    4. VIS nicht mehr erreichbar
      crunchip Forum Testing Most Active @Thomas Braun last edited by
      @thomas-braun hast du ihm nicht gesagt😜
        Thomas Braun Most Active @crunchip last edited by
        @crunchip
        Das ist so eine Selbstverständlichkeit...
          @thomas-braun steht ja extra in deiner Anleitung die du ihm verlinkt hast
          Wichtig ist LITE, ohne Desktop!
            @crunchip
            Ja, wollte ich gerade auch schreiben 😄
            • Sven Muthke
              Sven Muthke @crunchip last edited by
              @crunchip
              bekomme diese meldung, der adapter steht aber immer noch auf 1.4.16
              iobroker install vis@1.4.0
              adapter "vis" already installed. Use "upgrade" to upgrade to a newer version.```
              DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
              • DJMarc75
                DJMarc75 @Sven Muthke last edited by
                @sven-muthke sagte in VIS nicht mehr erreichbar:
                das install durch upgrade ersetzen
                  Thomas Braun Most Active @Sven Muthke last edited by
                  @sven-muthke
                  iob upgrade vis@1.4.0
                  Sven Muthke 1 Reply Last reply Reply Quote 0
                  • Sven Muthke
                    Sven Muthke @Thomas Braun last edited by
                    @thomas-braun ruter hat geklappt. Hoch aber leider nicht 😞
                    This upgrade of "vis" will at least introduce the following changes:
                    -> 1.4.15:
                    Better check of the offline license
                    -> 1.4.14:
                    Corrected GUI bug
                    -> 1.4.13:
                    The group attributes will be replaced recursively
                    -> 1.4.12:
                    Fixed bug with the export of specific widgets
                    -> 1.4.11:
                    Removed ES6 commands to be supported by older browsers
                    Fixed problem with update of grouped widgets
                    Added web manifest to be able to handle vis as the web app
                    -> 1.4.8:
                    Added support for js-controller 4.x
                    -> 1.4.7:
                    Fixed subscribeOidAtRuntime if called with invalid IDs
                    Added support of license manager
                    Would you like to upgrade vis from @1.4.0 to @1.4.15 now? [(y)es, (n)o]: y
                    Update vis from @1.4.0 to @1.4.15
                    NPM version: 9.5.1
                    Installing iobroker.vis@1.4.15... (System call)
                    npm ERR! code 6
                    npm ERR! path /opt/iobroker/node_modules/iobroker.vis
                    npm ERR! command failed
                    npm ERR! command sh -c node main.js --install
                    npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T13_50_16_351Z-debug-0.log
                    host.iobroker Cannot install iobroker.vis@1.4.15: 6
                      @sven-muthke
                      Mit welchem Befehl?
                      Bitte immer vollständige Ein- wie Ausgaben (inkl. LogIn Prompt) aus der Konsole posten.
                      • Sven Muthke
                        iobroker@iobroker:~ $ iobroker upgrade vis@1.4.15
                        -> 1.4.15:
                        -> 1.4.14:
                        Corrected GUI bug
                        -> 1.4.13:
                        -> 1.4.12:
                        -> 1.4.11:
                        -> 1.4.8:
                        -> 1.4.7:
                        NPM version: 9.5.1
                        npm ERR! code 6
                        • DJMarc75
                          DJMarc75 @DJMarc75 last edited by
                          @djmarc75 sagte in VIS nicht mehr erreichbar:
                          Natürlich weisst Du das... Du hast Dein Repository auf BETA umgestellt und immer fleissig die updates der Adapter gemacht. Von alleine kommt das nicht
                          Geh erstmal auf STABLE zurück !
                          Und zum Downgrade:
                          such mal im Forum (Suchfunktion ist schon praktisch) den neuen offiziellen Thread zum JS-Beta - darin wirst fündig...
                          Ich hab den nicht installiert und weiss daher auch nicht wie man den downgraded... sorry
                          Glaub ich lieg da nicht so ganz falsch 😐
                          • Sven Muthke
                            Sven Muthke @DJMarc75 last edited by
                            @djmarc75 ich habe es auf stable zurück gestellt. wie bekomme ich den JS wieder zurück? ich versuche das grade in der suchfunktion zu finden, bin aber zu blind oder blöd
                            • DJMarc75
                              @sven-muthke
                              suchen Du musst 😉 weil ich machs nicht - bin da auch kein Tester von
                              https://forum.iobroker.net/topic/66108/js-controller-5-0-x-jetzt-in-der-beta/151
                                crunchip Forum Testing Most Active @Sven Muthke last edited by
                                iobroker@iobroker
                                den user gleichnamig wie den internen user iobroker zu nennen ist nicht unbedingt sinnig
                                • Sven Muthke
                                  @djmarc75 @crunchip @Thomas-Braun
                                  Nachdem ich das ganze gestern noch einmal neu aufgestezt habe, läuft die VIS jetzt. Habe auch dieses Mal die lite version genommen und alles auf stable gestellt. Vielen Dankfür Eure Hilfe und die ganzen Tips!!!
                                  Jetzt kann ich mich wieder meinem eigentlichen Problem (InfluxDB 2.x zu reaktivieren) widmen. Habe das System jetzt auf 64 Bit installiert, da das ein Knackpunkt war und komme aber wieder nciht weiter. Ich habe mich durch diverse Foren Einträge gelesen und diverse Anleitungen probiert, es hakt aber immer noch.
                                  Ich glaube ich habe es instaliert,kann es aber nicht starten und auch keinen organisation einrichten:
                                  Installed ioBroker-Instances
                                  Used repository: stable
                                  Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
                                  Adapter    "admin"        : 6.3.5    , installed 6.5.8
                                  Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                                  Adapter    "backitup"     : 2.6.19   , installed 2.6.20
                                  Adapter    "birthdays"    : 2.2.2    , installed 2.2.2
                                  Adapter    "cloud"        : 4.3.0    , installed 4.4.1
                                  Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                                  Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                  Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                  Adapter    "ekey"         : 1.2.3    , installed 1.2.3
                                  Adapter    "email"        : 1.1.4    , installed 1.1.4
                                  Adapter    "growatt"      : 2.1.1    , installed 3.0.2
                                  Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                                  Adapter    "hue"          : 3.7.1    , installed 3.9.2
                                  Adapter    "ical"         : 1.13.2   , installed 1.13.2
                                  Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                                  Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                                  Adapter    "javascript"   : 6.1.4    , installed 7.1.0
                                  Controller "js-controller": 4.0.24   , installed 4.0.24
                                  Adapter    "knx"          : 2.0.17   , installed 2.0.19
                                  Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                                  Adapter    "mbus"         : 2.4.0    , installed 2.4.0
                                  Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                                  Adapter    "mqtt"         : 4.0.7    , installed 4.1.1
                                  Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                                  Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
                                  Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                  Adapter    "psa"          : 0.0.11   , installed 0.0.11
                                  Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
                                  Adapter    "ring"         : 3.2.2    , installed 3.4.0
                                  Adapter    "roomba"       : 1.1.4    , installed 1.1.4
                                  Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                                  Adapter    "socketio"     : 4.2.0    , installed 6.3.5
                                  Adapter    "sonoff"       : 2.5.1    , installed 2.5.3
                                  Adapter    "sonos"        : 2.2.3    , installed 2.3.1
                                  Adapter    "telegram"     : 1.15.2   , installed 1.15.6
                                  Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                  Adapter    "text2command" : 2.3.0    , installed 3.0.2
                                  Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                                  Adapter    "vis"          : 1.4.16   , installed 1.4.16
                                  Adapter    "vis-colorpicker": 1.2.0  , installed 2.0.3
                                  Adapter    "vis-hqwidgets": 1.3.0    , installed 1.4.0
                                  Adapter    "vis-icontwo"  : 0.93.0   , installed 0.94.0
                                  Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
                                  Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                                  Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                  Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
                                  Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                  Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                  Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                  Adapter    "volvo"        : 0.1.0    , installed 0.1.0
                                  Adapter    "web"          : 4.3.0    , installed 5.5.3
                                  Adapter    "ws"           : 1.3.0    , installed 2.3.6
                                  iobroker@iobroker:~ $ influx org create -n DelaPena
                                  Error: failed to create org "DelaPena": 404 Not Found: unable to decode response content type "text/plain; charset=utf-8"
                                  iob diag
                                  Copy text starting here:
                                                       v.2023-04-16
                                  Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                                  Kernel:                 6.1.21-v8+
                                  Installation:           Native
                                  Timezone:               Europe/Berlin (CEST, +0200)
                                  User-ID:                1000
                                  X-Server:               false
                                  Boot Target:            multi-user.target
                                  Pending OS-Updates:     0
                                  Pending iob updates:    0
                                  Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                                          /usr/bin/node           v18.16.0
                                                          /usr/bin/npm            9.5.1
                                                          /usr/bin/npx            9.5.1
                                  Recommended versions are nodejs 18.x.y and npm 9.x.y
                                  MEMORY:
                                  Mem:            3.8G        2.6G        636M        1.0M        583M        1.1G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        2.6G        736M
                                  Active iob-Instances:   35
                                  Active repo(s): stable
                                  ioBroker Core:          js-controller           4.0.24
                                                          admin                   6.5.8
                                  Objects type: jsonl
                                  States  type: jsonl
                                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
                                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  Objects:                21167
                                  States:                 18618
                                  Size of iob-Database:
                                  34M     /opt/iobroker/iobroker-data/objects.jsonl
                                  22M     /opt/iobroker/iobroker-data/states.jsonl
                                  Habt ihr nen Plan was ich machen kann?
                                  Vielen Dnak und VG Sven
                                  crunchip Homoran 2 Replies Last reply Reply Quote 0
                                    diesen Thread abschließen und einen neuen beginnen mit entsprechendem Titel.
                                    Dort das Problem genaustens schildern und was wo und wie installiert wurde
                                      Homoran Global Moderator Administrators @Sven Muthke last edited by
                                      wie @crunchip schreibt
                                      @crunchip sagte in VIS nicht mehr erreichbar:
                                      ...und unter offTopic!
                                      die Installation und Konfiguration von influxdb hat nichts mit iobroker zu tun
                                      1.2k
                                      1939
