    2. English
    3. ioBroker general
    4. Node.js update
    Node.js update
      ap2017 @Thomas Braun last edited by ap2017
      @thomas-braun said in Node.js update:
      sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      Not sure what you mean by checking situation. I am not getting any response from the system after running line 1 and 2
        Thomas Braun Most Active @ap2017 last edited by
        @ap2017
        Too old.
        VERSION_CODENAME=tessa
        UBUNTU_CODENAME=bionic
        Keep your OS Up-to-date.
        Node@18 won't build on Bionic based Distributions.
          @ap2017
          Try
          sudo apt install nodejs
          A Duffy 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @ap2017 last edited by Thomas Braun
            @ap2017
            https://github.com/nodesource/distributions#deb
            Linux Mint 19.1 "Tessa" (via Ubuntu 18.04 LTS) WARNING: BUILD SYSTEM CURRENTLY BROKEN FOR NODEJS 18+
              ap@AP-Tiny:~$ sudo apt install nodejs
              Reading package lists... Done
              Building dependency tree
              Some packages could not be installed. This may mean that you have
              requested an impossible situation or if you are using the unstable
              distribution that some required packages have not yet been created
              or been moved out of Incoming.
              The following information may help to resolve the situation:
              The following packages have unmet dependencies:
               nodejs : Depends: libc6 (>= 2.28) but 2.27-3ubuntu1.6 is to be installed
              N: Ignoring file 'deconz.list.save.2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
              N: Ignoring file 'deconz.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
              N: Ignoring file 'deconz.list.save.3' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
              E: Unable to correct problems, you have held broken packages.
              ap@AP-Tiny:~$
                @thomas-braun Do I need to downgrade node.js to 16?
                  @ap2017
                  No, you really really need to upgrade your operating system.
                    @thomas-braun I updated OS within current release 19.1 - did not help, waiting for instructions from Mint on how to update to newer release.
                    In the mean time, I installed node.js 16 and everything started to work, I was able to log in to system from web interface. I started updating ADMIN adapter and lost ability to log in via web browser again. Interestingly, the control script is working - I see responses to sensors, but I am not able to get into system via browser, Any ideas?
                      @ap2017 sagte in Node.js update:
                      Run
                      iob diag
                      again so I can see where you are at now.
                      A 2 Replies Last reply Reply Quote 1
                        iob diag
                        *** ioBroker Diagnosis ***
                        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                        https://forum.iobroker.net
                        Just copy and paste the Summary Page, including the ``` characters at start and end.
                        It helps us to help you!
                        Press any key to continue
                        Skript v.2023-04-16
                        *** BASE SYSTEM ***
                        Architecture    : x86_64
                        Docker          : false
                        Virtualization  : none
                        Distributor ID: LinuxMint
                        Description:    Linux Mint 19.1 Tessa
                        Release:        19.1
                        Codename:       tessa
                        NAME="Linux Mint"
                        VERSION="19.1 (Tessa)"
                        ID=linuxmint
                        ID_LIKE=ubuntu
                        PRETTY_NAME="Linux Mint 19.1"
                        VERSION_ID="19.1"
                        HOME_URL="https://www.linuxmint.com/"
                        SUPPORT_URL="https://forums.linuxmint.com/"
                        BUG_REPORT_URL="http://linuxmint-troubleshooting-guide.readthedocs.io/en/latest/"
                        PRIVACY_POLICY_URL="https://www.linuxmint.com/"
                        Systemuptime and Load:
                         14:21:35 up 47 min,  2 users,  load average: 0.07, 0.04, 0.05
                        CPU threads: 4
                        *** Time and Time Zones ***
                                              Local time: Wed 2023-06-14 14:21:36 EDT
                                          Universal time: Wed 2023-06-14 18:21:36 UTC
                                                RTC time: Wed 2023-06-14 18:21:36
                                               Time zone: America/New_York (EDT, -0400)
                        systemd-timesyncd.service active: yes
                                         RTC in local TZ: no
                        *** User and Groups ***
                        ap
                        /home/ap
                        ap adm dialout cdrom sudo dip plugdev lpadmin sambashare iobroker
                        *** X-Server-Setup ***
                        X-Server:       true
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Mem:           3.9G        1.3G        478M        118M        2.1G        2.2G
                        Swap:          2.1G        262K        2.1G
                        Total:         6.0G        1.3G        2.6G
                                 3768 M total memory
                                 1253 M used memory
                                 2134 M active memory
                                  810 M inactive memory
                                  467 M free memory
                                  136 M buffer memory
                                 1910 M swap cache
                                 2047 M total swap
                                    0 M used swap
                                 2047 M free swap
                        *** FILESYSTEM ***
                        udev           devtmpfs  1.9G     0  1.9G   0% /dev
                        tmpfs          tmpfs     377M  1.3M  376M   1% /run
                        /dev/sda1      ext4      220G  132G   77G  64% /
                        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                        tmpfs          tmpfs     377M   28K  377M   1% /run/user/1000
                        [Wed Jun 14 13:34:25 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                        [Wed Jun 14 13:34:27 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                        Show mounted filesystems (real ones only):
                        findmnt: unrecognized option '--real'
                        Try 'findmnt --help' for more information.
                        /var:
                        4.2G    /var/
                        1.9G    /var/lib
                        1.7G    /var/log/journal/82929df7ee394b73b81252fe3b4e5020
                        1.7G    /var/log
                        Archived and active journals take up 1.6G in the file system.
                        /opt/iobroker/backups:
                        24M     /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        56G     /opt/iobroker/iobroker-data/
                        55G     /opt/iobroker/iobroker-data/history
                        429M    /opt/iobroker/iobroker-data/files
                        125M    /opt/iobroker/iobroker-data/history/20210321
                        125M    /opt/iobroker/iobroker-data/history/20210320
                        23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.de9334af.js.map
                        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.e7d9968b.js.map
                        23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.de9334af.js.map
                        20M     /opt/iobroker/iobroker-data/objects.jsonl
                        20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v16.20.0
                        /usr/bin/node           v16.20.0
                        /usr/bin/npm            8.19.4
                        /usr/bin/npx            8.19.4
                        nodejs:
                          Installed: 16.20.0-deb-1nodesource1
                          Candidate: 16.20.0-deb-1nodesource1
                          Version table:
                         *** 16.20.0-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_16.x bionic/main amd64 Packages
                                100 /var/lib/dpkg/status
                             8.10.0~dfsg-2ubuntu0.4 500
                                500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
                             8.10.0~dfsg-2ubuntu0.2 500
                                500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
                             8.10.0~dfsg-2 500
                                500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
                        No problems detected
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        MULTIHOSTSERVICE/enabled: false
                        Core adapters versions
                        js-controller:  5.0.2
                        admin:          6.5.7
                        javascript:     7.0.8
                        Adapters from github:   0
                        Adapter State
                          system.adapter.accuweather.0            : accuweather           : AP-Tiny                                  - disabled
                          system.adapter.admin.0                  : admin                 : AP-Tiny                                  - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.backitup.0               : backitup              : AP-Tiny                                  - disabled
                          system.adapter.cloud.0                  : cloud                 : AP-Tiny                                  - disabled
                          system.adapter.deconz.0                 : deconz                : AP-Tiny                                  - disabled, port: 8080
                        + system.adapter.discovery.0              : discovery             : AP-Tiny                                  -  enabled
                          system.adapter.echarts.0                : echarts               : AP-Tiny                                  -  enabled
                          system.adapter.flot.0                   : flot                  : AP-Tiny                                  -  enabled
                        + system.adapter.history.0                : history               : AP-Tiny                                  -  enabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : AP-Tiny                                  -  enabled
                        + system.adapter.info.0                   : info                  : AP-Tiny                                  -  enabled
                        + system.adapter.javascript.0             : javascript            : AP-Tiny                                  -  enabled
                          system.adapter.mysensors.0              : mysensors             : AP-Tiny                                  - disabled, port: 5003, bind: 0.0.0.0
                        + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                          system.adapter.socketio.0               : socketio              : AP-Tiny                                  - disabled, port: 8084, bind: 192.168.1.74, run as: admin
                          system.adapter.sonoff.0                 : sonoff                : AP-Tiny                                  - disabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.telegram.0               : telegram              : AP-Tiny                                  -  enabled, port: 8443, bind: 0.0.0.0
                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : AP-Tiny                                  -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : AP-Tiny                                  -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : AP-Tiny                                  -  enabled
                          system.adapter.vis-material-advanced.0  : vis-material-advanced : AP-Tiny                                  -  enabled
                          system.adapter.vis-material-webfont.0   : vis-material-webfont  : AP-Tiny                                  -  enabled
                          system.adapter.vis-material.0           : vis-material          : AP-Tiny                                  -  enabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : AP-Tiny                                  -  enabled
                          system.adapter.vis-metro.0              : vis-metro             : AP-Tiny                                  -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : AP-Tiny                                  -  enabled
                          system.adapter.vis.0                    : vis                   : AP-Tiny                                  -  enabled
                        + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
                        + system.adapter.zwave2.0                 : zwave2                : AP-Tiny                                  -  enabled
                        + instance is alive
                        ioBroker-Repositories
                        Stable (default): http://download.iobroker.net/sources-dist.json
                        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                        Active repo(s): Beta (latest)
                        Installed ioBroker-Instances
                        Used repository: Beta (latest)
                        Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
                        Adapter    "admin"        : 6.5.8    , installed 6.5.7  [Updatable]
                        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                        Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                        Adapter    "echarts"      : 1.5.1    , installed 1.4.15 [Updatable]
                        Adapter    "history"      : 2.2.4    , installed 2.2.4
                        Adapter    "info"         : 1.9.26   , installed 1.9.26
                        Adapter    "javascript"   : 7.1.0    , installed 7.0.8  [Updatable]
                        Controller "js-controller": 5.0.3    , installed 5.0.2  [Updatable]
                        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                        Adapter    "mysensors"    : 3.0.0    , installed 3.0.0
                        Adapter    "socketio"     : 6.3.5    , installed 6.3.5
                        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                        Adapter    "telegram"     : 1.15.6   , installed 1.15.6
                        Adapter    "vis"          : 1.4.16   , installed 1.4.16
                        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                        Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                        Adapter    "web"          : 5.5.3    , installed 5.5.3
                        Adapter    "ws"           : 2.3.6    , installed 2.3.6
                        Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                        Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
                        Objects and States
                        Objects:        3955
                        States:         3402
                        Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
                        Hit:2 http://security.ubuntu.com/ubuntu bionic-security InRelease
                        Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
                        Ign:4 http://packages.linuxmint.com tessa InRelease
                        Hit:5 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
                        Hit:6 https://deb.nodesource.com/node_16.x bionic InRelease
                        Hit:7 http://packages.linuxmint.com tessa Release
                        Hit:8 http://archive.canonical.com/ubuntu bionic InRelease
                        Hit:9 http://phoscon.de/apt/deconz bionic InRelease
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27152      807/iobroker.js-con
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27102      807/iobroker.js-con
                        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22290      630/systemd-resolve
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          27647      816/sshd
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          23220      712/cupsd
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       33556      1983/io.web.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          32769      816/sshd
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       33684      2397/io.simple-api.
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          23219      712/cupsd
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        25966      695/avahi-daemon: r
                        udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22289      630/systemd-resolve
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          29500      1120/dhclient
                        udp        0      0 0.0.0.0:32983           0.0.0.0:*                           115        25968      695/avahi-daemon: r
                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23232      747/cups-browsed
                        udp6       0      0 :::5353                 :::*                                115        25967      695/avahi-daemon: r
                        udp6       0      0 :::58743                :::*                                115        25969      695/avahi-daemon: r
                        2023-06-14 14:20:54.236  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
                        2023-06-14 14:20:54.236  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                        2023-06-14 14:20:54.237  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
                        2023-06-14 14:20:54.237  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                        2023-06-14 14:20:54.262  - debug: zigbee.0 (1725) Publish {"state":"OFF"} to "00124b0022419f47"
                        2023-06-14 14:20:54.266  - debug: zigbee.0 (1725) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854266,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                        2023-06-14 14:20:54.267  - debug: zigbee.0 (1725) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                        2023-06-14 14:20:54.268  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
                        2023-06-14 14:20:54.268  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                        2023-06-14 14:20:54.269  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                        2023-06-14 14:21:22.550  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13895a0a783f8 TS0207 was last seen '5077.171' seconds ago.
                        2023-06-14 14:21:22.550  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d00044678ff lumi.sensor_switch.aq3 was last seen '3689232.264' seconds ago.
                        2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00124b0022658a2b WB01 was last seen '304.075' seconds ago.
                        2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d00045a362e lumi.sensor_wleak.aq1 was last seen '703.242' seconds ago.
                        2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x04cf8cdf3c79009e lumi.sen_ill.mgl01 was last seen '177.775' seconds ago.
                        2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006ea578f lumi.sensor_wleak.aq1 was last seen '1047.042' seconds ago.
                        2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006e9796b lumi.sensor_wleak.aq1 was last seen '1620.726' seconds ago.
                        2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006e97800 lumi.sensor_wleak.aq1 was last seen '917.723' seconds ago.
                        2023-06-14 14:21:22.555  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006f93fb0 lumi.sensor_wleak.aq1 was last seen '561.83' seconds ago.
                        2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c138206a165e63 TS0207 was last seen '1379.288' seconds ago.
                        2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13808caa1c4e6 TS0207 was last seen '4434.999' seconds ago.
                        2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c138375c1e064d TS0207 was last seen '2260.278' seconds ago.
                        2023-06-14 14:21:22.557  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13855ba4e66b6 TS0207 was last seen '8996.791' seconds ago.
                        2023-06-14 14:21:22.557  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c1388acbf249aa TS0011 was last seen '14447731.067' seconds ago.
                        iob diag has finished.
                          @thomas-braun I guess I need to execute admin adapter right?
                            @ap2017
                            iob start admin
                              Homoran Global Moderator Administrators @ap2017 last edited by Homoran
                              yes, iob start admin
                              but you will encounter a lot of more or less severe problens, because you have installed beta versions of several adapters and the brand new bleeding edge js-controller
                                ap2017 @Homoran last edited by
                                @homoran said in Node.js update:
                                iob start admin
                                Thank you, I am back in business (till the next time)...
                                  iob start admin
                                  please read my edit!
                                    @ap2017
                                    Now check how to upgrade your operating system to the current release.
                                    'Tessa' is out of any support.
                                    19.1 'Tessa' (LTS)
                                    Security Support Ended 2 months and 2 weeks ago
                                    (01 Apr 2023)
                                    And run your iob on 'stable' not beta-stage.
                                      @thomas-braun Here is what I received from Mint support:
                                      Linux Mint 19.1 has reached end of life 2 months ago, so it's good to upgrade it. SO you'll keep getting security updates again for your software.
                                      The newest version of node.js on Linux Mint is 12 but you can add the NodeSource PPA on Linux Mint 20.x or 21.x to get node.js 18 (or newer). The instructions are here: https://github.com/nodesource/distribut ... /README.md. Use the Ubuntu instructions. So on Linux Mint 20.x or 21.x you would run this to add node.js 18.x:
                                      CODE: SELECT ALL
                                      curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash - &&\
                                      sudo apt-get install -y nodejs
                                      To upgrade from Linux Mint 19.1 to 20.x or 21.x you can follow the instructions here: viewtopic.php?t=235992. First upgrade to 19.3, then to 20 and if you want upgrade further to 20.3 and then 21. You can see till when each release is supported here: https://linuxmint.com/download_all.php.
                                      It will be some work to upgrade, and especially going from 19.3 to 20 is a hassle. Upgrading between major releases is easier and more reliable from 20 to 21. Still, because you're 2 major releases behind it may be recommended to instead do a fresh install of Linux Mint 21.x.
                                      I am wondering if it will be better to switch to different Linux version like Ubuntu. How difficult is to port ioBroker to new Linux installation?
                                        Easy. Backup your current installation, change your OS to a current distribution (I recommend Debian 12 'Bookworm' for running a server), install a plain ioBroker and install your backup. Very easy with the Backitup-Adapter.
                                          diffi...what?
                                          backup with backitup
                                          install new OS
                                          install iobroker and the latest recommended node with one line
                                          install vis if you use it, because of an actual bug
                                          restore the backup
                                          drink a cup of coffee or what you prefer
                                          ready
                                            @thomas-braun Sounds doable. Just to be safe I will do it on differed solid state drive in my controller.
                                            My system recovered but I see two issues:
                                            1. Not able to start VIS, getting message
                                            File edit.html not found: {}
                                            1. When updating adapters getting error 25. Tried to follow https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/2 still having error 25
                                            Here is additional info:
                                            ap@AP-Tiny:/opt/iobroker$ iobroker list instances
                                            + system.adapter.admin.0                  : admin                 : AP-Tiny                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                            n
                                            + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admi                            n
                                            + system.adapter.socketio.0               : socketio              : AP-Tiny                                  -  enabled, port: 8084, bind: 192.168.1.74, run as:                             admin
                                            + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admi                            n
                                            + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonof                            f_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
                                            + instance is alive
                                            node.js
                                            4899
