    4. Javascript Stürtzt ab
      Thomas Braun Most Active @manrum1 last edited by Thomas Braun
      @manrum1
      iob stop
      iob fix
      iob start
      Abwarten bis der iobroker wieder vollständig läuft.
      iob diag
        Homoran Global Moderator Administrators @manrum1 last edited by
        @manrum1 sagte in Javascript Stürtzt ab:
        Sietz wohl etwas auf der Leitung?
        oder deine Installation ist zu alt
          manrum1 @Thomas Braun last edited by Homoran
          @thomas-braun Danke für die Hilfe!
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Architecture    : aarch64
          Docker          : false
          Virtualization  : none
          Distributor ID: Debian
          Description:    Debian GNU/Linux 11 (bullseye)
          Release:        11
          Codename:       bullseye
          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
          NAME="Debian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          Systemuptime and Load:
           22:19:35 up 48 min,  1 user,  load average: 4.43, 2.38, 1.44
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          Other values than 0x0 hint to temperature/voltage problems
          temp=62.8'C
          volt=0.9260V
          *** Time and Time Zones ***
                         Local time: Tue 2023-06-13 22:19:35 CEST
                     Universal time: Tue 2023-06-13 20:19:35 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          iobroker
          /home/iobroker
          iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            7.8G        1.9G        5.0G        1.0M        905M        5.8G
          Swap:            99M          0B         99M
          Total:          7.9G        1.9G        5.1G
                   7812 M total memory
                   1876 M used memory
                   2081 M active memory
                    501 M inactive memory
                   5030 M free memory
                    105 M buffer memory
                    799 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4       29G  8.2G   19G  30% /
          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
          /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
          tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
          [Tue Jun 13 21:31:13 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:DB:77:FD vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=02088660-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Tue Jun 13 21:31:14 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Tue Jun 13 21:31:14 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Tue Jun 13 21:31:16 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          Show mounted filesystems (real ones only):
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          3.2G    /var/
          1.9G    /var/log/journal/54074e39055a46ce8cf0e1657f7640a7
          1.9G    /var/log
          665M    /var/lib
          Archived and active journals take up 1.8G in the file system.
          /opt/iobroker/backups:
          1014M   /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          306M    /opt/iobroker/iobroker-data/
          180M    /opt/iobroker/iobroker-data/files
          86M     /opt/iobroker/iobroker-data/backup-objects
          51M     /opt/iobroker/iobroker-data/files/javascript.admin
          45M     /opt/iobroker/iobroker-data/files/devices.admin/static
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          27M     /opt/iobroker/iobroker-data/objects.jsonl
          20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
          8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
          8.3M    /opt/iobroker/iobroker-data/states.jsonl
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v16.20.0
          /usr/bin/node           v16.20.0
          /usr/bin/npm            8.19.4
          /usr/bin/npx            8.19.4
          nodejs:
            Installed: 16.20.0-deb-1nodesource1
            Candidate: 16.20.0-deb-1nodesource1
            Version table:
           *** 16.20.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u4 500
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
               12.22.12~dfsg-1~deb11u3 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          MULTIHOSTSERVICE/enabled: false
          Core adapters versions
          js-controller:  5.0.2
          admin:          6.5.8
          javascript:     7.1.0
          Adapters from github:   0
          Adapter State
          + system.adapter.accuweather.0            : accuweather           : iob1                                     -  enabled
          + system.adapter.admin.0                  : admin                 : iob1                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alias-manager.0          : alias-manager         : iob1                                     - disabled
          + system.adapter.backitup.0               : backitup              : iob1                                     -  enabled
          + system.adapter.cloud.0                  : cloud                 : iob1                                     -  enabled
            system.adapter.daswetter.0              : daswetter             : iob1                                     -  enabled
            system.adapter.daswetter.1              : daswetter             : iob1                                     -  enabled
            system.adapter.devices.0                : devices               : iob1                                     - disabled
          + system.adapter.discovery.0              : discovery             : iob1                                     -  enabled
          + system.adapter.email.0                  : email                 : iob1                                     -  enabled
          + system.adapter.ems-esp.0                : ems-esp               : iob1                                     -  enabled
          + system.adapter.ems-esp.1                : ems-esp               : iob1                                     -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iob1                                     -  enabled
          + system.adapter.fb-checkpresence.1       : fb-checkpresence      : iob1                                     -  enabled
          + system.adapter.fb-checkpresence.2       : fb-checkpresence      : iob1                                     -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : iob1                                     -  enabled
          + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iob1                                     -  enabled
            system.adapter.habpanel.0               : habpanel              : iob1                                     - disabled
          + system.adapter.history.0                : history               : iob1                                     -  enabled
            system.adapter.ical.0                   : ical                  : iob1                                     -  enabled
          + system.adapter.influxdb.0               : influxdb              : iob1                                     -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : iob1                                     -  enabled
          + system.adapter.javascript.0             : javascript            : iob1                                     -  enabled
          + system.adapter.maxcube.0                : maxcube               : iob1                                     -  enabled, port: 62910, bind: 0.0.0.0
            system.adapter.modbus.0                 : modbus                : iob1                                     - disabled
          + system.adapter.mqtt.0                   : mqtt                  : iob1                                     -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.net-tools.0              : net-tools             : iob1                                     -  enabled
          + system.adapter.ping.0                   : ping                  : iob1                                     -  enabled
          + system.adapter.shelly.0                 : shelly                : iob1                                     -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.sonoff.0                 : sonoff                : iob1                                     -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.tuya.0                   : tuya                  : iob1                                     -  enabled
            system.adapter.viessmannapi.0           : viessmannapi          : iob1                                     - disabled
          + system.adapter.web.0                    : web                   : iob1                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
          Stable (default): http://download.iobroker.net/sources-dist.json
          Active repo(s): Beta (latest)
          Installed ioBroker-Instances
          Used repository: Beta (latest)
          Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
          Adapter    "admin"        : 6.5.8    , installed 6.5.8
          Adapter    "backitup"     : 2.6.23   , installed 2.6.23
          Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "email"        : 1.2.0    , installed 1.2.0
          Adapter    "ems-esp"      : 1.30.0   , installed 1.30.0
          Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
          Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
          Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "history"      : 2.2.4    , installed 2.2.4
          Adapter    "ical"         : 1.13.2   , installed 1.13.2
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "info"         : 1.9.26   , installed 1.9.26
          Adapter    "javascript"   : 7.1.0    , installed 7.1.0
          Controller "js-controller": 5.0.2    , installed 5.0.2
          Adapter    "maxcube"      : 1.0.4    , installed 1.0.4
          Adapter    "modbus"       : 5.0.11   , installed 5.0.11
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "ping"         : 1.5.3    , installed 1.5.3
          Adapter    "semp"         : 1.3.2    , installed 1.3.2
          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
          Adapter    "socketio"     : 6.3.5    , installed 6.3.5
          Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
          Adapter    "viessmannapi" : 2.1.1    , installed 2.1.1
          Adapter    "web"          : 5.5.3    , installed 5.5.3
          Adapter    "ws"           : 2.3.6    , installed 2.3.6
          Objects and States
          Objects:        31133
          States:         28561
          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
          W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Some index files failed to download. They have been ignored, or old ones used instead.
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
          Get:6 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
          Get:7 https://repos.influxdata.com/debian stable InRelease [6892 B]
          Err:6 https://packages.grafana.com/oss/deb stable InRelease
          Err:7 https://repos.influxdata.com/debian stable InRelease
          Fetched 6892 B in 2s (3242 B/s)
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       65362      4337/iobroker.js-co
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       63828      4337/iobroker.js-co
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12823      510/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       67756      4472/io.mqtt.0
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       67244      4502/io.shelly.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       67931      4517/io.sonoff.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          11952      510/sshd: /usr/sbin
          tcp6       0      0 :::3000                 :::*                    LISTEN      111        14637      611/grafana-server
          tcp6       0      0 :::8086                 :::*                    LISTEN      110        13034      615/influxd
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       68370      4849/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       65399      4355/io.admin.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1502       610/dhcpcd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11903      358/avahi-daemon: r
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       64472      4524/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       64473      4524/io.tuya.0
          udp        0      0 0.0.0.0:47825           0.0.0.0:*                           108        11905      358/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        11904      358/avahi-daemon: r
          udp6       0      0 :::53030                :::*                                108        11906      358/avahi-daemon: r
          2023-06-13 22:20:35.083  - warn: shelly.0 (4502) [authEnabled] 192.168.10.35 (shellyswitch25 / shellyswitch25-E098068D2495 / SHSW-25#E098068D2495#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:39.626  - warn: shelly.0 (4502) [authEnabled] 192.168.10.58 (shellydimmer2 / shellydimmer2-F4CFA2ECA923 / SHDM-2#F4CFA2ECA923#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:39.630  - warn: shelly.0 (4502) [authEnabled] 192.168.10.52 (shellydimmer2 / shellydimmer2-3C6105E53F3E / SHDM-2#3C6105E53F3E#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:40.048  - warn: shelly.0 (4502) [authEnabled] 192.168.10.51 (shellydimmer2 / shellydimmer2-F4CFA2ECA892 / SHDM-2#F4CFA2ECA892#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:40.359  - warn: shelly.0 (4502) [authEnabled] 192.168.10.35 (shellyswitch25 / shellyswitch25-E098068D2495 / SHSW-25#E098068D2495#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:45.482  - warn: shelly.0 (4502) [authEnabled] 192.168.10.52 (shellydimmer2 / shellydimmer2-3C6105E53F3E / SHDM-2#3C6105E53F3E#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:45.487  - warn: shelly.0 (4502) [authEnabled] 192.168.10.58 (shellydimmer2 / shellydimmer2-F4CFA2ECA923 / SHDM-2#F4CFA2ECA923#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:45.645  - warn: shelly.0 (4502) [authEnabled] 192.168.10.35 (shellyswitch25 / shellyswitch25-E098068D2495 / SHSW-25#E098068D2495#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:45.650  - warn: shelly.0 (4502) [authEnabled] 192.168.10.51 (shellydimmer2 / shellydimmer2-F4CFA2ECA892 / SHDM-2#F4CFA2ECA892#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:49.428  - error: shelly.0 (4502) [MQTT] Wrong MQTT authentification of client "shelly1-48551902A079"
          2023-06-13 22:20:49.437  - info: shelly.0 (4502) [MQTT] Client Close:  (shelly1 / shelly1-48551902A079 / SHSW-1#48551902A079#1) (false)
          2023-06-13 22:20:50.678  - warn: shelly.0 (4502) [authEnabled] 192.168.10.52 (shellydimmer2 / shellydimmer2-3C6105E53F3E / SHDM-2#3C6105E53F3E#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:50.690  - warn: shelly.0 (4502) [authEnabled] 192.168.10.58 (shellydimmer2 / shellydimmer2-F4CFA2ECA923 / SHDM-2#F4CFA2ECA923#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:50.948  - warn: shelly.0 (4502) [authEnabled] 192.168.10.35 (shellyswitch25 / shellyswitch25-E098068D2495 / SHSW-25#E098068D2495#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:51.050  - warn: shelly.0 (4502) [authEnabled] 192.168.10.51 (shellydimmer2 / shellydimmer2-F4CFA2ECA892 / SHDM-2#F4CFA2ECA892#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:55.908  - warn: shelly.0 (4502) [authEnabled] 192.168.10.52 (shellydimmer2 / shellydimmer2-3C6105E53F3E / SHDM-2#3C6105E53F3E#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:55.933  - warn: shelly.0 (4502) [authEnabled] 192.168.10.58 (shellydimmer2 / shellydimmer2-F4CFA2ECA923 / SHDM-2#F4CFA2ECA923#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:56.260  - warn: shelly.0 (4502) [authEnabled] 192.168.10.35 (shellyswitch25 / shellyswitch25-E098068D2495 / SHSW-25#E098068D2495#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:56.294  - info: tuya.0 (4524) bf0774134c70c4201fr04k: Error on Reconnect (7): connect EHOSTUNREACH 192.168.10.82:6668
          2023-06-13 22:20:56.429  - warn: shelly.0 (4502) [authEnabled] 192.168.10.51 (shellydimmer2 / shellydimmer2-F4CFA2ECA892 / SHDM-2#F4CFA2ECA892#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:20:58.437  - info: tuya.0 (4524) bfdff6db2893d4426eyjwq: Error on Reconnect (7): connect EHOSTUNREACH 192.168.10.79:6668
          2023-06-13 22:21:01.043  - warn: shelly.0 (4502) [authEnabled] 192.168.10.52 (shellydimmer2 / shellydimmer2-3C6105E53F3E / SHDM-2#3C6105E53F3E#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:21:01.066  - warn: shelly.0 (4502) [authEnabled] 192.168.10.58 (shellydimmer2 / shellydimmer2-F4CFA2ECA923 / SHDM-2#F4CFA2ECA923#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:21:01.486  - warn: shelly.0 (4502) [authEnabled] 192.168.10.35 (shellyswitch25 / shellyswitch25-E098068D2495 / SHSW-25#E098068D2495#1): This device is not protected via restricted login (see adapter documentation for details)
          2023-06-13 22:21:01.835  - warn: shelly.0 (4502) [authEnabled] 192.168.10.51 (shellydimmer2 / shellydimmer2-F4CFA2ECA892 / SHDM-2#F4CFA2ECA892#1): This device is not protected via restricted login (see adapter documentation for details)
            @manrum1
            Bis auf die Beta-Versionen und den fehlenden Keys für grafana und influxdb soweit keine dicken Hunde.
            • DJMarc75
              DJMarc75 @Thomas Braun last edited by
              @thomas-braun sagte in Javascript Stürtzt ab:
              Naja, der TE spielt ja in der ganz aktuellen Betatester-Liga vom js-controller und javaskriptadapter mit. Da sollte doch zumindest Node auf "empfohlen" gehoben werden ?!
                Thomas Braun Most Active @DJMarc75 last edited by
                @djmarc75
                Ja, nodejs@18 würde sich empfehlen, aber mit 16 muss es auch rennen. Insgesamt habe ich hier halt auch schon ganz andere Setups gesehen, da ist node16 statt 18 kein 'dicker Hund'.
                Wichtig sind halt die Quellen für influxdb und grafana aktuell laufend zu halten.
                  @manrum1
                  und nicht gerade die bleeding edge Versionen nehmen, an denen gerade geschraubt wird
                  • a200
                    a200 last edited by a200
                    @homoran Habe die gleichen Probleme mit Javascript Adapter. Habe downgrade auf die letzte laufende Version durchgeführt, was aber auch nicht geholfen hat.
                    Könnt ihr da was sehen?
                    BASE SYSTEM:
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Architecture    : x86_64
                    Docker          : false
                    Virtualization  : kvm
                    Release:        11
                    Codename:       bullseye
                    VERSION_ID="11"
                    ID=debian
                    23:06:20 up 12 min,  3 users,  load average: 0.57, 0.80, 0.45
                    CPU threads: 2
                                  Local time: Thu 2023-06-15 23:06:20 CEST
                              Universal time: Thu 2023-06-15 21:06:20 UTC
                                    RTC time: Thu 2023-06-15 21:06:21
                                 NTP service: active
                             RTC in local TZ: no
                    root
                    /root
                    root
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:             11G        2.0G        9.3G        0.0K        618M        9.7G
                    Swap:           255M          0B        255M
                    Total:           12G        2.0G        9.6G
                           11965 M total memory
                            2031 M used memory
                             300 M active memory
                            2130 M inactive memory
                            9315 M free memory
                              74 M buffer memory
                             544 M swap cache
                             255 M total swap
                               0 M used swap
                             255 M free swap
                    *** FILESYSTEM ***
                    udev           devtmpfs  5.9G     0  5.9G   0% /dev
                    tmpfs          tmpfs     1.2G  568K  1.2G   1% /run
                    /dev/sdb1      ext4       76G   38G   36G  52% /
                    tmpfs          tmpfs     5.9G     0  5.9G   0% /dev/shm
                    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                    tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/0
                    [Thu Jun 15 22:53:53 2023] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
                    [Thu Jun 15 22:53:54 2023] EXT4-fs (sdb1): re-mounted. Opts: errors=remount-ro
                    /      /dev/sdb1 ext4   rw,relatime,errors=remount-ro
                    /var:
                    20G     /var/
                    15G     /var/lib/influxdb/.influxdbv2/engine/data/7bf64f61a42d54f8/autogen
                    Archived and active journals take up 3.9G in the file system.
                    2.0G    /opt/iobroker/backups/
                    1.2G    /opt/iobroker/iobroker-data/
                    781M    /opt/iobroker/iobroker-data/files
                    258M    /opt/iobroker/iobroker-data/files/minuvis
                    222M    /opt/iobroker/iobroker-data/files/minuvis/app
                    221M    /opt/iobroker/iobroker-data/files/minuvis/app/static
                    23M     /opt/iobroker/iobroker-data/objects.jsonl
                    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                    23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                    /usr/bin/nodejs         v18.16.0
                    /usr/bin/node           v18.16.0
                    /usr/bin/npm            9.5.1
                    /usr/bin/npx            9.5.1
                    nodejs:
                     Installed: 18.16.0-deb-1nodesource1
                     Candidate: 18.16.0-deb-1nodesource1
                     Version table:
                    *** 18.16.0-deb-1nodesource1 500
                           500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                           500 http://deb.debian.org/debian bullseye/main amd64 Packages
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    js-controller:  5.0.4
                    admin:          6.5.8
                    javascript:     7.0.8
                    Adapters from github:   4
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                     system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                     system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                     system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                     system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                    + system.adapter.ebus.0                   : ebus                  : iobroker                                 -  enabled
                    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                    + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
                    + system.adapter.eventlist.0              : eventlist             : iobroker                                 -  enabled
                    + system.adapter.ford.0                   : ford                  : iobroker                                 -  enabled
                    + system.adapter.frigate.0                : frigate               : iobroker                                 -  enabled
                    + system.adapter.fully-mqtt.0             : fully-mqtt            : iobroker                                 -  enabled
                     system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 - disabled
                     system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
                     system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : iobroker                                 - disabled
                    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                     system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                     system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                     system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
                     system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                     system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                     system.adapter.influxdb.1               : influxdb              : iobroker                                 - disabled, port: 8086
                     system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                     system.adapter.minuvis.0                : minuvis               : iobroker                                 -  enabled
                     system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 8883, bind: 0.0.0.0
                    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1889, bind: 0.0.0.0
                    + system.adapter.mqtt.3                   : mqtt                  : iobroker                                 -  enabled, port: 1888, bind: 0.0.0.0
                     system.adapter.mqtt.4                   : mqtt                  : iobroker                                 - disabled, port: 1885, bind: 0.0.0.0
                    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                     system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
                    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                     system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8187, bind: 0.0.0.0, run as: admin
                    + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
                     system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1890, bind: 0.0.0.0
                    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                     system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 - disabled
                    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                     system.adapter.systeminfo.0             : systeminfo            : iobroker                                 - disabled
                    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                     system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                     system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                     system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                     system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                     system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
                     system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                     system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                     system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                     system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                     system.adapter.vofo-speedtest.0         : vofo-speedtest        : iobroker                                 - disabled
                     system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                     system.adapter.zigbee.1                 : zigbee                : iobroker                                 - disabled, port: tcp://192.168.10.109:6638
                    + instance is alive
                    Active repo(s): beta
                    Used repository: beta
                    Adapter    "discovery"    : 3.2.0    , installed 3.2.0
                    Adapter    "ebus"         : 3.2.1    , installed 3.2.1
                    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                    Adapter    "esphome"      : 0.2.4    , installed 0.2.4
                    Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
                    Adapter    "ford"         : 0.0.14   , installed 0.0.14
                    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
                    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                    Adapter    "javascript"   : 7.1.0    , installed 7.0.8  [Updatable]
                    Controller "js-controller": 5.0.4    , installed 5.0.4
                    Adapter    "minuvis"      : 2.3.3    , installed 2.3.3
                    Adapter    "nut"          : 1.6.0    , installed 1.6.0
                    Adapter    "parser"       : 1.3.2    , installed 1.3.2
                    Adapter    "pi-hole"      : 1.3.5    , installed 1.3.4  [Updatable]
                    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                    Adapter    "sql"          : 2.2.0    , installed 2.2.0
                    Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
                    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
                    Adapter    "unifi"        : 0.6.4    , installed 0.6.4
                    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                    Adapter    "vis"          : 1.4.16   , installed 1.4.16
                    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                    Adapter    "vofo-speedtest": 0.0.13  , installed 0.0.13
                    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                    Objects and States
                    Objects:        27438
                    States:         26557
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Hit:2 https://repos.influxdata.com/debian stable InRelease
                    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                    Hit:4 https://repos.influxdata.com/debian buster InRelease
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       21487      2083/io.mqtt.3
                    tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       21405      2060/io.mqtt.1
                    tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          13423      -
                    tcp        0      0 0.0.0.0:45921           0.0.0.0:*               LISTEN      0          13353      558/rpc.mountd
                    tcp        0      0 0.0.0.0:1890            0.0.0.0:*               LISTEN      1001       21290      2011/io.sonoff.0
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20009      1714/iobroker.js-co
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20002      1714/iobroker.js-co
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11197      1/init
                    tcp        0      0 0.0.0.0:42001           0.0.0.0:*               LISTEN      1001       20602      1854/io.hm-rpc.0
                    tcp        0      0 0.0.0.0:33875           0.0.0.0:*               LISTEN      0          13365      558/rpc.mountd
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13738      604/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:43735           0.0.0.0:*               LISTEN      0          13444      -
                    tcp        0      0 0.0.0.0:47865           0.0.0.0:*               LISTEN      0          13377      558/rpc.mountd
                    tcp        0      0 0.0.0.0:42010           0.0.0.0:*               LISTEN      1001       20706      1884/io.hm-rpc.2
                    tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      0          14274      666/sshd: root@pts/
                    tcp        0      0 127.0.0.1:6011          0.0.0.0:*               LISTEN      0          15227      761/sshd: root@pts/
                    tcp        0      0 127.0.0.1:6012          0.0.0.0:*               LISTEN      0          17904      1259/sshd: root@pts
                    tcp        0      0 0.0.0.0:8701            0.0.0.0:*               LISTEN      1001       20653      1869/io.hm-rpc.1
                    tcp6       0      0 :::2049                 :::*                    LISTEN      0          13435      -
                    tcp6       0      0 :::33799                :::*                    LISTEN      0          13446      -
                    tcp6       0      0 :::41517                :::*                    LISTEN      0          13384      558/rpc.mountd
                    tcp6       0      0 :::47949                :::*                    LISTEN      0          13371      558/rpc.mountd
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          11205      1/init
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20150      1741/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22050      2218/io.web.0
                    tcp6       0      0 :::41075                :::*                    LISTEN      0          13359      558/rpc.mountd
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          13760      604/sshd: /usr/sbin
                    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       22833      2414/io.fully-mqtt.
                    tcp6       0      0 ::1:6010                :::*                    LISTEN      0          14273      666/sshd: root@pts/
                    tcp6       0      0 :::8187                 :::*                    LISTEN      1001       22103      2229/io.simple-api.
                    tcp6       0      0 ::1:6011                :::*                    LISTEN      0          15226      761/sshd: root@pts/
                    tcp6       0      0 ::1:6012                :::*                    LISTEN      0          17903      1259/sshd: root@pts
                    tcp6       0      0 :::6556                 :::*                    LISTEN      0          13501      1/init
                    udp        0      0 0.0.0.0:40655           0.0.0.0:*                           1001       21832      2173/io.upnp.0
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11200      1/init
                    udp        0      0 0.0.0.0:32923           0.0.0.0:*                           0          13350      558/rpc.mountd
                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       22105      2173/io.upnp.0
                    udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          13434      -
                    udp        0      0 0.0.0.0:36843           0.0.0.0:*                           0          13362      558/rpc.mountd
                    udp        0      0 0.0.0.0:45422           0.0.0.0:*                           0          13374      558/rpc.mountd
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22249      2278/io.esphome.0
                    udp        0      0 0.0.0.0:47381           0.0.0.0:*                           0          13443      -
                    udp6       0      0 :::57273                :::*                                0          13380      558/rpc.mountd
                    udp6       0      0 :::111                  :::*                                0          11210      1/init
                    udp6       0      0 :::32953                :::*                                0          13445      -
                    udp6       0      0 :::2049                 :::*                                0          13436      -
                    udp6       0      0 :::51396                :::*                                0          13368      558/rpc.mountd
                    udp6       0      0 :::36744                :::*                                0          13356      558/rpc.mountd
                    2023-06-15 23:04:00.027  - info: host.iobroker instance system.adapter.ical.0 started with pid 2446
                    2023-06-15 23:04:01.158  - info: ical.0 (2446) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    2023-06-15 23:04:01.339  - info: ical.0 (2446) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.0, js-controller: 5.0.4
                    2023-06-15 23:04:01.945  - info: ical.0 (2446) processing URL: Geburtstage Marek https://nc.malcherek.com/remote.php/dav/calendars/Marek/geburtstage-marek?export
                    2023-06-15 23:04:02.077  - info: ical.0 (2446) processing URL: Geburtstage https://nc.malcherek.com/remote.php/dav/calendars/Marek/geburstage?export
                    2023-06-15 23:04:02.079  - info: ical.0 (2446) processing URL: Geburtstage von Kontakten https://nc.malcherek.com/remote.php/dav/calendars/Marek/contact_birthdays?export
                    2023-06-15 23:04:07.230  - info: ical.0 (2446) Terminated (NO_ERROR): Without reason
                    2023-06-15 23:04:07.761  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                    2023-06-15 23:05:09.945  - warn: ebus.0 (2359) no update since 2.3.2023, 01:00:43 cc.messages.Mode.lastup
                    2023-06-15 23:05:10.164  - warn: ebus.0 (2359) no update since 2.3.2023, 01:00:57 hwc.messages.Params.lastup
                    2023-06-15 23:05:10.281  - warn: ebus.0 (2359) no update since 2.3.2023, 01:00:44 mc.messages.Params.lastup
                    2023-06-15 23:05:10.770  - info: ebus.0 (2359) installed ebusd version is 23.1
                    2023-06-15 23:05:10.802  - info: ebus.0 (2359) all http done
                    2023-06-15 23:06:00.018  - info: host.iobroker instance system.adapter.ical.2 started with pid 2489
                    2023-06-15 23:06:00.320  - info: smartmeter.0 (1974) Error: No or too long answer from Serial Device after last request.
                    2023-06-15 23:06:00.320  - warn: smartmeter.0 (1974) No or too long answer from Serial Device after last request.
                    2023-06-15 23:06:01.261  - info: ical.2 (2489) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    2023-06-15 23:06:01.431  - info: ical.2 (2489) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.0, js-controller: 5.0.4
                    2023-06-15 23:06:02.417  - info: ical.2 (2489) processing URL: Conselite https://nc.malcherek.com/remote.php/dav/calendars/Marek/conselite-1?export
                    2023-06-15 23:06:03.647  - info: ical.2 (2489) processing URL: Mika https://nc.malcherek.eu/remote.php/dav/calendars/Marek/mika_shared_by_Mika?export
                    2023-06-15 23:06:03.648  - info: ical.2 (2489) processing URL: Kunde https://nc.malcherek.com/remote.php/dav/calendars/Marek/kunde-1?export
                    2023-06-15 23:06:03.939  - info: ical.2 (2489) processing URL: Masha https://nc.malcherek.eu/remote.php/dav/calendars/Marek/personal_shared_by_Masha?export
                    2023-06-15 23:06:04.196  - info: ical.2 (2489) processing URL: Marek https://nc.malcherek.com/remote.php/dav/calendars/Marek/marek?export
                    2023-06-15 23:06:09.433  - info: ical.2 (2489) Terminated (NO_ERROR): Without reason
                    2023-06-15 23:06:09.968  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
                    SUMMARY:
                                        v.2023-04-16
                    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                    Kernel:                 5.10.0-22-amd64
                    Installation:           kvm
                    Timezone:               Europe/Berlin (CEST, +0200)
                    User-ID:                0
                    X-Server:               false
                    Boot Target:            graphical.target
                    Pending OS-Updates:     0
                    Pending iob updates:    2
                    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                           /usr/bin/npm            9.5.1
                                           /usr/bin/npx            9.5.1
                    Recommended versions are nodejs 18.x.y and npm 9.x.y
                    MEMORY:
                    Mem:             11G        2.1G        9.0G        0.0K        905M        9.6G
                    Swap:           255M          0B        255M
                    Total:           12G        2.1G        9.2G
                    Active iob-Instances:   33
                    ioBroker Core:          js-controller           5.0.4
                                           admin                   6.5.8
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                27438
                    States:                 26557
                    Size of iob-Database:
                    16M     /opt/iobroker/iobroker-data/objects.json.migrated
                    16M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                    9.9M    /opt/iobroker/iobroker-data/states.jsonl
                    4.2M    /opt/iobroker/iobroker-data/states.json.migrated
                    4.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                      Thomas Braun Most Active @a200 last edited by
                      @a200 sagte in Javascript Stürtzt ab:
                      CPU threads: 2
                      Spendier dem Ding mal mehr PS.
                      root
                      Macht man nicht, als user anmelden.
                      Gute Wahl?
                      Und wenn du schon betatestest, warum dann keine aktuelle Version?
                      Die 7.0.8 interessiert keinen mehr.
                      Falses Release, du fährst ja ein bullseye, kein buster.
                      a200 1 Reply Last reply Reply Quote 0
                      • a200
                        a200 @Thomas Braun last edited by
                        CPU threads: 2
                        An Performance sollte es nicht liegen, kann ich aber gerne versuchen.
                        root
                        ist historisch gewachsen. Sollte aber auch keinen Einfluss haben. Werde ich ändern.
                        Gute Wahl?
                        WIe oben beschrieben 7.1.0 ging nicht, deshalb habe ich auf 7.0.8 downgegraded mit der Hoffnung, dass es laufen wird.
                        Auch nicht schlimm, die DB ist eh auf einem anderen Host. Die Instanz, die hier lief ist deaktiviert.
                        Summa summarum es gibt hier nichts wirklich böses, oder? Mein Web-Adapter schmiert auch ständig ab. Jetzt bleibt nur noch das hier:
                        javascript.0	2023-06-16 08:38:33.382	error	request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                        javascript.0	2023-06-16 08:38:33.381	error	deprecated
                        javascript.0	2023-06-16 08:38:33.380	error
                        javascript.0	2023-06-16 08:38:33.379	error	WARN
                        javascript.0	2023-06-16 08:38:33.378	error
                        javascript.0	2023-06-16 08:38:33.377	error	npm
                        javascript.0	2023-06-16 08:38:33.357	error	uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                        javascript.0	2023-06-16 08:38:33.356	error	deprecated
                        javascript.0	2023-06-16 08:38:33.355	error
                        javascript.0	2023-06-16 08:38:33.354	error	WARN
                        javascript.0	2023-06-16 08:38:33.353	error
                        javascript.0	2023-06-16 08:38:33.351	error	npm
                        javascript.0	2023-06-16 08:38:33.316	error	node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                        javascript.0	2023-06-16 08:38:33.314	error	deprecated
                        javascript.0	2023-06-16 08:38:33.313	error
                        javascript.0	2023-06-16 08:38:33.312	error	WARN
                        javascript.0	2023-06-16 08:38:33.311	error
                        javascript.0	2023-06-16 08:38:33.310	error	npm
                        javascript.0	2023-06-16 08:38:33.294	error	querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                        javascript.0	2023-06-16 08:38:33.292	error	deprecated
                        javascript.0	2023-06-16 08:38:33.291	error
                        javascript.0	2023-06-16 08:38:33.290	error	WARN
                        javascript.0	2023-06-16 08:38:33.289	error
                        javascript.0	2023-06-16 08:38:33.288	error	npm
                        javascript.0	2023-06-16 08:38:33.216	error	deprecated har-validator@5.1.5: this library is no longer supported
                        javascript.0	2023-06-16 08:38:33.215	error
                        javascript.0	2023-06-16 08:38:33.214	error	WARN
                        javascript.0	2023-06-16 08:38:33.212	error
                        javascript.0	2023-06-16 08:38:33.211	error	npm
                        host.iobroker	2023-06-16 08:40:45.186	error	instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        javascript.0	2023-06-16 08:40:45.074	info	terminating
                        javascript.0	2023-06-16 08:40:44.584	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        javascript.0	2023-06-16 08:40:44.584	debug	Plugin sentry destroyed
                        javascript.0	2023-06-16 08:40:44.584	info	terminating
                        javascript.0	2023-06-16 08:40:44.570	error	Debug Failure. Invalid cast. The supplied value [object Object] did not pass the test 'isIdentifier'.
                        javascript.0	2023-06-16 08:40:44.570	error	Error: Debug Failure. Invalid cast. The supplied value [object Object] did not pass the test 'isIdentifier'. at cast (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:1170:18) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111076:31) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114845:7) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at emitIdentifierName (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110984:7) at emitClassDeclarationOrExpression (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112891:9) at emitClassDeclaration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112873:7) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111243:20) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114845:7) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110978:7) at emitListItemWithParenthesizerRule (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115291:5) at emitNodeListItems (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114002:9) at emitNodeList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113941:9) at emitList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113899:7) at emitBlockStatements (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112494:7) at emitModuleBlock (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112989:7) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111253:20) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114845:7) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110978:7) at emitModuleDeclaration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112984:7) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111251:20) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114845:7) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110978:7) at emitListItemWithParenthesizerRule (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115291:5) at emitNodeListItems (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114002:9) at emitNodeList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113941:9) at emitList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113899:7) at emitSourceFileWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113579:7) at emitBodyWithDetachedComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114951:9) at emitSourceFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113507:9) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111074:16) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at print (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110923:7) at writeFile2 (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110907:7) at printFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110747:7) at Object.printNode (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110724:18) at transformGlobalDeclarations (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:501:31) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:1168:64) at processImmediate (node:internal/timers:478:21)
                        javascript.0	2023-06-16 08:40:44.570	error	unhandled promise rejection: Debug Failure. Invalid cast. The supplied value [object Object] did not pass the test 'isIdentifier'.
                        javascript.0	2023-06-16 08:40:44.570	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        mikeal created this issue in request/request
                        open Request’s Past, Present and Future #3142
                          Homoran Global Moderator Administrators @a200 last edited by Homoran
                          auch du bist im Beta-Test des controllers, bitte dort fragen
                            @a200
                            Wie historisch ist das? root login wird seit Jahrzehnten nicht mehr verwendet.
                            Und natürlich kann das einen Einfluss haben.
                              Sinn und Zweck eines Beta-Tests ist es ja nicht, dass du da ein laufendes System hast sondern das Fehler gefunden und in der Folge gefixt werden können.
                                das gab es vor kurzem schon mal hier irgendwo in einem Thread
                                  Das hat auch mit den iob-Instanzen nichts zu tun sondern mit den Paketen im Betriebssystem. Die Quellen müsssen passen, sonst ziehst du dir das System krumm.
                                    A Former User @crunchip last edited by
                                    @crunchip
                                    Hey. Ich habe auch die gleichen Probleme.
                                    Meinst du diesen hier?
                                    https://forum.iobroker.net/topic/66004/instance-javascript-0-stürzt-immer-ab
                                      Homoran Global Moderator Administrators @Guest last edited by
                                      @darkness_08 sagte in Javascript Stürtzt ab:
                                      auch die gleichen Beta-Versionen?
                                        A Former User @Homoran last edited by
                                        @homoran sagte in Javascript Stürtzt ab:
                                        Welche meinst du alle?
                                        Adapter    "javascript"   : 7.1.0    , installed 6.1.4  [Updatable]
                                        bei Javascript bin ich von 7.1.0 auf 6.1.4 zurück. Damit läuft es.
                                        Gebe aber zu ich habe keine Ahnung ob das so sinvoll war. Bin noch recht neu in iobroker und teste etwas.
                                        Bin vorgestern auf den "latest" Branch gewechselt, habe vorhin alle Adapter aktualisiert und verschiedene Probleme gehabt. Der den Rest konnte ich aber soweit lösen.
                                          Macht irgendwie wenig Sinn für einen Test von Software im Beta-Stand, oder?
                                            @darkness_08 du bist ebenfalls Betatester für den noch nicht fertigen Controller.
                                            ich mach jetzt hier zu!
                                            2044
