    4. ioBroker update führt zu GLIBCXX_3.4.26-Problem - GELÖST!
    • R. Frase
      R. Frase @Thomas Braun last edited by
      Oh, Verzeihung...
      sudo apt-get purge nodejs
        Thomas Braun Most Active @R. Frase last edited by
        @r-frase
        Jein. Man passt seine Quelle an, in dem Fall die /etc/apt/sources.list.d/nodesource.list
        Trag da statt 20 eine 18 ein.
        Dann
        sudo apt update
        sudo apt install nodejs=18.16.0-deb-1nodesource1
        R. Frase 1 Reply Last reply Reply Quote 0
        • R. Frase
          ... ich bin gerade dran... kleinen Moment bitte
          • R. Frase
            R. Frase @Thomas Braun last edited by R. Frase
            @thomas-braun sagte in ioBroker update führt zu GLIBCXX_3.4.26-Problem:
            curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
            Jetzt hat das hier funktioniert:
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Model           : Raspberry Pi 4 Model B Rev 1.1
            Architecture    : armv7l
            Docker          : false
            Virtualization  : none
            Distributor ID: Raspbian
            Description:    Raspbian GNU/Linux 10 (buster)
            Release:        10
            Codename:       buster
            PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
            NAME="Raspbian GNU/Linux"
            VERSION_ID="10"
            VERSION="10 (buster)"
            VERSION_CODENAME=buster
            ID=raspbian
            ID_LIKE=debian
            HOME_URL="http://www.raspbian.org/"
            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
            Systemuptime and Load:
             23:43:25 up  1:31,  1 user,  load average: 4.70, 3.45, 1.83
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            Other values than 0x0 hint to temperature/voltage problems
            temp=61.8'C
            volt=0.8625V
            *** Time and Time Zones ***
                           Local time: Wed 2023-06-21 23:43:36 CEST
                       Universal time: Wed 2023-06-21 21:43:36 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:           1.9G        124M        834M        8.0M        913M        1.6G
            Swap:           99M          0B         99M
            Total:         2.0G        124M        934M
                     1872 M total memory
                      124 M used memory
                      238 M active memory
                      726 M inactive memory
                      834 M free memory
                      272 M buffer memory
                      641 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /dev/root      ext4       29G  8.8G   20G  32% /
            devtmpfs       devtmpfs  776M     0  776M   0% /dev
            tmpfs          tmpfs     937M     0  937M   0% /dev/shm
            tmpfs          tmpfs     937M  8.6M  928M   1% /run
            tmpfs          tmpfs     937M     0  937M   0% /sys/fs/cgroup
            /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
            tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
            [Wed Jun 21 22:11:39 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:12:E3:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8578e3fa-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait fsck.mode=force
            [Wed Jun 21 22:11:40 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Jun 21 22:11:40 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Wed Jun 21 22:12:11 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
            Show mounted filesystems (real ones only):
            TARGET        SOURCE         FSTYPE OPTIONS
            /             /dev/mmcblk0p2 ext4   rw,noatime
            |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
            `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            408M    /var/
            165M    /var/lib
            129M    /var/cache
            123M    /var/cache/apt
            69M     /var/lib/apt/lists
            Archived and active journals take up 8.0M in the file system.
            /opt/iobroker/backups:
            95M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            499M    /opt/iobroker/iobroker-data/
            341M    /opt/iobroker/iobroker-data/files
            96M     /opt/iobroker/iobroker-data/backup-objects
            78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
            51M     /opt/iobroker/iobroker-data/files/javascript.admin
            28M     /opt/iobroker/iobroker-data/objects.jsonl
            19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
            12M     /opt/iobroker/iobroker-data/objects.json.migrated
            12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
            9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.16.0
            /home/pi/.nvm/versions/node/v16.13.0/bin/node           v16.13.0
            /home/pi/.nvm/versions/node/v16.13.0/bin/npm            8.1.0
            /home/pi/.nvm/versions/node/v16.13.0/bin/npx            8.1.0
            *** nodejs is NOT correctly installed ***
            nodejs:
              Installed: 18.16.0-deb-1nodesource1
              Candidate: 18.16.0-deb-1nodesource1
              Version table:
             *** 18.16.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u3 500
            find: '/opt/iobroker/node_modules': No such file or directory
            No problems detected
            *** ioBroker-Installation ***
            ioBroker Status
            node:internal/modules/cjs/loader:1078
              throw err;
            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
                at Module._load (node:internal/modules/cjs/loader:920:27)
                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                at node:internal/main/run_main_module:23:47 {
              code: 'MODULE_NOT_FOUND',
              requireStack: []
            Node.js v18.16.0
              throw err;
              requireStack: []
            Node.js v18.16.0
            Core adapters versions
              throw err;
              requireStack: []
            Node.js v18.16.0
            js-controller:
              throw err;
              requireStack: []
            Node.js v18.16.0
            admin:
              throw err;
              requireStack: []
            Node.js v18.16.0
            javascript:
            npm ERR! code ELSPROBLEMS
            npm ERR! missing: iobroker.accuweather@1.2.4, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.admin@6.3.5, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.alexa2@3.23.2, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.backitup@2.6.19, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.coronavirus-statistics@^0.8.7, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.cul@2.0.2, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.daswetter@3.1.8, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.deconz@1.3.21, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.discovery@3.1.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.dwd@2.8.3, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.feiertage@1.1.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.fhem@^1.6.3, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.firetv@1.0.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.fritzdect@2.2.6, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.fullybrowser@2.1.2, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.hue-extended@2.0.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.hue@3.7.1, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.ical@1.13.2, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.icons-addictive-flavour-png@0.1.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.icons-fatcow-hosting@0.1.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.icons-icons8@0.0.1, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.icons-material-png@0.1.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.icons-material-svg@0.1.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.icons-mfd-png@1.1.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.icons-mfd-svg@1.1.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.icons-open-icon-library-png@0.1.2, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.icons-ultimate-png@^1.0.1, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.iot@1.14.2, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.javascript@6.1.4, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.js-controller@4.0.24, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.mqtt@4.1.1, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.net-tools@0.2.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.octoprint@4.0.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.onvif@1.0.4, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.philips-tv@0.5.3, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.ping@1.5.3, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.plex@0.9.1, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.plexconnect@0.0.7, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.pollenflug@^1.0.6, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.scenes@2.3.9, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.simple-api@2.7.2, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.smartthings@0.0.4, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.socketio@4.2.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.spotify-premium@1.2.1, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.synology@2.1.13, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.tankerkoenig@^2.1.1, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.terminal@1.0.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.text2command@2.3.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.tr-064@4.2.18, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.trashschedule@2.2.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.tuya@3.14.2, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.upnp@1.0.21, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.virtualpowermeter@1.4.6, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-bars@^0.1.4, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-canvas-gauges@1.0.1, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-colorpicker@1.2.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-fancyswitch@1.1.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-history@1.0.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-hqwidgets@1.4.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-icontwo@0.93.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-inventwo@3.3.1, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-jqui-mfd@1.0.12, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-justgage@1.0.2, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-material-advanced@1.7.2, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-metro@1.2.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-players@0.1.6, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-rgraph@0.0.2, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis-timeandweather@1.2.2, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.vis@1.4.16, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.web@4.3.0, required by iobroker.inst@3.0.0
            npm ERR! missing: iobroker.whatsapp-cmb@0.2.3, required by iobroker.inst@3.0.0
            npm ERR!     /home/pi/.npm/_logs/2023-06-21T21_43_48_180Z-debug.log
            Adapters from github:   0
            Adapter State
              throw err;
              requireStack: []
            Node.js v18.16.0
              throw err;
              requireStack: []
            Node.js v18.16.0
            ioBroker-Repositories
              throw err;
              requireStack: []
            Node.js v18.16.0
            Installed ioBroker-Instances
              throw err;
              requireStack: []
            Node.js v18.16.0
            Objects and States
            Objects:        0
            States:         0
            Hit:1 http://phoscon.de/apt/deconz buster InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Hit:3 http://archive.raspberrypi.org/debian buster InRelease
            Hit:4 https://dl.yarnpkg.com/debian stable InRelease
            Reading package lists... Donecom/node_18.x buster InRelease
            Pending Updates: 0sts... 0%
            *** Listening Ports ***
            tcp        1      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       17991      361/deCONZ
            tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        19920      945/perl
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20894      864/sshd
            tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       18004      361/deCONZ
            tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        19921      945/perl
            tcp6       0      0 :::22                   :::*                    LISTEN      0          20896      864/sshd
            tcp6       0      0 :::3000                 :::*                    LISTEN      109        21378      815/grafana-server
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18020      813/dhcpcd
            udp        0      0 0.0.0.0:38564           0.0.0.0:*                           108        14951      352/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14949      352/avahi-daemon: r
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15209      361/deCONZ
            udp6       0      0 :::546                  :::*                                0          18039      813/dhcpcd
            udp6       0      0 :::5353                 :::*                                108        14950      352/avahi-daemon: r
            udp6       0      0 :::49470                :::*                                108        14952      352/avahi-daemon: r
            2023-06-21 20:11:26.179  - info: host.ioBroker instance system.adapter.fhem.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-06-21 20:11:26.180  - info: host.ioBroker instance system.adapter.hue-extended.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-06-21 20:11:26.211  - info: host.ioBroker instance system.adapter.smartthings.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-06-21 20:11:27.076  - info: host.ioBroker instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-06-21 20:11:27.078  - info: host.ioBroker instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-06-21 20:11:27.078  - warn: host.ioBroker instance system.adapter.whatsapp-cmb.0 terminated due to SIGTERM
            2023-06-21 20:11:27.078  - info: host.ioBroker instance system.adapter.whatsapp-cmb.0 terminated with code null ()
            2023-06-21 20:11:27.190  - warn: host.ioBroker instance system.adapter.mqtt.0 terminated due to SIGTERM
            2023-06-21 20:11:27.190  - info: host.ioBroker instance system.adapter.mqtt.0 terminated with code null ()
            2023-06-21 20:11:27.191  - warn: host.ioBroker instance system.adapter.ping.0 terminated due to SIGTERM
            2023-06-21 20:11:27.191  - info: host.ioBroker instance system.adapter.ping.0 terminated with code null ()
            2023-06-21 20:11:27.191  - warn: host.ioBroker instance system.adapter.hue.0 terminated due to SIGTERM
            2023-06-21 20:11:27.192  - info: host.ioBroker instance system.adapter.hue.0 terminated with code null ()
            2023-06-21 20:11:27.285  - warn: host.ioBroker instance system.adapter.text2command.0 terminated due to SIGTERM
            2023-06-21 20:11:27.286  - info: host.ioBroker instance system.adapter.text2command.0 terminated with code null ()
            2023-06-21 20:11:27.286  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGTERM
            2023-06-21 20:11:27.286  - info: host.ioBroker instance system.adapter.web.0 terminated with code null ()
            2023-06-21 20:11:27.287  - warn: host.ioBroker instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
            2023-06-21 20:11:27.287  - info: host.ioBroker instance system.adapter.tankerkoenig.0 terminated with code null ()
            2023-06-21 20:11:27.358  - warn: host.ioBroker instance system.adapter.net-tools.0 terminated due to SIGTERM
            2023-06-21 20:11:27.358  - info: host.ioBroker instance system.adapter.net-tools.0 terminated with code null ()
            2023-06-21 20:11:27.359  - info: host.ioBroker instance system.adapter.virtualpowermeter.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-06-21 20:11:28.046  - info: host.ioBroker instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-06-21 20:11:28.047  - info: host.ioBroker All instances are stopped.
            2023-06-21 20:11:28.277  - info: host.ioBroker terminated
            iob diag has finished.
            Ich lese, dass der js-controller nicht zu lesen ist und die Adapter sind auch alle nicht erreichbar.
            Ach ja, die Zusammenfassung:
                                 v.2023-04-16
            Operatingsystem:        Raspbian GNU/Linux 10 (buster)
            Kernel:                 5.10.103-v7l+
            Installation:           Native
            Timezone:               Europe/Berlin (CEST, +0200)
            User-ID:                1000
            X-Server:               false
            Boot Target:            graphical.target
            Pending OS-Updates:     0
              throw err;
              requireStack: []
            Node.js v18.16.0
            Pending iob updates:    0
            Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
            Recommended versions are nodejs 18.x.y and npm 9.x.y
            MEMORY:
            Mem:           1.9G        124M        859M        8.0M        887M        1.6G
            Swap:           99M          0B         99M
            Total:         2.0G        124M        959M
              throw err;
              requireStack: []
            Node.js v18.16.0
            Active iob-Instances:   0
              throw err;
              requireStack: []
            Node.js v18.16.0
              throw err;
              requireStack: []
            Node.js v18.16.0
            ioBroker Core:          js-controller
              throw err;
              requireStack: []
            Node.js v18.16.0
                                    admin
              throw err;
              requireStack: []
            Node.js v18.16.0
            ioBroker Status:
              throw err;
              requireStack: []
            Node.js v18.16.0
            Objects:                0
            States:                 0
            Size of iob-Database:
            7.0M    /opt/iobroker/iobroker-data/states.jsonl
            2.8M    /opt/iobroker/iobroker-data/states.json.migrated
            2.8M    /opt/iobroker/iobroker-data/states.json.bak.migrated
              @r-frase sagte in ioBroker update führt zu GLIBCXX_3.4.26-Problem:
              Lass die Finger von wirren Installationen via nvm oder sonstigem Kram.
              Softwarepakete werden ausschließlich via Paketmanager gehandhabt. Gerade wenn man sich nicht auskennt.
              Lösch den Mist:
              rm -rf /home/pi/.nvm/
              Schlecht...
              • R. Frase
                Lösch den Mist:
                Schlecht...
                Lösch den Mist:
                okay... hab ich.
                Schlecht...
                das heißt ich hab ein echtes Problem?
                  Thomas Braun Most Active @R. Frase last edited by Thomas Braun
                  Möglicherweise.
                  cd /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.js-controller
                  iob start
                  • R. Frase
                    Die Installation läuft gerade...
                    Nebenbei: Der Ordner /opt/iobroker/node_modules_ existiert und ist gefüllt.
                      Rühr da jetzt nicht drin rum!!
                      • R. Frase
                        Oh nein - ganz sicher nicht!!! 😨
                        Die Installation bleibt bei 470k bis 540k ms... das dauert wohl eine Weile
                          @r-frase
                          Sooooo lange sollte das eigentlich auch nicht dauern.
                          uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          sagt?
                          • R. Frase
                            Das sieht aus, als ob alle Module neu heruntergeladen und installiert werden.
                            Ich kann es leider nicht kopieren, weil das durch die aktualisierten ms-Zahlen verhindert wird.
                            unter anderem kamen einige npm WARN deprecated Warnungen.
                            darunter reify:localform und reify localforage bzgl. der Module.
                            Im Moment läuft die Schätzung auf über 900k ms und ich erhalte die nächste Eingabemöglichkeit bestimmt erst, wenn der Raspi fertig ist
                              Zweite Terminal-Session? Hat man i.d.R. eh mindestens zwei von offen.
                              • R. Frase
                                Ich komme üblicherweise mit einer durchs Leben 😇 - aber okay, ich versuche es!
                                Die zweite Session reagiert nicht - der Raspi ist wohl zu beschäftigt 🙄
                                ... doch, ich konnte mich anmelden. Es dauert leider...
                                ich konnte
                                eben eingeben... der Raspi arbeitet gerade an der Antwort
                                Zumindest bremst es den Raspi so aus, dass ich aus der anderen Session eine Kopie extrahieren kann:
                                reify:iobroker.iot: timing reifyNode:node_modules/iobroker.vis-icontwo Completed in 1773824ms
                                  Sind ganz normale Meldungen, wenn die Module neugebaut werden.
                                  • R. Frase
                                    Ich habe Hoffnung!
                                      @r-frase
                                      Wobei ich zugeben muss, dass es nicht die brillianteste Idee von mir war, auf einen 2GB-RAM Raspberry auch noch die ganzen apt aktionen parallel drauf zu werfen... Und das gleich im Doppeldecker...
                                      Brauchst halt was Geduld jetzt. Kann sein das die Kiste die Nacht dazu braucht.
                                      • R. Frase
                                        Ich kenne die Sprache nicht in der Du schreibst, weil es bei mir mit Turbo-Pascal aufgehört hat. Hinter mir liegt ein Buch zur Einführung in PERL, weil ich mich grundsätzlich gerne mit Dingen auseinandersetze die einen Anreiz haben. In groben Zügen verstehe ich das über die ersten 30 Seiten (ich hab auch erst angefangen...)
                                        Sollte es die ganze Nacht dauern bin ich in jedem Fall schon sehr viel weiter als bevor ich mich hier gemeldet habe!
                                        Ich kann mich also morgen wieder melden - dann bekommen wir alle auch etwas Schlaf. Vielen lieben Dank schonmal!
                                          @r-frase
                                          Knall den zweiten Prozess mal mit Strg-C weg.
                                          sollte dann aber flugs durch laufen.
                                          • R. Frase
                                            @r-frase
                                            /usr/bin/nodejs
                                            /usr/bin/node
                                            /usr/bin/npm
                                            /usr/bin/npx
                                            v18.16.0
                                            v18.16.0
                                            9.5.1
                                            9.5.1
                                            10347
