    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      RGT @arteck last edited by
      @arteck So sieht es im ioBroker als Objektliste aus: 2023-06-08 20_59_28-objects - raspberrypi.jpg
      Es gibt für jeden Tag ein "Verzeichnis" mit den Summenwerte des entsprechenden Tages.
      Unter "Tripinfo" steht dann die ANzahl der Fahrten, die sich aber nicht mehr einzeln darstellen lassen.
      Wenn ich die ankommenden Daten aus dem Debug-Log hole, kommen sie so an:
      driveHistory-Data: {
      "cumulated":[
      {"period":0,"consumption":{"total":46497,"engine":37691,"climate":3636,"devices":5170,"battery":0},"regen":17568,"distance":327},
      {"period":1,"consumption":{"total":6642,"engine":5384,"climate":519,"devices":738,"battery":0},"regen":2509,"distance":46.714285714285715},
      {"period":2,"consumption":{"total":8790,"engine":7235,"climate":805,"devices":750,"battery":0},"regen":3437,"distance":71}],
      "history":[
      {"period":0,"rawDate":"20230608","date":"2023-06-07T22:00:00.000Z","consumption":{"total":4783,"engine":3939,"climate":464,"devices":380,"battery":0},"regen":1589,"distance":36},
      {"period":0,"rawDate":"20230607","date":"2023-06-06T22:00:00.000Z","consumption":{"total":8995,"engine":7386,"climate":909,"devices":700,"battery":0},"regen":3368,"distance":70},
      {"period":0,"rawDate":"20230606","date":"2023-06-05T22:00:00.000Z","consumption":{"total":3951,"engine":2656,"climate":405,"devices":890,"battery":0},"regen":1616,"distance":22},
      {"period":0,"rawDate":"20230605","date":"2023-06-04T22:00:00.000Z","consumption":{"total":11185,"engine":9077,"climate":928,"devices":1180,"battery":0},"regen":4713,"distance":80},
      {"period":0,"rawDate":"20230603","date":"2023-06-02T22:00:00.000Z","consumption":{"total":2752,"engine":2124,"climate":198,"devices":430,"battery":0},"regen":1055,"distance":15},
      {"period":0,"rawDate":"20230602","date":"2023-06-01T22:00:00.000Z","consumption":{"total":10119,"engine":8505,"climate":614,"devices":1000,"battery":0},"regen":3939,"distance":74},
      {"period":0,"rawDate":"20230601","date":"2023-05-31T22:00:00.000Z","consumption":{"total":4712,"engine":4004,"climate":118,"devices":590,"battery":0},"regen":1288,"distance":30}]}
      Leider habe ich meinen Ionic erst eine Woche, daher werden nur Werte ab dem 1.6 übertragen.
      Wie weit es in die Vergangenheit zurückgeht, kann ich noch nicht sagen.
      Für den Status der 12V Batterie steht folgendes in den Objekten:
      Was wird noch gebraucht? Vielleicht kann ich helfen.
      LG RGT
        arteck Developer Most Active @RGT last edited by
        @rgt das bringt mich schon mal weiter.DANKE... muss bissel Gehirnschmalz investieren...
        • FredF
          FredF Most Active Forum Testing @arteck last edited by
          @arteck wie schon geschrieben: für jeden Tag seit der Adapter läuft und das Fahrzeug bewegt wurde gibt es einen Ordner. Das sind nach 9 Monaten schon sehr viele…
            arteck Developer Most Active @FredF last edited by
            @fredf ach du scheixxxx... ich dachte letzten 7 Tage oder so..aber.. ok vergiss es..:-)
              A Former User @arteck last edited by
              @arteck
              Es gibt auf Git irgendwo n Tool, das bereitet das in ner excel Tabelle auf…
              Schau mal connect Monitor
                adapter von GIT installieren.. da sollte jetzt für heute ein Datenpunkt entstehen
                es wird in den History Daten nach heutigem Datum gesucht und die Daten werden übernommen..
                wenn nix da ist.. also keine Fahrt erfolgte.. schreibe ich aber auch keine 0 Werte.
                ich kann es nicht testen.. bei meinem PHEV kommen da keine Daten
                  toki1973 @arteck last edited by
                  @arteck said in Adapter Hyundai (Bluelink) oder KIA (UVO):
                  @toki1973 wie kommst du drauf ?
                  Der Datenpunkt wurde seit 27.04. nicht mehr aktualisiert
                    @arteck
                    Ich habe das Update über GIT gemacht sehen aber noch kein Today Datenpunkt. Wird der soc-12V Status nciht mehr von Bluelink übermittelt?
                    arteck ? 2 Replies Last reply Reply Quote 0
                      arteck Developer Most Active @toki1973 last edited by arteck
                      @toki1973 kein plan .. was fährst du ?? wie ist der adapter eingestellt .. ist die batterie 12V ausreichend geladen.. und und und
                      der today ordner entsteht erst an dem Tag wo das Datum passt.. also bist die nicht am 13.06 gefahren oder der adapter lief da nicht.. gibbet auch kein today..
                      soll ich es für dich umbenennen auf ... binichNURheutegefahrendatenpunkt
                        RGT last edited by
                        @arteck
                        Herzlichen Dank für deine Arbeit und den neuen Channel "today", der bei mir super funktioniert:
                        Darf ich eine Bitte / einen Wunsch äußern, ohne unverschämt zu wirken?
                        Leider habe ich noch keine Ahnung, wie ich es hier sonst einkippen kann. Im Prinzip in eine "Wunschliste".
                        Da du es hinbekommen hast, die Tagesdaten immer wieder in diesen einen Channel zu schreiben und ich/alle die Daten somit selber fortlaufend in eine DB schreiben können, habe ich damit automatisch die Historie.
                        Kannst du dann in den Einstellungen der Adapter-Instanz eine Checkbox einbauen, die den Download der Historie aus der Datenquelle (siehe Kontoeinstellungen) in den Adapter ausschaltet.
                        Die Historie wird ja nun nicht mehr als eigener Channel pro Tag benötigt.
                        Und wenn sie jemand haben möchte, um seine eigene in seiner DB nachzupflegen, kann er sie anschalten.
                        LG RGT
                          arteck Developer Most Active @RGT last edited by arteck
                          @rgt gute idee..mach ich..wird aber erst nächste Woche..
                            A Former User @toki1973 last edited by
                            @toki1973
                            Hi, ich fahre einen Ioniq5 und da funktioniert der 12V Batterie Status und Wert einwandfrei.
                            Den Datenpunkt Today kommt bei mir aber auch nicht, ich fahre aber auch zur Zeit nicht jeden Tag..
                            Aktuelle Version von Git ist drauf.. js-controller 5.x Beta..
                              @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                              ja, sehr gute Idee!
                              Eine History und geloggt mit Influx/SQL und da kann man es mit Grafana oder was auch immer auswerten...
                                toki1973 @Guest last edited by
                                @ilovegym Habe das geleiche Fahrzeug. Nun bekomme ich den Today History Wert. Aber immer noch nicht eine Aktualisierung des 12V SOC.
                                  @toki1973
                                  neueste Infotainmentsoftware haste drauf im Ioniq? ( seit heute gibts uebrigens das lang angekuendigte Fruehjahr-Update.. also den Navi-Update auf dem Windows Rechner anwerfen und runterladen oder auf OTA warten... )
                                  Die 12V aktualisiert sich erst nach ca 20min fahren... oder wenn er am laden ist...
                                  Heute ist auch bei mir der Datenpunkt Today aufgetaucht...
                                  T Meister Mopper 2 Replies Last reply Reply Quote 0
                                    @ilovegym
                                    Danke für den Hinweis auf das Update 🙂
                                    • Meister Mopper
                                      Meister Mopper @Guest last edited by
                                      @ilovegym sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                      Da warte ich mal, bin gespannt, ob das ota auch wirklich funzt. Aber, da muss man, glaube ich, ein paar Kilometer schrubben, bis die Daten komplett über SIM-Karte übermittelt wurden.
                                      • Winni
                                        Winni last edited by
                                        Auf ota warten dauert mir zu lange 😉. Habe gerade runter geladen und mittels usb-stick installiert. Lief problemlos durch.
                                          g.polat last edited by
                                          Ich habe gestern JS-Controller auf 5.0.3 geupdatet, seitdem läuft der Adapter bei mir nicht mehr 😞
                                          bluelink.0	2023-06-14 13:29:56.365	error	unhandled promise rejection: undefined is not a valid state value
                                          bluelink.0	2023-06-14 13:29:56.364	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          bluelink.0	2023-06-14 13:29:56.350	error	undefined is not a valid state value
                                          bluelink.0	2023-06-14 13:29:56.350	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5372:49) at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5333:21) at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34) at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21) at async Bluelink.receiveEVInformation (/opt/iobroker/node_modules/iobroker.bluelink/main.js:383:17) at async ae. (/opt/iobroker/node_modules/iobroker.bluelink/main.js:222:25)
                                          bluelink.0	2023-06-14 13:29:56.350	error	unhandled promise rejection: undefined is not a valid state value
                                          bluelink.0	2023-06-14 13:29:56.349	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          ? R 2 Replies Last reply Reply Quote 0
                                            A Former User @g.polat last edited by A Former User
                                            @g-polat
                                            bei mir laeuft er seit 5.x Alpha problemlos... welche Node und NPM Version, welches BS ?
                                            dein Logauszug ist etwas kurz.. das wichtigste fehlt.. ( was vorher passiert und warum..)
                                            Bei so Sachen bitte immer den Adapter auf Debug stellen und das Log von Start an posten, da werden auch NPM usw mit angezeigt.
                                            81.1k
                                            2276
                                            850660
