    4. Support Adapter Energiefluss-erweitert v0.7.7
      @SKB
      SORRY!!
      host.iobroker-VM03
      	2023-06-15 11:24:12.944	error	instance system.adapter.energiefluss-erweitert.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
      	2023-06-15 11:24:12.191	error	Cannot read property 'id' of undefined
      	2023-06-15 11:24:12.191	error	TypeError: Cannot read property 'id' of undefined at EnergieflussErweitert.onStateChange (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:154:45) at EnergieflussErweitert.emit (events.js:400:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5712:38) at processImmediate (internal/timers.js:464:21)
      	2023-06-15 11:24:12.191	error	uncaught exception: Cannot read property 'id' of undefined
      	2023-06-15 11:24:12.189	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      	2023-06-15 11:24:12.187	error	Cannot read property 'id' of undefined
      	2023-06-15 11:24:12.186	error	TypeError: Cannot read property 'id' of undefined at EnergieflussErweitert.onStateChange (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:154:45) at EnergieflussErweitert.emit (events.js:400:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5712:38) at processImmediate (internal/timers.js:464:21)
      	2023-06-15 11:24:12.186	error	uncaught exception: Cannot read property 'id' of undefined
      	2023-06-15 11:24:12.172	error	Cannot read property 'id' of undefined
      	2023-06-15 11:24:12.171	error	TypeError: Cannot read property 'id' of undefined at EnergieflussErweitert.onStateChange (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:154:45) at EnergieflussErweitert.emit (events.js:400:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5712:38) at processImmediate (internal/timers.js:464:21)
      	2023-06-15 11:24:12.169	error	uncaught exception: Cannot read property 'id' of undefined
      host.iobroker-VM03
      	2023-06-15 11:02:55.204	error	instance system.adapter.energiefluss-erweitert.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
      	2023-06-15 11:02:54.344	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      	2023-06-15 11:02:54.338	error	Cannot read property 'id' of undefined
      	2023-06-15 11:02:54.338	error	TypeError: Cannot read property 'id' of undefined at EnergieflussErweitert.onStateChange (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:154:45) at EnergieflussErweitert.emit (events.js:400:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5712:38) at processImmediate (internal/timers.js:464:21)
      	2023-06-15 11:02:54.337	error	uncaught exception: Cannot read property 'id' of undefined
      	2023-06-15 11:02:54.326	error	Cannot read property 'id' of undefined
      	2023-06-15 11:02:54.326	error	TypeError: Cannot read property 'id' of undefined at EnergieflussErweitert.onStateChange (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:154:45) at EnergieflussErweitert.emit (events.js:400:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5712:38) at processImmediate (internal/timers.js:464:21)
      	2023-06-15 11:02:54.325	error	uncaught exception: Cannot read property 'id' of undefined
      	2023-06-15 11:02:54.317	error	Cannot read property 'id' of undefined
      	2023-06-15 11:02:54.317	error	TypeError: Cannot read property 'id' of undefined at EnergieflussErweitert.onStateChange (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:154:45) at EnergieflussErweitert.emit (events.js:400:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5712:38) at processImmediate (internal/timers.js:464:21)
      	2023-06-15 11:02:54.314	error	uncaught exception: Cannot read property 'id' of undefined
      Ich hab 4 neue sources angelegt und 4 neue Datenpunkte (Text with Datasource).
      leider erst später in das log gesehen 😢
      Was kann ich dir jetzt schicken?
      • SKB
        SKB Developer Most Active @Homoran last edited by SKB
        @homoran Es würde mir helfen, wenn Du kurz die Schritte beschreiben könntest.
        Also, Text with Datasource auf den Workspace gelegt - wie ging es dann weiter?
        Direkt gespeichert - oder etwas zugewiesen?
          Homoran Global Moderator Administrators @SKB last edited by Homoran
          @skb sagte in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
          würde mir auch helfen 😁
          Soweit ich mich erinnern kann:
          • 2 sources angelegt
          • 2 "Datenpunkte" angelegt und jeweils sofort Sources zugewiesen, Farben, Ausrichtung Position und Nachkommastellen zugewiesen
          • save and exit
          • erneut editiert
          • erst jetzt finetuning der Positionen, da aus Datasourcexxx jetzt erst der Wert entstanden ist.
          • save&exit
          Anschließend das selbe nochmal mit 2 weiteren Sources
            @SKB
            tut mir leid, ich hab es bis jetzt nicht wieder reproduziert bekommen.
            Jedenfalls nicht, indem ich jetzt nach jedem Schritt gespeichert und dann im log nachgesehen habe.
            ich bleib dran!
              erwini last edited by
              Habe den energiefluss adapter in Betrieb und bin nun auf diesen Adapter gestolpert und will diesen nun ausprobieren.
              Installiert mit
              npm install https://github.com/SKB-CGN/ioBroker.energiefluss-erweitert
              added 4 packages in 8s
              und
              iob upload energiefluss-erweitert
              No alive host found which has the adapter energiefluss-erweitert installed! No upload possible. Skipped.
              Als normaler user (nicht root).
              Was habe ich vergessen ? Kenne die Feinheiten von iobroken da noch nicht gut genug.
              • BananaJoe
                @erwini warum auch immer du den Adapter über die CLI statt GUI installierst:
                Du musst noch eine Instanz hinzufügen:
                Also in die Adapter Ansicht, die Kachel des Energiefluss - erweitert suchen, auf die 3 ... klicken das die Kachel sich umdreht und dann auf das + unten links.
                Danach taucht der Adapter unterhalb von Instanzen links auf und ist nutzbar sofern dieser gestartet ist.
                Den CLI Befehl dafür habe ich gerade nicht parat.
                  erwini @BananaJoe last edited by
                  @bananajoe said in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
                  Mhh, weil der in der Adapterliste nicht auftaucht ... warum auch immer. Deswegen via CLI. Und er taucht in der Adpaterliste immer noch nicht auf nach dem
                  npm install ....
                    Thomas Braun Most Active @erwini last edited by
                    @erwini
                    In welchem Verzeichnis hast du gestanden?
                    npm Kommandos müssen in /opt/iobroker ausgeführt werden.
                      erwini @Thomas Braun last edited by
                      @thomas-braun said in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
                      Das war der Trick. Dann fragt er auch nach dem root/sudo pw. Dann noch den iob update hinterher und schon ist er als Adapter sichtbar. Dann nur noch eine Instanz via GUI erzeugen. Dann kann es ja mal losgehen mit probieren ;-).
                      Besten Dank (war fast zu einfach 😞 )
                        Thomas Braun Most Active @erwini last edited by Thomas Braun
                        @erwini sagte in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
                        Das ist falsch. Bei richtigem Setup (dein User ist in der Gruppe 'iobroker') wird nicht danach gefragt.
                          Ist er:
                          erwini@io:/opt/iobroker$ groups
                          erwini sudo iobroker
                            @erwini
                            Da stimmt dennoch irgendwas nicht. Jag den fixer über deine Installation.
                              Das sieht verdächtig aus, das da was nicht stimmt(e):
                                  Checking ioBroker user and directory permissions (2/5)
                              Created /etc/sudoers.d/iobroker
                              Fixing directory permissions...
                              Vorher iob stop gemacht und wieder gestartet ..
                              • O
                                oxident last edited by
                                @SKB Gratulation zu diesem tollen Adapter. Ist wirklich genial.
                                Ich würde aber auch gerne mein "+1" für die Möglichkeit zum Kopieren oder Duplizieren von Elementen abgeben. Auch ein Gruppieren wäre toll.
                                Wurde schon vorgeschlagen, ich weiß 😉
                                So sieht's momentan bei mir aus:
                                • BananaJoe
                                  Weil der Adapter noch sehr neu und noch nicht fertig ist. Und somit noch nicht in der offiziellen Liste aufgeführt wird.
                                  Installiert wird über die Katze. - Adapter Übersicht, oben auf Expertenansicht umschalten, eine Reihe tiefer erscheint dann die Katze:
                                  Wenn man darauf klickt geht ein neues Fenster auf, oben lassen sich 3 Reiter wählen, bei dem ganz rechts kann man dann die GitHub-Adresse reinkopieren.
                                  • SKB
                                    SKB Developer Most Active @oxident last edited by
                                    @oxident das freut mich doch, wenn die Arbeit Früchte trägt 😉
                                    Deinen Vorschlag nehme ich mit auf die Liste.
                                    Ich denke, markieren mit Lasso (mehrere) oder per Klick auswählen und dann "Duplicate" drücken, ist der gewünschte Weg, oder?
                                    • O
                                      oxident @SKB last edited by
                                      @skb Perfekt ... oder einfach "Kopieren/Einfügen". Das würde bestimmt reichen 😉
                                      • SKB
                                        @oxident ich denke, ein Duplicate ist einfacher.
                                        • O
                                          @skb Du bist der Boss 😊
                                          • SKB
                                            @oxident ich richte mich nach Euch 🙂
                                            Hast du einen Vorschlag, wie die Elemente dann positioniert werden, wenn sie dupliziert wurden?
                                            81.1k
                                            vis
                                            191
                                            4317
                                            5639833
