    4. [Frage] Xiaomi Vacuum cleaner
      SlowMoe last edited by
      Also als ich noch den 0.56 Adapter drauf hatte kam kein Reply vom Staubsauger, was im Nachgang ja auch logisch erscheint, da das 96er Token nicht verarbeitet werden konnte. Sprich das Log sah so aus wie bei anderen hier auf S.56:
      ` > mihome-vacuum.0 2017-08-17 19:55:38.553 debug Receive <<< Helo <<< 213100200000000003d941d45995d7a0ffffffffffffffffffffffffffffffff
      mihome-vacuum.0 2017-08-17 19:55:18.582 debug Receive <<< Helo <<< 213100200000000003d941d45995d78cffffffffffffffffffffffffffffffff
      mihome-vacuum.0 2017-08-17 19:55:00.489 debug sendMsgRaw >>> 213100500000000003d941d45995d7796b01db07545e87e764cca53fba0266e79b2cb1b46fe3a2bb1f2975629a206d6e8408e7a06874e0e1ebb7d8b0b9ffe480b5100b2bfcd973af8be6fd4ac30ce39d
      mihome-vacuum.0 2017-08-17 19:55:00.489 debug sendMsg >>> {"id":1003,"method":"get_clean_summary"}
      mihome-vacuum.0 2017-08-17 19:55:00.489 debug lastid{"get_status":1001,"get_consumable":1002,"get_clean_summary":1003,"get_clean_record":0,"X_send_command":0,"app_start":1000}
      mihome-vacuum.0 2017-08-17 19:54:59.489 debug sendMsgRaw >>> 213100500000000003d941d45995d778d3bd8c9bf454167b0bef2a81b9a6b42bd00103addb77b3b67b0e5a747647bc3f7625805e83bc3afdbf57b9512d4ed8657dceb73175afde0dc68227cc2334437c
      mihome-vacuum.0 2017-08-17 19:54:59.489 debug sendMsg >>> {"id":1002,"method":"get_consumable"}
      mihome-vacuum.0 2017-08-17 19:54:59.489 debug lastid{"get_status":1001,"get_consumable":1002,"get_clean_summary":0,"get_clean_record":0,"X_send_command":0,"app_start":1000}
      mihome-vacuum.0 2017-08-17 19:54:58.512 debug Receive <<< Helo <<< 213100200000000003d941d45995d778ffffffffffffffffffffffffffffffff
      mihome-vacuum.0 2017-08-17 19:54:58.488 debug sendMsgRaw >>> 213100500000000003d941d45995d777bf78b415a181ce9daba4a4af41a9495c51761b53365999df7ea4d04c2240914e77fa2dd70a5cf6e680594ea86488045774c532d73c3432f1fc9ce52a8344a564
      mihome-vacuum.0 2017-08-17 19:54:58.488 debug sendMsg >>> {"id":1001,"method":"get_status"}
      mihome-vacuum.0 2017-08-17 19:54:58.487 debug lastid{"get_status":1001,"get_consumable":0,"get_clean_summary":0,"get_clean_record":0,"X_send_command":0,"app_start":1000}
      mihome-vacuum.0 2017-08-17 19:54:58.487 debug request params all: 60 Sec
      mihome-vacuum.0 2017-08-17 19:54:38.660 debug Receive <<< Helo <<< 213100200000000003d941d45995d764ffffffffffffffffffffffffffffffff
      mihome-vacuum.0 2017-08-17 19:54:25.017 debug inMem message mihome-vacuum.0.* mihome-vacuum.0.control.start val=true, ack=true, ts=1502992465016, q=0, from=system.adapter.mihome-vacuum.0, lc=1502991719866
      mihome-vacuum.0 2017-08-17 19:54:25.016 debug sendMsgRaw >>> 213100500000000003d941d45995d756d30c6d6629bacb8b191973528e53ad44fa0713c8297c7a91cfdd6173669368987b20153a61ffed5744ca0ea12cc679404ee56026d80dc34fa2da7949b93c7ba1
      mihome-vacuum.0 2017-08-17 19:54:25.015 debug sendMsg >>> {"id":1000,"method":"app_start"}
      mihome-vacuum.0 2017-08-17 19:54:25.014 debug lastid{"get_status":0,"get_consumable":0,"get_clean_summary":0,"get_clean_record":0,"X_send_command":0,"app_start":1000}
      mihome-vacuum.0 2017-08-17 19:54:25.014 debug stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1502992465012,"q":0,"from":"system.adapter.admin.0","lc":1502991719866}
      mihome-vacuum.0 2017-08-17 19:54:25.013 debug inMem message mihome-vacuum.0.* mihome-vacuum.0.control.start val=true, ack=false, ts=1502992465012, q=0, from=system.adapter.admin.0, lc=1502991719866
      mihome-vacuum.0 2017-08-17 19:54:18.576 debug Receive <<< Helo <<< 213100200000000003d941d45995d750ffffffffffffffffffffffffffffffff
      mihome-vacuum.0 2017-08-17 19:53:58.513 debug inMem message mihome-vacuum.0.* mihome-vacuum.0.info.connection val=true, ack=true, ts=1502992438509, q=0, from=system.adapter.mihome-vacuum.0, lc=1502992438509
      mihome-vacuum.0 2017-08-17 19:53:58.508 info Connected
      mihome-vacuum.0 2017-08-17 19:53:58.508 warn Timedifference between Mihome Vacuum and ioBroker: -250508 Milliseconds
      mihome-vacuum.0 2017-08-17 19:53:58.508 debug Receive <<< Helo <<< 213100200000000003d941d45995d73cffffffffffffffffffffffffffffffff
      mihome-vacuum.0 2017-08-17 19:53:58.479 debug server started on 0.0.0.0:53421 `
      Jetzt mit der der Adapterversion 0.58 wird beim einfügen des 96er Tokens aber quasi auch nichts mehr rausgesendet an den Sauger wenn ich das richtig sehe:
      ` > mihome-vacuum.0 2017-10-07 22:22:02.817 info Create state clean_home for controlling by cloud adapter
      mihome-vacuum.0 2017-10-07 22:22:02.813 info Expert mode disabled, states deleded
      mihome-vacuum.0 2017-10-07 22:22:02.798 info starting. Version 0.5.8 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v6.11.1
      host.loxberry 2017-10-07 22:22:01.499 info instance system.adapter.mihome-vacuum.0 started with pid 2965
      host.loxberry 2017-10-07 22:21:59.092 info instance system.adapter.mihome-vacuum.0 terminated with code 0 (OK)
      mihome-vacuum.0 2017-10-07 22:21:59.021 info terminating
      host.loxberry 2017-10-07 22:21:58.982 info stopInstance system.adapter.mihome-vacuum.0 killing pid 2931
      host.loxberry 2017-10-07 22:21:58.981 info stopInstance system.adapter.mihome-vacuum.0
      host.loxberry 2017-10-07 22:21:58.979 info object change system.adapter.mihome-vacuum.0
      cloud.0 2017-10-07 22:19:32.217 info Request devices
      mihome-vacuum.0 2017-10-07 22:18:47.793 warn Time difference between Mihome Vacuum and ioBroker: -1 sec
      mihome-vacuum.0 2017-10-07 22:18:47.697 info Create state clean_home for controlling by cloud adapter
      mihome-vacuum.0 2017-10-07 22:18:47.692 info Expert mode disabled, states deleded
      mihome-vacuum.0 2017-10-07 22:18:47.677 info starting. Version 0.5.8 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v6.11.1
      host.loxberry 2017-10-07 22:18:45.992 info instance system.adapter.mihome-vacuum.0 started with pid 2931
      host.loxberry 2017-10-07 22:18:45.967 info object change system.adapter.mihome-vacuum.0 `
      Vielleicht hilft der Screenshot hier auch noch
      • Meistertr
        habe gerade ein pull request gesendet, die zeilenlänge war noch auf 32 begrenzt… nun sollte e3s funktionieren
          @Meistertr:
          habe gerade ein pull request gesendet, die zeilenlänge war noch auf 32 begrenzt… nun sollte e3s funktionieren `
          Heisst das der Adpater hat jetzt ein Update erfahren? Muss ich ihn noch mal installieren um den 96er Token zu testen?
          • Meistertr
            @SlowMoe:
            @Meistertr:
            Heisst das der Adpater hat jetzt ein Update erfahren? Muss ich ihn noch mal installieren um den 96er Token zu testen? `
            Der Pullrequest muss noch eingebunden werden.. ich sag bescheid wenn er drin ist
            • AlCalzone
              Ich dachte ich hätte das schon gefixt, aber die Stelle hab ich in meinem PR damals wohl übersehen :?
              https://github.com/ioBroker/ioBroker.mi … um/pull/21
              • Meistertr
                @AlCalzone:
                https://github.com/ioBroker/ioBroker.mi … um/pull/21 ` Dachte auch als ich es eingebunden hatte, dass ich es mit hochgeladen habe, aber irgendwie war die Index.html nicht dabei..
                Gesendet von meinem Handy
                • Bluefox
                  Bluefox last edited by
                  Ich konnte folgende Endpunkt für die Karte finden:
                  c.callSmartHomeAPI("/home/getmapfileurl", {
                              model: c.deviceModel,
                              obj_name: a
                  Wer weist, wie sieht China Mainland API endpoint aus?
                    dna909 last edited by
                    Die Url zur Karte scheint die hier zu sein:
                    http://awsbj0-cdn.fds-ssl.api.xiaomi.co … oboroommap
                    Falls es weiterhilft?
                    • Meistertr
                      @Bluefox:
                                  obj_name: a
                      Wer weist, wie sieht China Mainland API endpoint aus? ` http://forum.iobroker.net/viewtopic.php?p=87419#p87419
                      In den Dateien verliert sich bei mir die Spur…
                      • tommyr84
                        tommyr84 last edited by
                        Hallo Leute, ich bitte um eure Hilfe!
                        Ich habe versucht meinen mi robot via iobroker einzubinden, leider ohne Erfolg.
                        Zuerst habe ich versucht den Token via bluestaks (android emulator für windows) und wireshark zum mitschneiden des traffics
                        auszulesen, was soweit ganz gut funktionierte, nur dass mein "Yoda"=mi robot nicht reagierte, als ich die HEX streams via packetsender geschickt habe…
                        gut, einen ganzen Abend lang versucht, kein Erfolg... also andere Methode!
                        Hab dann den Token via Raspberry PI 3 mit Python-miio ausgelesen... soweit so gut!
                        Hab also den 32bit HEX token im mi robot adapter bei IObroker eingetragen, leider abermals keine Reaktion meines Yoda's...
                        bei jeglichen verfügbaren befehlen.
                        der Log von IO Broker zeigt mir jedoch auch nichts an, wenn ich versuche ein Start Signal zu schicken.
                        Der Token 33465a574d4655697063494476505xxx ist jedoch definitiv richtig!
                        Hat jemand von euch eine Idee, was ich noch tun könnte? Steuerung via handy und auch via bluestack funktioniert tadellos, ebenso die steuerung eines Broadlink adapters via Iobroker.
                        Danke für eure Hilfe!
                        • Meistertr
                          @tommyr84:
                          Danke für eure Hilfe! ` Bitte einfach das readme zum Adapter lesen. Nach 5 min hast du den richtigen token und kannst ihn verwenden.
                          Du hast jede erdenkliche Art probiert, die nicht mehr funktioniert. Aber die die funktionieren nicht..
                          • tommyr84
                            Hab das mit meinem Android Handy versucht.
                            Jedoch lässt sich mit meinem Honor und Android 7.0 KEIN Backup ohne Passwort erstellen!
                            Ich denke das Problem sollte jeder ab Android 7.0 haben… richtig?
                            Gibt es eine andere Möglichkeit? Iphone habe ich keines zur Hand.
                            • tommyr84
                              Sodala… das wars!
                              Hab noch ein altes android Handy gefunden, dass mich eine Sicherung OHNE Passwort erstellen lies.
                              Danke für die Unterstützung!
                              • Meistertr
                                Ich habe auch Android 7 und es geht ohne Probleme… Aber das Hornor ist schon öfters aufgefallen weil es nicht damit geklappt hat..
                                  weimaraner last edited by
                                  So jetzt ich. 😄 Mein Saugi ist heute endlich angekommen! 😄 😄
                                  Mi-home app ist eingerichtet, aber… 😞
                                  ich habe USB-debuggimg aktiviert und trotzdem kommt folgende Meldung bei mi toolkit
                                  Probiert habe ich es mit einem Samsung S3 neo Android 4.4.2, samsung S3 mini Android 4.1.2. und einem wiko Lenny Android 6.0
                                  PC habe ich zwei Stück jeweils mit Windows 7 benutzt. Überall das gleich Ergebnis.
                                  Was mache ich falsch?
                                  Grüße Andreas
                                  Edit: USB Port und Kabel habe ich auch gewechselt.
                                  • kmxak
                                    musste man da nicht auch Treiber installieren? Hattest du das? Kann mich nur wage dran erinnern das ich da mal was für mein Samsung installiert hatte von Kies.
                                    Bei manchen Geräten kann man auch einstellen welcher Modus aktiv ist Kamera Mediashare usw. passt das?
                                      Kommando zurück!!! 😄 😄 😄 😄
                                      Das Lenny hing ein paar Minuten am Laptop und plötzlch ging eine Meldung auf, ob USB-debugging zugelassen werden soll. Natürlich okay gedrück! 🙂 Token ausgelesen!!! Und läuft!
                                      Ihr seit allesamt absolut spitze!
                                      Grüße Andreas
                                        habe heute eine Runde ioBroker aktualisiert und ein Backup gezogen.
                                        Nach dem Restart von ioBroker bleibt der mihome-vacuum.0 gelb, scheint aber zu funktionieren.
                                        Dem Sauger habe ich den Internet-Zugang in der Fritzbox verweigert.
                                        mihome-vacuum.0	2017-10-14 07:52:27.076	info	Connected
                                        mihome-vacuum.0	2017-10-14 07:52:26.911	info	Cloud control disabled
                                        mihome-vacuum.0	2017-10-14 07:52:26.905	info	Expretmode disabled, states deleded
                                        mihome-vacuum.0	2017-10-14 07:52:26.853	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v4.8.4
                                        mihome-vacuum.0	2017-10-14 07:52:20.701	info	terminating
                                        Muss mich das beunruhigen oder ist das normal?
                                        • Meistertr
                                          @klassisch:
                                          Muss mich das beunruhigen oder ist das normal? ` Also laut deinem log ist alles ok und auch grün
                                            Vielen Dank, dann hätte ich das wohl besser aussitzen sollen. Jetzt ist er tatsächlich grün. Sorry für die Zeitverschwendung.
                                            2196
                                            963158
