    2. English
    3. ioBroker general
    4. Node.js update
    Node.js update
      Thomas Braun Most Active @ap2017 last edited by Thomas Braun
      @ap2017
      Check the situation:
      sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
      uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      For even more details on your system use
      iob diag
      If you can understand German, please also check the instructions regarding nodejs in my signature.
      A 2 Replies Last reply Reply Quote 1
        ap2017 @Thomas Braun last edited by
        @thomas-braun said in Node.js update:
        iob diag
        *** ioBroker Diagnosis ***
        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
        https://forum.iobroker.net
        Just copy and paste the Summary Page, including the ``` characters at start and end.
        It helps us to help you!
        Press any key to continue
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Architecture    : x86_64
        Docker          : false
        Virtualization  : none
        Distributor ID: LinuxMint
        Description:    Linux Mint 19.1 Tessa
        Release:        19.1
        Codename:       tessa
        NAME="Linux Mint"
        VERSION="19.1 (Tessa)"
        ID=linuxmint
        ID_LIKE=ubuntu
        PRETTY_NAME="Linux Mint 19.1"
        VERSION_ID="19.1"
        HOME_URL="https://www.linuxmint.com/"
        SUPPORT_URL="https://forums.linuxmint.com/"
        BUG_REPORT_URL="http://linuxmint-troubleshooting-guide.readthedocs.io/en/latest/"
        PRIVACY_POLICY_URL="https://www.linuxmint.com/"
        VERSION_CODENAME=tessa
        UBUNTU_CODENAME=bionic
        Systemuptime and Load:
         16:21:23 up 20:38,  2 users,  load average: 0.10, 0.05, 0.02
        CPU threads: 4
        *** Time and Time Zones ***
                              Local time: Tue 2023-06-13 16:21:23 EDT
                          Universal time: Tue 2023-06-13 20:21:23 UTC
                                RTC time: Tue 2023-06-13 20:21:23
                               Time zone: America/New_York (EDT, -0400)
        systemd-timesyncd.service active: yes
                         RTC in local TZ: no
        *** User and Groups ***
        ap
        /home/ap
        ap adm dialout cdrom sudo dip plugdev lpadmin sambashare iobroker
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:           3.9G        494M        1.2G         45M        2.2G        3.0G
        Swap:          2.1G          0B        2.1G
        Total:         6.0G        494M        3.3G
                 3768 M total memory
                  483 M used memory
                 1418 M active memory
                  567 M inactive memory
                 1155 M free memory
                  666 M buffer memory
                 1462 M swap cache
                 2047 M total swap
                    0 M used swap
                 2047 M free swap
        *** FILESYSTEM ***
        udev           devtmpfs  1.9G     0  1.9G   0% /dev
        tmpfs          tmpfs     377M  1.2M  376M   1% /run
        /dev/sda1      ext4      220G  131G   78G  63% /
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
        tmpfs          tmpfs     377M   20K  377M   1% /run/user/1000
        [Mon Jun 12 19:42:48 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
        [Mon Jun 12 19:42:49 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
        Show mounted filesystems (real ones only):
        findmnt: unrecognized option '--real'
        Try 'findmnt --help' for more information.
        /var:
        3.8G    /var/
        1.9G    /var/lib
        1.7G    /var/log/journal/82929df7ee394b73b81252fe3b4e5020
        1.7G    /var/log
        Archived and active journals take up 1.6G in the file system.
        /opt/iobroker/backups:
        24M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        56G     /opt/iobroker/iobroker-data/
        55G     /opt/iobroker/iobroker-data/history
        429M    /opt/iobroker/iobroker-data/files
        125M    /opt/iobroker/iobroker-data/history/20210321
        125M    /opt/iobroker/iobroker-data/history/20210320
        23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.de9334af.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.e7d9968b.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.de9334af.js.map
        20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
        17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.52d0ccae.js.map
        *** NodeJS-Installation ***
        /home/iobroker/.diag.sh: line 166: nodejs: command not found
        /home/iobroker/.diag.sh: line 167: node: command not found
        /home/iobroker/.diag.sh: line 168: npm: command not found
        /home/iobroker/.diag.sh: line 169: npx: command not found
        /home/iobroker/.diag.sh: line 175: nodejs: command not found
        /home/iobroker/.diag.sh: line 176: node: command not found
        /home/iobroker/.diag.sh: line 177: npm: command not found
        /home/iobroker/.diag.sh: line 178: npx: command not found
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: (none)
          Candidate: 18.16.0-deb-1nodesource1
          Version table:
             18.16.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bionic/main amd64 Packages
             8.10.0~dfsg-2ubuntu0.4 500
                500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
             8.10.0~dfsg-2ubuntu0.2 500
                500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
             8.10.0~dfsg-2 500
                500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        sudo: node: command not found
        Core adapters versions
        js-controller:
        admin:
        javascript:
        /home/iobroker/.diag.sh: line 248: npm: command not found
        Adapters from github:   0
        Adapter State
        ioBroker-Repositories
        Installed ioBroker-Instances
        Objects and States
        Objects:        0
        States:         0
        Hit:1 http://security.ubuntu.com/ubuntu bionic-security InRelease
        Hit:2 http://archive.canonical.com/ubuntu bionic InRelease
        Hit:3 http://archive.ubuntu.com/ubuntu bionic InRelease
        Ign:4 http://packages.linuxmint.com tessa InRelease
        Hit:5 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
        Hit:6 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
        Hit:7 https://deb.nodesource.com/node_18.x bionic InRelease
        Hit:8 http://packages.linuxmint.com tessa Release
        Hit:9 http://phoscon.de/apt/deconz bionic InRelease
        Reading package lists...
        Pending Updates: 133
        *** Listening Ports ***
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        17852      677/systemd-resolve
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          30232      818/sshd
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          494799     13412/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          30234      818/sshd
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          494798     13412/cupsd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          494804     13414/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        24257      690/avahi-daemon: r
        udp        0      0 0.0.0.0:57102           0.0.0.0:*                           115        24259      690/avahi-daemon: r
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        17851      677/systemd-resolve
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          28412      1091/dhclient
        udp6       0      0 :::48359                :::*                                115        24260      690/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                115        24258      690/avahi-daemon: r
        2023-06-12 19:29:38.392  - debug: zigbee.0 (13952) DeviceAvailability:Publish available for 0xa4c138375c1e064d = false
        2023-06-12 19:29:38.394  - debug: zigbee.0 (13952) DeviceAvailability:Publish LQ for 0xa4c138375c1e064d = 0
        2023-06-12 19:29:38.397  - debug: zigbee.0 (13952) DeviceAvailability:Publish available for 0xa4c13855ba4e66b6 = false
        2023-06-12 19:29:38.399  - debug: zigbee.0 (13952) DeviceAvailability:Publish LQ for 0xa4c13855ba4e66b6 = 0
        2023-06-12 19:29:38.403  - info: zigbee.0 (13952) Zigbee: disabling joining new devices.
        2023-06-12 19:29:38.799  - info: zigbee.0 (13952) Got terminate signal TERMINATE_YOURSELF
        2023-06-12 19:29:38.884  - info: zwave2.0 (14596) terminating
        2023-06-12 19:29:38.885  - info: host.AP-Tiny instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
        2023-06-12 19:29:38.896  - info: zigbee.0 (13952) terminating
        2023-06-12 19:29:38.897  - debug: zigbee.0 (13952) Plugin sentry destroyed
        2023-06-12 19:29:38.898  - info: zigbee.0 (13952) Terminated (NO_ERROR): Without reason
        2023-06-12 19:29:38.950  - info: host.AP-Tiny instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
        2023-06-12 19:29:38.998  - info: host.AP-Tiny instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
        2023-06-12 19:29:39.031  - info: host.AP-Tiny instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
        2023-06-12 19:29:39.077  - info: host.AP-Tiny instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
        2023-06-12 19:29:39.157  - info: host.AP-Tiny instance system.adapter.zwave2.0 terminated with code 0 (NO_ERROR)
        2023-06-12 19:29:39.247  - info: host.AP-Tiny instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
        2023-06-12 19:29:39.324  - info: host.AP-Tiny stopInstance system.adapter.zigbee.0 killing pid 13952
        2023-06-12 19:29:39.370  - warn: host.AP-Tiny instance system.adapter.zigbee.0 terminated due to SIGTERM
        2023-06-12 19:29:39.370  - info: host.AP-Tiny instance system.adapter.zigbee.0 terminated with code null ()
        2023-06-12 19:29:39.789  - info: history.0 (13935) terminating
        2023-06-12 19:29:39.793  - info: history.0 (13935) Terminated (NO_ERROR): Without reason
        2023-06-12 19:29:40.348  - info: host.AP-Tiny instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
        2023-06-12 19:29:40.349  - info: host.AP-Tiny All instances are stopped.
        2023-06-12 19:29:40.422  - info: host.AP-Tiny terminated
        iob diag has finished.
        Press any key for a summary
        Copy text starting here:
                             v.2023-04-16
        Operatingsystem:        Linux Mint 19.1 Tessa
        Kernel:                 4.15.0-65-generic
        Installation:           Native
        Timezone:                zone: America/New_York (EDT, -0400)
        User-ID:                1000
        X-Server:               true
        Boot Target:            graphical.target
        Pending OS-Updates:     133
        Pending iob updates:    0
        /home/iobroker/.diag.sh: line 340: nodejs: command not found
        Nodejs-Installation:
        /home/iobroker/.diag.sh: line 341: node: command not found
        /home/iobroker/.diag.sh: line 342: npm: command not found
        /home/iobroker/.diag.sh: line 343: npx: command not found
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:           3.9G        496M        1.2G         45M        2.2G        3.0G
        Swap:          2.1G          0B        2.1G
        Total:         6.0G        496M        3.3G
        Active iob-Instances:   0
        ioBroker Core:          js-controller
                                admin
        ioBroker Status:
        Objects:                0
        States:                 0
        Size of iob-Database:
        14M     /opt/iobroker/iobroker-data/objects.jsonl
        6.9M    /opt/iobroker/iobroker-data/objects.json.migrated
        6.9M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        9.0M    /opt/iobroker/iobroker-data/states.jsonl
        424K    /opt/iobroker/iobroker-data/states.json.migrated
        424K    /opt/iobroker/iobroker-data/states.json.bak.migrated
        0       /opt/iobroker/iobroker-data/states.json.broken
          ap2017 @Thomas Braun last edited by ap2017
          sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          Not sure what you mean by checking situation. I am not getting any response from the system after running line 1 and 2
            @ap2017
            Too old.
            Keep your OS Up-to-date.
            Node@18 won't build on Bionic based Distributions.
              @ap2017
              Try
              sudo apt install nodejs
              A Duffy 2 Replies Last reply Reply Quote 0
                @ap2017
                https://github.com/nodesource/distributions#deb
                Linux Mint 19.1 "Tessa" (via Ubuntu 18.04 LTS) WARNING: BUILD SYSTEM CURRENTLY BROKEN FOR NODEJS 18+
                  ap@AP-Tiny:~$ sudo apt install nodejs
                  Reading package lists... Done
                  Building dependency tree
                  Some packages could not be installed. This may mean that you have
                  requested an impossible situation or if you are using the unstable
                  distribution that some required packages have not yet been created
                  or been moved out of Incoming.
                  The following information may help to resolve the situation:
                  The following packages have unmet dependencies:
                   nodejs : Depends: libc6 (>= 2.28) but 2.27-3ubuntu1.6 is to be installed
                  N: Ignoring file 'deconz.list.save.2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
                  N: Ignoring file 'deconz.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
                  N: Ignoring file 'deconz.list.save.3' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
                  E: Unable to correct problems, you have held broken packages.
                  ap@AP-Tiny:~$
                    @thomas-braun Do I need to downgrade node.js to 16?
                      @ap2017
                      No, you really really need to upgrade your operating system.
                        @thomas-braun I updated OS within current release 19.1 - did not help, waiting for instructions from Mint on how to update to newer release.
                        In the mean time, I installed node.js 16 and everything started to work, I was able to log in to system from web interface. I started updating ADMIN adapter and lost ability to log in via web browser again. Interestingly, the control script is working - I see responses to sensors, but I am not able to get into system via browser, Any ideas?
                          @ap2017 sagte in Node.js update:
                          Run
                          iob diag
                          again so I can see where you are at now.
                            iob diag
                            Skript v.2023-04-16
                            *** BASE SYSTEM ***
                            Docker          : false
                            Release:        19.1
                            Codename:       tessa
                            NAME="Linux Mint"
                            ID=linuxmint
                            ID_LIKE=ubuntu
                            VERSION_ID="19.1"
                             14:21:35 up 47 min,  2 users,  load average: 0.07, 0.04, 0.05
                            CPU threads: 4
                                                  Local time: Wed 2023-06-14 14:21:36 EDT
                                              Universal time: Wed 2023-06-14 18:21:36 UTC
                                                    RTC time: Wed 2023-06-14 18:21:36
                                             RTC in local TZ: no
                            ap
                            /home/ap
                            X-Server:       true
                            Desktop:
                            Terminal:
                            *** MEMORY ***
                            Mem:           3.9G        1.3G        478M        118M        2.1G        2.2G
                            Swap:          2.1G        262K        2.1G
                            Total:         6.0G        1.3G        2.6G
                                     3768 M total memory
                                     1253 M used memory
                                     2134 M active memory
                                      810 M inactive memory
                                      467 M free memory
                                      136 M buffer memory
                                     1910 M swap cache
                                     2047 M total swap
                                        0 M used swap
                                     2047 M free swap
                            *** FILESYSTEM ***
                            tmpfs          tmpfs     377M  1.3M  376M   1% /run
                            /dev/sda1      ext4      220G  132G   77G  64% /
                            tmpfs          tmpfs     377M   28K  377M   1% /run/user/1000
                            [Wed Jun 14 13:34:25 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                            [Wed Jun 14 13:34:27 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                            /var:
                            4.2G    /var/
                            1.9G    /var/lib
                            1.7G    /var/log
                            20M     /opt/iobroker/iobroker-data/objects.jsonl
                            /usr/bin/nodejs         v16.20.0
                            /usr/bin/node           v16.20.0
                            /usr/bin/npm            8.19.4
                            /usr/bin/npx            8.19.4
                            nodejs:
                              Installed: 16.20.0-deb-1nodesource1
                              Candidate: 16.20.0-deb-1nodesource1
                              Version table:
                             *** 16.20.0-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_16.x bionic/main amd64 Packages
                                    100 /var/lib/dpkg/status
                                 8.10.0~dfsg-2 500
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            MULTIHOSTSERVICE/enabled: false
                            js-controller:  5.0.2
                            admin:          6.5.7
                            javascript:     7.0.8
                            Adapter State
                              system.adapter.accuweather.0            : accuweather           : AP-Tiny                                  - disabled
                              system.adapter.admin.0                  : admin                 : AP-Tiny                                  - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.backitup.0               : backitup              : AP-Tiny                                  - disabled
                              system.adapter.cloud.0                  : cloud                 : AP-Tiny                                  - disabled
                              system.adapter.deconz.0                 : deconz                : AP-Tiny                                  - disabled, port: 8080
                            + system.adapter.discovery.0              : discovery             : AP-Tiny                                  -  enabled
                              system.adapter.echarts.0                : echarts               : AP-Tiny                                  -  enabled
                              system.adapter.flot.0                   : flot                  : AP-Tiny                                  -  enabled
                            + system.adapter.history.0                : history               : AP-Tiny                                  -  enabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : AP-Tiny                                  -  enabled
                            + system.adapter.info.0                   : info                  : AP-Tiny                                  -  enabled
                            + system.adapter.javascript.0             : javascript            : AP-Tiny                                  -  enabled
                              system.adapter.mysensors.0              : mysensors             : AP-Tiny                                  - disabled, port: 5003, bind: 0.0.0.0
                            + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                              system.adapter.socketio.0               : socketio              : AP-Tiny                                  - disabled, port: 8084, bind: 192.168.1.74, run as: admin
                              system.adapter.sonoff.0                 : sonoff                : AP-Tiny                                  - disabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.telegram.0               : telegram              : AP-Tiny                                  -  enabled, port: 8443, bind: 0.0.0.0
                              system.adapter.vis-google-fonts.0       : vis-google-fonts      : AP-Tiny                                  -  enabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : AP-Tiny                                  -  enabled
                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : AP-Tiny                                  -  enabled
                              system.adapter.vis-material-advanced.0  : vis-material-advanced : AP-Tiny                                  -  enabled
                              system.adapter.vis-material-webfont.0   : vis-material-webfont  : AP-Tiny                                  -  enabled
                              system.adapter.vis-material.0           : vis-material          : AP-Tiny                                  -  enabled
                              system.adapter.vis-materialdesign.0     : vis-materialdesign    : AP-Tiny                                  -  enabled
                              system.adapter.vis-metro.0              : vis-metro             : AP-Tiny                                  -  enabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : AP-Tiny                                  -  enabled
                              system.adapter.vis.0                    : vis                   : AP-Tiny                                  -  enabled
                            + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
                            + system.adapter.zwave2.0                 : zwave2                : AP-Tiny                                  -  enabled
                            + instance is alive
                            Stable (default): http://download.iobroker.net/sources-dist.json
                            Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                            Active repo(s): Beta (latest)
                            Used repository: Beta (latest)
                            Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
                            Adapter    "admin"        : 6.5.8    , installed 6.5.7  [Updatable]
                            Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                            Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                            Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                            Adapter    "echarts"      : 1.5.1    , installed 1.4.15 [Updatable]
                            Adapter    "history"      : 2.2.4    , installed 2.2.4
                            Adapter    "info"         : 1.9.26   , installed 1.9.26
                            Adapter    "javascript"   : 7.1.0    , installed 7.0.8  [Updatable]
                            Controller "js-controller": 5.0.3    , installed 5.0.2  [Updatable]
                            Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                            Adapter    "mysensors"    : 3.0.0    , installed 3.0.0
                            Adapter    "socketio"     : 6.3.5    , installed 6.3.5
                            Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                            Adapter    "telegram"     : 1.15.6   , installed 1.15.6
                            Adapter    "vis"          : 1.4.16   , installed 1.4.16
                            Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                            Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                            Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                            Adapter    "web"          : 5.5.3    , installed 5.5.3
                            Adapter    "ws"           : 2.3.6    , installed 2.3.6
                            Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                            Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
                            Objects and States
                            Objects:        3955
                            States:         3402
                            Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
                            Hit:2 http://security.ubuntu.com/ubuntu bionic-security InRelease
                            Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
                            Hit:5 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
                            Hit:6 https://deb.nodesource.com/node_16.x bionic InRelease
                            Hit:7 http://packages.linuxmint.com tessa Release
                            Hit:8 http://archive.canonical.com/ubuntu bionic InRelease
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27152      807/iobroker.js-con
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27102      807/iobroker.js-con
                            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22290      630/systemd-resolve
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          27647      816/sshd
                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          23220      712/cupsd
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       33556      1983/io.web.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          32769      816/sshd
                            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       33684      2397/io.simple-api.
                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          23219      712/cupsd
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        25966      695/avahi-daemon: r
                            udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22289      630/systemd-resolve
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          29500      1120/dhclient
                            udp        0      0 0.0.0.0:32983           0.0.0.0:*                           115        25968      695/avahi-daemon: r
                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23232      747/cups-browsed
                            udp6       0      0 :::5353                 :::*                                115        25967      695/avahi-daemon: r
                            udp6       0      0 :::58743                :::*                                115        25969      695/avahi-daemon: r
                            2023-06-14 14:20:54.236  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
                            2023-06-14 14:20:54.236  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                            2023-06-14 14:20:54.237  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
                            2023-06-14 14:20:54.237  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                            2023-06-14 14:20:54.262  - debug: zigbee.0 (1725) Publish {"state":"OFF"} to "00124b0022419f47"
                            2023-06-14 14:20:54.266  - debug: zigbee.0 (1725) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854266,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                            2023-06-14 14:20:54.267  - debug: zigbee.0 (1725) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                            2023-06-14 14:20:54.268  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
                            2023-06-14 14:20:54.268  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                            2023-06-14 14:20:54.269  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                            2023-06-14 14:21:22.550  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13895a0a783f8 TS0207 was last seen '5077.171' seconds ago.
                            2023-06-14 14:21:22.550  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d00044678ff lumi.sensor_switch.aq3 was last seen '3689232.264' seconds ago.
                            2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00124b0022658a2b WB01 was last seen '304.075' seconds ago.
                            2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d00045a362e lumi.sensor_wleak.aq1 was last seen '703.242' seconds ago.
                            2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x04cf8cdf3c79009e lumi.sen_ill.mgl01 was last seen '177.775' seconds ago.
                            2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006ea578f lumi.sensor_wleak.aq1 was last seen '1047.042' seconds ago.
                            2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006e9796b lumi.sensor_wleak.aq1 was last seen '1620.726' seconds ago.
                            2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006e97800 lumi.sensor_wleak.aq1 was last seen '917.723' seconds ago.
                            2023-06-14 14:21:22.555  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006f93fb0 lumi.sensor_wleak.aq1 was last seen '561.83' seconds ago.
                            2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c138206a165e63 TS0207 was last seen '1379.288' seconds ago.
                            2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13808caa1c4e6 TS0207 was last seen '4434.999' seconds ago.
                            2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c138375c1e064d TS0207 was last seen '2260.278' seconds ago.
                            2023-06-14 14:21:22.557  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13855ba4e66b6 TS0207 was last seen '8996.791' seconds ago.
                            2023-06-14 14:21:22.557  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c1388acbf249aa TS0011 was last seen '14447731.067' seconds ago.
                              @thomas-braun I guess I need to execute admin adapter right?
                                @ap2017
                                iob start admin
                                  Homoran Global Moderator Administrators @ap2017 last edited by Homoran
                                  yes, iob start admin
                                  but you will encounter a lot of more or less severe problens, because you have installed beta versions of several adapters and the brand new bleeding edge js-controller
                                    ap2017 @Homoran last edited by
                                    @homoran said in Node.js update:
                                    iob start admin
                                    Thank you, I am back in business (till the next time)...
                                      iob start admin
                                      please read my edit!
                                        @ap2017
                                        Now check how to upgrade your operating system to the current release.
                                        'Tessa' is out of any support.
                                        19.1 'Tessa' (LTS)
                                        Security Support Ended 2 months and 2 weeks ago
                                        (01 Apr 2023)
                                        And run your iob on 'stable' not beta-stage.
                                          @thomas-braun Here is what I received from Mint support:
                                          Linux Mint 19.1 has reached end of life 2 months ago, so it's good to upgrade it. SO you'll keep getting security updates again for your software.
                                          The newest version of node.js on Linux Mint is 12 but you can add the NodeSource PPA on Linux Mint 20.x or 21.x to get node.js 18 (or newer). The instructions are here: https://github.com/nodesource/distribut ... /README.md. Use the Ubuntu instructions. So on Linux Mint 20.x or 21.x you would run this to add node.js 18.x:
                                          CODE: SELECT ALL
                                          curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash - &&\
                                          sudo apt-get install -y nodejs
                                          To upgrade from Linux Mint 19.1 to 20.x or 21.x you can follow the instructions here: viewtopic.php?t=235992. First upgrade to 19.3, then to 20 and if you want upgrade further to 20.3 and then 21. You can see till when each release is supported here: https://linuxmint.com/download_all.php.
                                          It will be some work to upgrade, and especially going from 19.3 to 20 is a hassle. Upgrading between major releases is easier and more reliable from 20 to 21. Still, because you're 2 major releases behind it may be recommended to instead do a fresh install of Linux Mint 21.x.
                                          I am wondering if it will be better to switch to different Linux version like Ubuntu. How difficult is to port ioBroker to new Linux installation?
                                            Easy. Backup your current installation, change your OS to a current distribution (I recommend Debian 12 'Bookworm' for running a server), install a plain ioBroker and install your backup. Very easy with the Backitup-Adapter.
                                            node.js
                                            4899
