    4. VIS nicht mehr erreichbar
      Thomas Braun Most Active @crunchip last edited by
      @crunchip
      Das ist so eine Selbstverständlichkeit...
        crunchip Forum Testing Most Active @Thomas Braun last edited by
        @thomas-braun steht ja extra in deiner Anleitung die du ihm verlinkt hast
        Wichtig ist LITE, ohne Desktop!
          @crunchip
          Ja, wollte ich gerade auch schreiben 😄
          • Sven Muthke
            Sven Muthke @crunchip last edited by
            @crunchip
            bekomme diese meldung, der adapter steht aber immer noch auf 1.4.16
            iobroker install vis@1.4.0
            adapter "vis" already installed. Use "upgrade" to upgrade to a newer version.```
            DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
            • DJMarc75
              DJMarc75 @Sven Muthke last edited by
              @sven-muthke sagte in VIS nicht mehr erreichbar:
              das install durch upgrade ersetzen
                Thomas Braun Most Active @Sven Muthke last edited by
                @sven-muthke
                iob upgrade vis@1.4.0
                Sven Muthke 1 Reply Last reply Reply Quote 0
                • Sven Muthke
                  Sven Muthke @Thomas Braun last edited by
                  @thomas-braun ruter hat geklappt. Hoch aber leider nicht 😞
                  This upgrade of "vis" will at least introduce the following changes:
                  -> 1.4.15:
                  Better check of the offline license
                  -> 1.4.14:
                  Corrected GUI bug
                  -> 1.4.13:
                  The group attributes will be replaced recursively
                  -> 1.4.12:
                  Fixed bug with the export of specific widgets
                  -> 1.4.11:
                  Removed ES6 commands to be supported by older browsers
                  Fixed problem with update of grouped widgets
                  Added web manifest to be able to handle vis as the web app
                  -> 1.4.8:
                  Added support for js-controller 4.x
                  -> 1.4.7:
                  Fixed subscribeOidAtRuntime if called with invalid IDs
                  Added support of license manager
                  Would you like to upgrade vis from @1.4.0 to @1.4.15 now? [(y)es, (n)o]: y
                  Update vis from @1.4.0 to @1.4.15
                  NPM version: 9.5.1
                  Installing iobroker.vis@1.4.15... (System call)
                  npm ERR! code 6
                  npm ERR! path /opt/iobroker/node_modules/iobroker.vis
                  npm ERR! command failed
                  npm ERR! command sh -c node main.js --install
                  npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T13_50_16_351Z-debug-0.log
                  host.iobroker Cannot install iobroker.vis@1.4.15: 6
                    @sven-muthke
                    Mit welchem Befehl?
                    Bitte immer vollständige Ein- wie Ausgaben (inkl. LogIn Prompt) aus der Konsole posten.
                    • Sven Muthke
                      iobroker@iobroker:~ $ iobroker upgrade vis@1.4.15
                      -> 1.4.15:
                      -> 1.4.14:
                      Corrected GUI bug
                      -> 1.4.13:
                      -> 1.4.12:
                      -> 1.4.11:
                      -> 1.4.8:
                      -> 1.4.7:
                      NPM version: 9.5.1
                      npm ERR! code 6
                      • DJMarc75
                        DJMarc75 @DJMarc75 last edited by
                        @djmarc75 sagte in VIS nicht mehr erreichbar:
                        Natürlich weisst Du das... Du hast Dein Repository auf BETA umgestellt und immer fleissig die updates der Adapter gemacht. Von alleine kommt das nicht
                        Geh erstmal auf STABLE zurück !
                        Und zum Downgrade:
                        such mal im Forum (Suchfunktion ist schon praktisch) den neuen offiziellen Thread zum JS-Beta - darin wirst fündig...
                        Ich hab den nicht installiert und weiss daher auch nicht wie man den downgraded... sorry
                        Glaub ich lieg da nicht so ganz falsch 😐
                        • Sven Muthke
                          Sven Muthke @DJMarc75 last edited by
                          @djmarc75 ich habe es auf stable zurück gestellt. wie bekomme ich den JS wieder zurück? ich versuche das grade in der suchfunktion zu finden, bin aber zu blind oder blöd
                          • DJMarc75
                            @sven-muthke
                            suchen Du musst 😉 weil ich machs nicht - bin da auch kein Tester von
                            https://forum.iobroker.net/topic/66108/js-controller-5-0-x-jetzt-in-der-beta/151
                              crunchip Forum Testing Most Active @Sven Muthke last edited by
                              iobroker@iobroker
                              den user gleichnamig wie den internen user iobroker zu nennen ist nicht unbedingt sinnig
                              • Sven Muthke
                                @djmarc75 @crunchip @Thomas-Braun
                                Nachdem ich das ganze gestern noch einmal neu aufgestezt habe, läuft die VIS jetzt. Habe auch dieses Mal die lite version genommen und alles auf stable gestellt. Vielen Dankfür Eure Hilfe und die ganzen Tips!!!
                                Jetzt kann ich mich wieder meinem eigentlichen Problem (InfluxDB 2.x zu reaktivieren) widmen. Habe das System jetzt auf 64 Bit installiert, da das ein Knackpunkt war und komme aber wieder nciht weiter. Ich habe mich durch diverse Foren Einträge gelesen und diverse Anleitungen probiert, es hakt aber immer noch.
                                Ich glaube ich habe es instaliert,kann es aber nicht starten und auch keinen organisation einrichten:
                                Installed ioBroker-Instances
                                Used repository: stable
                                Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
                                Adapter    "admin"        : 6.3.5    , installed 6.5.8
                                Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                                Adapter    "backitup"     : 2.6.19   , installed 2.6.20
                                Adapter    "birthdays"    : 2.2.2    , installed 2.2.2
                                Adapter    "cloud"        : 4.3.0    , installed 4.4.1
                                Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                                Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                Adapter    "ekey"         : 1.2.3    , installed 1.2.3
                                Adapter    "email"        : 1.1.4    , installed 1.1.4
                                Adapter    "growatt"      : 2.1.1    , installed 3.0.2
                                Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                                Adapter    "hue"          : 3.7.1    , installed 3.9.2
                                Adapter    "ical"         : 1.13.2   , installed 1.13.2
                                Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                                Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                                Adapter    "javascript"   : 6.1.4    , installed 7.1.0
                                Controller "js-controller": 4.0.24   , installed 4.0.24
                                Adapter    "knx"          : 2.0.17   , installed 2.0.19
                                Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                                Adapter    "mbus"         : 2.4.0    , installed 2.4.0
                                Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                                Adapter    "mqtt"         : 4.0.7    , installed 4.1.1
                                Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                                Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
                                Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                Adapter    "psa"          : 0.0.11   , installed 0.0.11
                                Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
                                Adapter    "ring"         : 3.2.2    , installed 3.4.0
                                Adapter    "roomba"       : 1.1.4    , installed 1.1.4
                                Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                                Adapter    "socketio"     : 4.2.0    , installed 6.3.5
                                Adapter    "sonoff"       : 2.5.1    , installed 2.5.3
                                Adapter    "sonos"        : 2.2.3    , installed 2.3.1
                                Adapter    "telegram"     : 1.15.2   , installed 1.15.6
                                Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                Adapter    "text2command" : 2.3.0    , installed 3.0.2
                                Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                                Adapter    "vis"          : 1.4.16   , installed 1.4.16
                                Adapter    "vis-colorpicker": 1.2.0  , installed 2.0.3
                                Adapter    "vis-hqwidgets": 1.3.0    , installed 1.4.0
                                Adapter    "vis-icontwo"  : 0.93.0   , installed 0.94.0
                                Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
                                Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                                Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
                                Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                Adapter    "volvo"        : 0.1.0    , installed 0.1.0
                                Adapter    "web"          : 4.3.0    , installed 5.5.3
                                Adapter    "ws"           : 1.3.0    , installed 2.3.6
                                iobroker@iobroker:~ $ influx org create -n DelaPena
                                Error: failed to create org "DelaPena": 404 Not Found: unable to decode response content type "text/plain; charset=utf-8"
                                iob diag
                                Copy text starting here:
                                                     v.2023-04-16
                                Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                                Kernel:                 6.1.21-v8+
                                Installation:           Native
                                Timezone:               Europe/Berlin (CEST, +0200)
                                User-ID:                1000
                                X-Server:               false
                                Boot Target:            multi-user.target
                                Pending OS-Updates:     0
                                Pending iob updates:    0
                                Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                                        /usr/bin/node           v18.16.0
                                                        /usr/bin/npm            9.5.1
                                                        /usr/bin/npx            9.5.1
                                Recommended versions are nodejs 18.x.y and npm 9.x.y
                                MEMORY:
                                Mem:            3.8G        2.6G        636M        1.0M        583M        1.1G
                                Swap:            99M          0B         99M
                                Total:          3.9G        2.6G        736M
                                Active iob-Instances:   35
                                Active repo(s): stable
                                ioBroker Core:          js-controller           4.0.24
                                                        admin                   6.5.8
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
                                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                Objects:                21167
                                States:                 18618
                                Size of iob-Database:
                                34M     /opt/iobroker/iobroker-data/objects.jsonl
                                22M     /opt/iobroker/iobroker-data/states.jsonl
                                Habt ihr nen Plan was ich machen kann?
                                Vielen Dnak und VG Sven
                                crunchip Homoran 2 Replies Last reply Reply Quote 0
                                  diesen Thread abschließen und einen neuen beginnen mit entsprechendem Titel.
                                  Dort das Problem genaustens schildern und was wo und wie installiert wurde
                                    Homoran Global Moderator Administrators @Sven Muthke last edited by
                                    wie @crunchip schreibt
                                    @crunchip sagte in VIS nicht mehr erreichbar:
                                    ...und unter offTopic!
                                    die Installation und Konfiguration von influxdb hat nichts mit iobroker zu tun
                                    1939
