Wolf-Adapter
{ "type": "state", "common": { "name": "Sollwertkorrektur", "role": "tempd", "type": "number", "read": true, "write": true, "unit": "K", "min": 0, "max": 1000 }, "native": { "rw": "rw" }, "from": "system.adapter.wolf.0", "user": "system.user.admin", "ts": 1672929210388, "_id": "wolf.0.bm2_t.78", "acl": { "object": 1636, "state": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator" } }
jetzt hab ichs
@nr5lebt sagte in Wolf-Adapter:
@sigi234 RAW?
Moin,
soweit ich das hier sehe, solltest Du mal von den Dreien die RAW Daten zeigen, also vom DP 65, 70, 78
VG
Bernd -
@dp20eic dp 65
{ "type": "state", "common": { "name": "Sollwertkorrektur", "role": "tempd", "type": "number", "read": true, "write": true, "unit": "K", "min": 0, "max": 1000 }, "native": { "rw": "rw" }, "from": "system.adapter.wolf.0", "user": "system.user.admin", "ts": 1672929207738, "_id": "wolf.0.bm1_t.65", "acl": { "object": 1636, "state": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator" } }
dp 70
{ "type": "state", "common": { "name": "Programmwahl Mischer", "role": "hvacmode", "type": "string", "read": true, "write": true, "unit": "" }, "native": { "rw": "rw" }, "from": "system.adapter.wolf.0", "user": "system.user.admin", "ts": 1672929210365, "_id": "wolf.0.bm2_t.70", "acl": { "object": 1636, "state": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator" } }
dp 78
@nr5lebt So prinzipiell solltest Du auch mal Dein System auf den Stand bringen und (auch in Codetags) die Ausgabe von
iob diag
posten
Skript v.2023-04-16 *** BASE SYSTEM *** Architecture : x86_64 Docker : false Virtualization : none Distributor ID: Debian Description: Debian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye PRETTY_NAME="Debian GNU/Linux 11 (bullseye)" NAME="Debian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" Systemuptime and Load: 14:35:48 up 2 days, 5:14, 1 user, load average: 0.60, 0.71, 0.74 CPU threads: 4 *** Time and Time Zones *** Local time: Sun 2023-06-18 14:35:48 CEST Universal time: Sun 2023-06-18 12:35:48 UTC RTC time: Sun 2023-06-18 12:35:48 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** root /root root *** X-Server-Setup *** X-Server: false Desktop: Terminal: Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 7.7G 4.6G 1.1G 730M 2.1G 2.1G Swap: 975M 957M 18M Total: 8.7G 5.6G 1.1G 7735 M total memory 4608 M used memory 1246 M active memory 4733 M inactive memory 1064 M free memory 68 M buffer memory 1993 M swap cache 975 M total swap 957 M used swap 18 M free swap *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.8G 0 3.8G 0% /dev tmpfs tmpfs 774M 1.9M 772M 1% /run /dev/sda1 ext4 116G 21G 90G 19% / tmpfs tmpfs 3.8G 84K 3.8G 1% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 3.8G 0 3.8G 0% /tmp folder2ram tmpfs 3.8G 995M 2.9G 26% /var/log /dev/md127 ext4 1.8T 278G 1.6T 16% /srv/dev-disk-by-uuid-116af1e4-0bfa-4ac3-a48b-327907662441 folder2ram tmpfs 3.8G 0 3.8G 0% /var/tmp folder2ram tmpfs 3.8G 1008K 3.8G 1% /var/lib/openmediavault/rrd folder2ram tmpfs 3.8G 18M 3.8G 1% /var/spool folder2ram tmpfs 3.8G 15M 3.8G 1% /var/lib/rrdcached folder2ram tmpfs 3.8G 4.0K 3.8G 1% /var/lib/monit folder2ram tmpfs 3.8G 28K 3.8G 1% /var/cache/samba shm tmpfs 63M 0 63M 0% /var/lib/containers/storage/overlay-containers/4e0d9ded34cc2e6c672a02b3309d03c6832516516cf0e303126795eeb462533a/userdata/shm overlay overlay 116G 21G 90G 19% /var/lib/containers/storage/overlay/40b137ba6c08353a4570a7d8a784067efd395d7c74c881aec99c85f39d5e5c9c/merged shm tmpfs 63M 0 63M 0% /var/lib/containers/storage/overlay-containers/5bf65afcaa05073f272555dcc1a913c7509d27808139211b4fce220ac3dc2e7b/userdata/shm overlay overlay 116G 21G 90G 19% /var/lib/containers/storage/overlay/27dfa1731b5158a54103d096586a96a5332611d26366612fa3ee9f076c4b9c71/merged overlay overlay 116G 21G 90G 19% /var/lib/containers/storage/overlay/ab0d2792a47c4be6b2df9649da20e3dde1f6433dc3542456dcef1b85160f91c8/merged overlay overlay 116G 21G 90G 19% /var/lib/containers/storage/overlay/9561cc61f5a53870d89ca92c6774b4f0ae931a68d38c80c78606ddd43a561d2d/merged overlay overlay 116G 21G 90G 19% /var/lib/docker/overlay2/4921e2522b52f301b490dec6ff8c235cbeb2d50d84008ff204c2add25f1771c7/merged overlay overlay 116G 21G 90G 19% /var/lib/docker/overlay2/a600b065040eb82692c3ded70ad42513e47fd0e8d996185a43529d9a3ec06005/merged overlay overlay 116G 21G 90G 19% /var/lib/docker/overlay2/f7ac1d87fb43c0a93cc4d137a28e83555a32068e4432d7c941e181d1ed4780eb/merged overlay overlay 116G 21G 90G 19% /var/lib/docker/overlay2/663f35293b46f570fefafb88f5931ef3653ccffc45cde9b846a9a2a80732f74b/merged overlay overlay 116G 21G 90G 19% /var/lib/docker/overlay2/81f521fdac9199fbc133e395ccd93164ba2d315f6e236f2b9eb8279f4b001775/merged overlay overlay 116G 21G 90G 19% /var/lib/docker/overlay2/af63d07382d628fad9e0c7b713a02eff4f6a868619de209145da63f09dcac9eb/merged overlay overlay 116G 21G 90G 19% /var/lib/docker/overlay2/430cf55bf10346a53689604e1da7193f9c9ec3844408c8dd76c4b9b3d74c1eba/merged overlay overlay 116G 21G 90G 19% /var/lib/docker/overlay2/b54a593f85dbb2040c3c81b2d11ac860e70443800813174d0175c64b2ea08f1a/merged Messages concerning ext4 filesystem in dmesg: [Fri Jun 16 09:21:14 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none. [Fri Jun 16 09:21:15 2023] EXT4-fs (sda1): re-mounted. Quota mode: none. [Fri Jun 16 09:21:16 2023] EXT4-fs (md127): mounted filesystem with ordered data mode. Quota mode: journalled. Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro |-/var/folder2ram/var/log /dev/sda1[/var/log] ext4 rw,relatime,errors=remount-ro |-/srv/dev-disk-by-uuid-116af1e4-0bfa-4ac3-a48b-327907662441 /dev/md127 ext4 rw,relatime,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group |-/var/folder2ram/var/tmp /dev/sda1[/var/tmp] ext4 rw,relatime,errors=remount-ro |-/var/folder2ram/var/lib/openmediavault/rrd /dev/sda1[/var/lib/openmediavault/rrd] ext4 rw,relatime,errors=remount-ro |-/var/folder2ram/var/spool /dev/sda1[/var/spool] ext4 rw,relatime,errors=remount-ro |-/var/folder2ram/var/lib/rrdcached /dev/sda1[/var/lib/rrdcached] ext4 rw,relatime,errors=remount-ro |-/var/folder2ram/var/lib/monit /dev/sda1[/var/lib/monit] ext4 rw,relatime,errors=remount-ro |-/var/folder2ram/var/cache/samba /dev/sda1[/var/cache/samba] ext4 rw,relatime,errors=remount-ro `-/var/lib/containers/storage/overlay /dev/sda1[/var/lib/containers/storage/overlay] ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 19G /var/ 17G /var/lib 16G /var/lib/docker 11G /var/lib/docker/overlay2 5.1G /var/lib/docker/volumes/7cc5ad14a4feac6a25e64003062dd6382044cd763909c60c3aa98501fe5dee6e/_data/engine/data/18326347655309da/autogen Archived and active journals take up 800.0M in the file system. /opt/iobroker/backups: 891M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 415M /opt/iobroker/iobroker-data/ 320M /opt/iobroker/iobroker-data/files 72M /opt/iobroker/iobroker-data/files/telegram.admin 72M /opt/iobroker/iobroker-data/backup-objects 51M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 33M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map 15M /opt/iobroker/iobroker-data/objects.jsonl 15M /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map 9.7M /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map 8.6M /opt/iobroker/iobroker-data/states.jsonl *** NodeJS-Installation *** /usr/bin/nodejs v16.20.0 /usr/bin/node v16.20.0 /usr/bin/npm 8.19.4 /usr/bin/npx 8.19.4 nodejs: Installed: 16.20.0-deb-1nodesource1 Candidate: 16.20.0-deb-1nodesource1 Version table: *** 16.20.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u4 500 500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages 12.22.12~dfsg-1~deb11u3 500 500 http://ftp.halifax.rwth-aachen.de/debian bullseye/main amd64 Packages Temp directories causing npm8 problem: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl MULTIHOSTSERVICE/enabled: true Core adapters versions js-controller: 4.0.24 admin: 6.3.5 javascript: 6.1.4 Adapters from github: 0 Adapter State + system.adapter.admin.0 : admin : nas - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alias-manager.0 : alias-manager : nas - disabled + system.adapter.backitup.0 : backitup : nas - enabled + system.adapter.backitup.1 : backitup : raspi-keller - enabled system.adapter.bosch-ebike.0 : bosch-ebike : nas - enabled system.adapter.cloud.0 : cloud : nas - disabled system.adapter.daswetter.0 : daswetter : nas - enabled system.adapter.devices.0 : devices : nas - disabled + system.adapter.discovery.0 : discovery : nas - enabled system.adapter.dwd.0 : dwd : nas - enabled system.adapter.email.0 : email : nas - disabled system.adapter.feiertage.0 : feiertage : nas - enabled + system.adapter.history.0 : history : nas - enabled + system.adapter.hm-rega.0 : hm-rega : nas - enabled + system.adapter.hm-rpc.0 : hm-rpc : nas - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : nas - enabled, port: 0 system.adapter.ical.0 : ical : nas - enabled system.adapter.icons-icons8.0 : icons-icons8 : nas - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : nas - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : nas - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : nas - disabled + system.adapter.influxdb.0 : influxdb : nas - enabled, port: 8086 + system.adapter.info.0 : info : nas - enabled + system.adapter.jarvis.0 : jarvis : nas - enabled + system.adapter.javascript.0 : javascript : nas - enabled system.adapter.ping.0 : ping : nas - disabled + system.adapter.pvforecast.0 : pvforecast : nas - enabled system.adapter.radar2.0 : radar2 : nas - disabled system.adapter.schoolfree.0 : schoolfree : nas - enabled + system.adapter.shelly.0 : shelly : nas - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.smartmeter.0 : smartmeter : raspi-keller - enabled + system.adapter.smartmeter.1 : smartmeter : raspi-keller - enabled + system.adapter.telegram.0 : telegram : nas - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : nas - enabled + system.adapter.tr-064.0 : tr-064 : nas - enabled system.adapter.vis-bars.0 : vis-bars : nas - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : nas - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : nas - enabled system.adapter.vis-history.0 : vis-history : nas - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : nas - disabled system.adapter.vis-icontwo.0 : vis-icontwo : nas - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : nas - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : nas - enabled system.adapter.vis-justgage.0 : vis-justgage : nas - enabled system.adapter.vis-lcars.0 : vis-lcars : nas - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : nas - enabled system.adapter.vis-metro.0 : vis-metro : nas - disabled system.adapter.vis-plumb.0 : vis-plumb : nas - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : nas - disabled system.adapter.vis-weather.0 : vis-weather : nas - enabled system.adapter.vis.0 : vis : nas - enabled + system.adapter.web.0 : web : nas - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.wolf.0 : wolf : nas - enabled, port: 12004, bind: 0.0.0.0 + system.adapter.worx.0 : worx : nas - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : nas - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : nas - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : nas - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : nas - enabled, port: 8086 + system.adapter.shelly.0 : shelly : nas - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : nas - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : nas - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.wolf.0 : wolf : nas - enabled, port: 12004, bind: 0.0.0.0 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.3.5 , installed 6.3.5 Adapter "alias-manager": 1.2.4 , installed 1.2.4 Adapter "backitup" : 2.6.19 , installed 2.6.19 Adapter "bosch-ebike" : 0.0.3 , installed 0.0.3 Adapter "cloud" : 4.3.0 , installed 4.3.0 Adapter "daswetter" : 3.1.8 , installed 3.1.8 Adapter "devices" : 1.1.2 , installed 1.1.2 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "email" : 1.1.4 , installed 1.1.4 Adapter "feiertage" : 1.1.0 , installed 1.1.0 Adapter "history" : 2.2.4 , installed 2.2.4 Adapter "hm-rega" : 3.0.46 , installed 3.0.46 Adapter "hm-rpc" : 1.15.16 , installed 1.15.16 Adapter "ical" : 1.13.2 , installed 1.13.2 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "info" : 1.9.26 , installed 1.9.26 Adapter "jarvis" : 3.1.2 , installed 3.1.2 Adapter "javascript" : 6.1.4 , installed 6.1.4 Controller "js-controller": 4.0.24 , installed 4.0.24 Adapter "ping" : 1.5.3 , installed 1.5.3 Adapter "pvforecast" : 2.7.1 , installed 2.7.1 Adapter "radar2" : 2.0.3 , installed 2.0.3 Adapter "schoolfree" : 1.1.1 , installed 1.1.1 Adapter "shelly" : 6.4.1 , installed 6.4.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "telegram" : 1.15.2 , installed 1.15.2 Adapter "text2command" : 2.3.0 , installed 2.3.0 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.3.0 , installed 1.3.0 Adapter "vis-icontwo" : 0.93.0 , installed 0.93.0 Adapter "vis-inventwo" : 3.3.1 , installed 3.3.1 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-justgage" : 1.0.2 , installed 1.0.2 Adapter "vis-lcars" : 1.0.4 , installed 1.0.4 Adapter "vis-material-advanced": 1.7.2, installed 1.7.2 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.6 , installed 2.5.6 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "wolf" : 1.5.0 , installed 1.5.0 Adapter "worx" : 2.1.3 , installed 2.1.3 Adapter "ws" : 1.3.0 , installed 1.3.0 Objects and States Please stand by - This may take a while Objects: 9611 States: 8140 *** OS-Repositories and Updates *** W: GPG error: https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8E61C2AB9A6D1557 E: The repository 'https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease' is not signed. Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:2222 0.0.0.0:* LISTEN 0 21333 1800/node tcp 0 0 192.168.178.50:2001 0.0.0.0:* LISTEN 1002 3499689 65425/io.hm-rpc.1 tcp 0 0 127.0.0.1:3493 0.0.0.0:* LISTEN 0 25067 2664/upsd tcp 0 0 0.0.0.0:3000 0.0.0.0:* LISTEN 0 24757 2301/docker-proxy tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 114 18080 1208/mariadbd tcp 0 0 0.0.0.0:12004 0.0.0.0:* LISTEN 1002 30974 4061/io.wolf.0 tcp 0 0 0.0.0.0:3670 0.0.0.0:* LISTEN 0 22826 1731/conmon tcp 0 0 0.0.0.0:8086 0.0.0.0:* LISTEN 0 25821 2445/docker-proxy tcp 0 0 0.0.0.0:8088 0.0.0.0:* LISTEN 0 24817 2399/docker-proxy tcp 0 0 0.0.0.0:8001 0.0.0.0:* LISTEN 0 25875 2479/docker-proxy tcp 0 0 0.0.0.0:8000 0.0.0.0:* LISTEN 0 24752 2302/docker-proxy tcp 0 0 0.0.0.0:8400 0.0.0.0:* LISTEN 1002 33036 4307/io.jarvis.0 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 18772 1145/sshd: /usr/sbi tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 0 18045 1232/nginx: master tcp 0 0 0.0.0.0:8281 0.0.0.0:* LISTEN 0 21257 2173/docker-proxy tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 15457 1/init tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 0 18047 1232/nginx: master tcp 0 0 0.0.0.0:8765 0.0.0.0:* LISTEN 0 23512 2144/docker-proxy tcp 0 0 0.0.0.0:9003 0.0.0.0:* LISTEN 1002 18260 1121/iobroker.js-co tcp 0 0 0.0.0.0:9002 0.0.0.0:* LISTEN 1002 18265 1121/iobroker.js-co tcp 0 0 0.0.0.0:9010 0.0.0.0:* LISTEN 0 25638 2243/docker-proxy tcp 0 0 0.0.0.0:5355 0.0.0.0:* LISTEN 102 17778 789/systemd-resolve tcp 0 0 0.0.0.0:1080 0.0.0.0:* LISTEN 0 24703 2229/docker-proxy tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 102 17784 789/systemd-resolve tcp 0 0 0.0.0.0:1443 0.0.0.0:* LISTEN 0 24634 2197/docker-proxy tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 0 19001 1532/master tcp 0 0 0.0.0.0:2010 0.0.0.0:* LISTEN 1002 3504645 65410/io.hm-rpc.0 tcp6 0 0 ::1:3493 :::* LISTEN 0 25066 2664/upsd tcp6 0 0 :::3000 :::* LISTEN 0 25719 2317/docker-proxy tcp6 0 0 :::8081 :::* LISTEN 1002 24736 1319/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1002 32928 4278/io.web.0 tcp6 0 0 :::8086 :::* LISTEN 0 25828 2451/docker-proxy tcp6 0 0 :::8088 :::* LISTEN 0 24832 2408/docker-proxy tcp6 0 0 :::8001 :::* LISTEN 0 25880 2485/docker-proxy tcp6 0 0 :::8000 :::* LISTEN 0 24762 2311/docker-proxy tcp6 0 0 :::22 :::* LISTEN 0 18774 1145/sshd: /usr/sbi tcp6 0 0 :::80 :::* LISTEN 0 18046 1232/nginx: master tcp6 0 0 :::8281 :::* LISTEN 0 24620 2183/docker-proxy tcp6 0 0 :::111 :::* LISTEN 0 15461 1/init tcp6 0 0 :::443 :::* LISTEN 0 18048 1232/nginx: master tcp6 0 0 :::8765 :::* LISTEN 0 23518 2150/docker-proxy tcp6 0 0 :::9010 :::* LISTEN 0 25657 2266/docker-proxy tcp6 0 0 :::5355 :::* LISTEN 102 17781 789/systemd-resolve tcp6 0 0 :::1080 :::* LISTEN 0 25633 2235/docker-proxy tcp6 0 0 :::1443 :::* LISTEN 0 24655 2203/docker-proxy udp 0 0 127.0.0.53:53 0.0.0.0:* 102 17783 789/systemd-resolve udp 0 0 192.168.178.50:68 0.0.0.0:* 101 17101 336/systemd-network udp 0 0 0.0.0.0:111 0.0.0.0:* 0 15458 1/init udp 0 0 127.0.0.1:323 0.0.0.0:* 0 17981 1134/chronyd udp 0 0 0.0.0.0:37609 0.0.0.0:* 111 16870 1103/avahi-daemon: udp 0 0 172.20.0.1:5353 0.0.0.0:* 1002 28523 3564/io.tr-064.0 udp 0 0 172.19.0.1:5353 0.0.0.0:* 1002 28522 3564/io.tr-064.0 udp 0 0 172.17.0.1:5353 0.0.0.0:* 1002 28521 3564/io.tr-064.0 udp 0 0 172.24.0.1:5353 0.0.0.0:* 1002 28520 3564/io.tr-064.0 udp 0 0 172.18.0.1:5353 0.0.0.0:* 1002 28519 3564/io.tr-064.0 udp 0 0 172.16.16.1:5353 0.0.0.0:* 1002 28518 3564/io.tr-064.0 udp 0 0 192.168.178.50:5353 0.0.0.0:* 1002 28517 3564/io.tr-064.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 111 16868 1103/avahi-daemon: udp 0 0 0.0.0.0:5355 0.0.0.0:* 102 17777 789/systemd-resolve udp 0 0 0.0.0.0:5683 0.0.0.0:* 1002 30040 3947/io.shelly.0 udp6 0 0 :::111 :::* 0 15464 1/init udp6 0 0 :::49317 :::* 111 16871 1103/avahi-daemon: udp6 0 0 ::1:323 :::* 0 17982 1134/chronyd udp6 0 0 fe80::921b:eff:fed8:546 :::* 101 17103 336/systemd-network udp6 0 0 :::5353 :::* 111 16869 1103/avahi-daemon: udp6 0 0 :::5355 :::* 102 17780 789/systemd-resolve *** Log File - Last 25 Lines *** 2023-06-18 14:30:23.392 - info: javascript.0 (3463) script.js.common.Sonstiges.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 6.4 MB/s | Upload: 1.13 MB/s | Ping: 22.933ms 2023-06-18 14:31:55.547 - info: javascript.0 (3463) script.js.common.Rolladen.Rolladen_Temperatur: 1.1 => 1 2023-06-18 14:33:00.014 - info: javascript.0 (3463) script.js.common.Rolladen.Rolladen_Sonnenschein_Temp: Bedingung 1 Sonnen_Counter alt 7 2023-06-18 14:35:00.037 - info: host.nas instance system.adapter.dwd.0 started with pid 136251 2023-06-18 14:35:00.169 - info: javascript.0 (3463) Stop script script.js.common.Photovoltaik.Goodwe-Wechselrichter 2023-06-18 14:35:00.280 - info: javascript.0 (3463) Start javascript script.js.common.Photovoltaik.Goodwe-Wechselrichter 2023-06-18 14:35:00.294 - info: javascript.0 (3463) script.js.common.Photovoltaik.Goodwe-Wechselrichter: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions 2023-06-18 14:35:00.719 - info: dwd.0 (136251) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.20.0, js-controller: 4.0.24 2023-06-18 14:35:01.119 - info: dwd.0 (136251) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2023-06-18 14:35:01.655 - info: host.nas instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-06-18 14:35:44.099 - warn: javascript.0 (3463) script.js.common.Photovoltaik.Goodwe-Wechselrichter: Fehler Python: ERROR:root:RequestException during do_login(): HTTPSConnectionPool(host='semsportal.com', port=443): Read timed out. (read timeout=10) ERROR:root:Failed to log in, bailing ERROR:root:no inverter data, try True, trying again in 30 seconds Traceback (most recent call last): File "/opt/iobroker/pygoodwe-master/allinone.py", line 8, in <module> gw = SingleInverter( File "/opt/iobroker/pygoodwe-master/pygoodwe/__init__.py", line 446, in __init__ super().__init__(system_id, account, password, **kwargs) File "/opt/iobroker/pygoodwe-master/pygoodwe/__init__.py", line 60, in __init__ self.getCurrentReadings(raw=True) File "/opt/iobroker/pygoodwe-master/pygoodwe/__init__.py", line 460, in getCurrentReadings self.data["inverter"] = self.data["inverter"][0] KeyError: 0 2023-06-18 14:36:00.017 - info: javascript.0 (3463) script.js.common.Rolladen.Rolladen_Sonnenschein_Temp: Bedingung 1 Sonnen_Counter alt 7
ok
@nr5lebt
aha, als root unterwegs und das System ist auch nicht grad so nach der EmpfehlungDa gibts tolle Anleitungen wie man manches machen soll und nicht machen soll....
Schau z.B. mal in der Signatu von @Thomas-Braun nach wie man auf das empfohlene Node geht... und hör mit Root auf... gescheiten User anlegen dann klappt das auch -
@djmarc75 ich weiß ich weiß ich weiß
aber kannst du mal nach dem problem schauen was ich gemeldet habe!!! -
Das eine kann halt aus dem anderen erwachsen. Setz die Basis gescheit auf, dann klappt es auch in den anderen Ebenen besser.
Bei deinen Software-Quellen klemmt es auch gewaltig.
jo jo jo
nö, weil dreifache Satzzeichen und eine Aufforderung einfach nicht dienlich sind. Keine Lust mehr.
Moin,
ich kann Dir noch keine Lösung für Deine ursprüngliche Frage geben, denn es gibt da noch ein, zwei Fragen, die Du vorher noch beantworten solltest.
- Ok, Versionen kann man sich ja selbst zusammensuchen, im
iob diag
, so etwas gehört immer in den ersten Post - Hast Du schon einmal die Version 1.7.0 des Adapters probiert?
Zu dem Problem mit
Can't parse DP .... - length: 21
schau mal hier https://github.com/ioBroker/ioBroker.wolf/issues/92Zu den anderen Einstellungen muss dann mal der Adapter Guru etwas sagen, vielleicht ist das auch schon in 1.7.0 gefixed.
VG
BerndP.S.: Ach, das wollte ich ja auch noch anmerken, eins Deiner Repositorys, die Du eingerichtet hast, ist defekt
W: GPG error: https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8E61C2AB9A6D1557E: The repository 'https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease' is not signed.
Dann scheinst Du ein Problem mit einem Skript zu haben!
Moin zusammen, hab auch immer wieder Fehlermeldungen:
wolf.0 2023-10-25 11:06:08.546 error Can't parse DP : 346, type DPT_Unknown2 - data: 0620f080001404000000f006015a0001015a0300 - length: 20 wolf.0 2023-10-25 11:05:58.727 error Can't parse DP : 191, type DPT_Power - data: 0620f080001404000000f00600bf000100bf0300 - length: 20
DP 191 (Leistungsaufnahme in kw) tritt sporadisch auf. DP 346 (nicht in Doku). Würde mich nicht stören, wenn diese nicht so hoch (als error) klassifiziert werden. Zur Info.
