    4. js-controller 5.0.x jetzt in der BETA
    • Feuersturm
      Feuersturm @apollon77 last edited by
      @apollon77 mit einem Browser Cache löschen hat sich das Problem gelöst.
        fastfoot @MalleRalle last edited by
        @malleralle ja, gibt ein issue dazu und für controller 5.x nutzer auch einen Workaround
          fastfoot @foxriver76 last edited by
          @foxriver76 ja, tritt auch mit altem controller auf, issue gibt es schon
          https://github.com/ioBroker/ioBroker.javascript/issues/1340#issuecomment-1591811349
          MK-66 created this issue in ioBroker/ioBroker.javascript
          closed Export all scripts does not work since v7.0.5 #1340
          • Chaot
            Chaot last edited by Chaot
            Bei mir kommt eine Fehlermeldung deren Ursprung ich nicht so richtig lokalisieren kann:
            host.ioBroker
            2023-06-17 10:02:01.583	error	instance system.adapter.web.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            host.ioBroker
            2023-06-17 10:02:01.582	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
            host.ioBroker
            2023-06-17 10:02:01.582	error	Caught by controller[1]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1116:27)
            host.ioBroker
            2023-06-17 10:02:01.581	error	Caught by controller[1]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2415:15)
            host.ioBroker
            2023-06-17 10:02:01.580	error	Caught by controller[1]: Error: The pattern "io.Samstag<br>17.06.2023" is not a valid ID pattern
            host.ioBroker
            2023-06-17 10:02:01.574	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            web.0
            2023-06-17 10:02:00.667	error	The pattern "io.Samstag<br>17.06.2023" is not a valid ID pattern
            web.0
            2023-06-17 10:02:00.667	error	Error: The pattern "io.Samstag<br>17.06.2023" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2415:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1116:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
            web.0
            2023-06-17 10:02:00.506	error	unhandled promise rejection: The pattern "io.Samstag<br>17.06.2023" is not a valid ID pattern
            web.0
            2023-06-17 10:02:00.497	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            Hat jemand eine Idee wo diese ungültige ID Pattern stehen könnte? Habe ich die eventuell selbst eingebaut, weil ich in der VIS öfter mal mit Bindings gearbeitet habe?
            Wenn ich meinen VIS Editor aufrufe habe ich Verbindungsprobleme. Es Kommt immer die Einblendung "no connection" am oberen Rand. Edit: Browser refresh sollte man schon mal machen
            Edit2:
            Die Fehlermeldung ist erweitert:
            host.ioBroker
            2023-06-17 10:22:01.014	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.ioBroker
            2023-06-17 10:22:01.013	error	Caught by controller[1]: at processImmediate (node:internal/timers:476:21)
            host.ioBroker
            2023-06-17 10:22:01.013	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/ws-server/index.js:152:83)
            host.ioBroker
            2023-06-17 10:22:01.013	error	Caught by controller[1]: at Array.forEach (<anonymous>)
            host.ioBroker
            2023-06-17 10:22:01.013	error	Caught by controller[1]: at /opt/iobroker/node_modules/@iobroker/ws-server/index.js:152:100
            host.ioBroker
            2023-06-17 10:22:01.013	error	Caught by controller[1]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1556:43)
            host.ioBroker
            2023-06-17 10:22:01.012	error	Caught by controller[1]: at Object.commands.subscribe (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1356:25)
            host.ioBroker
            2023-06-17 10:22:01.012	error	Caught by controller[1]: at SocketCommands._subscribeStates (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:492:22)
            host.ioBroker
            2023-06-17 10:22:01.011	error	Caught by controller[1]: at SocketCommands.subscribe (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:267:13)
            host.ioBroker
            2023-06-17 10:22:01.011	error	Caught by controller[1]: at pattern2RegEx (/opt/iobroker/node_modules/@iobroker/adapter-core/build/controllerTools.js:94:44)
            host.ioBroker
            2023-06-17 10:22:01.011	error	Caught by controller[1]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2415:15)
            host.ioBroker
            2023-06-17 10:22:01.011	error	Caught by controller[1]: Error: The pattern "Samstag<br>17.06.2023" is not a valid ID pattern
            host.ioBroker
            2023-06-17 10:22:01.011	error	Caught by controller[0]: at processImmediate (node:internal/timers:476:21)
            host.ioBroker
            2023-06-17 10:22:01.010	error	Caught by controller[0]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/ws-server/index.js:152:83)
            host.ioBroker
            2023-06-17 10:22:01.010	error	Caught by controller[0]: at Array.forEach (<anonymous>)
            host.ioBroker
            2023-06-17 10:22:01.010	error	Caught by controller[0]: at /opt/iobroker/node_modules/@iobroker/ws-server/index.js:152:100
            host.ioBroker
            2023-06-17 10:22:01.010	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1556:43)
            host.ioBroker
            2023-06-17 10:22:01.010	error	Caught by controller[0]: at Object.commands.subscribe (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1356:25)
            host.ioBroker
            2023-06-17 10:22:01.010	error	Caught by controller[0]: at SocketCommands._subscribeStates (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:492:22)
            host.ioBroker
            2023-06-17 10:22:01.009	error	Caught by controller[0]: at SocketCommands.subscribe (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:267:13)
            host.ioBroker
            2023-06-17 10:22:01.009	error	Caught by controller[0]: at pattern2RegEx (/opt/iobroker/node_modules/@iobroker/adapter-core/build/controllerTools.js:94:44)
            host.ioBroker
            2023-06-17 10:22:01.009	error	Caught by controller[0]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2415:15)
            host.ioBroker
            2023-06-17 10:22:01.006	error	Caught by controller[0]: Error: The pattern "Samstag<br>17.06.2023" is not a valid ID pattern
            web.0
            2023-06-17 10:22:00.556	error	The pattern "Samstag<br>17.06.2023" is not a valid ID pattern
            web.0
            2023-06-17 10:22:00.555	error	Error: The pattern "Samstag<br>17.06.2023" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2415:15) at pattern2RegEx (/opt/iobroker/node_modules/@iobroker/adapter-core/build/controllerTools.js:94:44) at SocketCommands.subscribe (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:267:13) at SocketCommands._subscribeStates (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:492:22) at Object.commands.subscribe (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1356:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.ws/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1556:43) at /opt/iobroker/node_modules/@iobroker/ws-server/index.js:152:100 at Array.forEach (<anonymous>) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/ws-server/index.js:152:83) at processImmediate (node:internal/timers:476:21)
            web.0
            2023-06-17 10:22:00.547	error	uncaught exception: The pattern "Samstag<br>17.06.2023" is not a valid ID pattern
            • foxriver76
              foxriver76 Developer @Chaot last edited by
              @chaot Bitte mal allgemein jemand das Issue im Web Adapter melden, dass der bei sowas nicht mehr crasht.
              Ansonsten ja im Falle von @Feuersturm war es auch ein selbst erstelltes Binding, das aus Versehen die kompeltte Logik als ID hatte. Also einerseits schön, weil so auffällt, dass ein Binding kaputt ist, aber hart crashen sollte Adapter nicht.
              Feuersturm Chaot apollon77 4 Replies Last reply Reply Quote 1
              • Feuersturm
                Feuersturm @foxriver76 last edited by
                @foxriver76 sagte in js-controller 5.0.x jetzt in der BETA:
                Braucht ihr noch ein issue dafür beim Web Adapter?
                • foxriver76
                  @feuersturm Ja bitte gg
                  • Chaot
                    Chaot @foxriver76 last edited by
                    @foxriver76 Danke.
                    Das fehlerhafte binding habe ich mittlerweile lokalisiert:
                    {javascript.0.variables.dayTime.lc;momentDate(dddd)}<br>{javascript.0.variables.dayTime.lc;momentDate(DD.MM.YYYY)}
                    Komischerweise läuft das andere Binding in der zweiten View ohne Probleme, obwohl es (fast) gleich ist:
                    {javascript.0.variables.dayTime.lc;momentDate(dd)}  {javascript.0.variables.dayTime.lc;momentDate(DD.MM.YYYY)}
                    • mcm1957
                      mcm1957 @Chaot last edited by
                      @apollon77
                      Update für Problemliste:
                      linux-control scheint ein Problem zu haben:
                      https://github.com/Scrounger/ioBroker.linux-control/issues/49
                      Für stiebel-isg und pi-hole dürfte es Updates geben:
                      Im latest verfügbar (spätestens morgen), stable pending (kurze Karenzzeit erscheint sinnvoll)
                      https://github.com/ioBroker/ioBroker.repositories/pull/2367
                      Strobelix80 created this issue in Scrounger/ioBroker.linux-control
                      closed Error with js-controller 5.x #49
                      unltdnetworx created this issue in ioBroker/ioBroker.repositories
                      closed Update sources-dist-stable.json - pi-hole and stiebel-isg #2367
                      • skvarel
                        skvarel Developer last edited by
                        Moin zusammen.
                        bei mir crashed der Web Adpater. Ich werde aus dem Log nicht schlau 😞
                        Alle Adapter sind Beta, js-controller 5.0.4, Node 18.16.0
                        skvarel 1 Reply Last reply Reply Quote 0
                        • skvarel
                          skvarel Developer @skvarel last edited by skvarel
                          Es scheint an irgendwelchen Widgets zu liegen.
                          @skvarel sagte in js-controller 5.0.x jetzt in der BETA:
                          Moin zusammen.
                          M DJMarc75 2 Replies Last reply Reply Quote 0
                            Marty56 @skvarel last edited by
                            Ich habe gerade diesen "Alias Error Burst" bekommen.
                            Schade, es scheint das js-controller 5 hier nicht geholfen hat.
                            • DJMarc75
                              DJMarc75 @skvarel last edited by
                              @skvarel Texte in Codetags packen bitte.
                              • Feuersturm
                                @Chaot Du kannst dich mit deinem Problem mit an dieses issue hängen: https://github.com/ioBroker/ioBroker.web/issues/316
                                Feuer-sturm created this issue in ioBroker/ioBroker.web
                                closed unvalid binding in vis crashes web adapter with jjs-controller 5.0.4 #316
                                • foxriver76
                                  Controller v5.0.5 wird zeitnah verfügbar sein:
                                  • Probleme mit falschem Loglevel bei Beenden von Adaptern behoben
                                  • UI Upgrade wird nur noch angeboten, wenn das Betriebssystem dies unterstützt (das heißt aktuell: nativ Linux oder offizielles ioBroker Docker Image)
                                  • UI Upgrade für offizielles Docker Image eingebaut
                                  • Probleme mit dem Aufruf von deleteState in manchen Konstellationen behoben, was zB verhindert hat Geräte in Zigbee zu löschen
                                  dontobi 1 Reply Last reply Reply Quote 4
                                  • Feuersturm
                                    Feuersturm last edited by Feuersturm
                                    @foxriver76 Ich hab gerade meinen Master erfolgreich über die Admin GUI auf 5.0.5 aktualisiert.
                                    Als ich jetzt im nächsten Schritt meinen Slave über die Admin GUI aktualisiseren wollte kam folgende Fehlermeldung:
                                    Das Update scheint aber erfolgreich gewesen zu sein. Über die Konsole meldet sich ioBroker mit der Version 5.0.5 sowie auch in der Admin UI.
                                    Das steht im Log vom Slave
                                    2023-06-18 16:52:15.022 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                                    2023-06-18 16:52:15.134 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                                    2023-06-18 16:52:20.037 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                                    2023-06-18 16:52:20.140 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                                    2023-06-18 16:52:25.045 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                                    2023-06-18 16:52:25.147 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                                    2023-06-18 16:52:30.050 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                                    2023-06-18 16:52:30.153 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                                    2023-06-18 16:52:35.058 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                                    2023-06-18 16:52:35.158 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                                    2023-06-18 16:52:40.071 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                                    2023-06-18 16:52:40.163 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                                    2023-06-18 16:52:45.080 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                                    2023-06-18 16:52:45.170 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                                    2023-06-18 16:52:50.087 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                                    2023-06-18 16:52:50.180 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                                    2023-06-18 16:52:55.092 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                                    2023-06-18 16:52:55.187 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                                    2023-06-18 16:53:00.102 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                                    2023-06-18 16:53:00.194 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                                    2023-06-18 16:53:05.116 - info: host.ioBrokerNew Objects database successfully reconnected
                                    2023-06-18 16:53:05.201 - info: host.ioBrokerNew Objects database successfully reconnected
                                    2023-06-18 16:53:13.922 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                                    2023-06-18 16:53:14.033 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                                    2023-06-18 16:53:18.929 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                                    2023-06-18 16:53:19.046 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                                    2023-06-18 16:53:23.935 - info: host.ioBrokerNew Objects database successfully reconnected
                                    2023-06-18 16:53:24.052 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                                    2023-06-18 16:53:29.064 - info: host.ioBrokerNew Objects database successfully reconnected
                                    2023-06-18 16:58:12.225 - info: host.ioBrokerNew Controller will upgrade itself to version 5.0.5
                                    2023-06-18 16:58:16.320 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Stopping controller
                                    2023-06-18 16:58:16.437 - info: host.ioBrokerNew received SIGTERM
                                    2023-06-18 16:58:16.443 - info: host.ioBrokerNew stopInstance system.adapter.history.1 (force=false, process=false)
                                    2023-06-18 16:58:16.444 - info: host.ioBrokerNew stopInstance system.adapter.sql.0 (force=false, process=false)
                                    2023-06-18 16:58:16.445 - info: host.ioBrokerNew stopInstance system.adapter.discovery.0 (force=false, process=false)
                                    2023-06-18 16:58:16.492 - info: host.ioBrokerNew terminated
                                    2023-06-18 16:58:20.638 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
                                    2023-06-18 16:58:20.655 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
                                    2023-06-18 16:58:57.178 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE]
                                    changed 12 packages in 34s
                                    81 packages are looking for funding
                                    run `npm fund` for details
                                    2023-06-18 16:59:07.193 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Timeout expired, initializing shutdown
                                    2023-06-18 16:59:07.286 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Successfully started js-controller
                                    2023-06-18 16:59:09.687 - info: host.ioBrokerNew iobroker.js-controller version 5.0.5 js-controller starting
                                    2023-06-18 16:59:09.699 - info: host.ioBrokerNew Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                    2023-06-18 16:59:09.702 - info: host.ioBrokerNew hostname: ioBrokerNew, node: v18.16.0
                                    2023-06-18 16:59:09.704 - info: host.ioBrokerNew ip addresses: 192.168.178.78 fe80::d4a0:37ff:fe8e:f0c1
                                    2023-06-18 16:59:10.347 - info: host.ioBrokerNew connected to Objects and States
                                    2023-06-18 16:59:10.391 - info: host.ioBrokerNew added notifications configuration of host
                                    2023-06-18 16:59:11.478 - info: host.ioBrokerNew 61 instances found
                                    2023-06-18 16:59:11.603 - warn: host.ioBrokerNew does not start any instances on this host
                                    Edit: Github issue: https://github.com/ioBroker/ioBroker.admin/issues/1963
                                    Feuer-sturm created this issue in ioBroker/ioBroker.admin
                                    closed Updating js-controller 5.x on Slave over admin "TypeError: Network Error when attempting to fetch ressource" #1963
                                    • foxriver76
                                      foxriver76 Developer @Feuersturm last edited by
                                      @feuersturm danke schaue ich mir mit BF an. Läuft der Admin von dem aus das gestartet wurde auf Master oder Slave? Hat das vorher schon auf Slave mal sauber funktioniert. Logfile selbst schaut sehr gut aus.
                                      • Feuersturm
                                        @foxriver76 der Admin läuft auf dem Master von dem das Update gestartet wurde. Den slave habe ich bisher immer über die Konsole aktualisiert und nicht über die gui.
                                        • foxriver76
                                          @feuersturm danke für die Info. Ich vermute Admin fragt immer lokal an auch wenn auf anderem Host aktualisiert wird. Muss voraussichtlich in Admin gefixt werden. Schauen wir uns an. 👍🏼
                                            crunchip Forum Testing Most Active @foxriver76 last edited by crunchip
                                            @foxriver76 Update wieder per admin mit anschließendem Browser refresh
                                            sieht nun besser aus, aber bei mir hat der shelly nach wie vor Probleme, hatte ich schon mal ne zeitlang, werd ich wohl ggf issue wieder eröffnen
                                            2023-06-18 22:14:20.204 - info: host.IoBroker stopInstance system.adapter.countdown.0 send kill signal
                                            2023-06-18 22:14:20.205 - info: host.IoBroker stopInstance system.adapter.tibberconnect.0 send kill signal
                                            2023-06-18 22:14:20.205 - info: host.IoBroker stopInstance system.adapter.opendtu.0 send kill signal
                                            2023-06-18 22:14:20.420 - info: mytime.0 (1104559) terminating with timeout
                                            2023-06-18 22:14:20.423 - info: virtualpowermeter.0 (1105082) terminating
                                            2023-06-18 22:14:20.784 - warn: sonoff.0 (1103739) redis get sonoff.0.PC-Server.alive, error - Connection is closed.
                                            2023-06-18 22:14:20.793 - warn: sonoff.0 (1103739) get state error: Connection is closed.
                                            2023-06-18 22:14:20.794 - warn: sonoff.0 (1103739) redis get sonoff.0.PC-Server.alive, error - DB closed
                                            2023-06-18 22:14:20.757 - warn: shelly.0 (1103714) get state error: Connection is closed.
                                            2023-06-18 22:14:20.767 - error: shelly.0 (1103714) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                            2023-06-18 22:14:20.769 - error: shelly.0 (1103714) unhandled promise rejection: DB closed
                                            2023-06-18 22:14:20.973 - error: shelly.0 (1103714) Error: DB closed
                                            at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                            at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                            at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
                                            at Shelly._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7585:34)
                                            2023-06-18 22:14:20.974 - error: shelly.0 (1103714) DB closed
                                            2023-06-18 22:14:21.132 - warn: sonoff.0 (1103739) get state error: Connection is closed.
                                            2023-06-18 22:14:21.173 - warn: sonoff.0 (1103739) get state error: Connection is closed.
                                            2023-06-18 22:14:21.175 - warn: sonoff.0 (1103739) get state error: Connection is closed.
                                            2023-06-18 22:14:21.316 - info: host.IoBroker stopInstance system.adapter.admin.0 killing pid 1103011
                                            2023-06-18 22:14:21.349 - warn: opendtu.0 (1105739) Cannot get view: Connection is closed.
                                            2023-06-18 22:14:21.316 - info: host.IoBroker stopInstance system.adapter.javascript.0 killing pid 1103278
                                            2023-06-18 22:14:21.317 - info: host.IoBroker stopInstance system.adapter.telegram.0 killing pid 1727115
                                            2023-06-18 22:14:27.599 - warn: host.IoBroker instance system.adapter.net-tools.0 terminated due to SIGTERM
                                            2023-06-18 22:14:27.599 - info: host.IoBroker instance system.adapter.net-tools.0 terminated with code null ()
                                            2023-06-18 22:14:27.692 - warn: host.IoBroker instance system.adapter.nut.0 terminated due to SIGTERM
                                            2023-06-18 22:14:27.693 - info: host.IoBroker instance system.adapter.nut.0 terminated with code null ()
                                            2023-06-18 22:14:27.795 - error: host.IoBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                            2023-06-18 22:14:27.796 - error: host.IoBroker Caught by controller[0]: Error: DB closed
                                            2023-06-18 22:14:27.797 - error: host.IoBroker Caught by controller[0]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                            2023-06-18 22:14:27.798 - error: host.IoBroker Caught by controller[0]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                            2023-06-18 22:14:27.798 - error: host.IoBroker Caught by controller[0]: at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
                                            2023-06-18 22:14:27.799 - error: host.IoBroker Caught by controller[0]: at Shelly._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7585:34)
                                            2023-06-18 22:14:27.799 - warn: host.IoBroker instance system.adapter.shelly.0 terminated due to SIGTERM
                                            ansonsten
                                            2023-06-18 22:14:31.618 - info: host.IoBroker All instances are stopped.
                                            2023-06-18 22:14:31.652 - info: host.IoBroker terminated
                                            2023-06-18 22:14:36.282 - info: host.IoBroker [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
                                            2023-06-18 22:14:36.290 - info: host.IoBroker [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
                                            2023-06-18 22:15:30.526 - info: host.IoBroker [CONTROLLER_AUTO_UPGRADE]
                                            changed 12 packages in 53s
                                            226 packages are looking for funding
                                            2023-06-18 22:15:31.506 - info: host.IoBroker [CONTROLLER_AUTO_UPGRADE] Final information delivered
                                            2023-06-18 22:15:39.805 - info: host.IoBroker [CONTROLLER_AUTO_UPGRADE] Successfully started js-controller
                                            2023-06-18 22:15:40.972 - info: host.IoBroker iobroker.js-controller version 5.0.5 js-controller starting
                                            2023-06-18 22:15:40.978 - info: host.IoBroker Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                            2023-06-18 22:15:40.979 - info: host.IoBroker hostname: IoBroker, node: v18.16.0
                                            2023-06-18 22:15:40.980 - info: host.IoBroker ip addresses: 10.1.1.10 fe80::d428:e1ff:fe76:b484
                                            2023-06-18 22:15:44.891 - info: host.IoBroker connected to Objects and States
                                            2023-06-18 22:15:45.021 - info: host.IoBroker added notifications configuration of host
                                            2023-06-18 22:15:46.309 - info: host.IoBroker Delete state "system.host.IoBroker.versions.nodeCurrent"
                                            2023-06-18 22:15:46.360 - info: host.IoBroker 139 instances found
                                            2023-06-18 22:15:46.490 - info: host.IoBroker starting 57 instances
                                            2023-06-18 22:15:46.764 - info: host.IoBroker Delete state "system.host.IoBroker.versions.nodeNewest"
                                            2023-06-18 22:15:46.772 - info: host.IoBroker Delete state "system.host.IoBroker.versions.nodeNewestNext"
                                            2023-06-18 22:15:46.778 - info: host.IoBroker Delete state "system.host.IoBroker.versions.npmCurrent"
                                            2023-06-18 22:15:46.852 - info: host.IoBroker instance system.adapter.admin.0 started with pid 3026764
                                            2023-06-18 22:15:46.861 - info: host.IoBroker Delete state "system.host.IoBroker.versions.npmNewest"
                                            2023-06-18 22:15:46.908 - info: host.IoBroker Delete state "system.host.IoBroker.versions.npmNewestNext"
                                            2023-06-18 22:15:46.914 - info: host.IoBroker Some obsolete host states deleted.
                                            2023-06-18 22:15:49.609 - info: admin.0 (3026764) starting. Version 6.5.8 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 5.0.5
                                            2023-06-18 22:15:49.659 - info: admin.0 (3026764) requesting all states
                                            2023-06-18 22:15:49.660 - info: admin.0 (3026764) requesting all objects
                                            2023-06-18 22:15:52.077 - info: host.IoBroker instance system.adapter.history.0 started with pid 3026791
                                            2023-06-18 22:15:52.838 - info: admin.0 (3026764) received all objects
                                            2023-06-18 22:15:53.252 - info: admin.0 (3026764) Request actual repository...
                                            2023-06-18 22:15:53.281 - info: admin.0 (3026764) socket.io server listening on port 8081
                                            2023-06-18 22:15:53.284 - info: admin.0 (3026764) http server listening on port 8081
                                            2023-06-18 22:15:53.285 - info: admin.0 (3026764) Use link "http://127.0.0.1:8081" to configure.
                                            580
                                            185554
