    2. English
    3. ioBroker general
    4. Node.js update
    Node.js update
      ap2017 @Thomas Braun last edited by
      @thomas-braun I updated OS within current release 19.1 - did not help, waiting for instructions from Mint on how to update to newer release.
      In the mean time, I installed node.js 16 and everything started to work, I was able to log in to system from web interface. I started updating ADMIN adapter and lost ability to log in via web browser again. Interestingly, the control script is working - I see responses to sensors, but I am not able to get into system via browser, Any ideas?
        Thomas Braun Most Active @ap2017 last edited by
        @ap2017 sagte in Node.js update:
        Run
        iob diag
        again so I can see where you are at now.
        A 2 Replies Last reply Reply Quote 1
          @thomas-braun said in Node.js update:
          iob diag
          *** ioBroker Diagnosis ***
          Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
          The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
          https://forum.iobroker.net
          Just copy and paste the Summary Page, including the ``` characters at start and end.
          It helps us to help you!
          Press any key to continue
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Architecture    : x86_64
          Docker          : false
          Virtualization  : none
          Distributor ID: LinuxMint
          Description:    Linux Mint 19.1 Tessa
          Release:        19.1
          Codename:       tessa
          NAME="Linux Mint"
          VERSION="19.1 (Tessa)"
          ID=linuxmint
          ID_LIKE=ubuntu
          PRETTY_NAME="Linux Mint 19.1"
          VERSION_ID="19.1"
          HOME_URL="https://www.linuxmint.com/"
          SUPPORT_URL="https://forums.linuxmint.com/"
          BUG_REPORT_URL="http://linuxmint-troubleshooting-guide.readthedocs.io/en/latest/"
          PRIVACY_POLICY_URL="https://www.linuxmint.com/"
          VERSION_CODENAME=tessa
          UBUNTU_CODENAME=bionic
          Systemuptime and Load:
           14:21:35 up 47 min,  2 users,  load average: 0.07, 0.04, 0.05
          CPU threads: 4
          *** Time and Time Zones ***
                                Local time: Wed 2023-06-14 14:21:36 EDT
                            Universal time: Wed 2023-06-14 18:21:36 UTC
                                  RTC time: Wed 2023-06-14 18:21:36
                                 Time zone: America/New_York (EDT, -0400)
          systemd-timesyncd.service active: yes
                           RTC in local TZ: no
          *** User and Groups ***
          ap
          /home/ap
          ap adm dialout cdrom sudo dip plugdev lpadmin sambashare iobroker
          *** X-Server-Setup ***
          X-Server:       true
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:           3.9G        1.3G        478M        118M        2.1G        2.2G
          Swap:          2.1G        262K        2.1G
          Total:         6.0G        1.3G        2.6G
                   3768 M total memory
                   1253 M used memory
                   2134 M active memory
                    810 M inactive memory
                    467 M free memory
                    136 M buffer memory
                   1910 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          *** FILESYSTEM ***
          udev           devtmpfs  1.9G     0  1.9G   0% /dev
          tmpfs          tmpfs     377M  1.3M  376M   1% /run
          /dev/sda1      ext4      220G  132G   77G  64% /
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
          tmpfs          tmpfs     377M   28K  377M   1% /run/user/1000
          [Wed Jun 14 13:34:25 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
          [Wed Jun 14 13:34:27 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
          Show mounted filesystems (real ones only):
          findmnt: unrecognized option '--real'
          Try 'findmnt --help' for more information.
          /var:
          4.2G    /var/
          1.9G    /var/lib
          1.7G    /var/log/journal/82929df7ee394b73b81252fe3b4e5020
          1.7G    /var/log
          Archived and active journals take up 1.6G in the file system.
          /opt/iobroker/backups:
          24M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          56G     /opt/iobroker/iobroker-data/
          55G     /opt/iobroker/iobroker-data/history
          429M    /opt/iobroker/iobroker-data/files
          125M    /opt/iobroker/iobroker-data/history/20210321
          125M    /opt/iobroker/iobroker-data/history/20210320
          23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.de9334af.js.map
          23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.e7d9968b.js.map
          23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.de9334af.js.map
          20M     /opt/iobroker/iobroker-data/objects.jsonl
          20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v16.20.0
          /usr/bin/node           v16.20.0
          /usr/bin/npm            8.19.4
          /usr/bin/npx            8.19.4
          nodejs:
            Installed: 16.20.0-deb-1nodesource1
            Candidate: 16.20.0-deb-1nodesource1
            Version table:
           *** 16.20.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bionic/main amd64 Packages
                  100 /var/lib/dpkg/status
               8.10.0~dfsg-2ubuntu0.4 500
                  500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
               8.10.0~dfsg-2ubuntu0.2 500
                  500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
               8.10.0~dfsg-2 500
                  500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          MULTIHOSTSERVICE/enabled: false
          Core adapters versions
          js-controller:  5.0.2
          admin:          6.5.7
          javascript:     7.0.8
          Adapters from github:   0
          Adapter State
            system.adapter.accuweather.0            : accuweather           : AP-Tiny                                  - disabled
            system.adapter.admin.0                  : admin                 : AP-Tiny                                  - disabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.backitup.0               : backitup              : AP-Tiny                                  - disabled
            system.adapter.cloud.0                  : cloud                 : AP-Tiny                                  - disabled
            system.adapter.deconz.0                 : deconz                : AP-Tiny                                  - disabled, port: 8080
          + system.adapter.discovery.0              : discovery             : AP-Tiny                                  -  enabled
            system.adapter.echarts.0                : echarts               : AP-Tiny                                  -  enabled
            system.adapter.flot.0                   : flot                  : AP-Tiny                                  -  enabled
          + system.adapter.history.0                : history               : AP-Tiny                                  -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : AP-Tiny                                  -  enabled
          + system.adapter.info.0                   : info                  : AP-Tiny                                  -  enabled
          + system.adapter.javascript.0             : javascript            : AP-Tiny                                  -  enabled
            system.adapter.mysensors.0              : mysensors             : AP-Tiny                                  - disabled, port: 5003, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.socketio.0               : socketio              : AP-Tiny                                  - disabled, port: 8084, bind: 192.168.1.74, run as: admin
            system.adapter.sonoff.0                 : sonoff                : AP-Tiny                                  - disabled, port: 1883, bind: 0.0.0.0
          + system.adapter.telegram.0               : telegram              : AP-Tiny                                  -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : AP-Tiny                                  -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : AP-Tiny                                  -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : AP-Tiny                                  -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : AP-Tiny                                  -  enabled
            system.adapter.vis-material-webfont.0   : vis-material-webfont  : AP-Tiny                                  -  enabled
            system.adapter.vis-material.0           : vis-material          : AP-Tiny                                  -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : AP-Tiny                                  -  enabled
            system.adapter.vis-metro.0              : vis-metro             : AP-Tiny                                  -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : AP-Tiny                                  -  enabled
            system.adapter.vis.0                    : vis                   : AP-Tiny                                  -  enabled
          + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
          + system.adapter.zwave2.0                 : zwave2                : AP-Tiny                                  -  enabled
          + instance is alive
          ioBroker-Repositories
          Stable (default): http://download.iobroker.net/sources-dist.json
          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
          Active repo(s): Beta (latest)
          Installed ioBroker-Instances
          Used repository: Beta (latest)
          Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
          Adapter    "admin"        : 6.5.8    , installed 6.5.7  [Updatable]
          Adapter    "backitup"     : 2.6.23   , installed 2.6.23
          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "echarts"      : 1.5.1    , installed 1.4.15 [Updatable]
          Adapter    "history"      : 2.2.4    , installed 2.2.4
          Adapter    "info"         : 1.9.26   , installed 1.9.26
          Adapter    "javascript"   : 7.1.0    , installed 7.0.8  [Updatable]
          Controller "js-controller": 5.0.3    , installed 5.0.2  [Updatable]
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "mysensors"    : 3.0.0    , installed 3.0.0
          Adapter    "socketio"     : 6.3.5    , installed 6.3.5
          Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
          Adapter    "telegram"     : 1.15.6   , installed 1.15.6
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-material" : 0.1.3    , installed 0.1.3
          Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
          Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
          Adapter    "web"          : 5.5.3    , installed 5.5.3
          Adapter    "ws"           : 2.3.6    , installed 2.3.6
          Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
          Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
          Objects and States
          Objects:        3955
          States:         3402
          Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
          Hit:2 http://security.ubuntu.com/ubuntu bionic-security InRelease
          Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
          Ign:4 http://packages.linuxmint.com tessa InRelease
          Hit:5 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
          Hit:6 https://deb.nodesource.com/node_16.x bionic InRelease
          Hit:7 http://packages.linuxmint.com tessa Release
          Hit:8 http://archive.canonical.com/ubuntu bionic InRelease
          Hit:9 http://phoscon.de/apt/deconz bionic InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27152      807/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27102      807/iobroker.js-con
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22290      630/systemd-resolve
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          27647      816/sshd
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          23220      712/cupsd
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       33556      1983/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          32769      816/sshd
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       33684      2397/io.simple-api.
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          23219      712/cupsd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        25966      695/avahi-daemon: r
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22289      630/systemd-resolve
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          29500      1120/dhclient
          udp        0      0 0.0.0.0:32983           0.0.0.0:*                           115        25968      695/avahi-daemon: r
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23232      747/cups-browsed
          udp6       0      0 :::5353                 :::*                                115        25967      695/avahi-daemon: r
          udp6       0      0 :::58743                :::*                                115        25969      695/avahi-daemon: r
          2023-06-14 14:20:54.236  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
          2023-06-14 14:20:54.236  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
          2023-06-14 14:20:54.237  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
          2023-06-14 14:20:54.237  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
          2023-06-14 14:20:54.262  - debug: zigbee.0 (1725) Publish {"state":"OFF"} to "00124b0022419f47"
          2023-06-14 14:20:54.266  - debug: zigbee.0 (1725) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854266,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
          2023-06-14 14:20:54.267  - debug: zigbee.0 (1725) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
          2023-06-14 14:20:54.268  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
          2023-06-14 14:20:54.268  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
          2023-06-14 14:20:54.269  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
          2023-06-14 14:21:22.550  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13895a0a783f8 TS0207 was last seen '5077.171' seconds ago.
          2023-06-14 14:21:22.550  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d00044678ff lumi.sensor_switch.aq3 was last seen '3689232.264' seconds ago.
          2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00124b0022658a2b WB01 was last seen '304.075' seconds ago.
          2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d00045a362e lumi.sensor_wleak.aq1 was last seen '703.242' seconds ago.
          2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x04cf8cdf3c79009e lumi.sen_ill.mgl01 was last seen '177.775' seconds ago.
          2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006ea578f lumi.sensor_wleak.aq1 was last seen '1047.042' seconds ago.
          2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006e9796b lumi.sensor_wleak.aq1 was last seen '1620.726' seconds ago.
          2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006e97800 lumi.sensor_wleak.aq1 was last seen '917.723' seconds ago.
          2023-06-14 14:21:22.555  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006f93fb0 lumi.sensor_wleak.aq1 was last seen '561.83' seconds ago.
          2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c138206a165e63 TS0207 was last seen '1379.288' seconds ago.
          2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13808caa1c4e6 TS0207 was last seen '4434.999' seconds ago.
          2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c138375c1e064d TS0207 was last seen '2260.278' seconds ago.
          2023-06-14 14:21:22.557  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13855ba4e66b6 TS0207 was last seen '8996.791' seconds ago.
          2023-06-14 14:21:22.557  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c1388acbf249aa TS0011 was last seen '14447731.067' seconds ago.
          iob diag has finished.
            @thomas-braun I guess I need to execute admin adapter right?
              @ap2017
              iob start admin
                Homoran Global Moderator Administrators @ap2017 last edited by Homoran
                yes, iob start admin
                but you will encounter a lot of more or less severe problens, because you have installed beta versions of several adapters and the brand new bleeding edge js-controller
                  ap2017 @Homoran last edited by
                  @homoran said in Node.js update:
                  iob start admin
                  Thank you, I am back in business (till the next time)...
                    iob start admin
                    please read my edit!
                      Thomas Braun Most Active @ap2017 last edited by Thomas Braun
                      @ap2017
                      Now check how to upgrade your operating system to the current release.
                      'Tessa' is out of any support.
                      19.1 'Tessa' (LTS)
                      Security Support Ended 2 months and 2 weeks ago
                      (01 Apr 2023)
                      And run your iob on 'stable' not beta-stage.
                        @thomas-braun Here is what I received from Mint support:
                        Linux Mint 19.1 has reached end of life 2 months ago, so it's good to upgrade it. SO you'll keep getting security updates again for your software.
                        The newest version of node.js on Linux Mint is 12 but you can add the NodeSource PPA on Linux Mint 20.x or 21.x to get node.js 18 (or newer). The instructions are here: https://github.com/nodesource/distribut ... /README.md. Use the Ubuntu instructions. So on Linux Mint 20.x or 21.x you would run this to add node.js 18.x:
                        CODE: SELECT ALL
                        curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash - &&\
                        sudo apt-get install -y nodejs
                        To upgrade from Linux Mint 19.1 to 20.x or 21.x you can follow the instructions here: viewtopic.php?t=235992. First upgrade to 19.3, then to 20 and if you want upgrade further to 20.3 and then 21. You can see till when each release is supported here: https://linuxmint.com/download_all.php.
                        It will be some work to upgrade, and especially going from 19.3 to 20 is a hassle. Upgrading between major releases is easier and more reliable from 20 to 21. Still, because you're 2 major releases behind it may be recommended to instead do a fresh install of Linux Mint 21.x.
                        I am wondering if it will be better to switch to different Linux version like Ubuntu. How difficult is to port ioBroker to new Linux installation?
                          Easy. Backup your current installation, change your OS to a current distribution (I recommend Debian 12 'Bookworm' for running a server), install a plain ioBroker and install your backup. Very easy with the Backitup-Adapter.
                            diffi...what?
                            backup with backitup
                            install new OS
                            install iobroker and the latest recommended node with one line
                            install vis if you use it, because of an actual bug
                            restore the backup
                            drink a cup of coffee or what you prefer
                            ready
                              @thomas-braun Sounds doable. Just to be safe I will do it on differed solid state drive in my controller.
                              My system recovered but I see two issues:
                              1. Not able to start VIS, getting message
                              File edit.html not found: {}
                              1. When updating adapters getting error 25. Tried to follow https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/2 still having error 25
                              Here is additional info:
                              ap@AP-Tiny:/opt/iobroker$ iobroker list instances
                              + system.adapter.admin.0                  : admin                 : AP-Tiny                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                            n
                              + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admi                            n
                              + system.adapter.socketio.0               : socketio              : AP-Tiny                                  -  enabled, port: 8084, bind: 192.168.1.74, run as:                             admin
                              + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admi                            n
                              + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonof                            f_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
                              + instance is alive
                                @ap2017
                                i stall vis if you use it, because of an actual bug
                                You have to install vis prior to restoring your backup. Known issue.
                                1. Error 25 ist very generic, it can have a lot of causes for this error.
                                Try
                                iob stop
                                iob fix
                                iob start
                                  1. Assuming that I have to delete VIS adapter and add it back. Will all my screens stay in the system?
                                  2. Tried this, did not help.
                                  iob stop
                                  iob fix
                                  iob start
                                  Here is detailed error message
                                  $ ./iobroker upgrade echarts
                                  Update echarts from @1.4.15 to @1.5.1
                                  NPM version: 8.19.4
                                  Installing iobroker.echarts@1.5.1... (System call)
                                  ERROR: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c -- node main.js --installnpm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T20_57_44_562Z-debug-0.log
                                  ERROR: host.AP-Tiny Cannot install iobroker.echarts@1.5.1: 6
                                  ERROR: process exited with code 25
                                    Thomas Braun Most Active last edited by
                                    @ap2017
                                    Do it via command line interface and debug option:
                                    iobroker upgrade echarts --debug
                                      ap@AP-Tiny:/opt/iobroker$ iobroker upgrade echarts --debug
                                      This upgrade of "echarts" will introduce the following changes:
                                      -> 1.5.1:
                                      Error handling in JSON data was improved
                                      -> 1.5.0:
                                      Implemented raw data export
                                      Would you like to upgrade echarts from @1.4.15 to @1.5.1 now? [(y)es, (n)o]: y
                                      NPM version: 8.19.4
                                      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                      npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                      npm ERR! code 6
                                      npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T21_31_07_618Z-debug-0.log
                                      npm ERR! code 6
                                      mikeal created this issue in request/request
                                      open Request’s Past, Present and Future #3142
                                      Qix- created this issue in visionmedia/debug
                                      closed ReDos Vulnerability Regression Visibility Notice #797
                                        npm ERR! code 6
                                        The broken vis install blocks any other npm actions.
                                        Try
                                        iobroker upgrade vis@1.4.10
                                        Restore your backup again.
                                        And avoid the beta Repository!
                                        A 2 Replies Last reply Reply Quote 0
                                          ap@AP-Tiny:~$ iobroker upgrade vis@1.4.10
                                          This downgrade of "vis" will at least remove the following changes:
                                          -> 1.4.16
                                          Corrected connection with "only port" URLs
                                          -> 1.4.15
                                          Better check of the offline license
                                          -> 1.4.14
                                          Corrected GUI bug
                                          -> 1.4.13
                                          The group attributes will be replaced recursively
                                          -> 1.4.12
                                          Fixed bug with the export of specific widgets
                                          -> 1.4.11
                                          Removed ES6 commands to be supported by older browsers
                                          Fixed problem with update of grouped widgets
                                          Added web manifest to be able to handle vis as the web app
                                          Would you like to downgrade vis from @1.4.16 to @1.4.10 now? [(y)es, (n)o]: y
                                          Update vis from @1.4.16 to @1.4.10
                                          NPM version: 8.19.4
                                          Installing iobroker.vis@1.4.10... (System call)
                                          npm ERR! code 6
                                          npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T22_28_10_906Z-debug-0.log
                                          host.AP-Tiny Cannot install iobroker.vis@1.4.10: 6
                                          ap@AP-Tiny:~$
                                            What do you mean by "Restore your backup again."? I did not do nor restore backup
                                            node.js
                                            4899
