    2. English
    3. ioBroker general
    4. Node.js update
    Node.js update
      Homoran Global Moderator Administrators @ap2017 last edited by Homoran
      @ap2017 sagte in Node.js update:
      How difficult is to port ioBroker to new Linux installation?
      diffi...what?
      backup with backitup
      install new OS
      install iobroker and the latest recommended node with one line
      install vis if you use it, because of an actual bug
      restore the backup
      drink a cup of coffee or what you prefer
      ready
        ap2017 @Thomas Braun last edited by
        @thomas-braun Sounds doable. Just to be safe I will do it on differed solid state drive in my controller.
        My system recovered but I see two issues:
        1. Not able to start VIS, getting message
        File edit.html not found: {}
        1. When updating adapters getting error 25. Tried to follow https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/2 still having error 25
        Here is additional info:
        ap@AP-Tiny:/opt/iobroker$ iobroker list instances
          system.adapter.accuweather.0            : accuweather           : AP-Tiny                                  - disabled
        + system.adapter.admin.0                  : admin                 : AP-Tiny                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                            n
          system.adapter.backitup.0               : backitup              : AP-Tiny                                  - disabled
          system.adapter.cloud.0                  : cloud                 : AP-Tiny                                  - disabled
          system.adapter.deconz.0                 : deconz                : AP-Tiny                                  - disabled, port: 8080
        + system.adapter.discovery.0              : discovery             : AP-Tiny                                  -  enabled
          system.adapter.echarts.0                : echarts               : AP-Tiny                                  -  enabled
          system.adapter.flot.0                   : flot                  : AP-Tiny                                  -  enabled
        + system.adapter.history.0                : history               : AP-Tiny                                  -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : AP-Tiny                                  -  enabled
        + system.adapter.info.0                   : info                  : AP-Tiny                                  -  enabled
        + system.adapter.javascript.0             : javascript            : AP-Tiny                                  -  enabled
          system.adapter.mysensors.0              : mysensors             : AP-Tiny                                  - disabled, port: 5003, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admi                            n
        + system.adapter.socketio.0               : socketio              : AP-Tiny                                  -  enabled, port: 8084, bind: 192.168.1.74, run as:                             admin
          system.adapter.sonoff.0                 : sonoff                : AP-Tiny                                  - disabled, port: 1883, bind: 0.0.0.0
        + system.adapter.telegram.0               : telegram              : AP-Tiny                                  -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : AP-Tiny                                  -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : AP-Tiny                                  -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : AP-Tiny                                  -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : AP-Tiny                                  -  enabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : AP-Tiny                                  -  enabled
          system.adapter.vis-material.0           : vis-material          : AP-Tiny                                  -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : AP-Tiny                                  -  enabled
          system.adapter.vis-metro.0              : vis-metro             : AP-Tiny                                  -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : AP-Tiny                                  -  enabled
          system.adapter.vis.0                    : vis                   : AP-Tiny                                  -  enabled
        + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admi                            n
        + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonof                            f_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
        + system.adapter.zwave2.0                 : zwave2                : AP-Tiny                                  -  enabled
        + instance is alive
          Thomas Braun Most Active @ap2017 last edited by
          @ap2017
          i stall vis if you use it, because of an actual bug
          You have to install vis prior to restoring your backup. Known issue.
          1. Error 25 ist very generic, it can have a lot of causes for this error.
          Try
          iob stop
          iob fix
          iob start
            1. Assuming that I have to delete VIS adapter and add it back. Will all my screens stay in the system?
            2. Tried this, did not help.
            iob stop
            iob fix
            iob start
            Here is detailed error message
            $ ./iobroker upgrade echarts
            Update echarts from @1.4.15 to @1.5.1
            NPM version: 8.19.4
            Installing iobroker.echarts@1.5.1... (System call)
            ERROR: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c -- node main.js --installnpm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T20_57_44_562Z-debug-0.log
            ERROR: host.AP-Tiny Cannot install iobroker.echarts@1.5.1: 6
            ERROR: process exited with code 25
              Thomas Braun Most Active last edited by
              @ap2017
              Do it via command line interface and debug option:
              iobroker upgrade echarts --debug
                ap@AP-Tiny:/opt/iobroker$ iobroker upgrade echarts --debug
                This upgrade of "echarts" will introduce the following changes:
                -> 1.5.1:
                Error handling in JSON data was improved
                -> 1.5.0:
                Implemented raw data export
                Would you like to upgrade echarts from @1.4.15 to @1.5.1 now? [(y)es, (n)o]: y
                NPM version: 8.19.4
                npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                npm ERR! code 6
                npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T21_31_07_618Z-debug-0.log
                npm ERR! code 6
                mikeal created this issue in request/request
                open Request’s Past, Present and Future #3142
                Qix- created this issue in visionmedia/debug
                closed ReDos Vulnerability Regression Visibility Notice #797
                  npm ERR! code 6
                  The broken vis install blocks any other npm actions.
                  Try
                  iobroker upgrade vis@1.4.10
                  Restore your backup again.
                  And avoid the beta Repository!
                  A 2 Replies Last reply Reply Quote 0
                    ap@AP-Tiny:~$ iobroker upgrade vis@1.4.10
                    This downgrade of "vis" will at least remove the following changes:
                    -> 1.4.16
                    Corrected connection with "only port" URLs
                    -> 1.4.15
                    Better check of the offline license
                    -> 1.4.14
                    Corrected GUI bug
                    -> 1.4.13
                    The group attributes will be replaced recursively
                    -> 1.4.12
                    Fixed bug with the export of specific widgets
                    -> 1.4.11
                    Removed ES6 commands to be supported by older browsers
                    Fixed problem with update of grouped widgets
                    Added web manifest to be able to handle vis as the web app
                    Would you like to downgrade vis from @1.4.16 to @1.4.10 now? [(y)es, (n)o]: y
                    Update vis from @1.4.16 to @1.4.10
                    NPM version: 8.19.4
                    Installing iobroker.vis@1.4.10... (System call)
                    npm ERR! code 6
                    npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T22_28_10_906Z-debug-0.log
                    host.AP-Tiny Cannot install iobroker.vis@1.4.10: 6
                    ap@AP-Tiny:~$
                      @thomas-braun said in Node.js update:
                      What do you mean by "Restore your backup again."? I did not do nor restore backup
                        @ap2017
                        I thought you did change your operating system?
                          @thomas-braun Not yet, it will take me a while
                            @ap2017
                            Then take your time and come again when done.
                              NO!!
                              Don't delete the vis adapter!
                              Just install a "blank" version before restoring.
                                ap2017 @Thomas Braun last edited by ap2017
                                @thomas-braun Installed latest Ubuntu, restored ioBroker from backup (had to use latest beta controller to match with backup), but new installation of ioBroker is set for stable repositories. Everything seems to be working, including VIS. Having a bit of an issue with info adapter. It works for few seconds then turns red with error messages
                                2023-06-16 16:09:19.354 - info: info.0 (3352) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                2023-06-16 16:09:20.660 - info: info.0 (3352) starting. Version 1.9.26 in /opt/iobroker/node_modules/iobroker.info, node: v18.16.0, js-controller: 5.0.4
                                2023-06-16 16:09:21.033 - info: info.0 (3352) Reading/updating systemdata.
                                2023-06-16 16:09:22.167 - info: info.0 (3352) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                                2023-06-16 16:09:22.323 - info: info.0 (3352) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                                2023-06-16 16:09:22.583 - info: info.0 (3352) cpu Temp res = {"main":62,"cores":[62,61],"max":62,"socket":[],"chipset":null}
                                2023-06-16 16:09:25.284 - info: admin.0 (1913) ==> Connected system.user.admin from ::ffff:192.168.1.244
                                2023-06-16 16:09:27.785 - info: host.ap-EB1033 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                                2023-06-16 16:09:31.423 - info: info.0 (3352) State value to set for "info.0.sysinfo.disks.diskLayout.dev0.size" has to be type "string" but received type "number"
                                Should I change Info objects types to match received vs. set?
                                  @ap2017
                                  Usually this would be reported as 'Issue' at the GitHub:
                                  https://github.com/iobroker-community-adapters/ioBroker.info/issues
                                  This may be due to the beta-version of the js-controller. Have seen similar errors with different adapters.
                                    @thomas-braun Would it make sense to downgrade controller?
                                      Thomas Braun Most Active @ap2017 last edited by Thomas Braun
                                      @ap2017 To avoid the errors that come with a beta-js-contoller I 'd recommend to downgrade. But it's not that trivial
                                      Instructions on how to do a downgrade are only available in German, afaics.
                                      https://forum.iobroker.net/topic/66108/js-controller-5-0-x-jetzt-in-der-beta
                                        @thomas-braun Here is what I have in my records to downgrade. This from https://forum.iobroker.net/topic/19885/probleme-nach-js-controller-1-5-6-1-4-2-downgrade?_=1686947115238
                                        cd /opt/iobroker
                                        iobroker stop
                                        npm i iobroker.js-controller@x.x.x --production
                                        iobroker start
                                        node.js
                                        4899
