    4. js-controller 5.0.x jetzt in der BETA
      A Former User @apollon77 last edited by
      @apollon77
      eine Weiterentwicklung von @foxriver76 da LG Änderungen gemacht hat..
      • haselchen
        haselchen Most Active @mcm1957 last edited by haselchen
        @apollon77
        @foxriver76
        2023-06-12 22:36:40.964 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"short_release","updated":"2023-06-12T20:36:39.955Z"},"last_event":"short_release"},"id":"a3ffd014-1ce6-465f-b2ca-610336764b10","id_v1":"/sensors/72","owner":{"rid":"5e33ed7a-aef2-40ab-a1e2-11d1fdeb9e46","rtype":"device"},"type":"button"}
        2023-06-12 22:36:40.964 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"initial_press","updated":"2023-06-12T20:36:40.709Z"},"last_event":"initial_press"},"id":"b427bb8c-c890-42ab-beac-364383ef9378","id_v1":"/sensors/98","owner":{"rid":"ebc2d5e7-a972-4fd7-9290-45b2fa7c5562","rtype":"device"},"type":"button"}
        2023-06-12 22:36:40.964 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"short_release","updated":"2023-06-12T20:36:40.839Z"},"last_event":"short_release"},"id":"b427bb8c-c890-42ab-beac-364383ef9378","id_v1":"/sensors/98","owner":{"rid":"ebc2d5e7-a972-4fd7-9290-45b2fa7c5562","rtype":"device"},"type":"button"}
        2023-06-12 22:36:54.785 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"initial_press","updated":"2023-06-12T20:36:54.587Z"},"last_event":"initial_press"},"id":"b427bb8c-c890-42ab-beac-364383ef9378","id_v1":"/sensors/98","owner":{"rid":"ebc2d5e7-a972-4fd7-9290-45b2fa7c5562","rtype":"device"},"type":"button"}
        2023-06-12 22:36:54.785 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"short_release","updated":"2023-06-12T20:36:54.723Z"},"last_event":"short_release"},"id":"b427bb8c-c890-42ab-beac-364383ef9378","id_v1":"/sensors/98","owner":{"rid":"ebc2d5e7-a972-4fd7-9290-45b2fa7c5562","rtype":"device"},"type":"button"}
        2023-06-12 11:52:17.705 - warn: ws.0 (845) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
        2023-06-12 22:23:08.219 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
        2023-06-12 22:23:12.210 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
        2023-06-12 22:23:15.311 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
        2023-06-12 22:23:17.289 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
        2023-06-12 22:23:18.341 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
        2023-06-12 22:23:45.705 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
        HUE Adapter 3.9.0
        Shelly Adapter 6.4.1
        WS Adapter 2.3.6
        Weil das Log durchgehend mit den Warnmeldungen vollgespamt wurde, bin ich zurück auf 4.0.24
        Ich weiß, es sind nur Warnmeldungen, aber ich möchte schon sehen, was da im System los ist.
        Das sind leider nur Auszüge, die ich noch retten konnte, ich meine der Sonoff Adapter war auch dabei mit Warnmeldungen.
        Edit: Die/der Shelly war nicht offline. War ganz normal zu erreichen.
        foxriver76 apollon77 crunchip 3 Replies Last reply Reply Quote 0
        • foxriver76
          foxriver76 Developer @haselchen last edited by
          @haselchen Hue Warnmeldungen kommen von hue 3.9.0 unabhängig von Controller
          • haselchen
            haselchen Most Active @foxriver76 last edited by
            @foxriver76
            Diese Meldungen habe ich aber mit JS 4.0.24 nicht mehr.
            • foxriver76
              @haselchen würde mich sehr sehr stark wundern ^^
              • haselchen
                haselchen Most Active @foxriver76 last edited by haselchen
                @foxriver76
                Sonst würde ich es nicht schreiben 😉
                Edit: Das Log selber ist mit der 4.0.24 viel ruhiger bzw. mit "normalen" Warnmeldungen versehen.
                Nachdem ich die 5.0.2 probiert hatte explodierte das Log förmlich.
                Auch 2-3 Neustarts haben da nicht geholfen.
                  apollon77 @haselchen last edited by
                  @haselchen ws bitte Issue anlegen, aber sollte nur einmalig beim start kommen.
                  Shelly... naja das device ist offline? Wüsste nicht wie das am controller liegen sollte
                  • foxriver76
                    @haselchen villt hast du das Loglevel auf error geändert. Schalte mal ne Lampe insofern noch 3.9.0 drauf ist.. aber ja off topic https://github.com/iobroker-community-adapters/ioBroker.hue/issues/413
                    Baenker created this issue in iobroker-community-adapters/ioBroker.hue
                    closed Mit Version 3.9 Unknown update for type "xxxxx" #413
                    • haselchen
                      haselchen Most Active @apollon77 last edited by
                      @apollon77
                      Ich gehe immer nach dem Ausschlussverfahren vor.
                      Wenn vorher diese Meldung nicht kam und nach einem Update da ist.....dann ist für MICH das Update die Ursache 😬
                      Wie gesagt, mit der JS Stable Version läuft alles am Schnürchen. Die Warnungen oder Hinweise aus 5.0.2 gibt es nicht.
                      Die WS Info kam vermutlich nach den Neustarts. Also wie Du sagst, 1 Mal.
                      • haselchen
                        @foxriver76
                        Ich hab Debug als Loglevel.
                        Bin halt neugierig 🙂
                        Hab den Button auf dem Dimmer Switch gerade nochmal gedrückt.
                        Keine Meldung im Log. Lampen sind aber an wie es soll.
                        • foxriver76
                          @haselchen oder du hast nicht die offizielle 3.9.0 sondern nochmal von GitHub aktualisiert, da ists nämlich auch schon weg.
                          • haselchen
                            @foxriver76
                            Das wurmt mich doch nen bisschen.
                            Ich setz hier mal nen Test Raspi auf und nudel die 5.0.2 rauf und runter.
                              crunchip Forum Testing Most Active @haselchen last edited by
                              @haselchen also ich hatte bisher keine Probleme mit sonoff oder shelly, allerdings hab ich noch den js-controller alpha laufen
                              Vllt liegt es eher an der Firmware der shelly's
                              • haselchen
                                haselchen Most Active @crunchip last edited by
                                @crunchip
                                Wie gesagt, ich guck mir das vor und nach einem Update an.
                                Und vorher war alles tutti.
                                Die Meldungen kamen nach dem Update (und habe ich so zum ersten Mal gesehen).
                                Diese waren aber schlichtweg falsch, da ich sie erreichen konnte mit jedem anderen Medium.
                                  Marty56 @apollon77 last edited by
                                  @apollon77 sagte in js-controller 5.0.x jetzt in der BETA:
                                  iob upload vis
                                  Hat leider nicht funktioniert.
                                  Issue in Yakha habe ich angelegt.
                                    Megawaldi last edited by
                                    Das Upgrade auf 5.0.2 lief ohne Probleme durch.
                                    Ich hab nur noch Problemen mit dem Miio Adapter.
                                    Denke der wird aber leider nicht mehr aktualisiert.
                                    Vieleicht kann man den in die community übernehmen?
                                    https://github.com/SchumyHao/ioBroker.miio
                                      bommel_030 last edited by
                                      Upgrade von 4.0.24 auf 5.0.2 und im Anschluss "iob fix" lief problemlos.
                                      Bekomme seitdem von einigen CRON-getriggerten Adaptern Warnmeldungen die vorher nicht im LOG auftauchten:
                                      dwd.0		warn	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      yr.0			warn	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      host.iobroker-master	warn	instance system.adapter.uv-protect.0 already running with pid 1652
                                      daswetter.0	warn	Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                      Zusätzlich in unregelmäßigen Abständen:
                                      host.iobroker-master	error	cannot call visUtils: Not exists
                                      Und der km200 Adapter lässt sich nicht mehr starten.
                                      km200 Initialization Error:TypeError: Cannot read properties of undefined (reading '_subscribeForeignStates') at subscribeStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:7382:21) at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:830:111 at new Promise (<anonymous>) at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:830:20 at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:311:77
                                      crunchip mcm1957 2 Replies Last reply Reply Quote 0
                                        crunchip Forum Testing Most Active @bommel_030 last edited by
                                        @bommel_030 sagte in js-controller 5.0.x jetzt in der BETA:
                                        iob stop vis
                                        iob upload vis
                                        iob start vis
                                        • mcm1957
                                          mcm1957 @Megawaldi last edited by
                                          @megawaldi said in js-controller 5.0.x jetzt in der BETA:
                                          In den Repos ist ein fork enthalten:
                                          https://github.com/smarthomefans/ioBroker.miio/issues
                                          Prinzipiell sollte es möglich sein den in die Community zu übernehmen sofern der jetzige Dev da nichts mehr machen nmöchte (bitte diesen zuerst mal kontaktieren/fragen) - ABER ohne dass es einen Entwickler gibt der zumindest die wichtigsten Aktualisierungen und Anpassungen vornehmen kann / will und das auch testen kann wird es schwierig.
                                          Falls sich hier jemand bereit erklären will zumindest die notwendigsten Anpassungen durchführen zu wollen kann ich gerne beim Verschieben des Adapters (= Anpassen der Umgebung) udn Fragen helfen. Mangels Testmöglichkeiten (und auch Zeit) macht es keine Sinn wenn ich das selbst zusage bzw. an mich reiße.
                                          Zusätzlich wäre ev. ein Issue bei Adapterrequests sinnvoll um den Wunsche / Bedarf in Evidenz zu halten.
                                          • mcm1957
                                            mcm1957 @bommel_030 last edited by
                                            @bommel_030
                                            Bitte issue beim km200 Adapter (https://github.com/iobroker-community-adapters/ioBroker.km200)
                                            Und bitte kurz testen, ob das Problem mit der aktuellen github version noch existiert
                                            Der Adapter wurde in den community Bereich verschoben - aber soweit ich weiß noch nicht aktualisiert. Auch wenn es mit der GH Version geht, bitte ein Issue mit dieser INfo beim Adapter ablegen damit möglichst bald eine Version eingezogen wir.
                                            mcm1957 B 2 Replies Last reply Reply Quote 0
                                            580
                                            125930
