03-11T23:40:54Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Rika Breuer"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.434 - debug: birthdays.0 (7102) [ical] found birthday: Rika Breuer (2017)
                            2023-06-12 10:36:45.435 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-03-07"],["dtend",{},"date","2022-03-08"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","3ra6d3h1t9o64hjjt7kfapekru@google.com"],["created",{},"date-time","2022-03-12T01:03:07Z"],["description",{},"text","2021"],["last-modified",{},"date-time","2022-03-12T01:03:07Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Joe Bradtke"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.435 - debug: birthdays.0 (7102) [ical] found birthday: Joe Bradtke (2021)
                            2023-06-12 10:36:45.436 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-03-05"],["dtend",{},"date","2022-03-06"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","68avg7vhhdu6e8vbo652uji0s0@google.com"],["created",{},"date-time","2022-03-12T01:04:19Z"],["description",{},"text","1982"],["last-modified",{},"date-time","2022-03-12T01:04:19Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Michael Hannes"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.436 - debug: birthdays.0 (7102) [ical] found birthday: Michael Hannes (1982)
                            2023-06-12 10:36:45.436 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-03-19"],["dtend",{},"date","2022-03-20"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","2v96q5qg4vc58u0qaoage2gkcu@google.com"],["created",{},"date-time","2022-03-12T01:05:18Z"],["description",{},"text","1993"],["last-modified",{},"date-time","2022-03-12T01:05:34Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Laura Hannes"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.437 - debug: birthdays.0 (7102) [ical] found birthday: Laura Hannes (1993)
                            2023-06-12 10:36:45.437 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-04-02"],["dtend",{},"date","2022-04-03"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","62dqaantph398hp82tboldktf2@google.com"],["created",{},"date-time","2022-03-12T01:06:43Z"],["description",{},"text","1952"],["last-modified",{},"date-time","2022-03-12T01:06:43Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Brigitte Meisinger"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.437 - debug: birthdays.0 (7102) [ical] found birthday: Brigitte Meisinger (1952)
                            2023-06-12 10:36:45.438 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-20"],["dtend",{},"date","2022-05-21"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","4aiuu3j3e3q1oo1917t9sbruef@google.com"],["created",{},"date-time","2022-03-12T01:10:03Z"],["description",{},"text","1999"],["last-modified",{},"date-time","2022-03-12T01:10:03Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Eddi Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.438 - debug: birthdays.0 (7102) [ical] found birthday: Eddi Schmidt (1999)
                            2023-06-12 10:36:45.439 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-20"],["dtend",{},"date","2022-05-21"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","7sjcb675ks68fc9p8g34on55v7@google.com"],["created",{},"date-time","2022-03-12T01:10:44Z"],["description",{},"text","2013"],["last-modified",{},"date-time","2022-03-12T01:10:44Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Lina Grywnow"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.439 - debug: birthdays.0 (7102) [ical] found birthday: Lina Grywnow (2013)
                            2023-06-12 10:36:45.439 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-07-21"],["dtend",{},"date","2022-07-22"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","34sa560m9pomird6r8e2rjlphm@google.com"],["created",{},"date-time","2022-03-12T01:12:41Z"],["description",{},"text","2016"],["last-modified",{},"date-time","2022-03-12T01:12:41Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Lisa Hannes"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.440 - debug: birthdays.0 (7102) [ical] found birthday: Lisa Hannes (2016)
                            2023-06-12 10:36:45.440 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-07-26"],["dtend",{},"date","2022-07-27"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","04lc53novck2dntnsgh217hksr@google.com"],["created",{},"date-time","2022-03-12T01:14:22Z"],["description",{},"text","2015"],["last-modified",{},"date-time","2022-03-12T01:14:22Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Louis Eisenreich"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.440 - debug: birthdays.0 (7102) [ical] found birthday: Louis Eisenreich (2015)
                            2023-06-12 10:36:45.441 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-08-14"],["dtend",{},"date","2022-08-15"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","34jl36nto17r7ju7fd9tm74fik@google.com"],["created",{},"date-time","2022-03-12T01:16:38Z"],["description",{},"text","1960"],["last-modified",{},"date-time","2022-03-12T01:16:38Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Andrea Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.441 - debug: birthdays.0 (7102) [ical] found birthday: Andrea Schmidt (1960)
                            2023-06-12 10:36:45.441 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-08-17"],["dtend",{},"date","2022-08-18"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","5gpptvr00j7drj2inrqd2d0n9c@google.com"],["created",{},"date-time","2022-03-11T23:42:29Z"],["description",{},"text","1977"],["last-modified",{},"date-time","2022-03-12T01:17:33Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Tatiana Grywnow"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.441 - debug: birthdays.0 (7102) [ical] found birthday: Tatiana Grywnow (1977)
                            2023-06-12 10:36:45.442 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-09-10"],["dtend",{},"date","2022-09-11"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","0tl3bpl7lu936irogi545g34dt@google.com"],["created",{},"date-time","2022-03-11T23:43:07Z"],["description",{},"text","1987"],["last-modified",{},"date-time","2022-03-12T01:18:11Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Rebecca Bradtke"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.442 - debug: birthdays.0 (7102) [ical] found birthday: Rebecca Bradtke (1987)
                            2023-06-12 10:36:45.442 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-09-11"],["dtend",{},"date","2022-09-12"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","4c9e477rjccsetgo46qp3js6mj@google.com"],["created",{},"date-time","2022-03-12T01:18:44Z"],["description",{},"text","2011"],["last-modified",{},"date-time","2022-03-12T01:18:44Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Tom Grywnow"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.443 - debug: birthdays.0 (7102) [ical] found birthday: Tom Grywnow (2011)
                            2023-06-12 10:36:45.443 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-10-12"],["dtend",{},"date","2022-10-13"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","6r3nr678ei1fg4sva8287qu1iu@google.com"],["created",{},"date-time","2022-03-12T01:19:53Z"],["description",{},"text","1983"],["last-modified",{},"date-time","2022-03-12T01:19:53Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Stefan Bradtke"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.443 - debug: birthdays.0 (7102) [ical] found birthday: Stefan Bradtke (1983)
                            2023-06-12 10:36:45.444 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-12-13"],["dtend",{},"date","2022-12-14"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","5o9al65m4b7l7d4a5gf01h7eid@google.com"],["created",{},"date-time","2022-03-12T01:21:29Z"],["description",{},"text","1949"],["last-modified",{},"date-time","2022-03-12T01:21:29Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Alfred Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.444 - debug: birthdays.0 (7102) [ical] found birthday: Alfred Schmidt (1949)
                            2023-06-12 10:36:45.444 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-01-22"],["dtend",{},"date","2022-01-23"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","3kqfi92bq257bja94b5cgsuarp@google.com"],["created",{},"date-time","2022-03-12T08:02:48Z"],["description",{},"text","1983"],["last-modified",{},"date-time","2022-03-12T08:04:47Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Michael Grebeldinger"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.444 - debug: birthdays.0 (7102) [ical] found birthday: Michael Grebeldinger (1983)
                            2023-06-12 10:36:45.445 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-08"],["dtend",{},"date","2022-05-09"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","2a4uk2k76pp7qbh7192ufci5ee@google.com"],["created",{},"date-time","2022-03-12T08:11:20Z"],["description",{},"text","1981"],["last-modified",{},"date-time","2022-03-12T08:11:20Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Nils Gerlach"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.445 - debug: birthdays.0 (7102) [ical] found birthday: Nils Gerlach (1981)
                            2023-06-12 10:36:45.447 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-06-03"],["dtend",{},"date","2022-06-04"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","5t5qtqsrj65oh154svhj6kvqb5@google.com"],["created",{},"date-time","2022-03-12T08:12:26Z"],["description",{},"text","1979"],["last-modified",{},"date-time","2022-03-12T08:12:26Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Stephan Panz"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.448 - debug: birthdays.0 (7102) [ical] found birthday: Stephan Panz (1979)
                            2023-06-12 10:36:45.448 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-08-11"],["dtend",{},"date","2022-08-12"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","6gp1bhjl056fts8327gboftdr1@google.com"],["created",{},"date-time","2022-03-12T08:13:16Z"],["description",{},"text","1979"],["last-modified",{},"date-time","2022-03-12T08:13:16Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Hendrik Müller"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.448 - debug: birthdays.0 (7102) [ical] found birthday: Hendrik Müller (1979)
                            2023-06-12 10:36:45.449 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-06-22"],["dtend",{},"date","2022-06-23"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","7ifrrvn7ghq5i30enm1s860ah2@google.com"],["created",{},"date-time","2022-03-12T08:14:40Z"],["description",{},"text","1983"],["last-modified",{},"date-time","2022-03-12T08:14:40Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Oliver Paul"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.449 - debug: birthdays.0 (7102) [ical] found birthday: Oliver Paul (1983)
                            2023-06-12 10:36:45.449 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-07-26"],["dtend",{},"date","2022-07-27"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","58r62m8gdbuj68jkdm6v9l6fgq@google.com"],["created",{},"date-time","2022-03-12T01:14:48Z"],["description",{},"text","1960"],["last-modified",{},"date-time","2022-03-12T08:15:52Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Ines"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.449 - debug: birthdays.0 (7102) [ical] found birthday: Ines (1960)
                            2023-06-12 10:36:45.450 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-04-05"],["dtend",{},"date","2022-04-06"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","2qh6779fgob5t5bb8rrm0svjrp@google.com"],["created",{},"date-time","2022-03-12T01:07:42Z"],["description",{},"text","1969"],["last-modified",{},"date-time","2022-03-12T08:17:20Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Michael Meisinger"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.450 - debug: birthdays.0 (7102) [ical] found birthday: Michael Meisinger (1969)
                            2023-06-12 10:36:45.450 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-01-10"],["dtend",{},"date","2022-01-11"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","1tdpucqq0j3gjqacahqvslqccu@google.com"],["created",{},"date-time","2022-03-12T01:00:23Z"],["description",{},"text","1971"],["last-modified",{},"date-time","2022-03-12T08:18:04Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Juliane Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.451 - debug: birthdays.0 (7102) [ical] found birthday: Juliane Schmidt (1971)
                            2023-06-12 10:36:45.451 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-01-12"],["dtend",{},"date","2022-01-13"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","422kq5sle3pdg3sb715c83nra1@google.com"],["created",{},"date-time","2022-03-12T01:00:56Z"],["description",{},"text","1999"],["last-modified",{},"date-time","2022-03-12T08:18:21Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Calvin Seum"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.451 - debug: birthdays.0 (7102) [ical] found birthday: Calvin Seum (1999)
                            2023-06-12 10:36:45.452 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-18"],["dtend",{},"date","2022-05-19"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","1k0p7ckv2046m3rkn378e13kdo@google.com"],["created",{},"date-time","2022-03-12T01:09:22Z"],["description",{},"text","1996"],["last-modified",{},"date-time","2022-03-12T08:19:07Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Tabea Meinhardt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.452 - debug: birthdays.0 (7102) [ical] found birthday: Tabea Meinhardt (1996)
                            2023-06-12 10:36:45.452 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-28"],["dtend",{},"date","2022-05-29"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","1v0e13bhbmtirbllobo69r8gq8@google.com"],["created",{},"date-time","2023-06-12T07:32:29Z"],["description",{},"text","1983"],["last-modified",{},"date-time","2023-06-12T07:32:41Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Benjamin Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.452 - debug: birthdays.0 (7102) [ical] found birthday: Benjamin Schmidt (1983)
                            2023-06-12 10:36:45.453 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-10-15"],["dtend",{},"date","2022-10-16"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","7i0kn2tvjl9n7akcb0k493b8lg@google.com"],["created",{},"date-time","2023-06-12T07:36:01Z"],["description",{},"text","1979"],["last-modified",{},"date-time","2023-06-12T07:36:13Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Jennifer Schmidt-Förster"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                            2023-06-12 10:36:45.453 - debug: birthdays.0 (7102) [ical] found birthday: Jennifer Schmidt-Förster (1979)
                            2023-06-12 10:36:45.453 - debug: birthdays.0 (7102) [ical] processed all events
                            2023-06-12 10:36:45.453 - debug: birthdays.0 (7102) [onReady] everything collected: [0,35,0]
                            2023-06-12 10:36:45.455 - debug: birthdays.0 (7102) [fillStates] birthdays: [{"name":"Renè Grywnow","birthYear":1977,"dateFormat":"20.06.2023","age":46,"daysLeft":8,"_birthday":"1977-06-19T23:00:00.000Z","_nextBirthday":"2023-06-19T22:00:00.000Z"},{"name":"Oliver Paul","birthYear":1983,"dateFormat":"22.06.2023","age":40,"daysLeft":10,"_birthday":"1983-06-21T22:00:00.000Z","_nextBirthday":"2023-06-21T22:00:00.000Z"},{"name":"Horst Schmidt","birthYear":1959,"dateFormat":"27.06.2023","age":64,"daysLeft":15,"_birthday":"1959-06-26T23:00:00.000Z","_nextBirthday":"2023-06-26T22:00:00.000Z"},{"name":"Lisa Hannes","birthYear":2016,"dateFormat":"21.07.2023","age":7,"daysLeft":39,"_birthday":"2016-07-20T22:00:00.000Z","_nextBirthday":"2023-07-20T22:00:00.000Z"},{"name":"Käthe Schmidt","birthYear":1956,"dateFormat":"25.07.2023","age":67,"daysLeft":43,"_birthday":"1956-07-24T23:00:00.000Z","_nextBirthday":"2023-07-24T22:00:00.000Z"},{"name":"Ines","birthYear":1960,"dateFormat":"26.07.2023","age":63,"daysLeft":44,"_birthday":"1960-07-25T23:00:00.000Z","_nextBirthday":"2023-07-25T22:00:00.000Z"},{"name":"Louis Eisenreich","birthYear":2015,"dateFormat":"26.07.2023","age":8,"daysLeft":44,"_birthday":"2015-07-25T22:00:00.000Z","_nextBirthday":"2023-07-25T22:00:00.000Z"},{"name":"Hendrik Müller","birthYear":1979,"dateFormat":"11.08.2023","age":44,"daysLeft":60,"_birthday":"1979-08-10T23:00:00.000Z","_nextBirthday":"2023-08-10T22:00:00.000Z"},{"name":"Andrea Schmidt","birthYear":1960,"dateFormat":"14.08.2023","age":63,"daysLeft":63,"_birthday":"1960-08-13T23:00:00.000Z","_nextBirthday":"2023-08-13T22:00:00.000Z"},{"name":"Tatiana Grywnow","birthYear":1977,"dateFormat":"17.08.2023","age":46,"daysLeft":66,"_birthday":"1977-08-16T23:00:00.000Z","_nextBirthday":"2023-08-16T22:00:00.000Z"},{"name":"Rika Breuer","birthYear":2017,"dateFormat":"20.08.2023","age":6,"daysLeft":69,"_birthday":"2017-08-19T22:00:00.000Z","_nextBirthday":"2023-08-19T22:00:00.000Z"},{"name":"Rebecca Bradtke","birthYear":1987,"dateFormat":"10.09.2023","age":36,"daysLeft":90,"_birthday":"1987-09-09T22:00:00.000Z","_nextBirthday":"2023-09-09T22:00:00.000Z"},{"name":"Tom Grywnow","birthYear":2011,"dateFormat":"11.09.2023","age":12,"daysLeft":91,"_birthday":"2011-09-10T22:00:00.000Z","_nextBirthday":"2023-09-10T22:00:00.000Z"},{"name":"Stefan Bradtke","birthYear":1983,"dateFormat":"12.10.2023","age":40,"daysLeft":122,"_birthday":"1983-10-11T23:00:00.000Z","_nextBirthday":"2023-10-11T22:00:00.000Z"},{"name":"Jennifer Schmidt-Förster","birthYear":1979,"dateFormat":"15.10.2023","age":44,"daysLeft":125,"_birthday":"1979-10-14T23:00:00.000Z","_nextBirthday":"2023-10-14T22:00:00.000Z"},{"name":"Alfred Schmidt","birthYear":1949,"dateFormat":"13.12.2023","age":74,"daysLeft":184,"_birthday":"1949-12-12T23:00:00.000Z","_nextBirthday":"2023-12-12T23:00:00.000Z"},{"name":"Juliane Schmidt","birthYear":1971,"dateFormat":"10.01.2024","age":53,"daysLeft":212,"_birthday":"1971-01-09T23:00:00.000Z","_nextBirthday":"2024-01-09T23:00:00.000Z"},{"name":"Calvin Seum","birthYear":1999,"dateFormat":"12.01.2024","age":25,"daysLeft":214,"_birthday":"1999-01-11T23:00:00.000Z","_nextBirthday":"2024-01-11T23:00:00.000Z"},{"name":"Marick Förster","birthYear":1999,"dateFormat":"15.01.2024","age":25,"daysLeft":217,"_birthday":"1999-01-14T23:00:00.000Z","_nextBirthday":"2024-01-14T23:00:00.000Z"},{"name":"Michael Grebeldinger","birthYear":1983,"dateFormat":"22.01.2024","age":41,"daysLeft":224,"_birthday":"1983-01-21T23:00:00.000Z","_nextBirthday":"2024-01-21T23:00:00.000Z"},{"name":"Michael Hannes","birthYear":1982,"dateFormat":"05.03.2024","age":42,"daysLeft":267,"_birthday":"1982-03-04T23:00:00.000Z","_nextBirthday":"2024-03-04T23:00:00.000Z"},{"name":"Joe Bradtke","birthYear":2021,"dateFormat":"07.03.2024","age":3,"daysLeft":269,"_birthday":"2021-03-06T23:00:00.000Z","_nextBirthday":"2024-03-06T23:00:00.000Z"},{"name":"Laura Hannes","birthYear":1993,"dateFormat":"19.03.2024","age":31,"daysLeft":281,"_birthday":"1993-03-18T23:00:00.000Z","_nextBirthday":"2024-03-18T23:00:00.000Z"},{"name":"Brigitte Meisinger","birthYear":1952,"dateFormat":"02.04.2024","age":72,"daysLeft":295,"_birthday":"1952-04-01T23:00:00.000Z","_nextBirthday":"2024-04-01T22:00:00.000Z"},{"name":"Michael Meisinger","birthYear":1969,"dateFormat":"05.04.2024","age":55,"daysLeft":298,"_birthday":"1969-04-04T23:00:00.000Z","_nextBirthday":"2024-04-04T22:00:00.000Z"},{"name":"Nils Gerlach","birthYear":1981,"dateFormat":"08.05.2024","age":43,"daysLeft":331,"_birthday":"1981-05-07T22:00:00.000Z","_nextBirthday":"2024-05-07T22:00:00.000Z"},{"name":"Valentina Breuer","birthYear":1987,"dateFormat":"12.05.2024","age":37,"daysLeft":335,"_birthday":"1987-05-11T22:00:00.000Z","_nextBirthday":"2024-05-11T22:00:00.000Z"},{"name":"Valeska Breuer","birthYear":1989,"dateFormat":"17.05.2024","age":35,"daysLeft":340,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2024-05-16T22:00:00.000Z"},{"name":"Constantin Breuer","birthYear":1989,"dateFormat":"17.05.2024","age":35,"daysLeft":340,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2024-05-16T22:00:00.000Z"},{"name":"Tabea Meinhardt","birthYear":1996,"dateFormat":"18.05.2024","age":28,"daysLeft":341,"_birthday":"1996-05-17T22:00:00.000Z","_nextBirthday":"2024-05-17T22:00:00.000Z"},{"name":"Lina Grywnow","birthYear":2013,"dateFormat":"20.05.2024","age":11,"daysLeft":343,"_birthday":"2013-05-19T22:00:00.000Z","_nextBirthday":"2024-05-19T22:00:00.000Z"},{"name":"Eddi Schmidt","birthYear":1999,"dateFormat":"20.05.2024","age":25,"daysLeft":343,"_birthday":"1999-05-19T22:00:00.000Z","_nextBirthday":"2024-05-19T22:00:00.000Z"},{"name":"Max Breuer","birthYear":1994,"dateFormat":"25.05.2024","age":30,"daysLeft":348,"_birthday":"1994-05-24T22:00:00.000Z","_nextBirthday":"2024-05-24T22:00:00.000Z"},{"name":"Benjamin Schmidt","birthYear":1983,"dateFormat":"28.05.2024","age":41,"daysLeft":351,"_birthday":"1983-05-27T22:00:00.000Z","_nextBirthday":"2024-05-27T22:00:00.000Z"},{"name":"Stephan Panz","birthYear":1979,"dateFormat":"03.06.2024","age":45,"daysLeft":357,"_birthday":"1979-06-02T23:00:00.000Z","_nextBirthday":"2024-06-02T22:00:00.000Z"}]
                            2023-06-12 10:36:45.545 - debug: birthdays.0 (7102) [fillStates] birthdays significant: [{"name":"Oliver Paul","birthYear":1983,"dateFormat":"22.06.2023","age":40,"daysLeft":10,"_birthday":"1983-06-21T22:00:00.000Z","_nextBirthday":"2023-06-21T22:00:00.000Z"},{"name":"Stefan Bradtke","birthYear":1983,"dateFormat":"12.10.2023","age":40,"daysLeft":122,"_birthday":"1983-10-11T23:00:00.000Z","_nextBirthday":"2023-10-11T22:00:00.000Z"},{"name":"Max Breuer","birthYear":1994,"dateFormat":"25.05.2024","age":30,"daysLeft":348,"_birthday":"1994-05-24T22:00:00.000Z","_nextBirthday":"2024-05-24T22:00:00.000Z"},{"name":"Louis Eisenreich","birthYear":2015,"dateFormat":"26.07.2025","age":10,"daysLeft":775,"_birthday":"2015-07-25T22:00:00.000Z","_nextBirthday":"2025-07-25T22:00:00.000Z"},{"name":"Tabea Meinhardt","birthYear":1996,"dateFormat":"18.05.2026","age":30,"daysLeft":1071,"_birthday":"1996-05-17T22:00:00.000Z","_nextBirthday":"2026-05-17T22:00:00.000Z"},{"name":"Lisa Hannes","birthYear":2016,"dateFormat":"21.07.2026","age":10,"daysLeft":1135,"_birthday":"2016-07-20T22:00:00.000Z","_nextBirthday":"2026-07-20T22:00:00.000Z"},{"name":"Käthe Schmidt","birthYear":1956,"dateFormat":"25.07.2026","age":70,"daysLeft":1139,"_birthday":"1956-07-24T23:00:00.000Z","_nextBirthday":"2026-07-24T22:00:00.000Z"},{"name":"Valentina Breuer","birthYear":1987,"dateFormat":"12.05.2027","age":40,"daysLeft":1430,"_birthday":"1987-05-11T22:00:00.000Z","_nextBirthday":"2027-05-11T22:00:00.000Z"},{"name":"Renè Grywnow","birthYear":1977,"dateFormat":"20.06.2027","age":50,"daysLeft":1469,"_birthday":"1977-06-19T23:00:00.000Z","_nextBirthday":"2027-06-19T22:00:00.000Z"},{"name":"Tatiana Grywnow","birthYear":1977,"dateFormat":"17.08.2027","age":50,"daysLeft":1527,"_birthday":"1977-08-16T23:00:00.000Z","_nextBirthday":"2027-08-16T22:00:00.000Z"},{"name":"Rika Breuer","birthYear":2017,"dateFormat":"20.08.2027","age":10,"daysLeft":1530,"_birthday":"2017-08-19T22:00:00.000Z","_nextBirthday":"2027-08-19T22:00:00.000Z"},{"name":"Rebecca Bradtke","birthYear":1987,"dateFormat":"10.09.2027","age":40,"daysLeft":1551,"_birthday":"1987-09-09T22:00:00.000Z","_nextBirthday":"2027-09-09T22:00:00.000Z"},{"name":"Calvin Seum","birthYear":1999,"dateFormat":"12.01.2029","age":30,"daysLeft":2041,"_birthday":"1999-01-11T23:00:00.000Z","_nextBirthday":"2029-01-11T23:00:00.000Z"},{"name":"Marick Förster","birthYear":1999,"dateFormat":"15.01.2029","age":30,"daysLeft":2044,"_birthday":"1999-01-14T23:00:00.000Z","_nextBirthday":"2029-01-14T23:00:00.000Z"},{"name":"Michael Meisinger","birthYear":1969,"dateFormat":"05.04.2029","age":60,"daysLeft":2124,"_birthday":"1969-04-04T23:00:00.000Z","_nextBirthday":"2029-04-04T22:00:00.000Z"},{"name":"Valeska Breuer","birthYear":1989,"dateFormat":"17.05.2029","age":40,"daysLeft":2166,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2029-05-16T22:00:00.000Z"},{"name":"Constantin Breuer","birthYear":1989,"dateFormat":"17.05.2029","age":40,"daysLeft":2166,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2029-05-16T22:00:00.000Z"},{"name":"Eddi Schmidt","birthYear":1999,"dateFormat":"20.05.2029","age":30,"daysLeft":2169,"_birthday":"1999-05-19T22:00:00.000Z","_nextBirthday":"2029-05-19T22:00:00.000Z"},{"name":"Stephan Panz","birthYear":1979,"dateFormat":"03.06.2029","age":50,"daysLeft":2183,"_birthday":"1979-06-02T23:00:00.000Z","_nextBirthday":"2029-06-02T22:00:00.000Z"},{"name":"Horst Schmidt","birthYear":1959,"dateFormat":"27.06.2029","age":70,"daysLeft":2207,"_birthday":"1959-06-26T23:00:00.000Z","_nextBirthday":"2029-06-26T22:00:00.000Z"},{"name":"Hendrik Müller","birthYear":1979,"dateFormat":"11.08.2029","age":50,"daysLeft":2252,"_birthday":"1979-08-10T23:00:00.000Z","_nextBirthday":"2029-08-10T22:00:00.000Z"},{"name":"Jennifer Schmidt-Förster","birthYear":1979,"dateFormat":"15.10.2029","age":50,"daysLeft":2317,"_birthday":"1979-10-14T23:00:00.000Z","_nextBirthday":"2029-10-14T22:00:00.000Z"},{"name":"Alfred Schmidt","birthYear":1949,"dateFormat":"13.12.2029","age":80,"daysLeft":2376,"_birthday":"1949-12-12T23:00:00.000Z","_nextBirthday":"2029-12-12T23:00:00.000Z"},{"name":"Ines","birthYear":1960,"dateFormat":"26.07.2030","age":70,"daysLeft":2601,"_birthday":"1960-07-25T23:00:00.000Z","_nextBirthday":"2030-07-25T22:00:00.000Z"},{"name":"Andrea Schmidt","birthYear":1960,"dateFormat":"14.08.2030","age":70,"daysLeft":2620,"_birthday":"1960-08-13T23:00:00.000Z","_nextBirthday":"2030-08-13T22:00:00.000Z"},{"name":"Juliane Schmidt","birthYear":1971,"dateFormat":"10.01.2031","age":60,"daysLeft":2769,"_birthday":"1971-01-09T23:00:00.000Z","_nextBirthday":"2031-01-09T23:00:00.000Z"},{"name":"Joe Bradtke","birthYear":2021,"dateFormat":"07.03.2031","age":10,"daysLeft":2825,"_birthday":"2021-03-06T23:00:00.000Z","_nextBirthday":"2031-03-06T23:00:00.000Z"},{"name":"Nils Gerlach","birthYear":1981,"dateFormat":"08.05.2031","age":50,"daysLeft":2887,"_birthday":"1981-05-07T22:00:00.000Z","_nextBirthday":"2031-05-07T22:00:00.000Z"},{"name":"Tom Grywnow","birthYear":2011,"dateFormat":"11.09.2031","age":20,"daysLeft":3013,"_birthday":"2011-09-10T22:00:00.000Z","_nextBirthday":"2031-09-10T22:00:00.000Z"},{"name":"Michael Hannes","birthYear":1982,"dateFormat":"05.03.2032","age":50,"daysLeft":3189,"_birthday":"1982-03-04T23:00:00.000Z","_nextBirthday":"2032-03-04T23:00:00.000Z"},{"name":"Brigitte Meisinger","birthYear":1952,"dateFormat":"02.04.2032","age":80,"daysLeft":3217,"_birthday":"1952-04-01T23:00:00.000Z","_nextBirthday":"2032-04-01T22:00:00.000Z"},{"name":"Michael Grebeldinger","birthYear":1983,"dateFormat":"22.01.2033","age":50,"daysLeft":3512,"_birthday":"1983-01-21T23:00:00.000Z","_nextBirthday":"2033-01-21T23:00:00.000Z"},{"name":"Laura Hannes","birthYear":1993,"dateFormat":"19.03.2033","age":40,"daysLeft":3568,"_birthday":"1993-03-18T23:00:00.000Z","_nextBirthday":"2033-03-18T23:00:00.000Z"},{"name":"Lina Grywnow","birthYear":2013,"dateFormat":"20.05.2033","age":20,"daysLeft":3630,"_birthday":"2013-05-19T22:00:00.000Z","_nextBirthday":"2033-05-19T22:00:00.000Z"},{"name":"Benjamin Schmidt","birthYear":1983,"dateFormat":"28.05.2033","age":50,"daysLeft":3638,"_birthday":"1983-05-27T22:00:00.000Z","_nextBirthday":"2033-05-27T22:00:00.000Z"}]
                            2023-06-12 10:36:45.573 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.06.renèGrywnow", birthday: {"name":"Renè Grywnow","birthYear":1977,"dateFormat":"20.06.2023","age":46,"daysLeft":8,"_birthday":"1977-06-19T23:00:00.000Z","_nextBirthday":"2023-06-19T22:00:00.000Z"}
                            2023-06-12 10:36:45.580 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.06.oliverPaul", birthday: {"name":"Oliver Paul","birthYear":1983,"dateFormat":"22.06.2023","age":40,"daysLeft":10,"_birthday":"1983-06-21T22:00:00.000Z","_nextBirthday":"2023-06-21T22:00:00.000Z"}
                            2023-06-12 10:36:45.584 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.06.horstSchmidt", birthday: {"name":"Horst Schmidt","birthYear":1959,"dateFormat":"27.06.2023","age":64,"daysLeft":15,"_birthday":"1959-06-26T23:00:00.000Z","_nextBirthday":"2023-06-26T22:00:00.000Z"}
                            2023-06-12 10:36:45.590 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.07.lisaHannes", birthday: {"name":"Lisa Hannes","birthYear":2016,"dateFormat":"21.07.2023","age":7,"daysLeft":39,"_birthday":"2016-07-20T22:00:00.000Z","_nextBirthday":"2023-07-20T22:00:00.000Z"}
                            2023-06-12 10:36:45.595 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.07.kätheSchmidt", birthday: {"name":"Käthe Schmidt","birthYear":1956,"dateFormat":"25.07.2023","age":67,"daysLeft":43,"_birthday":"1956-07-24T23:00:00.000Z","_nextBirthday":"2023-07-24T22:00:00.000Z"}
                            2023-06-12 10:36:45.600 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.07.ines", birthday: {"name":"Ines","birthYear":1960,"dateFormat":"26.07.2023","age":63,"daysLeft":44,"_birthday":"1960-07-25T23:00:00.000Z","_nextBirthday":"2023-07-25T22:00:00.000Z"}
                            2023-06-12 10:36:45.604 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.07.louisEisenreich", birthday: {"name":"Louis Eisenreich","birthYear":2015,"dateFormat":"26.07.2023","age":8,"daysLeft":44,"_birthday":"2015-07-25T22:00:00.000Z","_nextBirthday":"2023-07-25T22:00:00.000Z"}
                            2023-06-12 10:36:45.612 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.08.hendrikMüller", birthday: {"name":"Hendrik Müller","birthYear":1979,"dateFormat":"11.08.2023","age":44,"daysLeft":60,"_birthday":"1979-08-10T23:00:00.000Z","_nextBirthday":"2023-08-10T22:00:00.000Z"}
                            2023-06-12 10:36:45.617 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.08.andreaSchmidt", birthday: {"name":"Andrea Schmidt","birthYear":1960,"dateFormat":"14.08.2023","age":63,"daysLeft":63,"_birthday":"1960-08-13T23:00:00.000Z","_nextBirthday":"2023-08-13T22:00:00.000Z"}
                            2023-06-12 10:36:45.623 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.08.tatianaGrywnow", birthday: {"name":"Tatiana Grywnow","birthYear":1977,"dateFormat":"17.08.2023","age":46,"daysLeft":66,"_birthday":"1977-08-16T23:00:00.000Z","_nextBirthday":"2023-08-16T22:00:00.000Z"}
                            2023-06-12 10:36:45.628 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.08.rikaBreuer", birthday: {"name":"Rika Breuer","birthYear":2017,"dateFormat":"20.08.2023","age":6,"daysLeft":69,"_birthday":"2017-08-19T22:00:00.000Z","_nextBirthday":"2023-08-19T22:00:00.000Z"}
                            2023-06-12 10:36:45.631 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.09.rebeccaBradtke", birthday: {"name":"Rebecca Bradtke","birthYear":1987,"dateFormat":"10.09.2023","age":36,"daysLeft":90,"_birthday":"1987-09-09T22:00:00.000Z","_nextBirthday":"2023-09-09T22:00:00.000Z"}
                            2023-06-12 10:36:45.635 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.09.tomGrywnow", birthday: {"name":"Tom Grywnow","birthYear":2011,"dateFormat":"11.09.2023","age":12,"daysLeft":91,"_birthday":"2011-09-10T22:00:00.000Z","_nextBirthday":"2023-09-10T22:00:00.000Z"}
                            2023-06-12 10:36:45.641 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.10.stefanBradtke", birthday: {"name":"Stefan Bradtke","birthYear":1983,"dateFormat":"12.10.2023","age":40,"daysLeft":122,"_birthday":"1983-10-11T23:00:00.000Z","_nextBirthday":"2023-10-11T22:00:00.000Z"}
                            2023-06-12 10:36:45.646 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.10.jenniferSchmidtFörster", birthday: {"name":"Jennifer Schmidt-Förster","birthYear":1979,"dateFormat":"15.10.2023","age":44,"daysLeft":125,"_birthday":"1979-10-14T23:00:00.000Z","_nextBirthday":"2023-10-14T22:00:00.000Z"}
                            2023-06-12 10:36:45.650 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.12.alfredSchmidt", birthday: {"name":"Alfred Schmidt","birthYear":1949,"dateFormat":"13.12.2023","age":74,"daysLeft":184,"_birthday":"1949-12-12T23:00:00.000Z","_nextBirthday":"2023-12-12T23:00:00.000Z"}
                            2023-06-12 10:36:45.654 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.01.julianeSchmidt", birthday: {"name":"Juliane Schmidt","birthYear":1971,"dateFormat":"10.01.2024","age":53,"daysLeft":212,"_birthday":"1971-01-09T23:00:00.000Z","_nextBirthday":"2024-01-09T23:00:00.000Z"}
                            2023-06-12 10:36:45.658 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.01.calvinSeum", birthday: {"name":"Calvin Seum","birthYear":1999,"dateFormat":"12.01.2024","age":25,"daysLeft":214,"_birthday":"1999-01-11T23:00:00.000Z","_nextBirthday":"2024-01-11T23:00:00.000Z"}
                            2023-06-12 10:36:45.662 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.01.marickFörster", birthday: {"name":"Marick Förster","birthYear":1999,"dateFormat":"15.01.2024","age":25,"daysLeft":217,"_birthday":"1999-01-14T23:00:00.000Z","_nextBirthday":"2024-01-14T23:00:00.000Z"}
                            2023-06-12 10:36:45.668 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.01.michaelGrebeldinger", birthday: {"name":"Michael Grebeldinger","birthYear":1983,"dateFormat":"22.01.2024","age":41,"daysLeft":224,"_birthday":"1983-01-21T23:00:00.000Z","_nextBirthday":"2024-01-21T23:00:00.000Z"}
                            2023-06-12 10:36:45.672 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.03.michaelHannes", birthday: {"name":"Michael Hannes","birthYear":1982,"dateFormat":"05.03.2024","age":42,"daysLeft":267,"_birthday":"1982-03-04T23:00:00.000Z","_nextBirthday":"2024-03-04T23:00:00.000Z"}
                            2023-06-12 10:36:45.676 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.03.joeBradtke", birthday: {"name":"Joe Bradtke","birthYear":2021,"dateFormat":"07.03.2024","age":3,"daysLeft":269,"_birthday":"2021-03-06T23:00:00.000Z","_nextBirthday":"2024-03-06T23:00:00.000Z"}
                            2023-06-12 10:36:45.680 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.03.lauraHannes", birthday: {"name":"Laura Hannes","birthYear":1993,"dateFormat":"19.03.2024","age":31,"daysLeft":281,"_birthday":"1993-03-18T23:00:00.000Z","_nextBirthday":"2024-03-18T23:00:00.000Z"}
                            2023-06-12 10:36:45.684 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.04.brigitteMeisinger", birthday: {"name":"Brigitte Meisinger","birthYear":1952,"dateFormat":"02.04.2024","age":72,"daysLeft":295,"_birthday":"1952-04-01T23:00:00.000Z","_nextBirthday":"2024-04-01T22:00:00.000Z"}
                            2023-06-12 10:36:45.690 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.04.michaelMeisinger", birthday: {"name":"Michael Meisinger","birthYear":1969,"dateFormat":"05.04.2024","age":55,"daysLeft":298,"_birthday":"1969-04-04T23:00:00.000Z","_nextBirthday":"2024-04-04T22:00:00.000Z"}
                            2023-06-12 10:36:45.694 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.nilsGerlach", birthday: {"name":"Nils Gerlach","birthYear":1981,"dateFormat":"08.05.2024","age":43,"daysLeft":331,"_birthday":"1981-05-07T22:00:00.000Z","_nextBirthday":"2024-05-07T22:00:00.000Z"}
                            2023-06-12 10:36:45.699 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.valentinaBreuer", birthday: {"name":"Valentina Breuer","birthYear":1987,"dateFormat":"12.05.2024","age":37,"daysLeft":335,"_birthday":"1987-05-11T22:00:00.000Z","_nextBirthday":"2024-05-11T22:00:00.000Z"}
                            2023-06-12 10:36:45.703 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.valeskaBreuer", birthday: {"name":"Valeska Breuer","birthYear":1989,"dateFormat":"17.05.2024","age":35,"daysLeft":340,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2024-05-16T22:00:00.000Z"}
                            2023-06-12 10:36:45.709 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.constantinBreuer", birthday: {"name":"Constantin Breuer","birthYear":1989,"dateFormat":"17.05.2024","age":35,"daysLeft":340,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2024-05-16T22:00:00.000Z"}
                            2023-06-12 10:36:45.713 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.tabeaMeinhardt", birthday: {"name":"Tabea Meinhardt","birthYear":1996,"dateFormat":"18.05.2024","age":28,"daysLeft":341,"_birthday":"1996-05-17T22:00:00.000Z","_nextBirthday":"2024-05-17T22:00:00.000Z"}
                            2023-06-12 10:36:45.717 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.linaGrywnow", birthday: {"name":"Lina Grywnow","birthYear":2013,"dateFormat":"20.05.2024","age":11,"daysLeft":343,"_birthday":"2013-05-19T22:00:00.000Z","_nextBirthday":"2024-05-19T22:00:00.000Z"}
                            2023-06-12 10:36:45.721 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.eddiSchmidt", birthday: {"name":"Eddi Schmidt","birthYear":1999,"dateFormat":"20.05.2024","age":25,"daysLeft":343,"_birthday":"1999-05-19T22:00:00.000Z","_nextBirthday":"2024-05-19T22:00:00.000Z"}
                            2023-06-12 10:36:45.725 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.maxBreuer", birthday: {"name":"Max Breuer","birthYear":1994,"dateFormat":"25.05.2024","age":30,"daysLeft":348,"_birthday":"1994-05-24T22:00:00.000Z","_nextBirthday":"2024-05-24T22:00:00.000Z"}
                            2023-06-12 10:36:45.729 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.benjaminSchmidt", birthday: {"name":"Benjamin Schmidt","birthYear":1983,"dateFormat":"28.05.2024","age":41,"daysLeft":351,"_birthday":"1983-05-27T22:00:00.000Z","_nextBirthday":"2024-05-27T22:00:00.000Z"}
                            2023-06-12 10:36:45.733 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.06.stephanPanz", birthday: {"name":"Stephan Panz","birthYear":1979,"dateFormat":"03.06.2024","age":45,"daysLeft":357,"_birthday":"1979-06-02T23:00:00.000Z","_nextBirthday":"2024-06-02T22:00:00.000Z"}
                            2023-06-12 10:36:45.738 - debug: birthdays.0 (7102) [fillAfter] filling next with 8 days left
                            2023-06-12 10:36:45.749 - debug: birthdays.0 (7102) [fillAfter] filling nextAfter with 10 days left
                            2023-06-12 10:36:45.759 - debug: birthdays.0 (7102) [fillAfter] filling nextSignificant with 10 days left
                            2023-06-12 10:36:45.775 - debug: birthdays.0 (7102) [onReady] Everything done
                            2023-06-12 10:36:45.776 - debug: birthdays.0 (7102) [onReady] Finally shutting down
                            2023-06-12 10:36:45.776 - debug: birthdays.0 (7102) cleaned everything up...
                            2023-06-12 10:36:45.819 - info: birthdays.0 (7102) Terminated (NO_ERROR): Without reason
                            2023-06-12 10:36:46.364 - info: host.buanet-iobroker_8_0_1 instance system.adapter.birthdays.0 terminated with code 0 (NO_ERROR)
                              Wie soll das technisch gehen? Du siehst doch, dass es im Code keinen Weg gibt, dass ein Geburtstag hinzugefügt wird, ohne dass die Meldung geschrieben wird.
                              • Ben1983
                                @haus-automatisierung Keine Ahnung, aber es klappt ja jetzt.
                                Danke für den Tipp mit dem einzeln raus gelöscht.
                                  sigi234 Forum Testing Most Active @haus-automatisierung last edited by
                                  kannst du eine Json für die Monate einbauen?
                                  Also, wer hat im Jan,Feb, ...usw. aller Geburtstag
                                    haus-automatisierung Developer Most Active @sigi234 last edited by
                                    @sigi234 sagte in Test Adapter Birthdays:
                                    Ja das ist schnell gemacht.
                                      Super, ev. mit Zähler. Also im Jänner haben XY Personen Geburtstag.
                                      Ist natürlich alles nice to have 😀
                                      • V
                                        valbuz last edited by
                                        Hallo Matthias
                                        Habe seit kurzem ein Problem mit dem Adapter.
                                        Ich benutze 2 Instanzen davon.
                                        Die 2. benutze ich für einige wichtige Termine. Ich weiss ist nicht dazu gedacht, aber es funzte bis anhin.
                                        Ich mache ebenfalls Einträge im Kalender mit Name/Datum/Ganztägig und Betreff das aktuelle Jahr.
                                        Wiederholung einmalig oder jährlich verursacht dasselbe Problem.
                                        Da es zum Teil Termine mit demselben Namen sind kommen diese mehrmals mit unterschiedlichem Datum vor.
                                        Seit nun einer Woche wird lediglich nur noch ein Termin mit selben Namen angezeigt. Ändere ich testhalber ein Name, erscheint dieser dann korrekt im Object Baum. Es wird also seit kurzem nur noch ein Eintrag gemacht mit demselben Namen
                                        Wie gesagt dies lief bis vor kurzem ohne Probleme.
                                        Kannst Du mir eine Hilfe geben wo ich suchen soll?
                                        • da_Woody
                                          da_Woody @valbuz last edited by
                                          @valbuz sagte in Test Adapter Birthdays:
                                          warum dann nicht den ical?
                                          der birthday ist entstanden, weil einige den ical für geburtstage missbraucht habn.
                                          V 1 Reply Last reply Reply Quote 2
                                          • V
                                            valbuz @da_Woody last edited by
                                            @da_woody sagte in Test Adapter Birthdays:
                                            Dann kann ich ja auch den birthday für ical missbrauchen 😊
                                            Wie geschrieben ist mir klar, aber es hat funktioniert und jetzt nicht mehr.
                                            Falls es ev. ein Problem mit dem Adapter oder Anpassungen im Google Kalender wären, ist es sicherlich für alle sinnvoll.
                                            31.7k
                                            79.8k
                                            adapter birthday erinnerung geburtstag tester
                                            55
                                            335
                                            47107
