    4. backitup Fehlermeldung
      maximinus @DJMarc75 last edited by Homoran
      @djmarc75
      Bin beeindruckt was da alles geht. Danke.
      Hoffentlich hilft das weiter
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Architecture    : armv7l
      Docker          : false
      Virtualization  : none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       14:59:18 up 51 days, 47 min,  2 users,  load average: 2.22, 1.16, 0.68
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=49.1'C
      volt=0.8375V
      *** Time and Time Zones ***
                     Local time: Wed 2023-06-14 14:59:18 CEST
                 Universal time: Wed 2023-06-14 12:59:18 UTC
                       RTC time: n/a
                      Time zone: Europe/Vienna (CEST, +0200)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            3.8G        1.1G        1.5G        0.0K        1.3G        3.0G
      Swap:            99M         29M         70M
      Total:          3.9G        1.1G        1.6G
               3837 M total memory
               1061 M used memory
                921 M active memory
               1201 M inactive memory
               1500 M free memory
                256 M buffer memory
               1019 M swap cache
                 99 M total swap
                 29 M used swap
                 70 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      117G   21G   91G  19% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     768M  1.3M  767M   1% /run
      /dev/sda1      vfat      253M   50M  203M  20% /boot
      tmpfs          tmpfs     384M   16K  384M   1% /run/user/1000
      [Mon Apr 24 14:11:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:64:1F:3C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=bcf4838c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Mon Apr 24 14:11:31 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Mon Apr 24 14:11:31 2023] EXT4-fs (sda2): write access will be enabled during recovery
      [Mon Apr 24 14:11:32 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
      [Mon Apr 24 14:11:32 2023] EXT4-fs (sda2): 1 orphan inode deleted
      [Mon Apr 24 14:11:32 2023] EXT4-fs (sda2): recovery complete
      [Mon Apr 24 14:11:32 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Mon Apr 24 14:11:32 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Mon Apr 24 14:11:35 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      5.7G    /var/
      4.8G    /var/log
      3.8G    /var/log/journal/576f358b250c4617b98a23b9a999219a
      638M    /var/lib
      Archived and active journals take up 3.7G in the file system.
      /opt/iobroker/backups:
      9.6G    /opt/iobroker/backups/
      4.0K    /opt/iobroker/backups/scripte
      /opt/iobroker/iobroker-data:
      347M    /opt/iobroker/iobroker-data/
      272M    /opt/iobroker/iobroker-data/files
      62M     /opt/iobroker/iobroker-data/backup-objects
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      37M     /opt/iobroker/iobroker-data/files/material
      27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
      21M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/2.2e59ed19.chunk.js.map
      11M     /opt/iobroker/iobroker-data/objects.jsonl
      9.3M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.2d545efe.chunk.js.map
      9.1M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.a2360eda.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v16.17.0
      /usr/bin/node           v16.17.0
      /usr/bin/npm            8.15.0
      /usr/bin/npx            8.15.0
      nodejs:
        Installed: 16.17.0-deb-1nodesource1
        Candidate: 16.20.0-deb-1nodesource1
        Version table:
           16.20.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
       *** 16.17.0-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   2
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
        system.adapter.awattar.0                : awattar               : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
        system.adapter.echarts.0                : echarts               : raspberrypi                              - disabled
        system.adapter.email.0                  : email                 : raspberrypi                              - disabled
      + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
      + system.adapter.evcc.1                   : evcc                  : raspberrypi                              -  enabled, port: 7070
        system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
        system.adapter.habpanel.0               : habpanel              : raspberrypi                              -  enabled
        system.adapter.history.0                : history               : raspberrypi                              - disabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
        system.adapter.info.0                   : info                  : raspberrypi                              - disabled
        system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
        system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              - disabled
        system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.material.0               : material              : raspberrypi                              - disabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
        system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
        system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
        system.adapter.pushover.0               : pushover              : raspberrypi                              - disabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1500, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      live-stable   : http://iobroker.live/repo/sources-dist.json
      live-beta     : http://iobroker.live/repo/sources-dist-latest.json
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "awattar"      : 1.0.6    , installed 1.0.6
      Adapter    "backitup"     : 2.6.19   , installed 2.6.19
      Adapter    "denon"        : 1.15.0   , installed 1.15.0
      Adapter    "devices"      : 1.1.2    , installed 1.0.10 [Updatable]
      Adapter    "discovery"    : 3.1.0    , installed 3.0.3  [Updatable]
      Adapter    "echarts"      : 1.0.12   , installed 1.0.7  [Updatable]
      Adapter    "email"        : 1.1.4    , installed 1.0.10 [Updatable]
      Adapter    "flot"         : 1.11.0   , installed 1.10.7 [Updatable]
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "history"      : 2.2.4    , installed 1.11.1 [Updatable]
      Adapter    "influxdb"     : 3.2.0    , installed 2.6.3  [Updatable]
      Adapter    "info"         : 1.9.26   , installed 1.9.19 [Updatable]
      Adapter    "iot"          : 1.14.2   , installed 1.11.4 [Updatable]
      Adapter    "iqontrol"     : 2.1.0    , installed 2.0.0  [Updatable]
      Adapter    "jarvis"       : 3.1.2    , installed 3.0.11 [Updatable]
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "material"     : 1.1.2    , installed 1.1.2
      Adapter    "mqtt"         : 4.0.7    , installed 2.7.4  [Updatable]
      Adapter    "node-red"     : 4.0.0    , installed 3.3.0  [Updatable]
      Adapter    "openhab"      : 1.1.0    , installed 1.1.0
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "pushover"     : 3.0.3    , installed 2.1.0  [Updatable]
      Adapter    "simple-api"   : 2.7.2    , installed 2.7.0  [Updatable]
      Adapter    "smart-eq"     : 0.0.4    , installed 0.0.4
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "telegram"     : 1.15.2   , installed 1.13.0 [Updatable]
      Adapter    "text2command" : 2.3.0    , installed 2.2.1  [Updatable]
      Adapter    "tr-064"       : 4.2.18   , installed 4.2.16 [Updatable]
      Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.2.0  [Updatable]
      Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Objects and States
      Objects:        5007
      States:         4233
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
      W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Get:3 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
      Get:4 https://repos.influxdata.com/debian bullseye InRelease [7040 B]
      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
      Err:3 https://packages.grafana.com/oss/deb stable InRelease
      Err:4 https://repos.influxdata.com/debian bullseye InRelease
      Fetched 7040 B in 1s (5422 B/s)
      Reading package lists...
      Pending Updates: 218
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14465      585/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      115        14482      558/redis-server 12
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          60731337   6200/cupsd
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        14508      560/influxd
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       61507536   27829/io.mqtt.0
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       61507537   27829/io.mqtt.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       61507072   27714/iobroker.js-c
      tcp        0      0 0.0.0.0:1500            0.0.0.0:*               LISTEN      1001       61509312   27879/io.sonoff.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14467      585/sshd: /usr/sbin
      tcp6       0      0 ::1:6379                :::*                    LISTEN      115        14483      558/redis-server 12
      tcp6       0      0 :::3000                 :::*                    LISTEN      116        15467      545/grafana-server
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          60731336   6200/cupsd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       61508812   27732/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       61510263   28144/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        16490      560/influxd
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12186      511/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          60733002   6201/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12768      424/avahi-daemon: r
      udp        0      0 0.0.0.0:43002           0.0.0.0:*                           108        12770      424/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        12769      424/avahi-daemon: r
      udp6       0      0 :::53527                :::*                                108        12771      424/avahi-daemon: r
      2023-06-14 15:00:30.030  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: EntlLadeleistungSum = 00
      2023-06-14 15:00:30.030  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: BattZustand W =  480.6
      2023-06-14 15:00:30.031  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: LadestromSum =   9
      2023-06-14 15:00:30.031  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: EntladestromSum =   00
      2023-06-14 15:00:30.032  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: Batteriestrom =  9
      2023-06-14 15:00:30.032  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: PV Summe =   2225 PV 1 =   01289 PV 2 =    00936
      2023-06-14 15:00:30.032  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: SumWirk =   1762 Wirk1 =   0946 Wirk2 =    0816
      2023-06-14 15:00:30.033  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: BezugSum =   -463
      2023-06-14 15:00:30.041  - info: javascript.0 (27784) script.js.common.Haus22.PV-Berechnungen.PVSumLeistungBilanz: BilanzEnergie = BezugSum + Batt_Zustand =    17.6
      2023-06-14 15:00:30.092  - info: javascript.0 (27784) script.js.common.Überschusssteuerung.03a_PVOptimierung_aus: PV Optimierung ein weil Batterisstrom =  9
      2023-06-14 15:00:30.096  - info: javascript.0 (27784) script.js.common.Überschusssteuerung.03bReglerAufBatteriestrom:  sonst: Batteriestrom = 9ReglerAuf =  true
      2023-06-14 15:00:30.097  - warn: javascript.0 (27784) getState "smart-eq.0.info.connection" not found (3)
      2023-06-14 15:00:30.099  - warn: javascript.0 (27784)     at Object.<anonymous> (script.js.common.SmartSolLadung:5:51)
      2023-06-14 15:00:30.100  - warn: javascript.0 (27784)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
      2023-06-14 15:00:30.100  - warn: javascript.0 (27784)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
      2023-06-14 15:00:30.101  - warn: javascript.0 (27784)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
      2023-06-14 15:00:30.101  - warn: javascript.0 (27784)     at processImmediate (node:internal/timers:466:21)
      2023-06-14 15:00:30.101  - warn: javascript.0 (27784) getState "smart-eq.0.info.connection" not found (3)
      2023-06-14 15:00:30.103  - warn: javascript.0 (27784)     at Object.<anonymous> (script.js.common.SmartSolLadung:8:14)
      2023-06-14 15:00:30.104  - warn: javascript.0 (27784)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
      2023-06-14 15:00:30.104  - warn: javascript.0 (27784)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
      2023-06-14 15:00:30.104  - warn: javascript.0 (27784)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
      2023-06-14 15:00:30.104  - warn: javascript.0 (27784)     at processImmediate (node:internal/timers:466:21)
      2023-06-14 15:00:30.153  - info: javascript.0 (27784) script.js.common.Hauptzähler.Tagesverbrauch: Tagesverbrauch ist 2.3659999999945285
      37020893
      DJMarc75 M 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @maximinus last edited by
        @maximinus sagte in backitup Fehlermeldung:
        Erst wenn Du das alles bitte in Codetags packst 😉
          maximinus @maximinus last edited by
          Mit Firefox ging da gar nichts (Error )
          Mit chrome schaut es nicht viel besser aus.
          • DJMarc75
            Dann machst Du was falsch... keine Ahnung... Text kopieren, hier einfügen und das hat schon jeder geschaft.
              Es geht nicht
              Der browser zerteilt das bei copy paste , vielleicht zu groß
              M Thomas Braun 2 Replies Last reply Reply Quote 0
                maximinus @maximinus last edited by Homoran
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Docker          : false
                Release:        11
                Codename:       bullseye
                VERSION_ID="11"
                ID=raspbian
                ID_LIKE=debian
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                temp=49.1'C
                volt=0.8375V
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M         29M         70M
                         3837 M total memory
                         1061 M used memory
                          921 M active memory
                         1500 M free memory
                          256 M buffer memory
                         1019 M swap cache
                           99 M total swap
                           29 M used swap
                           70 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                5.7G    /var/
                4.8G    /var/log
                638M    /var/lib
                /usr/bin/npm            8.15.0
                /usr/bin/npx            8.15.0
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: redis
                admin:          6.3.5
                javascript:     6.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        5007
                States:         4233
                37020893
                Im notepad++ ist es noch komplett aber hier wird es zerteilt.
                  Thomas Braun Most Active @maximinus last edited by Thomas Braun
                  Nein, das passt alles.
                  Dein Dateisystem hat 'nen Treffer erlitten, dann sind deine Paketquellen für grafana und influxdb nicht aktuell und müssen angepackt werden und dann hängen da noch drölftrilliarden ioBroker-Adapter-Updates in der Luft.
                  Und die noch offenen Updates des Betriebssystems kann ich fast gar nicht zählen.
                    A Former User @maximinus last edited by
                    Nur die Datensicherung macht Probleme.
                    Moin,
                    So der erste Screenshot hat ja schon mal geklappt, aber gerade der zweite, von den Einstellungen zu Grafana nicht 😉
                    Schau noch mal in meinen Post, da siehst Du einen zweiten Screenshot und da sollte bei Dir dann etwas Sinnvolles drin stehen, bei meinem nicht, denn ich nutze das nicht und habe den Adapter nur mal zu Doku Zwecken installiert.
                    VG
                    Bernd
                      maximinus @Guest last edited by
                      @dp20eic
                      Das ist die 2.Seite. Den api Key habe ich nochmals eingetragen und Grafana funktioniert immer noch. Ich werde zur Sicherheit nochmals ein manuelles Backup machen. Vielleicht hat sich seit iob fix etwas geändert.
                        Update
                        Die manuelle Sicherung ist durchgelaufen:
                        und hat jetzt diese beiden Fehlermeldungen gebracht:
                        [ERROR] [grafana] - cannot found Grafana Backup files
                        [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                          maximinus @Thomas Braun last edited by
                          "Never touch a running system" aber vielleicht ist das falsch.
                          Zum Thema update hatte ich mir folgendes notiert.
                          sudo apt-get update
                          sudo apt-get upgrade
                          sudo apt-get --allow-releaseinfo-change update
                          Ja bestätigen
                          --->>> lange warten
                          sudo iobroker stop
                          npm -v
                          falls der js-controller als updateable angezeigt wird : iobroker stop iobroker upgrade self iobroker start
                          sudo iobroker upgrade -y
                          npm -v
                          node -v
                          sudo iobroker start
                          sudo iobroker stop && sudo apt update && apt upgrade -y && sudo iobroker update && iobroker upgrade -y && sudo iobroker update && iobroker upgrade self | curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add - && sudo sh -c "echo deb https://deb.nodesource.com/node_12.x main \> /etc/apt/sources.list.d/nodesource.list" && sudo apt-get update && sudo apt-get install nodejs -y && iobroker start
                          Ist das so noch OK?
                            A Former User @maximinus last edited by A Former User
                            Moin,
                            das Bild zeigt nur die Sicherungen der influxDB, im Verzeichnis sollten eigentlich auch Dateien liegen, die Grafana im Namen haben.
                            Zu den Log File Eintragungen
                            • BackitUp versucht zuerst ältere Dateien zu löschen, wenn im Verzeichnis keine da sind, dann kommt wohl diese Meldung, warum als ERROR keine Ahnung
                            • Was dann die some errors sind kann ich nicht sagen.
                            Kannst Du den BackitUp Adapter mal auf Debug stellen
                            VG
                            Bernd
                            P.S.: Ich habe das gerade mal bei mir gemacht, das ist das Log
                            Started iobroker ...
                            [DEBUG] [iobroker] - host.arch-iob 6357 states saved
                            [DEBUG] [iobroker] - host.arch-iob 7276 objects saved
                            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_06_14-17_19_42_backupiobroker.tar.gz
                            [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
                            [DEBUG] [iobroker] - done
                            [DEBUG] [grafana] - Start Grafana Backup ...
                            [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                            [DEBUG] [grafana] - Created dashboard directory
                            [DEBUG] [grafana] - Created dashboards_manually_restore directory
                            [DEBUG] [grafana] - Created datasource directory
                            [DEBUG] [grafana] - start Grafana request ...
                            [DEBUG] [grafana] - Grafana is available ... Status: 200
                            [ERROR] [grafana] - Error on Grafana Datasource Request
                            [DEBUG] [grafana] - found Dashboard: ubersichten-raumklima
                            [DEBUG] [grafana] - found Dashboard: verbrauchubersicht-kaffeevollautomat
                            [DEBUG] [grafana] - found Dashboard: iobroker
                            [DEBUG] [grafana] - found Dashboard: zigbee-listen
                            [DEBUG] [grafana] - found Dashboard: logging-dashboard-via-loki
                            [DEBUG] [grafana] - found Dashboard: dashboards_by_dp20eic
                            [DEBUG] [grafana] - found Dashboard: verbrauchubersicht-gefrierschrank-new-alias
                            [DEBUG] [grafana] - found Dashboard: verbrauchubersicht-geschirrspuler-new-alias
                            [DEBUG] [grafana] - found Dashboard: verbrauchubersicht-waschmaschine-new-alias
                            [DEBUG] [grafana] - found Dashboard: internet-speed-test
                            [DEBUG] [grafana] - found Dashboard: verbrauchubersicht-waschetrokner-new-alias
                            [DEBUG] [grafana] - found Dashboard: spritpreise
                            [DEBUG] [grafana] - found Dashboard: logs-app
                            [DEBUG] [grafana] - found Dashboard: panel-library
                            [DEBUG] [grafana] - found Dashboard: linux-host-overview
                            [DEBUG] [grafana] - found Dashboard: loki-logs
                            [DEBUG] [grafana] - found Dashboard: proxmox-server
                            [DEBUG] [grafana] - found Dashboard: fritz-box-call-logs
                            [DEBUG] [grafana] - found Dashboard: verbrauchubersicht-garage-werkstatt-new-alias
                            [DEBUG] [grafana] - found Dashboard: lokiforlogs
                            [DEBUG] [grafana] - found Dashboard: test4forum
                            [DEBUG] [grafana] - found Dashboard: proxmox-flux
                            [DEBUG] [grafana] - found Dashboard: exchange-euro-thb
                            [DEBUG] [grafana] - found Dashboard: verbrauchubersicht-entertainment-new-alias
                            [DEBUG] [grafana] - found Dashboard: openweathermap
                            [DEBUG] [grafana] - found Dashboard: fritz-box-router-status
                            [DEBUG] [grafana] - found Dashboard: syslog
                            [DEBUG] [grafana] - found Dashboard: blutdruck
                            [DEBUG] [grafana] - found Dashboard: synology
                            [DEBUG] [grafana] - found Dashboard: temperaturubersicht-am-heizungkorper
                            [DEBUG] [grafana] - found Dashboard: fritz-box-home-automation
                            [DEBUG] [grafana] - found Dashboard: synology-dashboard-new
                            [DEBUG] [grafana] - found Dashboard: loki-syslog-aio-all-in-one
                            [DEBUG] [grafana] - found Dashboard: connection-over-time
                            [DEBUG] [grafana] - found Dashboard: linux-rechner
                            [DEBUG] [grafana] - found Dashboard: fritz-box-router-logs
                            [DEBUG] [grafana] - found Dashboard: synology-metrics
                            [DEBUG] [grafana] - found Dashboard: connection-over-time-copy
                            [DEBUG] [grafana] - found Dashboard: aktuelle-e10-benzinpreise
                            [DEBUG] [grafana] - found Dashboard: synology_dashboard
                            [DEBUG] [grafana] - start Grafana backup compress ...
                            [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                            [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                            [DEBUG] [grafana] - done
                            [DEBUG] [clean] - done
                            [DEBUG] [historyHTML] - new history html values created
                            [DEBUG] [historyHTML] - done
                            [DEBUG] [historyJSON] - new history json values created
                            [DEBUG] [historyJSON] - done
                            [EXIT] 0
                            P.P.S: also bei mir wird auch kein Backup erstellt, ich hab mal das Verzeichnis überwacht, schon das Anlegen des grafana_tmp Verzeichnis geschieht nicht, wenn ich es von Hand anlege wird es gelöscht aber nicht erstellt.
                            Ich schaue mir das morgen noch mal an.
                              @dp20eic
                              Die anderen Sicherungen habbe ich nicht gezeigt, sind aber alle da.alle Sicherungen.png
                              Adapter ist auf debug gestellt aber meiner ist in der Adapterliste auf v2.6.19, wo ist die v2.6.23 her?
                              Und jetzt nochmals sichern?
                                @dp20eic
                                das scheint also normal zu sein?
                                Ich warte einmal ab welche Nachricht ich vom nächtlichen Backup morgen bekomme.
                                Danke für die schnelle Hilfe
                                  Moin,
                                  ich fahre Beta Software, Du Stable denke ich
                                  VG
                                  Bernd
                                    @dp20eic
                                    Danke.
                                    seit ich einmal ohne zu wissen die beta repository eingestellt und danach Probleme mit dem admin Adapter hatte bleibe ich liebe auf stable.
                                    Würdest Du bitte meine Antwort an thomas-braun ansehen ob ich das so machen soll?
                                    LG Gerhard
                                      Grundfalsch. Das ist ausgemachter Blödsinn.
                                        Ist das so noch OK?
                                        Nein, das ist genauso veraltet wie deine Installation.
                                        Iobroker wird nie mit sudo angepackt.
                                        sudo apt update
                                        iob stop
                                        sudo apt full-upgrade
                                        sudo reboot
                                        notieren. Und regelmäßig ausführen.
                                          Ich greife das Thema nocheinmal auf. Nach Befolgung deiner Hinweise zeigt die Telegram Nachricht über das nächtliche Backup immer noch die selben Warnungen, obwohl die Backups alle auber gespeichert werden. Im Zusammenhanfg mit einer Aktualisierung des am selben Raspberry laufenden evcc, bekomme ich nach sudo apt update diese Warnungen:
                                          pi@raspberrypi:~ $ Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                                          W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://repos.influx        data.com/debian bullseye InRelease: The following signatures couldn't be verifie        d because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                          W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://packages.gra        fana.com/oss/deb stable InRelease: The following signatures couldn't be verified        because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                                          W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease        The following signatures couldn't be verified because the public key is not avai        lable: NO_PUBKEY 9E439B102CF3C0C6
                                          Nach Studium dieses Links scheint mir deren Behebeung als Linux Neuling zu kompliziert (gefährlich)
                                          https://itsfoss.com/apt-key-deprecated/
                                          sudo apt keylist bringt diese Ausgabe
                                          pi@raspberrypi:~ $ sudo apt-key list
                                          /etc/apt/trusted.gpg
                                          pub   rsa2048 2012-04-01 [SC]
                                                A0DA 38D0 D76E 8B5D 6388  7281 9165 938D 90FD DD2E
                                          uid           [ unknown] Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>
                                          sub   rsa2048 2012-04-01 [E]
                                          pub   rsa4096 2015-09-28 [SC]
                                                05CE 1508 5FC0 9D18 E99E  FB22 684A 14CF 2582 E0C5
                                          uid           [ unknown] InfluxDB Packaging Service <support@influxdb.com>
                                          sub   rsa4096 2015-09-28 [E]
                                          /etc/apt/trusted.gpg.d/raspberrypi-archive-stable.gpg
                                          pub   rsa2048 2012-06-17 [SC]
                                                CF8A 1AF5 02A2 AA2D 763B  AE7E 82B1 2992 7FA3 303E
                                          uid           [ unknown] Raspberry Pi Archive Signing Key
                                          sub   rsa2048 2012-06-17 [E]
                                          Gibt es eine einfachere Möglichkeit diese Warnungen zu beseitigen oder soll man das so lassen?
                                          Vielleicht hat das auch etwas mit den nicht endenden Fehlermeldungen des backitup adapters zu tun.
                                          LG Gerhard
                                            @maximinus
                                            https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
                                            2857
