    4. jarvis v3.1.x - just another remarkable vis
      MCU last edited by
      @dominik-f
      1. Issue unter github erstellen?
        https://github.com/Zefau/ioBroker.jarvis/issues
      2. Sind alle Updates gemacht worden? Welche webview Version im Einsatz?
      Dominik F. 1 Reply Last reply Reply Quote 0
        marsmännchen last edited by marsmännchen
        @mcu
        Hallo @MCU
        Wenn ich das Script zum erstellen von den DPs für timeTable:
        // Anlegen der Objekt für ein WochenTimeTable
        // timeTable v1.0.0
        // Copyright ©MCU
        let timeTableDP = '0_userdata.0.jarvis.timeTable';
        let weekDP      = timeTableDP + '.week';
        let weekArr = ['monday','tuesday','wednesday','thursday','friday','saturday','sunday'];
        let dpArr       = [{'name':'activeOn','text':'Tag aktivieren'   ,'type':'boolean','initial':false},
                           {'name':'timeOn'  ,'text':'Zeit einschalten' ,'type':'string' ,'initial':''},
                           {'name':'timeOff' ,'text':'Zeit ausschalten' ,'type':'string' ,'initial':''},
                           {'name':'duration','text':'Zeit Dauer'       ,'type':'number' ,'initial':0},
                           {'name':'option'  ,'text':'Kanten aktivieren','type':'boolean','initial':false},
                           {'name':'worked'  ,'text':'Genutzt'          ,'type':'boolean','initial':false}]
        let selektorOffDPs = '0_userdata.0.jarvis.timeTable.week.*.timeOff';
        let selektorOnDPs  = '0_userdata.0.jarvis.timeTable.week.*.timeOn';
        let todayDP        = weekDP + '.today';
        createStateAsync(todayDP,{read: true, write: true, name: 'Heute' , type: 'string', role: "", def: ''});
        // jeden Tag um 00:01 Uhr Tagesnamen setzen
        schedule('1 0 * * *', async function () {
          todaySetDP();
        function todaySetDP(){
            let dateNow = new Date();
            let dateDay  = getDateObject(dateNow).getDay();
            //log(dateDay); // 0 = Su, 1=Mo, 2=Di, 3=Mi, 4=Do 5=Fr 6=Sa usw.
            let dateStr = '';
            if (dateDay == 0){
                dateStr=weekArr[6];
            }else {
                dateStr=weekArr[dateDay-1];
            setState(todayDP, dateStr, false);
        //createDPs();
        function createDPs(){
            for (let day in weekArr){
                let x = parseInt(day) +1;
                log(x +' ' +weekArr[day]);
                for (let dp in dpArr){
                    //log(dpArr[dp].name);
                    let dpCreate = weekDP+'.'+ x +'_'+weekArr[day]+'.'+dpArr[dp].name;
                    //log(weekDP+'.'+weekArr[day]+'.'+dpArr[dp].name);
                    let nameCreate = dpArr[dp].text;
                    //log(dpArr[dp].text);
                    let typeCreate = dpArr[dp].type;
                    //log(typeCreate);
                    let defCreate = dpArr[dp].initial;
                    log(dpCreate +' - '+nameCreate+' - ' + typeCreate+' - '+defCreate);
                    createStateAsync(dpCreate,{read: true, write: true, name: nameCreate , type: typeCreate, role: "", def: defCreate});
                //break;
        $(selektorOnDPs).on(function (obj) {
            //let value = obj.state.val;
            //log(obj.channelId);
            duration(obj.channelId);
        $(selektorOffDPs).on(function (obj) {
        function duration(channelid){
            let timeOn = getState(channelid+'.timeOn').val;
            let timeOff = getState(channelid+'.timeOff').val;
            //log(timeOn +' - '+ timeOff);
            let dateOn = getDateObject(timeOn).getTime();
            let dateOff = getDateObject(timeOff).getTime();
            let diffDate = (dateOff - dateOn)/60000; // minutes
            //log (dateOn + ' - '+ dateOff + ' - '+diffDate);
            setStateAsync(channelid+'.duration',diffDate,false);
        starte, wird bei mir nur der Datenpunkt "0_userdata.0.jarvis.timeTable2.week.today"
        erstellt. Mehr nicht.
        Sollte das Script nicht komplett von Montag bis Sonntag, mit activeOn,...... erstellen? Oder hab ich da wieder mal etwas falsch verstanden?
        MfG
        Patrick
        P.S.: Sorry, hätte eigentlich in https://forum.iobroker.net/topic/52228/howto-zusatz-programme-fuer-jarvis-v3 sollen
          MCU @marsmännchen last edited by
          @marsmännchen Man muss das createDPs laufen lassen:
          createDPs();
          U 1 Reply Last reply Reply Quote 1
          • U
            uwe72 @MCU last edited by
            @mcu
            Ich suche irgendwie eine Matrix aufzubauen. Weiß nicht, ob es was besseres gibt als die statelist-Horizontal?!
            Aktuell habe ich das Problem, dass die Widget unterschiedlich breit sind und somit nicht alle Widgets einer "Column" gleich breit sind.
            Kannst Du mich in die richtige Richtung stoßen wie ich am besten so eine Matrix aufbauen kann?
            Es geht um eine Gartenbewässerung. Es gibt 8 Ventile und pro Ventil sollen pro Tag bis zu 3 Zeitbereiche konfiguriert werden können. Ggf. hat jemand auch schon mal so was in der Art gemacht.
              MCU @uwe72 last edited by
              @uwe72
              https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/system-effektprog./timetable
              Grizzelbee 1 Reply Last reply Reply Quote 1
              • Grizzelbee
                Grizzelbee Developer @MCU last edited by Grizzelbee
                @MCU
                Ich kasper hier gerade mit Bindings in der Anzeigevariante herum und hätte da jetzt gerne mal eine Frage:
                In mein VPN können sich User über mehrere Devices gleichzeitig einwählen - mir reicht aber eigentlich ein einziges mal die Anzeige, ob jemand online ist.
                Aktuell habe ich für jedes Device (Smartphone, Notebook, Tablet, ...) einen eigenen Datenpunkt im secondaryState und das führt zur Anzeige von "Online, Online, Online" falls alle Devices eingewählt sind - das ist einfach overkill.
                Jetzt möchte ich das über einen neuen Datenpunkt Online-State lösen, der alle drei Datenpunkte über ein Binding ODER-Verknüpft.
                Problem:
                Für zwei Datenpunkte funktioniert die ODER Verknüpfung - bei drei geht die kaputt und es wird nur der Status des Basis-DPs angezeigt:
                  "{wireguard.0.callisto-wg0.peers.UD18Lv/aVO2DXV0VFd3ELLpuE630pBhHd3tTfjXEnBg=.connected}=true
                || {wireguard.0.callisto-wg0.peers.N5rCZqLgpqJCeQP0RcuqZr3AGEkrBz3wzhCZ/DOCnUE=.connected}=true
                || {wireguard.0.callisto-wg0.peers.VzpXgjo+tSK+5+C2XUc5WAdJmyVoowruBRKS9JOu6V8=.connected}=true": "Online",
                  "default": ""
                Sobald ich nur 2 DPs ODER verknüpfe geht das:
                { "{wireguard.0.callisto-wg0.peers.UD18Lv/aVO2DXV0VFd3ELLpuE630pBhHd3tTfjXEnBg=.connected}=true
                || {wireguard.0.callisto-wg0.peers.N5rCZqLgpqJCeQP0RcuqZr3AGEkrBz3wzhCZ/DOCnUE=.connected}=true ":"Online"
                ,"default":""}
                Kann das Binding nur zwei DPs verknüpfen? Ich habe schon in den github-issue und in die Doku dazu(https://github.com/Zefau/ioBroker.jarvis/issues/158) geschaut , bin dabei aber nicht schlauer geworden.
                https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/binding/fenster-mit-2-haelften
                Zefau created this issue in Zefau/ioBroker.jarvis
                closed Use foreign device state values as input for state or icon style ("Binding") #158
                  MCU last edited by MCU
                  @grizzelbee Welche Version nutzt du?
                  Sinnvoll wäre da ein eigenes javascript oder Blockly mit dem man dann einen eigenen DP befüllt und diesen in Jarvis darstellt?
                  • Grizzelbee
                    Grizzelbee Developer last edited by Grizzelbee
                    @mcu
                    Oh! Sorry- vergessen: v3.1.9-beta.2
                    Wenn jarvis das partout nicht kann, werde ich darüber nachdenken, auch wenn ich solche Kunstgriffe echt hässlich finde.
                    Ich wollte nur erst einmal klären ob das ein Bug oder ein Feature ist. Ich fand es halt nicht intuitiv, das 2 funktioneren und drei nicht. 😉
                      MCU @Grizzelbee last edited by MCU
                      @grizzelbee Also momentan gibt es mit der Anzeigevariante auch in anderen Varianten ( false Wert setzen) Probleme.
                      Da war die Alternative über die Datenpunkt-Eigenschaften zu gehen. Muss ich aber erst noch probieren, ob es mit mehreren boolean geht.
                      Sonst halt eigener DP.
                        MCU @MCU last edited by MCU
                        @mcu Bekomme es auch dort nicht hin, also bleibt nur die Alternative mit eigenem DP.
                        Bei mir funktioniert es aber mit 3 boolean in der Anzeigevariante?
                        Vielleicht hilft ein Upload
                        iob upload jarvis
                        • Dominik F.
                          Dominik F. @MCU last edited by
                          @mcu sagte in jarvis v3.1.x - just another remarkable vis:
                          @dominik-f
                          Sorry für die späte Rückmeldung. Ich konnte das Problem nun lösen. In Chrome konnte ich den Zoom einstellen. Ich schätze, der hat sich bei nem Update von Chrome auf Standard oder sowas in der Art zurück gestellt.
                          • U
                            @mcu Frage, die Bezeichnungen der Items einer Dropdownlist kann man nicht zufällig auch über Binding beziehen?
                            Aktuell statisch:
                            Dachte an sowas:
                            Sieht dann allerdings so aus:
                            Grüße!
                              MCU @uwe72 last edited by MCU
                              @uwe72 Laut Doku hat es mal funktioniert.
                              https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/anzeigevariante
                              Sehr wahrscheinlich nicht im Zusammenhang mit der DropDownAction?
                              -> Feature Request
                              • U
                                @mcu
                                Kurze Frage, habs im wiki nicht gefunden. Kann man per URL der Jarvisseite Parameter mitgeben, welche man irgendwie mit JavaScript auswerten kann?
                                  @uwe72 Gib mal ein Beispiel und wofür ist es gedacht?
                                  • U
                                    @mcu
                                    Ich möchte in der unteren Tabelle (dynamisch erstelltes HTML) pro Zeile einen Button haben. Wenn ich auf den Button klicke:
                                    • sollen zuerst 3 Datenpunkte befüllt werden (steuert den Inhalt der Dropdowns im übernächsten Screenshot)
                                    und auf einen anderen Reiter navigieren:
                                    Vermutlich nicht so einfach.
                                    Andere Frage: Wenn ich beide Screens zu einem zusammenführe, zu einer Jarvis-Statelist. Ich kann die Einträge filtern, das habe ich schon gesehen. Kann ich sie auch sortieren?
                                      @uwe72 Sortieren geht nur mit Extraprogramm.Dieses?
                                      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/system-effektprog./v3-systemprogramme/statelistsort
                                      Zeitbereiche natürlich nicht, bislang nur Zahlenwerte.
                                      Die HTML erstellst du selber?
                                      Wenn ja dann kann man sie schon so aufbauen, dass man eine "javascript"(SCRIPTS) Funktion nutzt und diese bei Klick aufruft.
                                      Diese Scripts-Funktion kann dann die Werte von States füllen / setzen.
                                        marsmännchen @MCU last edited by
                                        @mcu
                                        Grüße euch.
                                        Gibt es eigentlich eine Möglichkeit mit Jarvis auf einem Touchscreen ohne Hardwaretastatur Buchstaben und Ziffern einzugeben?
                                        Ein keyboard wie bei Vis z. B?
                                        Mfg Patrick
                                          MCU @marsmännchen last edited by MCU
                                          @marsmännchen Meinst du ein Software Keyboard auf dem PC? Windows-PC mit Touchscreen?
                                            @mcu
                                            Ich rufe über einen raspberry im kiosk Modus die jarvis Vis auf, und habe über hdmi einen Dell Touchmonitor am raspberry.
                                            Und dort dann eine Software Tastatur.
                                            92
                                            1825
                                            690922
